MBMesquite::TMPQualityMetric Class Reference
Compare targets to mapping function Jacobian matrices. More...
#include <TMPQualityMetric.hpp>
+ Inheritance diagram for MBMesquite::TMPQualityMetric:
+ Collaboration diagram for MBMesquite::TMPQualityMetric:
Public Member Functions
 TMPQualityMetric (TargetCalculator *tc, WeightCalculator *wc)
virtual MESQUITE_EXPORT int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual MESQUITE_EXPORT void get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)
 Get locations at which metric can be evaluated.
virtual MESQUITE_EXPORT void get_element_evaluations (PatchData &pd, size_t elem_index, std::vector< size_t > &handles, MsqError &err)
 Get evaluation point handles for a given element.
virtual MESQUITE_EXPORT bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
virtual MESQUITE_EXPORT bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)
MESQUITE_EXPORT void set_target_calculator (TargetCalculator *tc)
MESQUITE_EXPORT void set_weight_calculator (WeightCalculator *wc)
MESQUITE_EXPORT TargetCalculatorget_target_calculator () const
MESQUITE_EXPORT WeightCalculatorget_weight_calculator () const
virtual MESQUITE_EXPORT void initialize_queue (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)
 Called at start of instruction queue processing.
Static Public Member Functions
static MESQUITE_EXPORT void get_patch_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)
Protected Types
enum  { MAX_ELEM_NODES = 27 }
Protected Member Functions
virtual MESQUITE_EXPORT bool evaluate_internal (PatchData &pd, size_t handle, double &value, size_t *indices, size_t &num_indices, MsqError &err)=0
MESQUITE_EXPORT bool evaluate_surface_common (PatchData &pd, Sample sample, size_t element_index, const NodeSet &bits, size_t *indices, size_t &num_indices, MsqVector< 2 > *derivs, MsqMatrix< 2, 2 > &W, MsqMatrix< 2, 2 > &A, MsqMatrix< 3, 2 > &S_a_transpose_Theta, MsqError &err)
MESQUITE_EXPORT void weight (PatchData &pd, Sample sample, size_t elem, int num_points, double &value, Vector3D *grad, SymMatrix3D *diag, Matrix3D *hess, MsqError &err)
Protected Attributes
size_t mIndices [MAX_ELEM_NODES]
std::vector< MsqMatrix< 2, 2 > > hess2d
MsqVector< 3 > mDerivs3D [MAX_ELEM_NODES]
MsqVector< 2 > mDerivs2D [MAX_ELEM_NODES]
TargetCalculatortargetCalc
Private Attributes
WeightCalculatorweightCalc
Detailed Description
Base class for various TMP QualityMetric implementations
Definition at line 55 of file TMPQualityMetric.hpp.
Member Enumeration Documentation
anonymous enum [protected]
Enumerator:
MAX_ELEM_NODES
Definition at line 147 of file TMPQualityMetric.hpp.
        MAX_ELEM_NODES = 27
Parameters:
tcThe target calculator
wcThe weight calculator
Definition at line 62 of file TMPQualityMetric.hpp.
: targetCalc( tc ), weightCalc( wc ) {}
Member Function Documentation
bool MBMesquite::TMPQualityMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 79 of file TMPQualityMetric.cpp.
References MBMesquite::ElemSampleQM::elem(), evaluate_internal(), MBMesquite::WeightCalculator::get_weight(), mIndices, MSQ_CHKERR, MSQ_ERRZERO, MBMesquite::ElemSampleQM::sample(), and weightCalc.
Referenced by MBMesquite::VertexMover::loop_over_mesh().
    size_t num_idx;
    bool valid = evaluate_internal( pd, p_handle, value, mIndices, num_idx, err );
    if( MSQ_CHKERR( err ) || !valid ) return false;
    // apply target weight to value
    if( weightCalc )
        const Sample s = ElemSampleQM::sample( p_handle );
        const size_t e = ElemSampleQM::elem( p_handle );
        double ck      = weightCalc->get_weight( pd, e, s, err );
        MSQ_ERRZERO( err );
        value *= ck;
    return true;
virtual MESQUITE_EXPORT bool MBMesquite::TMPQualityMetric::evaluate_internal ( PatchData pd,
size_t  handle,
double &  value,
size_t *  indices,
size_t &  num_indices,
MsqError err
) [protected, pure virtual]
bool MBMesquite::TMPQualityMetric::evaluate_surface_common ( PatchData pd,
Sample  sample,
const NodeSet bits,
size_t *  indices,
MsqVector< 2 > *  derivs,
MsqMatrix< 2, 2 > &  W,
MsqMatrix< 2, 2 > &  A,
MsqMatrix< 3, 2 > &  S_a_transpose_Theta,
MsqError err
) [protected]
Definition at line 249 of file TMPQualityMetric.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), MBMesquite::MsqMatrix< R, C >::data(), MBMesquite::PatchData::domain_set(), MBMesquite::PatchData::element_by_index(), MBMesquite::TargetCalculator::get_2D_target(), MBMesquite::PatchData::get_domain_normal_at_sample(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_mapping_function_2D(), MBMesquite::TargetCalculator::get_surface_target(), MBMesquite::TargetCalculator::have_surface_orient(), MBMesquite::MappingFunction2D::jacobian(), MSQ_ERRZERO, MSQ_SETERR, n, MBMesquite::project_to_matrix_plane(), MBMesquite::project_to_perp_plane(), MBMesquite::MsqMatrix< R, C >::row(), MBMesquite::MsqMatrix< R, C >::set_column(), MBMesquite::MsqMatrix< R, C >::set_row(), targetCalc, u, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by MBMesquite::AWQualityMetric::evaluate_internal(), MBMesquite::TQualityMetric::evaluate_internal(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), and MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal().
    EntityTopology type = pd.element_by_index( e ).get_element_type();
    const MappingFunction2D* mf = pd.get_mapping_function_2D( type );
    if( !mf )
        MSQ_SETERR( err )( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT );
        return false;
    MsqMatrix< 3, 2 > J;
    mf->jacobian( pd, e, bits, s, indices, derivs, num_indices, J, err );
    // If we have a 3x2 target matrix
    if( targetCalc->have_surface_orient() )
        MsqVector< 3 > u, u_perp;
        MsqMatrix< 3, 2 > W_hat;
        targetCalc->get_surface_target( pd, e, s, W_hat, err );
        MSQ_ERRZERO( err );
        // Use the cross product of the columns of W as the normal of the
        // plane to work in (i.e. u.).  W should have been constructed such
        // that said cross product is in the direction of (n_s)_init.  And if
        // for some reason it as not, then using something other than said
        // cross product is likely to produce very wrong results.
        project_to_matrix_plane( W_hat, W, u, u_perp );
        // Do the transforms on A to align it with W and project into the plane.
        if( !project_to_perp_plane( J, u, u_perp, A, S_a_transpose_Theta ) ) return false;
    // Otherwise if we have a 2x2 target matrix (i.e. the target does
    // not contain orientation information), project into the plane
    // tangent to J.
    else
        targetCalc->get_2D_target( pd, e, s, W, err );
        MSQ_ERRZERO( err );
        project_to_matrix_plane( J, A, u, u_perp );
        S_a_transpose_Theta.set_column( 0, u_perp );
        S_a_transpose_Theta.set_column( 1, u * u_perp );
        // If the domain is set, adjust the sign of things correctly
        // for the case where the element is inverted with respect
        // to the domain.
        if( pd.domain_set() )
            Vector3D n;
            pd.get_domain_normal_at_sample( e, s, n, err );
            MSQ_ERRZERO( err );
            // if sigma == -1
            if( Vector3D( u.data() ) % n < 0.0 )
                // flip u
                u = -u;
                // S_a_transpose_Theta == Theta, because S_a == I here.
                // u_perp is unaffected by flipping u, so only the second
                // column of S_a_transpose_Theta and the second row of A
                // are flipped because u x u_perp will be flipped.
                S_a_transpose_Theta.set_column( 1, -S_a_transpose_Theta.column( 1 ) );
                A.set_row( 1, -A.row( 1 ) );
    return true;
bool MBMesquite::TMPQualityMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
Definition at line 97 of file TMPQualityMetric.cpp.
References MBMesquite::arrptr(), MBMesquite::ElemSampleQM::elem(), evaluate_internal(), MBMesquite::WeightCalculator::get_weight(), MAX_ELEM_NODES, MSQ_CHKERR, MSQ_ERRZERO, MBMesquite::ElemSampleQM::sample(), and weightCalc.
    indices.resize( MAX_ELEM_NODES );
    size_t num_idx = 0;
    bool result    = evaluate_internal( pd, p_handle, value, arrptr( indices ), num_idx, err );
    if( MSQ_CHKERR( err ) || !result ) return false;
    indices.resize( num_idx );
    if( weightCalc )
        MSQ_ERRZERO( err );
        value *= ck;
    return true;
void MBMesquite::TMPQualityMetric::get_element_evaluations ( PatchData pd,
size_t  elem_index,
std::vector< size_t > &  handles,
MsqError err
) [virtual]
Similar to QualityMetric::get_evaluations, this method returns a list of handles corresponding to sample points at which the metric may be evaluated. While QualityMetric::get_evaluations returns sample points for all elements in a PatchData, this method returns only the subset corresponding to a single element.
Implements MBMesquite::ElemSampleQM.
Definition at line 71 of file TMPQualityMetric.cpp.
References MBMesquite::get_elem_sample_points().
    get_elem_sample_points( pd, p_elem, handles, err );
void MBMesquite::TMPQualityMetric::get_evaluations ( PatchData pd,
MsqError err
) [virtual]
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
Parameters:
pdThe patch
handlesOutput list of handles
free_vertices_onlyIf true, only pass back evaluation points that depend on at least one free vertex.
Definition at line 61 of file TMPQualityMetric.cpp.
References MBMesquite::get_sample_pt_evaluations().
Referenced by TQualityMetricTest::regression_inverse_mean_ratio_grad(), and TQualityMetricTest::regression_inverse_mean_ratio_hess().
    get_sample_pt_evaluations( pd, handles, free, err );
Definition at line 56 of file TMPQualityMetric.cpp.
    return 1;
void MBMesquite::TMPQualityMetric::get_patch_evaluations ( PatchData pd,
MsqError err
) [static]
Definition at line 66 of file TMPQualityMetric.cpp.
Referenced by MBMesquite::MeshUtil::lambda_distribution().
void MBMesquite::TMPQualityMetric::initialize_queue ( MeshDomainAssoc mesh_and_domain,
const Settings settings,
MsqError err
) [virtual]
Do any preliminary global initialization, consistency checking, etc. Default implementation does nothing.
Reimplemented from MBMesquite::QualityMetric.
Definition at line 358 of file TMPQualityMetric.cpp.
References MBMesquite::WeightCalculator::initialize_queue(), MBMesquite::TargetCalculator::initialize_queue(), MSQ_ERRRTN, targetCalc, and weightCalc.
    targetCalc->initialize_queue( mesh_and_domain, settings, err );MSQ_ERRRTN( err );
    if( weightCalc )
        weightCalc->initialize_queue( mesh_and_domain, settings, err );MSQ_ERRRTN( err );
void MBMesquite::TMPQualityMetric::weight ( PatchData pd,
Sample  sample,
size_t  elem,
int  num_points,
double &  value,
Vector3D grad,
SymMatrix3D diag,
Matrix3D hess,
MsqError err
) [protected]
Definition at line 326 of file TMPQualityMetric.cpp.
References MBMesquite::WeightCalculator::get_weight(), MSQ_ERRRTN, n, and weightCalc.
Referenced by MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), and MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal().
    if( !weightCalc ) return;
    double ck = weightCalc->get_weight( pd, p_elem, p_sample, err );MSQ_ERRRTN( err );
    value *= ck;
    if( grad )
        for( int i = 0; i < num_idx; ++i )
            grad[i] *= ck;
    if( diag )
            diag[i] *= ck;
    if( hess )
        const int n = num_idx * ( num_idx + 1 ) / 2;
        for( int i = 0; i < n; ++i )
            hess[i] *= ck;
Member Data Documentation
List of all members.
