MBMesquite::PowerQualityMetric Class Reference
Raises a single quality metrics (qMetric1) to an arbitrary power (a double value, scaleAlpha) for two- and three-diminsional elements. More...
#include <PowerQualityMetric.hpp>
+ Inheritance diagram for MBMesquite::PowerQualityMetric:
+ Collaboration diagram for MBMesquite::PowerQualityMetric:
Public Member Functions
 PowerQualityMetric (QualityMetric *qm1, double pow_double)
virtual ~PowerQualityMetric ()
MetricType get_metric_type () const
std::string get_name () const
int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
QualityMetricget_metric () const
virtual void get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)
 Get locations at which metric can be evaluated.
virtual bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
virtual bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)
virtual bool evaluate_with_gradient (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err)
 Get metric value and gradient at a logical location in the patch.
virtual bool evaluate_with_Hessian (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err)
 Get metric value and deravitives at a logical location in the patch.
Private Attributes
QualityMetricmMetric
MBMesquite::Exponent mPower
Detailed Description
Definition at line 55 of file PowerQualityMetric.hpp.
PowerQualityMetric::PowerQualityMetric ( QualityMetric qm1,
double  pow_double
Ensures that qm1 is not NULL. If qm1 is only valid on a certain feasible, then the composite metric has the same constraint. The composite metric also has the same negate flag as qm1.
Definition at line 40 of file PowerQualityMetric.cpp.
: mMetric( *qm ), mPower( pow_factor ) {}
Definition at line 42 of file PowerQualityMetric.cpp.
Member Function Documentation
bool PowerQualityMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 59 of file PowerQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate(), mMetric, mPower, MSQ_CHKERR, and MBMesquite::Exponent::raise().
    bool rval = mMetric.evaluate( pd, handle, value, err );
    value     = mPower.raise( value );
    return !MSQ_CHKERR( err ) && rval;
bool PowerQualityMetric::evaluate_with_gradient ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
std::vector< Vector3D > &  gradient,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
gradientThe gradient of the metric as a function of the coordinates of the free vertices passed back in the indices list.
Reimplemented from MBMesquite::QualityMetric.
Definition at line 77 of file PowerQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_gradient(), mMetric, mPower, MSQ_CHKERR, MBMesquite::Exponent::raise(), and MBMesquite::Exponent::value().
    bool rval      = mMetric.evaluate_with_gradient( pd, handle, value, indices, gradient, err );
    const double v = mPower.raise( value );
    const double g = fabs( value ) > DBL_EPSILON ? mPower.value() * v / value : 0;
    value          = v;
    for( std::vector< Vector3D >::iterator i = gradient.begin(); i != gradient.end(); ++i )
        *i *= g;
bool PowerQualityMetric::evaluate_with_Hessian ( PatchData pd,
size_t  handle,
double &  value,
std::vector< Matrix3D > &  Hessian,
MsqError err
) [virtual]
Parameters:
pdThe patch.
HessianThe Hessian of the metric as a function of the coordinates. The Hessian is passed back as the upper-triangular portion of the matrix in row-major order, where each Matrix3D is the portion of the Hessian with respect to the vertices at the corresponding positions in the indices list.
Definition at line 93 of file PowerQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_Hessian(), mMetric, mPower, MSQ_CHKERR, n, MBMesquite::Matrix3D::outer_product(), MBMesquite::Exponent::raise(), and MBMesquite::Exponent::value().
    indices.clear();
    bool rval      = mMetric.evaluate_with_Hessian( pd, handle, value, indices, gradient, Hessian, err );
    const double g = fabs( value ) > DBL_EPSILON ? mPower.value() * v / value : 0.0;
    const double h = fabs( value ) > DBL_EPSILON ? g * ( mPower.value() - 1 ) / value : 0.0;
    value          = v;
    Matrix3D op;
    unsigned idx = 0;
    unsigned n   = indices.size();
    for( unsigned r = 0; r < n; ++r )
        for( unsigned c = r; c < n; ++c )
            Hessian[idx] *= g;
            op.outer_product( gradient[r], gradient[c] );
            op *= h;
            Hessian[idx] += op;
            ++idx;
        gradient[r] *= g;
bool PowerQualityMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Parameters:
pdThe patch.
Definition at line 66 of file PowerQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_indices(), mMetric, mPower, MSQ_CHKERR, and MBMesquite::Exponent::raise().
    bool rval = mMetric.evaluate_with_indices( pd, handle, value, indices, err );
void PowerQualityMetric::get_evaluations ( PatchData pd,
std::vector< size_t > &  handles,
MsqError err
) [virtual]
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
Parameters:
pdThe patch
handlesOutput list of handles
free_vertices_onlyIf true, only pass back evaluation points that depend on at least one free vertex.
Definition at line 54 of file PowerQualityMetric.cpp.
References MBMesquite::QualityMetric::get_evaluations(), mMetric, and MSQ_CHKERR.
    mMetric.get_evaluations( pd, handles, free_only, err );MSQ_CHKERR( err );
Definition at line 77 of file PowerQualityMetric.hpp.
References mMetric.
        return &mMetric;
std::string PowerQualityMetric::get_name ( ) const [virtual]
Definition at line 44 of file PowerQualityMetric.cpp.
References MBMesquite::QualityMetric::get_name(), and mMetric.
    return std::string( "pow(" ) + mMetric.get_name() + ")";
int PowerQualityMetric::get_negate_flag ( ) const [virtual]
Definition at line 49 of file PowerQualityMetric.cpp.
References MBMesquite::QualityMetric::get_negate_flag(), mMetric, mPower, and MBMesquite::Exponent::value().
Member Data Documentation
List of all members.
