MBMesquite::QuasiNewton Class Reference
#include <QuasiNewton.hpp>
+ Inheritance diagram for MBMesquite::QuasiNewton:
+ Collaboration diagram for MBMesquite::QuasiNewton:
Public Member Functions
MESQUITE_EXPORT QuasiNewton (ObjectiveFunction *of)
virtual MESQUITE_EXPORT ~QuasiNewton ()
PatchSetget_patch_set ()
MESQUITE_EXPORT std::string get_name () const
 Get string name for use in diagnostic and status output.
Protected Member Functions
virtual void initialize (PatchData &pd, MsqError &err)
virtual void optimize_vertex_positions (PatchData &pd, MsqError &err)
virtual void initialize_mesh_iteration (PatchData &pd, MsqError &err)
virtual void terminate_mesh_iteration (PatchData &pd, MsqError &err)
virtual void cleanup ()
void solve (Vector3D *z, const Vector3D *v) const
Private Types
enum  Constants { QNVEC = 5 }
Private Attributes
PatchDataVerticesMementomMemento
std::vector< Vector3Dx
std::vector< Vector3Dv [QNVEC+1]
std::vector< Vector3Dw [QNVEC+1]
std::vector< Vector3Dd
std::vector< SymMatrix3DmHess
Detailed Description
Definition at line 45 of file QuasiNewton.hpp.
Member Enumeration Documentation
Enumerator:
QNVEC
Definition at line 66 of file QuasiNewton.hpp.
        QNVEC = 5
Definition at line 59 of file QuasiNewton.cpp.
: VertexMover( of ), PatchSetUser( true ), mMemento( 0 ) {}
Definition at line 61 of file QuasiNewton.cpp.
References mMemento.
    delete mMemento;
    mMemento = 0;
Member Function Documentation
void MBMesquite::QuasiNewton::cleanup ( ) [protected, virtual]
Implements MBMesquite::VertexMover.
Definition at line 79 of file QuasiNewton.cpp.
References d, MBMesquite::free_vector(), mHess, mMemento, v, w, and x.
    // release memento
    delete mMemento;
    mMemento = 0;
    // release coordinates
    for( size_t i = 0; i < ( sizeof( w ) / sizeof( w[0] ) ); ++i )
        free_vector( w[i] );
    // release gradients
    for( size_t i = 0; i < ( sizeof( v ) / sizeof( v[0] ) ); ++i )
        free_vector( v[i] );
    // release Hessian memory
    free_vector( mHess );
    // release temporary array memory
    free_vector( x );
    free_vector( d );
std::string MBMesquite::QuasiNewton::get_name ( ) const [virtual]
Implements MBMesquite::Instruction.
Definition at line 49 of file QuasiNewton.cpp.
    return "QuasiNewton";
Reimplemented from MBMesquite::PatchSetUser.
Definition at line 54 of file QuasiNewton.cpp.
void MBMesquite::QuasiNewton::initialize ( PatchData pd,
MsqError err
Definition at line 67 of file QuasiNewton.cpp.
References MBMesquite::PatchData::create_vertices_memento(), mMemento, and MSQ_CHKERR.
    if( !mMemento )
        mMemento = pd.create_vertices_memento( err );MSQ_CHKERR( err );
void MBMesquite::QuasiNewton::initialize_mesh_iteration ( PatchData pd,
MsqError err
Definition at line 75 of file QuasiNewton.cpp.
void MBMesquite::QuasiNewton::optimize_vertex_positions ( PatchData pd,
MsqError err
Definition at line 169 of file QuasiNewton.cpp.
References MBMesquite::TerminationCriterion::accumulate_inner(), MBMesquite::TerminationCriterion::accumulate_patch(), MBMesquite::arrptr(), b, MBMesquite::MsqError::BARRIER_VIOLATED, beta, MBMesquite::MsqError::clear(), d, epsilon, MBMesquite::MsqError::error_code(), MBMesquite::OFEvaluator::evaluate(), MBMesquite::PatchData::get_free_vertex_coordinates(), MBMesquite::QualityImprover::get_inner_termination_criterion(), MBMesquite::VertexMover::get_objective_function_evaluator(), MBMesquite::inner(), INTERNAL_ERROR, MBMesquite::MsqError::INVALID_MESH, MBMesquite::length(), mHess, mMemento, MBMesquite::PatchData::move_free_vertices_constrained(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::PatchData::num_free_vertices(), MBMesquite::plus_eq_scaled(), QNVEC, MBMesquite::PatchData::recreate_vertices_memento(), MBMesquite::PatchData::set_free_vertices_constrained(), MBMesquite::PatchData::set_to_vertices_memento(), solve(), MBMesquite::TerminationCriterion::terminate(), MBMesquite::OFEvaluator::update(), v, w, and x.
    TerminationCriterion& term = *get_inner_termination_criterion();
    OFEvaluator& func          = get_objective_function_evaluator();
    const double sigma   = 1e-4;
    const double beta0   = 0.25;
    const double beta1   = 0.80;
    const double tol1    = 1e-8;
    const double epsilon = 1e-10;
    // double norm_r; //, norm_g;
    double alpha, beta;
    double obj, objn;
    size_t i;
    // Initialize stuff
    const size_t nn = pd.num_free_vertices();
    double a[QNVEC], b[QNVEC], r[QNVEC];
    for( i = 0; i < QNVEC; ++i )
        r[i] = 0;
    for( i = 0; i <= QNVEC; ++i )
        v[i].clear();
        v[i].resize( nn, Vector3D( 0.0 ) );
        w[i].clear();
        w[i].resize( nn, Vector3D( 0.0 ) );
    d.resize( nn );
    mHess.resize( nn );  // hMesh(mesh);
    bool valid = func.update( pd, obj, v[QNVEC], mHess, err );MSQ_ERRRTN( err );
    if( !valid )
        MSQ_SETERR( err )( "Initial objective function is not valid", MsqError::INVALID_MESH );
        return;
    while( !term.terminate() )
        pd.recreate_vertices_memento( mMemento, err );MSQ_ERRRTN( err );
        pd.get_free_vertex_coordinates( w[QNVEC] );
        x = v[QNVEC];
        for( i = QNVEC; i--; )
            a[i] = r[i] * inner( &( w[i][0] ), arrptr( x ), nn );
            plus_eq_scaled( arrptr( x ), -a[i], &v[i][0], nn );
        solve( arrptr( d ), arrptr( x ) );
            b[i] = r[i] * inner( &( v[i][0] ), arrptr( d ), nn );
            plus_eq_scaled( arrptr( d ), a[i] - b[i], &( w[i][0] ), nn );
        alpha = -inner( &( v[QNVEC][0] ), arrptr( d ), nn ); /* direction is negated */
        if( alpha > 0.0 )
            MSQ_SETERR( err )( "No descent.", MsqError::INVALID_MESH );
            return;
        alpha *= sigma;
        beta = 1.0;
        pd.move_free_vertices_constrained( arrptr( d ), nn, -beta, err );MSQ_ERRRTN( err );
        valid = func.evaluate( pd, objn, v[QNVEC], err );
        if( err.error_code() == err.BARRIER_VIOLATED )
            err.clear();  // barrier violated does not represent an actual error here
        MSQ_ERRRTN( err );
        if( !valid || ( obj - objn < -alpha * beta - epsilon && length( &( v[QNVEC][0] ), nn ) >= tol1 ) )
            if( !valid )  // function not defined at trial point
                beta *= beta0;
            else  // unacceptable iterate
                beta *= beta1;
            for( ;; )
                if( beta < tol1 )
                    pd.set_to_vertices_memento( mMemento, err );MSQ_ERRRTN( err );
                    MSQ_SETERR( err )( "Newton step not good", MsqError::INTERNAL_ERROR );
                    return;
                pd.set_free_vertices_constrained( mMemento, arrptr( d ), nn, -beta, err );MSQ_ERRRTN( err );
                valid = func.evaluate( pd, objn, err );
                MSQ_ERRRTN( err );
                if( !valid )  // function undefined at trial point
                    beta *= beta0;
                else if( obj - objn < -alpha * beta - epsilon )  // unacceptlable iterate
                    beta *= beta1;
                else
                    break;
        for( i = 0; i < QNVEC - 1; ++i )
            r[i] = r[i + 1];
            w[i].swap( w[i + 1] );
            v[i].swap( v[i + 1] );
        w[QNVEC - 1].swap( w[0] );
        v[QNVEC - 1].swap( v[0] );
        // norm_r = length_squared( &(v[QNVEC][0]), nn );
        // norm_g = sqrt(norm_r);
        // checks stopping criterion
        term.accumulate_patch( pd, err );MSQ_ERRRTN( err );
        term.accumulate_inner( pd, objn, &v[QNVEC][0], err );MSQ_ERRRTN( err );
void MBMesquite::QuasiNewton::solve ( Vector3D z,
const Vector3D v
) const [protected]
Definition at line 108 of file QuasiNewton.cpp.
References mHess, and z.
Referenced by optimize_vertex_positions().
    SymMatrix3D pd;
    const double small = DBL_EPSILON;
    const size_t nn    = mHess.size();
    for( size_t i = 0; i < nn; ++i )
        // ensure positive definite: perturb a bit if
        // diagonal values are zero.
        SymMatrix3D dd = mHess[i];
        while( fabs( dd[0] ) < small || fabs( dd[3] ) < small || fabs( dd[5] ) < small )
            dd += small;
        // factor
        pd[0] = 1.0 / dd[0];
        pd[1] = dd[1] * pd[0];
        pd[2] = dd[2] * pd[0];
        pd[3] = 1.0 / ( dd[3] - dd[1] * pd[1] );
        pd[5] = dd[4] - dd[2] * pd[1];
        pd[4] = pd[3] * pd[5];
        pd[5] = 1.0 / ( dd[5] - dd[2] * pd[2] - pd[4] * pd[5] );
        if( pd[0] <= 0.0 || pd[3] <= 0.0 || pd[5] <= 0.0 )
            if( dd[0] + dd[3] + dd[5] <= 0 )
                // switch to diagonal
                pd[0] = 1.0 / fabs( dd[0] );
                pd[1] = 0.0;
                pd[2] = 0.0;
                pd[3] = 1.0 / fabs( dd[3] );
                pd[4] = 0.0;
                pd[5] = 1.0 / fabs( dd[5] );
            else
                // diagonal preconditioner
                pd[0] = pd[3] = pd[5] = 1.0 / ( dd[0] + dd[3] + dd[5] );
                pd[1] = pd[2] = pd[4] = 0.0;
        // solve
        const Vector3D& vv = v_arr[i];
        Vector3D& z        = z_arr[i];
        z[0]               = vv[0];
        z[1]               = vv[1] - pd[1] * z[0];
        z[2]               = vv[2] - pd[2] * z[0] - pd[4] * z[1];
        z[0] *= pd[0];
        z[1] *= pd[3];
        z[2] *= pd[5];
        z[1] -= pd[4] * z[2];
        z[0] -= pd[1] * z[1] + pd[2] * z[2];
void MBMesquite::QuasiNewton::terminate_mesh_iteration ( PatchData pd,
MsqError err
Definition at line 77 of file QuasiNewton.cpp.
Member Data Documentation
std::vector< Vector3D > MBMesquite::QuasiNewton::d [private]
Definition at line 72 of file QuasiNewton.hpp.
Referenced by cleanup(), and optimize_vertex_positions().
std::vector< SymMatrix3D > MBMesquite::QuasiNewton::mHess [private]
Definition at line 73 of file QuasiNewton.hpp.
Referenced by cleanup(), optimize_vertex_positions(), and solve().
std::vector< Vector3D > MBMesquite::QuasiNewton::v[QNVEC+1] [private]
std::vector< Vector3D > MBMesquite::QuasiNewton::w[QNVEC+1] [private]
std::vector< Vector3D > MBMesquite::QuasiNewton::x [private]
List of all members.
