MBMesquite::ScalarMultiplyQualityMetric Class Reference
Multiplies quality metric value by a number (a double). More...
#include <ScalarMultiplyQualityMetric.hpp>
+ Inheritance diagram for MBMesquite::ScalarMultiplyQualityMetric:
+ Collaboration diagram for MBMesquite::ScalarMultiplyQualityMetric:
Public Member Functions
 ScalarMultiplyQualityMetric (QualityMetric *metric, double scale)
 ~ScalarMultiplyQualityMetric ()
MetricType get_metric_type () const
std::string get_name () const
int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
void get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)
 Get locations at which metric can be evaluated.
bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)
bool evaluate_with_gradient (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err)
 Get metric value and gradient at a logical location in the patch.
bool evaluate_with_Hessian (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err)
 Get metric value and deravitives at a logical location in the patch.
Private Attributes
QualityMetricmMetric
double mScale
Detailed Description
Definition at line 49 of file ScalarMultiplyQualityMetric.hpp.
Definition at line 52 of file ScalarMultiplyQualityMetric.hpp.
: mMetric( metric ), mScale( scale ) {}
Member Function Documentation
bool ScalarMultiplyQualityMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 55 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate(), mMetric, and mScale.
    bool rval = mMetric->evaluate( pd, handle, value, err );
    value *= mScale;
    return rval;
bool ScalarMultiplyQualityMetric::evaluate_with_gradient ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
std::vector< Vector3D > &  gradient,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
gradientThe gradient of the metric as a function of the coordinates of the free vertices passed back in the indices list.
Reimplemented from MBMesquite::QualityMetric.
Definition at line 73 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_gradient(), mMetric, mScale, and MSQ_CHKERR.
    bool rval = mMetric->evaluate_with_gradient( pd, handle, value, indices, gradient, err );
    value *= mScale;
    for( std::vector< Vector3D >::iterator i = gradient.begin(); i != gradient.end(); ++i )
        *i *= mScale;
    return !MSQ_CHKERR( err ) && rval;
bool ScalarMultiplyQualityMetric::evaluate_with_Hessian ( PatchData pd,
size_t  handle,
double &  value,
std::vector< Matrix3D > &  Hessian,
MsqError err
) [virtual]
Parameters:
pdThe patch.
HessianThe Hessian of the metric as a function of the coordinates. The Hessian is passed back as the upper-triangular portion of the matrix in row-major order, where each Matrix3D is the portion of the Hessian with respect to the vertices at the corresponding positions in the indices list.
Definition at line 87 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_Hessian(), mMetric, mScale, and MSQ_CHKERR.
    bool rval = mMetric->evaluate_with_Hessian( pd, handle, value, indices, gradient, Hessian, err );
    value *= mScale;
        *i *= mScale;
    for( std::vector< Matrix3D >::iterator j = Hessian.begin(); j != Hessian.end(); ++j )
        *j *= mScale;
bool ScalarMultiplyQualityMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Parameters:
pdThe patch.
Definition at line 62 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_indices(), mMetric, mScale, and MSQ_CHKERR.
    bool rval = mMetric->evaluate_with_indices( pd, handle, value, indices, err );
    value *= mScale;
void ScalarMultiplyQualityMetric::get_evaluations ( PatchData pd,
std::vector< size_t > &  handles,
MsqError err
) [virtual]
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
Parameters:
pdThe patch
handlesOutput list of handles
free_vertices_onlyIf true, only pass back evaluation points that depend on at least one free vertex.
Definition at line 47 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::get_evaluations(), mMetric, and MSQ_CHKERR.
    mMetric->get_evaluations( pd, handles, free_vertices_only, err );MSQ_CHKERR( err );
std::string ScalarMultiplyQualityMetric::get_name ( ) const [virtual]
Definition at line 42 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::get_name(), and mMetric.
    return std::string( "Scale(" ) + mMetric->get_name() + ")";
Definition at line 63 of file ScalarMultiplyQualityMetric.hpp.
References MBMesquite::QualityMetric::get_negate_flag(), and mMetric.
        return mMetric->get_negate_flag();
Member Data Documentation
List of all members.
