MBMesquite::QualityMetric Class Reference
Base class for concrete quality metrics. More...
#include <QualityMetric.hpp>
+ Inheritance diagram for MBMesquite::QualityMetric:
Public Types
enum  MetricType { VERTEX_BASED, ELEMENT_BASED }
enum  AveragingMethod {
  LINEAR, RMS, HMS, SUM,
  SUM_SQUARED, HARMONIC, LAST_WITH_HESSIAN = HARMONIC, MINIMUM,
  MAXIMUM, GEOMETRIC, LAST_WITH_GRADIENT = GEOMETRIC, STANDARD_DEVIATION,
  MAX_OVER_MIN, MAX_MINUS_MIN, SUM_OF_RATIOS_SQUARED
Public Member Functions
virtual MESQUITE_EXPORT ~QualityMetric ()
virtual MESQUITE_EXPORT MetricType get_metric_type () const =0
virtual MESQUITE_EXPORT std::string get_name () const =0
virtual MESQUITE_EXPORT int get_negate_flag () const =0
 1 if metric should be minimized, -1 if metric should be maximized.
virtual MESQUITE_EXPORT void get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)=0
 Get locations at which metric can be evaluated.
virtual MESQUITE_EXPORT void get_single_pass (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)
 Get locations at which metric can be evaluated for use in BCD intialization and QualityAssessor.
virtual MESQUITE_EXPORT bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)=0
 Get metric value at a logical location in the patch.
virtual MESQUITE_EXPORT bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)=0
virtual MESQUITE_EXPORT bool evaluate_with_gradient (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err)
 Get metric value and gradient at a logical location in the patch.
virtual MESQUITE_EXPORT bool evaluate_with_Hessian_diagonal (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< SymMatrix3D > &Hessian_diagonal, MsqError &err)
virtual MESQUITE_EXPORT bool evaluate_with_Hessian (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err)
 Get metric value and deravitives at a logical location in the patch.
MESQUITE_EXPORT double weighted_average_metrics (const double coef[], const double metric_values[], const int &num_values, MsqError &err)
virtual MESQUITE_EXPORT void initialize_queue (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)
 Called at start of instruction queue processing.
Static Public Member Functions
static double vertex_barrier_function (double det, double delta)
 Escobar Barrier Function for Shape and Other Metrics.
static MESQUITE_EXPORT void remove_fixed_gradients (EntityTopology type, uint32_t fixed_vertices, std::vector< Vector3D > &gradients)
 Remove from vector any gradient terms corresponding to a fixed vertex.
static MESQUITE_EXPORT void remove_fixed_diagonals (EntityTopology type, uint32_t fixed_vertices, std::vector< Vector3D > &gradients, std::vector< SymMatrix3D > &hess_diagonal_blocks)
 Remove from vectors any gradient terms and hessian diagonal blcoks corresponding to a fixed vertex.
static MESQUITE_EXPORT void remove_fixed_hessians (EntityTopology type, uint32_t fixed_vertices, std::vector< Matrix3D > &hessians)
 Remove from vector any Hessian blocks corresponding to a fixed vertex.
static MESQUITE_EXPORT uint32_t fixed_vertex_bitmap (PatchData &pd, const MsqMeshEntity *elem, std::vector< size_t > &free_indices)
 Convert fixed vertex format from list to bit flags.
Protected Member Functions
 QualityMetric ()
Private Attributes
int feasible
std::vector< Matrix3DtmpHess
bool keepFiniteDiffEps
bool haveFiniteDiffEps
double finiteDiffEps
Detailed Description
Definition at line 71 of file QualityMetric.hpp.
Member Enumeration Documentation
AveragingMethod allows you to set how the quality metric values attained at each sample point will be averaged together to produce a single metric value for an element.
Enumerator:
LINEAR
the linear average
RMS
the root-mean-squared average
HMS
the harmonic-mean-squared average
SUM
the sum of the values
SUM_SQUARED
the sum of the squares of the values
HARMONIC
the harmonic average
LAST_WITH_HESSIAN
MINIMUM
the minimum value
MAXIMUM
the maximum value
GEOMETRIC
the geometric average
LAST_WITH_GRADIENT
STANDARD_DEVIATION
the standard deviation squared of the values
MAX_OVER_MIN
the maximum value minus the minum value
MAX_MINUS_MIN
the maximum value divided by the minimum value
(1/(N^2))*(SUM (SUM (v_i/v_j)^2))
Definition at line 303 of file QualityMetric.hpp.
        LINEAR,       //!< the linear average
        RMS,          //!< the root-mean-squared average
        HMS,          //!< the harmonic-mean-squared average
        SUM,          //!< the sum of the values
        SUM_SQUARED,  //!< the sum of the squares of the values
        HARMONIC,     //!< the harmonic average
        MINIMUM,    //!< the minimum value
        MAXIMUM,    //!< the maximum value
        GEOMETRIC,  //!< the geometric average
        STANDARD_DEVIATION,    //!< the standard deviation squared of the values
        MAX_OVER_MIN,          //!< the maximum value minus the minum value
        MAX_MINUS_MIN,         //!< the maximum value divided by the minimum value
        SUM_OF_RATIOS_SQUARED  //!< (1/(N^2))*(SUM (SUM (v_i/v_j)^2))
Enumerator:
VERTEX_BASED
Iterate over vertices to evaluate metric.
ELEMENT_BASED
Iterate over elements to evaluate metric.
Reimplemented in MBMesquite::AWQualityMetric, and MBMesquite::TQualityMetric.
Definition at line 77 of file QualityMetric.hpp.
        VERTEX_BASED, /**< Iterate over vertices to evaluate metric. */
        ELEMENT_BASED /**< Iterate over elements to evaluate metric. */
Definition at line 74 of file QualityMetric.hpp.
: keepFiniteDiffEps( false ), haveFiniteDiffEps( false ) {}
Definition at line 83 of file QualityMetric.hpp.
Member Function Documentation
virtual MESQUITE_EXPORT bool MBMesquite::QualityMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [pure virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implemented in OFTestBadQM, DistTestMetric, MetricLogger, TriTauMetric, ParabolicVertexMetric, OFTestQM, CompareMetric, ConstantElementMetric, LinearVertexMetric, NumericQM, FauxMetric< B >, MBMesquite::MultiplyQualityMetric, MBMesquite::CompareQM, MBMesquite::PowerQualityMetric, MBMesquite::IdealWeightInverseMeanRatio, MBMesquite::UntangleBetaQualityMetric, MBMesquite::TMPQualityMetric, MBMesquite::IdealWeightMeanRatio, MBMesquite::AffineMapMetric, MBMesquite::EdgeLengthRangeQualityMetric, MBMesquite::ScalarMultiplyQualityMetric, MBMesquite::ConditionNumberQualityMetric, MBMesquite::AddQualityMetric, MBMesquite::LocalSizeQualityMetric, MBMesquite::EdgeLengthQualityMetric, MBMesquite::NumericalQM, MBMesquite::VertexConditionNumberQualityMetric, MBMesquite::ScalarAddQualityMetric, MBMesquite::AspectRatioGammaQualityMetric, MBMesquite::ElementPMeanP, MBMesquite::VertexPMeanP, MBMesquite::ElementMaxQM, MBMesquite::VertexMaxQM, MBMesquite::ElementAvgQM, MBMesquite::SizeMetric, and MBMesquite::EdgeLengthMetric.
Referenced by MBMesquite::PMeanPMetric::average(), QualityMetricTester::compare_eval_and_eval_with_indices(), MBMesquite::NonSmoothDescent::compute_function(), MBMesquite::LInfTemplate::evaluate(), MBMesquite::ElementAvgQM::evaluate(), MBMesquite::MaxTemplate::evaluate(), MBMesquite::ElementMaxQM::evaluate(), MBMesquite::VertexMaxQM::evaluate(), MBMesquite::ScalarAddQualityMetric::evaluate(), MBMesquite::NumericalQM::evaluate(), MBMesquite::AddQualityMetric::evaluate(), MBMesquite::ScalarMultiplyQualityMetric::evaluate(), MBMesquite::PatchPowerMeanP::evaluate(), MBMesquite::VarianceTemplate::evaluate(), MBMesquite::LPtoPTemplate::evaluate(), MBMesquite::CompareQM::evaluate(), MBMesquite::PowerQualityMetric::evaluate(), MBMesquite::MultiplyQualityMetric::evaluate(), MBMesquite::PMeanPTemplate::evaluate(), evaluate_with_gradient(), MBMesquite::ElementQM::evaluate_with_indices(), MBMesquite::EdgeQM::evaluate_with_indices(), MBMesquite::MetricWeight::get_weight(), MBMesquite::InverseMetricWeight::get_weight(), test_bad_element(), QualityMetricTester::test_domain_deviation_quality(), test_evaluate(), QualityMetricTester::test_measures_quality(), QualityMetricTester::test_measures_transform(), QualityMetricTester::test_measures_vertex_quality(), QualityMetricTester::test_transform_invariant(), QualityMetricTester::test_type_is_not_supported(), and QualityMetricTester::test_type_is_supported().
bool MBMesquite::QualityMetric::evaluate_with_gradient ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
std::vector< Vector3D > &  gradient,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
gradientThe gradient of the metric as a function of the coordinates of the free vertices passed back in the indices list.
Reimplemented in CompareMetric, FauxMetric< B >, MBMesquite::MultiplyQualityMetric, MBMesquite::CompareQM, MBMesquite::PowerQualityMetric, MBMesquite::IdealWeightInverseMeanRatio, MBMesquite::IdealWeightMeanRatio, MBMesquite::AWQualityMetric, MBMesquite::TQualityMetric, MBMesquite::ScalarMultiplyQualityMetric, MBMesquite::AddQualityMetric, MBMesquite::NumericalQM, MBMesquite::ScalarAddQualityMetric, MBMesquite::VertexPMeanP, MBMesquite::ElementPMeanP, and MBMesquite::EdgeLengthMetric.
Definition at line 98 of file QualityMetric.cpp.
References evaluate(), evaluate_with_indices(), finiteDiffEps, MBMesquite::get_delta_C(), haveFiniteDiffEps, INTERNAL_ERROR, keepFiniteDiffEps, MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::PatchData::set_vertex_coordinates(), value(), and MBMesquite::PatchData::vertex_by_index().
Referenced by MBMesquite::PMeanPMetric::average_with_gradient(), QualityMetricTester::compare_analytical_and_numerical_gradients(), TMPQualityMetricTest< QMType >::compare_analytical_and_numerical_gradients(), QualityMetricTester::compare_eval_with_grad_and_eval_with_diagonal(), QualityMetricTester::compare_eval_with_grad_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_indices_and_eval_with_gradient(), QualityMetricTest::compare_gradient(), MBMesquite::NonSmoothDescent::compute_gradient(), MBMesquite::ScalarAddQualityMetric::evaluate_with_gradient(), MBMesquite::NumericalQM::evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_gradient(), MBMesquite::VarianceTemplate::evaluate_with_gradient(), MBMesquite::AddQualityMetric::evaluate_with_gradient(), MBMesquite::ScalarMultiplyQualityMetric::evaluate_with_gradient(), MBMesquite::LPtoPTemplate::evaluate_with_gradient(), MBMesquite::PowerQualityMetric::evaluate_with_gradient(), MBMesquite::CompareQM::evaluate_with_gradient(), MBMesquite::PMeanPTemplate::evaluate_with_gradient(), MBMesquite::MultiplyQualityMetric::evaluate_with_gradient(), evaluate_with_Hessian(), QualityMetricTester::test_domain_deviation_gradient(), QualityMetricTester::test_grad_transform_invariant(), QualityMetricTest::test_gradient_constant(), QualityMetricTest::test_gradient_linear(), QualityMetricTest::test_gradient_parabolic(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTest::test_gradient_tau(), QualityMetricTester::test_gradient_with_fixed_vertex(), QualityMetricTester::test_ideal_element_zero_gradient(), QualityMetricTester::test_ideal_element_zero_vertex_gradient(), QualityMetricTester::test_type_is_not_supported(), QualityMetricTester::test_type_is_supported(), and QualityMetricTester::test_vertex_gradient_reflects_quality().
    indices.clear();
    bool valid = evaluate_with_indices( pd, handle, value, indices, err );
    if( MSQ_CHKERR( err ) || !valid ) return false;
    if( indices.empty() ) return true;
    // get initial pertubation amount
    double delta_C = finiteDiffEps;
    if( !haveFiniteDiffEps )
        delta_C = get_delta_C( pd, indices, err );
        MSQ_ERRZERO( err );
        if( keepFiniteDiffEps )
            finiteDiffEps     = delta_C;
            haveFiniteDiffEps = true;
    const double delta_inv_C  = 1.0 / delta_C;
    const int reduction_limit = 15;
    gradient.resize( indices.size() );
    for( size_t v = 0; v < indices.size(); ++v )
        const Vector3D pos = pd.vertex_by_index( indices[v] );
        /* gradient in the x, y, z direction */
        for( int j = 0; j < 3; ++j )
            double delta     = delta_C;
            double delta_inv = delta_inv_C;
            double metric_value;
            Vector3D delta_v( 0, 0, 0 );
            // perturb the node and calculate gradient.  The while loop is a
            // safety net to make sure the epsilon perturbation does not take
            // the element out of the feasible region.
            int counter = 0;
            for( ;; )
                // perturb the coordinates of the free vertex in the j direction
                // by delta
                delta_v[j] = delta;
                pd.set_vertex_coordinates( pos + delta_v, indices[v], err );
                MSQ_ERRZERO( err );
                // compute the function at the perturbed point location
                valid = evaluate( pd, handle, metric_value, err );
                if( !MSQ_CHKERR( err ) && valid ) break;
                if( ++counter >= reduction_limit )
                    MSQ_SETERR( err )
                    ( "Perturbing vertex by delta caused an inverted element.", MsqError::INTERNAL_ERROR );
                    return false;
                delta *= 0.1;
                delta_inv *= 10.;
            // put the coordinates back where they belong
            pd.set_vertex_coordinates( pos, indices[v], err );
            // compute the numerical gradient
            gradient[v][j] = ( metric_value - value ) * delta_inv;
        }  // for(j)
    }      // for(indices)
    return true;
bool MBMesquite::QualityMetric::evaluate_with_Hessian ( PatchData pd,
size_t  handle,
double &  value,
std::vector< Matrix3D > &  Hessian,
MsqError err
) [virtual]
Parameters:
pdThe patch.
HessianThe Hessian of the metric as a function of the coordinates. The Hessian is passed back as the upper-triangular portion of the matrix in row-major order, where each Matrix3D is the portion of the Hessian with respect to the vertices at the corresponding positions in the indices list.
Reimplemented in CompareMetric, FauxMetric< B >, MBMesquite::CompareQM, MBMesquite::MultiplyQualityMetric, MBMesquite::IdealWeightInverseMeanRatio, MBMesquite::PowerQualityMetric, MBMesquite::IdealWeightMeanRatio, MBMesquite::AWQualityMetric, MBMesquite::TQualityMetric, MBMesquite::NumericalQM, MBMesquite::ScalarMultiplyQualityMetric, MBMesquite::AddQualityMetric, MBMesquite::ScalarAddQualityMetric, MBMesquite::VertexPMeanP, and MBMesquite::ElementPMeanP.
Definition at line 173 of file QualityMetric.cpp.
References evaluate_with_gradient(), finiteDiffEps, MBMesquite::get_delta_C(), haveFiniteDiffEps, INTERNAL_ERROR, keepFiniteDiffEps, MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::PatchData::set_vertex_coordinates(), and MBMesquite::PatchData::vertex_by_index().
Referenced by MBMesquite::PMeanPMetric::average_with_Hessian(), PMeanPTemplateTest::check_result(), QualityMetricTester::compare_analytical_and_numerical_hessians(), TMPQualityMetricTest< QMType >::compare_analytical_and_numerical_hessians(), QualityMetricTester::compare_eval_with_diag_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_grad_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_indices_and_eval_with_hessian(), MBMesquite::ScalarAddQualityMetric::evaluate_with_Hessian(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::AddQualityMetric::evaluate_with_Hessian(), MBMesquite::ScalarMultiplyQualityMetric::evaluate_with_Hessian(), MBMesquite::NumericalQM::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), MBMesquite::PowerQualityMetric::evaluate_with_Hessian(), MBMesquite::MultiplyQualityMetric::evaluate_with_Hessian(), MBMesquite::CompareQM::evaluate_with_Hessian(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian(), evaluate_with_Hessian_diagonal(), QualityMetricTest::test_Hessian_constant(), QualityMetricTest::test_Hessian_linear(), QualityMetricTest::test_Hessian_parabolic(), QualityMetricTest::test_Hessian_tau(), QualityMetricTester::test_hessian_transform_invariant(), QualityMetricTester::test_hessian_with_fixed_vertex(), QualityMetricTester::test_ideal_element_positive_definite_Hessian(), QualityMetricTester::test_symmetric_Hessian_diagonal_blocks(), QualityMetricTester::test_type_is_not_supported(), and QualityMetricTester::test_type_is_supported().
    indices.clear();
    gradient.clear();
    keepFiniteDiffEps = true;
    bool valid        = evaluate_with_gradient( pd, handle, value, indices, gradient, err );
    keepFiniteDiffEps = false;
        haveFiniteDiffEps = false;
        return false;
        return true;
    double delta_C;
    if( haveFiniteDiffEps )
    else
        MSQ_ERRZERO( err );
    assert( delta_C < 1e30 );
    std::vector< Vector3D > temp_gradient( indices.size() );
    const int num_hess = indices.size() * ( indices.size() + 1 ) / 2;
    Hessian.resize( num_hess );
    for( unsigned v = 0; v < indices.size(); ++v )
        {  // x, y, and z
            // find finite difference for gradient
            int counter = 0;
            for( ;; )
                delta_v[j] = delta;
                MSQ_ERRZERO( err );
                valid = evaluate_with_gradient( pd, handle, metric_value, indices, temp_gradient, err );
                    MSQ_SETERR( err )
                    ( "Algorithm did not successfully compute element's "
                      "Hessian.\n",
                    return false;
                delta *= 0.1;
                delta_inv *= 10.0;
            MSQ_ERRZERO( err );
            // compute the numerical Hessian
            for( unsigned w = 0; w <= v; ++w )
                // finite difference to get some entries of the Hessian
                Vector3D fd( temp_gradient[w] );
                fd -= gradient[w];
                fd *= delta_inv;
                // For the block at position w,v in a matrix, we need the corresponding index
                // (mat_index) in a 1D array containing only upper triangular blocks.
                unsigned sum_w           = w * ( w + 1 ) / 2;  // 1+2+3+...+w
                unsigned mat_index       = w * indices.size() + v - sum_w;
                Hessian[mat_index][0][j] = fd[0];
                Hessian[mat_index][1][j] = fd[1];
                Hessian[mat_index][2][j] = fd[2];
        }  // for(j)
    }      // for(indices)
    return true;
bool MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal ( PatchData pd,
size_t  handle,
double &  value,
std::vector< SymMatrix3D > &  Hessian_diagonal,
MsqError err
) [virtual]
Parameters:
pdThe patch.
Hessian_diagonalThe 3x3 blocks along the diagonal of the Hessian matrix.
Reimplemented in CompareMetric, MBMesquite::CompareQM, MBMesquite::IdealWeightInverseMeanRatio, MBMesquite::IdealWeightMeanRatio, MBMesquite::AWQualityMetric, MBMesquite::TQualityMetric, MBMesquite::VertexPMeanP, MBMesquite::NumericalQM, and MBMesquite::ElementPMeanP.
Definition at line 273 of file QualityMetric.cpp.
References evaluate_with_Hessian(), MSQ_CHKERR, and tmpHess.
Referenced by MBMesquite::PMeanPMetric::average_with_Hessian_diagonal(), QualityMetricTester::compare_analytical_and_numerical_diagonals(), TMPQualityMetricTest< QMType >::compare_analytical_and_numerical_diagonals(), QualityMetricTester::compare_eval_with_diag_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_grad_and_eval_with_diagonal(), QualityMetricTester::compare_eval_with_indices_and_eval_with_diagonal(), MBMesquite::NumericalQM::evaluate_with_Hessian_diagonal(), MBMesquite::VarianceTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::CompareQM::evaluate_with_Hessian_diagonal(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian_diagonal(), QualityMetricTest::test_diagonal_constant(), QualityMetricTest::test_diagonal_linear(), QualityMetricTest::test_diagonal_parabolic(), QualityMetricTest::test_diagonal_tau(), and QualityMetricTester::test_diagonal_with_fixed_vertex().
    bool rval = evaluate_with_Hessian( pd, handle, value, indices, gradient, tmpHess, err );
    if( MSQ_CHKERR( err ) || !rval ) return rval;
    size_t s = indices.size();
    Hessian_diagonal.resize( s );
    std::vector< Matrix3D >::const_iterator h = tmpHess.begin();
    for( size_t i = 0; i < indices.size(); ++i )
        Hessian_diagonal[i] = h->upper();
        h += s--;
    return rval;
virtual MESQUITE_EXPORT bool MBMesquite::QualityMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [pure virtual]
Parameters:
pdThe patch.
Implemented in TriTauMetric, ParabolicVertexMetric, ConstantElementMetric, CompareMetric, LinearVertexMetric, NumericQM, FauxMetric< B >, MBMesquite::MultiplyQualityMetric, MBMesquite::EdgeQM, MBMesquite::CompareQM, MBMesquite::PowerQualityMetric, MBMesquite::TMPQualityMetric, MBMesquite::AffineMapMetric, MBMesquite::EdgeLengthRangeQualityMetric, MBMesquite::ScalarMultiplyQualityMetric, MBMesquite::AddQualityMetric, MBMesquite::LocalSizeQualityMetric, MBMesquite::EdgeLengthQualityMetric, MBMesquite::NumericalQM, MBMesquite::ElementQM, MBMesquite::VertexConditionNumberQualityMetric, MBMesquite::ScalarAddQualityMetric, MBMesquite::VertexPMeanP, and MBMesquite::VertexMaxQM.
Referenced by MBMesquite::PMeanPMetric::average_with_indices(), QualityMetricTester::compare_eval_and_eval_with_indices(), QualityMetricTester::compare_eval_with_indices_and_eval_with_diagonal(), QualityMetricTester::compare_eval_with_indices_and_eval_with_gradient(), QualityMetricTester::compare_eval_with_indices_and_eval_with_hessian(), QualityMetricTest::compare_indices(), evaluate_with_gradient(), MBMesquite::VertexMaxQM::evaluate_with_indices(), MBMesquite::ScalarAddQualityMetric::evaluate_with_indices(), MBMesquite::NumericalQM::evaluate_with_indices(), MBMesquite::AddQualityMetric::evaluate_with_indices(), MBMesquite::ScalarMultiplyQualityMetric::evaluate_with_indices(), MBMesquite::CompareQM::evaluate_with_indices(), MBMesquite::PowerQualityMetric::evaluate_with_indices(), MBMesquite::MultiplyQualityMetric::evaluate_with_indices(), QualityMetricTester::test_domain_deviation_quality(), QualityMetricTester::test_get_element_indices(), QualityMetricTester::test_get_indices_fixed(), QualityMetricTester::test_get_sample_indices(), QualityMetricTester::test_get_vertex_indices(), QualityMetricTester::test_type_is_not_supported(), and QualityMetricTester::test_type_is_supported().
uint32_t MBMesquite::QualityMetric::fixed_vertex_bitmap ( PatchData pd,
const MsqMeshEntity elem,
std::vector< size_t > &  free_indices
) [static]
Given list of pointers to fixed vertices as passed to evaluation functions, convert to bit flag format used for many utility functions in this class. Bits correspond to vertices in the canonical vertex order, beginning with the least-significant bit. The bit is cleared for free vertices and set (1) for fixed vertices.
Definition at line 294 of file QualityMetric.cpp.
References MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::PatchData::num_free_vertices(), and MBMesquite::MsqMeshEntity::vertex_count().
Referenced by MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal(), and QualityMetricTest::test_fixed_vertex_list().
    indices.clear();
    uint32_t result        = ~(uint32_t)0;
    unsigned num_vtx       = elem->vertex_count();
    const size_t* vertices = elem->get_vertex_index_array();
    indices.clear();
    for( unsigned i = 0; i < num_vtx; ++i )
        if( vertices[i] < pd.num_free_vertices() )
            indices.push_back( vertices[i] );
            result &= ~(uint32_t)( 1 << i );
    return result;
virtual MESQUITE_EXPORT void MBMesquite::QualityMetric::get_evaluations ( PatchData pd,
std::vector< size_t > &  handles,
MsqError err
) [pure virtual]
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
Parameters:
pdThe patch
handlesOutput list of handles
free_vertices_onlyIf true, only pass back evaluation points that depend on at least one free vertex.
Implemented in CompareMetric, NumericQM, FauxMetric< B >, MBMesquite::MultiplyQualityMetric, MBMesquite::CompareQM, MBMesquite::PowerQualityMetric, MBMesquite::AffineMapMetric, MBMesquite::TMPQualityMetric, MBMesquite::ScalarMultiplyQualityMetric, MBMesquite::AddQualityMetric, MBMesquite::NumericalQM, MBMesquite::EdgeQM, MBMesquite::ScalarAddQualityMetric, MBMesquite::ElementQM, and MBMesquite::VertexQM.
Referenced by QualityMetricTester::compare_analytical_and_numerical_diagonals(), TMPQualityMetricTest< QMType >::compare_analytical_and_numerical_diagonals(), QualityMetricTester::compare_analytical_and_numerical_gradients(), TMPQualityMetricTest< QMType >::compare_analytical_and_numerical_gradients(), QualityMetricTester::compare_analytical_and_numerical_hessians(), TMPQualityMetricTest< QMType >::compare_analytical_and_numerical_hessians(), QualityMetricTester::compare_eval_and_eval_with_indices(), QualityMetricTester::compare_eval_with_diag_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_grad_and_eval_with_diagonal(), QualityMetricTester::compare_eval_with_grad_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_indices_and_eval_with_diagonal(), QualityMetricTester::compare_eval_with_indices_and_eval_with_gradient(), QualityMetricTester::compare_eval_with_indices_and_eval_with_hessian(), MBMesquite::LInfTemplate::evaluate(), MBMesquite::MaxTemplate::evaluate(), MBMesquite::PatchPowerMeanP::evaluate(), MBMesquite::VarianceTemplate::evaluate(), MBMesquite::LPtoPTemplate::evaluate(), MBMesquite::PMeanPTemplate::evaluate(), MBMesquite::PatchPowerMeanP::evaluate_with_gradient(), MBMesquite::VarianceTemplate::evaluate_with_gradient(), MBMesquite::LPtoPTemplate::evaluate_with_gradient(), MBMesquite::PMeanPTemplate::evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian(), MBMesquite::VarianceTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::ScalarAddQualityMetric::get_evaluations(), MBMesquite::NumericalQM::get_evaluations(), MBMesquite::AddQualityMetric::get_evaluations(), MBMesquite::ScalarMultiplyQualityMetric::get_evaluations(), MBMesquite::PowerQualityMetric::get_evaluations(), MBMesquite::CompareQM::get_evaluations(), MBMesquite::MultiplyQualityMetric::get_evaluations(), get_single_pass(), MBMesquite::NonSmoothDescent::init_opt(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), test_bad_element(), QualityMetricTester::test_diagonal_with_fixed_vertex(), QualityMetricTester::test_domain_deviation_gradient(), QualityMetricTester::test_domain_deviation_quality(), test_evaluate(), QualityMetricTester::test_get_element_evaluations(), QualityMetricTester::test_get_element_indices(), QualityMetricTester::test_get_in_element_evaluations(), QualityMetricTester::test_get_indices_fixed(), QualityMetricTester::test_get_sample_evaluations(), QualityMetricTester::test_get_sample_indices(), QualityMetricTester::test_get_vertex_evaluations(), QualityMetricTester::test_grad_transform_invariant(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTester::test_gradient_with_fixed_vertex(), QualityMetricTester::test_hessian_transform_invariant(), QualityMetricTester::test_hessian_with_fixed_vertex(), QualityMetricTester::test_ideal_element_positive_definite_Hessian(), QualityMetricTester::test_ideal_element_zero_gradient(), QualityMetricTester::test_ideal_element_zero_vertex_gradient(), QualityMetricTester::test_measures_quality(), QualityMetricTester::test_measures_transform(), QualityMetricTester::test_symmetric_Hessian_diagonal_blocks(), QualityMetricTester::test_transform_invariant(), QualityMetricTester::test_type_is_not_supported(), and QualityMetricTester::test_type_is_supported().
virtual MESQUITE_EXPORT std::string MBMesquite::QualityMetric::get_name ( ) const [pure virtual]
Implemented in OFTestBadQM, DistTestMetric, MetricLogger, TriTauMetric, ParabolicVertexMetric, CompareMetric, ConstantElementMetric, OFTestQM, LinearVertexMetric, NumericQM, FauxMetric< B >, MBMesquite::IdealWeightInverseMeanRatio, MBMesquite::UntangleBetaQualityMetric, MBMesquite::CompareQM, MBMesquite::AWQualityMetric, MBMesquite::TQualityMetric, MBMesquite::MultiplyQualityMetric, MBMesquite::IdealWeightMeanRatio, MBMesquite::PowerQualityMetric, FauxMetric< B >, MBMesquite::EdgeLengthRangeQualityMetric, MBMesquite::ConditionNumberQualityMetric, MBMesquite::LocalSizeQualityMetric, MBMesquite::EdgeLengthQualityMetric, MBMesquite::AffineMapMetric, MBMesquite::ScalarMultiplyQualityMetric, MBMesquite::VertexConditionNumberQualityMetric, MBMesquite::NumericalQM, MBMesquite::AspectRatioGammaQualityMetric, MBMesquite::ElementPMeanP, MBMesquite::VertexPMeanP, MBMesquite::ElementMaxQM, MBMesquite::VertexMaxQM, MBMesquite::ScalarAddQualityMetric, MBMesquite::ElementAvgQM, MBMesquite::SizeMetric, MBMesquite::AddQualityMetric, and MBMesquite::EdgeLengthMetric.
Referenced by MBMesquite::AddQualityMetric::get_name(), MBMesquite::ElementAvgQM::get_name(), MBMesquite::ScalarAddQualityMetric::get_name(), MBMesquite::ElementMaxQM::get_name(), MBMesquite::VertexMaxQM::get_name(), MBMesquite::ElementPMeanP::get_name(), MBMesquite::VertexPMeanP::get_name(), MBMesquite::NumericalQM::get_name(), MBMesquite::ScalarMultiplyQualityMetric::get_name(), MBMesquite::PowerQualityMetric::get_name(), MBMesquite::MultiplyQualityMetric::get_name(), MBMesquite::CompareQM::get_name(), MBMesquite::CompareQM::print_stats(), and smooth_mesh().
virtual MESQUITE_EXPORT int MBMesquite::QualityMetric::get_negate_flag ( ) const [pure virtual]
Implemented in OFTestBadQM, DistTestMetric, MetricLogger, TriTauMetric, ParabolicVertexMetric, CompareMetric, ConstantElementMetric, OFTestQM, LinearVertexMetric, NumericQM, FauxMetric< B >, MBMesquite::IdealWeightInverseMeanRatio, MBMesquite::UntangleBetaQualityMetric, MBMesquite::CompareQM, MBMesquite::MultiplyQualityMetric, MBMesquite::IdealWeightMeanRatio, MBMesquite::PowerQualityMetric, MBMesquite::EdgeLengthRangeQualityMetric, MBMesquite::ConditionNumberQualityMetric, MBMesquite::LocalSizeQualityMetric, MBMesquite::EdgeLengthQualityMetric, MBMesquite::ScalarMultiplyQualityMetric, MBMesquite::VertexConditionNumberQualityMetric, MBMesquite::AffineMapMetric, MBMesquite::TMPQualityMetric, MBMesquite::NumericalQM, MBMesquite::AspectRatioGammaQualityMetric, MBMesquite::ElementPMeanP, MBMesquite::VertexPMeanP, MBMesquite::ElementMaxQM, MBMesquite::ScalarAddQualityMetric, MBMesquite::VertexMaxQM, MBMesquite::ElementAvgQM, MBMesquite::SizeMetric, MBMesquite::AddQualityMetric, and MBMesquite::EdgeLengthMetric.
Referenced by MBMesquite::AddQualityMetric::AddQualityMetric(), MBMesquite::StdDevTemplate::evaluate(), MBMesquite::LInfTemplate::evaluate(), MBMesquite::MaxTemplate::evaluate(), MBMesquite::PatchPowerMeanP::evaluate(), MBMesquite::VarianceTemplate::evaluate(), MBMesquite::LPtoPTemplate::evaluate(), MBMesquite::PMeanPTemplate::evaluate(), MBMesquite::StdDevTemplate::evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_gradient(), MBMesquite::VarianceTemplate::evaluate_with_gradient(), MBMesquite::LPtoPTemplate::evaluate_with_gradient(), MBMesquite::PMeanPTemplate::evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian(), MBMesquite::StdDevTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::VarianceTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::AddQualityMetric::get_negate_flag(), MBMesquite::ElementAvgQM::get_negate_flag(), MBMesquite::ScalarAddQualityMetric::get_negate_flag(), MBMesquite::ElementMaxQM::get_negate_flag(), MBMesquite::VertexMaxQM::get_negate_flag(), MBMesquite::VertexPMeanP::get_negate_flag(), MBMesquite::ElementPMeanP::get_negate_flag(), MBMesquite::NumericalQM::get_negate_flag(), MBMesquite::ScalarMultiplyQualityMetric::get_negate_flag(), MBMesquite::PowerQualityMetric::get_negate_flag(), MBMesquite::MultiplyQualityMetric::get_negate_flag(), MBMesquite::CompareQM::get_negate_flag(), MBMesquite::MultiplyQualityMetric::MultiplyQualityMetric(), QualityMetricTester::test_domain_deviation_gradient(), QualityMetricTester::test_domain_deviation_quality(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTester::test_ideal_element_positive_definite_Hessian(), QualityMetricTester::test_measures_quality(), QualityMetricTester::test_measures_transform(), QualityMetricTester::test_measures_vertex_quality(), and QualityMetricTester::test_vertex_gradient_reflects_quality().
void MBMesquite::QualityMetric::get_single_pass ( PatchData pd,
MsqError err
) [virtual]
For element-based, sample-based, and vertex-based metrics, this function is the same as get_evaluations. For edge-based metrics it returns only a subset of the results for get_evaluations such that each edge in the mesh is visited only once even though it would normally be visited twice when iterating over patches of the mesh. This assumes that no vertex occurs in more than one patch without its MSQ_PATCH_FIXED flag set. This assumption is true for both element-on-vertex and global patches.
Parameters:
pdThe patch
Reimplemented in MBMesquite::EdgeQM.
Definition at line 48 of file QualityMetric.cpp.
References get_evaluations().
Referenced by MBMesquite::PatchPowerMeanP::evaluate(), MBMesquite::VarianceTemplate::evaluate(), MBMesquite::LPtoPTemplate::evaluate(), MBMesquite::PMeanPTemplate::evaluate(), and MBMesquite::QualityAssessor::loop_over_mesh_internal().
    get_evaluations( pd, handles, free_vertices_only, err );
void MBMesquite::QualityMetric::initialize_queue ( MeshDomainAssoc mesh_and_domain,
const Settings settings,
MsqError err
) [virtual]
Do any preliminary global initialization, consistency checking, etc. Default implementation does nothing.
Reimplemented in MBMesquite::TMPQualityMetric.
Definition at line 46 of file QualityMetric.cpp.
Referenced by MBMesquite::ObjectiveFunctionTemplate::initialize_queue().
void MBMesquite::QualityMetric::remove_fixed_diagonals ( EntityTopology  type,
std::vector< Vector3D > &  gradients,
std::vector< SymMatrix3D > &  hess_diagonal_blocks
) [static]
Remove terms from vector that correspond to fixed vertices.
Parameters:
typeElement type
fixed_verticesBit flags, one per vertex, 1 if vertex is fixed.
gradientsArray of gradients
hess_diagonal_blocksArray of diagonal blocks of Hessian matrix.
Definition at line 329 of file QualityMetric.cpp.
References corners.
Referenced by MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), and MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal().
    const unsigned num_vertex = TopologyInfo::corners( type );
    unsigned r, w;
    for( r = 0; r < num_vertex && !( fixed & ( 1 << r ) ); ++r )
    for( w = r++; r < num_vertex; ++r )
        if( !( fixed & ( 1 << r ) ) )
            grads[w] = grads[r];
            diags[w] = diags[r];
            ++w;
    grads.resize( w );
    diags.resize( w );
void MBMesquite::QualityMetric::remove_fixed_gradients ( EntityTopology  type,
) [static]
Parameters:
typeElement type
Definition at line 312 of file QualityMetric.cpp.
References corners.
Referenced by MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), and QualityMetricTest::test_remove_fixed_gradients().
    const unsigned num_vertex = TopologyInfo::corners( elem_type );
    unsigned r, w;
            ++w;
    grads.resize( w );
void MBMesquite::QualityMetric::remove_fixed_hessians ( EntityTopology  type,
std::vector< Matrix3D > &  hessians
) [static]
Remove blocks from vector that correspond to fixed vertices.
Parameters:
typeElement type
hessiansArray of Hessian blocks (upper trianguler, row-major)
Definition at line 351 of file QualityMetric.cpp.
References corners.
Referenced by MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), and QualityMetricTest::test_remove_fixed_hessians().
    unsigned r, c, i = 0, w = 0;
    for( r = 0; r < num_vertex; ++r )
        if( fixed & ( 1 << r ) )
            i += num_vertex - r;
            continue;
        for( c = r; c < num_vertex; ++c )
            if( !( fixed & ( 1 << c ) ) )
                hessians[w] = hessians[i];
                ++w;
            ++i;
    hessians.resize( w );
static double MBMesquite::QualityMetric::vertex_barrier_function ( double  det,
double  delta
) [inline, static]
Definition at line 227 of file QualityMetric.hpp.
        return 0.5 * ( det + sqrt( det * det + 4 * delta * delta ) );
double MBMesquite::QualityMetric::weighted_average_metrics ( const double  coef[],
const int &  num_values,
MsqError err
takes an array of coefficients and an array of metrics (both of length num_value) and averages the contents using averaging method 'method'.
Definition at line 375 of file QualityMetric.cpp.
    // MSQ_MAX needs to be made global?
    // double MSQ_MAX=1e10;
    double total_value = 0.0;
    int i              = 0;
    // if no values, return zero
    if( num_values <= 0 )
        return 0.0;
    for( i = 0; i < num_values; ++i )
        total_value += coef[i] * metric_values[i];
    total_value /= (double)num_values;
    return total_value;
Member Data Documentation
Definition at line 331 of file QualityMetric.hpp.
Location for finite difference Hessian code to store this value so that it doesn't need to be recalculated if the gradient calculation is also finite difference
Definition at line 338 of file QualityMetric.hpp.
Referenced by evaluate_with_gradient(), and evaluate_with_Hessian().
True if finite difference Hessian code has calculated finiteDiffEps
Definition at line 336 of file QualityMetric.hpp.
True if gradient finite difference calculation should set finiteDiffEps
Definition at line 334 of file QualityMetric.hpp.
std::vector< Matrix3D > MBMesquite::QualityMetric::tmpHess [private]
Definition at line 333 of file QualityMetric.hpp.
Referenced by evaluate_with_Hessian_diagonal().
List of all members.
