MBMesquite::VertexConditionNumberQualityMetric Class Reference
Computes the condition numbers of the corner's of elements connected to the given vertex and then averages those values. More...
#include <VertexConditionNumberQualityMetric.hpp>
+ Inheritance diagram for MBMesquite::VertexConditionNumberQualityMetric:
+ Collaboration diagram for MBMesquite::VertexConditionNumberQualityMetric:
Public Member Functions
 VertexConditionNumberQualityMetric ()
virtual ~VertexConditionNumberQualityMetric ()
 virtual destructor ensures use of polymorphism during destruction
virtual std::string get_name () const
virtual int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
virtual bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)
Detailed Description
The metric does not use the sample point functionality or the compute_weighted_jacobian. It uses the isotropic ideal element. This metric does require a feasible region, and the metric needs to be minimized.
Definition at line 53 of file VertexConditionNumberQualityMetric.hpp.
Definition at line 59 of file VertexConditionNumberQualityMetric.hpp.
Member Function Documentation
bool VertexConditionNumberQualityMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 56 of file VertexConditionNumberQualityMetric.cpp.
References MBMesquite::arrptr(), MBMesquite::AveragingQM::average_metrics(), MBMesquite::condition_number_2d(), MBMesquite::condition_number_3d(), MBMesquite::MsqMeshEntity::get_connected_vertices(), MBMesquite::PatchData::get_element_array(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::PatchData::get_vertex_element_adjacencies(), MBMesquite::HEXAHEDRON, MSQ_ERRZERO, MBMesquite::MSQ_MAX_CAP, MSQ_SETERR, MBMesquite::MSQ_SQRT_THREE, MBMesquite::MSQ_SQRT_THREE_INV, MBMesquite::MSQ_SQRT_TWO, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by evaluate_with_indices().
    // pd.generate_vertex_to_element_data();
    bool return_flag;
    fval = MSQ_MAX_CAP;
    // get the element array
    MsqMeshEntity* elems = pd.get_element_array( err );
    // get the vertex to element array and the offset array
    // const size_t* elem_offset = pd.get_vertex_to_elem_offset(err);  MSQ_ERRZERO(err);
    // const size_t* v_to_e_array = pd.get_vertex_to_elem_array(err);  MSQ_ERRZERO(err);
    // find the offset for this vertex
    // size_t this_offset = elem_offset[this_vert];
    // get the number of elements attached to this vertex (given by the
    // first entry in the vertex to element array)
    // size_t num_elems = v_to_e_array[this_offset];
    // PRINT_INFO("\nIN LOCAL SIZE CPP, num_elements = %i",num_elems);
    // if no elements, then return true
    size_t num_elems;
    const size_t* v_to_e_array = pd.get_vertex_element_adjacencies( this_vert, num_elems, err );
    MSQ_ERRZERO( err );
    if( num_elems <= 0 )
        return true;
    // create an array to store the local metric values before averaging
    // Can we remove this dynamic allocatio?
    std::vector< double > met_vals( num_elems );
    // vector to hold the other verts which form a corner.
    vector< size_t > other_vertices;
    other_vertices.reserve( 4 );
    size_t i = 0;
    // only 3 temp_vec will be sent to cond-num calculator, but the
    // additional vector3Ds may be needed during the calculations
    size_t elem_index;
    Vector3D temp_vec[6];
    const MsqVertex* vertices = pd.get_vertex_array( err );
    // loop over the elements attached to this vertex
    for( i = 0; i < num_elems; ++i )
        // get the vertices connected to this vertex for this element
        elem_index = v_to_e_array[i];
        elems[elem_index].get_connected_vertices( this_vert, other_vertices, err );
        MSQ_ERRZERO( err );
        // switch over the element type of this element
        switch( elems[v_to_e_array[i]].get_element_type() )
            case TRIANGLE:
                temp_vec[0] = vertices[other_vertices[0]] - vertices[this_vert];
                temp_vec[2] = vertices[other_vertices[1]] - vertices[this_vert];
                // make relative to equilateral
                temp_vec[1] = ( ( 2 * temp_vec[2] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV;
                return_flag = condition_number_2d( temp_vec, elem_index, pd, met_vals[i], err );
                MSQ_ERRZERO( err );
                if( !return_flag ) return return_flag;
                break;
            case QUADRILATERAL:
                temp_vec[1] = vertices[other_vertices[1]] - vertices[this_vert];
                MSQ_ERRZERO( err );
                break;
            case TETRAHEDRON:
                temp_vec[3] = vertices[other_vertices[1]] - vertices[this_vert];
                temp_vec[4] = vertices[other_vertices[2]] - vertices[this_vert];
                // transform to equilateral tet
                temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) / MSQ_SQRT_THREE;
                temp_vec[2] = ( ( 3 * temp_vec[4] ) - temp_vec[0] - temp_vec[3] ) / ( MSQ_SQRT_THREE * MSQ_SQRT_TWO );
                return_flag = condition_number_3d( temp_vec, pd, met_vals[i], err );
                MSQ_ERRZERO( err );
                break;
            case HEXAHEDRON:
                temp_vec[2] = vertices[other_vertices[2]] - vertices[this_vert];
                MSQ_ERRZERO( err );
                break;
            default:
                MSQ_SETERR( err )
                ( MsqError::UNSUPPORTED_ELEMENT, "Element type (%d) not uspported in VertexConditionNumberQM.\n",
                  (int)( elems[v_to_e_array[i]].get_element_type() ) );
                fval = MSQ_MAX_CAP;
                return false;
        }  // end switch over element type
        other_vertices.clear();
    }  // end loop over elements
    fval = average_metrics( arrptr( met_vals ), num_elems, err );
    MSQ_ERRZERO( err );
    return true;
bool VertexConditionNumberQualityMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
Definition at line 155 of file VertexConditionNumberQualityMetric.cpp.
References evaluate(), MBMesquite::MsqMeshEntity::get_connected_vertices(), MBMesquite::PatchData::get_element_array(), MBMesquite::PatchData::get_vertex_element_adjacencies(), MSQ_ERRFALSE, MSQ_ERRZERO, and MBMesquite::PatchData::num_free_vertices().
    bool rval = evaluate( pd, this_vert, value, err );
    MSQ_ERRFALSE( err );
    indices.clear();
    size_t num_elems;
    MSQ_ERRZERO( err );
    size_t i = 0;
        elems[v_to_e_array[i]].get_connected_vertices( this_vert, other_vertices, err );
        MSQ_ERRZERO( err );
        for( unsigned j = 0; j < other_vertices.size(); ++j )
            if( other_vertices[j] < pd.num_free_vertices() ) indices.push_back( other_vertices[j] );
    std::sort( indices.begin(), indices.end() );
    indices.erase( std::unique( indices.begin(), indices.end() ), indices.end() );
    if( this_vert < pd.num_free_vertices() ) indices.push_back( this_vert );
    return rval;
std::string VertexConditionNumberQualityMetric::get_name ( ) const [virtual]
Definition at line 46 of file VertexConditionNumberQualityMetric.cpp.
    return "Vertex Condition Number";
Definition at line 51 of file VertexConditionNumberQualityMetric.cpp.
    return 1;
List of all members.
