MBMesquite::XYPlanarDomain Class Reference
#include <XYPlanarDomain.hpp>
+ Inheritance diagram for MBMesquite::XYPlanarDomain:
+ Collaboration diagram for MBMesquite::XYPlanarDomain:
Public Member Functions
 XYPlanarDomain ()
virtual ~XYPlanarDomain ()
virtual void snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const
virtual void vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const
virtual void element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const
virtual void vertex_normal_at (const Mesh::VertexHandle *handle, Vector3D coords[], unsigned count, MsqError &err) const
 evaluate surface normals
virtual void closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const
 evaluate closest point and normal
virtual void domain_DoF (const Mesh::VertexHandle *handle_array, unsigned short *dof_array, size_t num_vertices, MsqError &err) const
Detailed Description
This is a template for a planar domain that exists in the xy-plane (z=0). It will provide the normal information necessary for surface mesh optimization.
Definition at line 51 of file XYPlanarDomain.hpp.
Definition at line 54 of file XYPlanarDomain.hpp.
Definition at line 35 of file XYPlanarDomain.cpp.
Member Function Documentation
void MBMesquite::XYPlanarDomain::closest_point ( Mesh::VertexHandle  handle,
const Vector3D position,
Vector3D closest,
Vector3D normal,
MsqError err
) const [virtual]
Given a position in space, return the closest position in the domain and the domain normal at that point.
Parameters:
entity_handleEvaluate the subset of the domain contianing this entity
positionInput position for which to evaluate
closestClosest position in the domain.
normalDomain normal at the location of 'closest'
Implements MBMesquite::MeshDomain.
Definition at line 63 of file XYPlanarDomain.cpp.
    closest = Vector3D( position[0], position[1], 0.0 );
void MBMesquite::XYPlanarDomain::domain_DoF ( const Mesh::VertexHandle handle_array,
unsigned short *  dof_array,
MsqError err
) const [virtual]
Definition at line 72 of file XYPlanarDomain.cpp.
    std::fill( dof_array, dof_array + num_vertices, 2 );
void MBMesquite::XYPlanarDomain::element_normal_at ( Mesh::ElementHandle  entity_handle,
MBMesquite::Vector3D coordinate
) const [virtual]
Definition at line 48 of file XYPlanarDomain.cpp.
    coordinate = Vector3D( 0.0, 0.0, 1.0 );
void MBMesquite::XYPlanarDomain::snap_to ( Mesh::VertexHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Definition at line 37 of file XYPlanarDomain.cpp.
    coordinate[2] = 0.0;
void MBMesquite::XYPlanarDomain::vertex_normal_at ( Mesh::VertexHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Definition at line 42 of file XYPlanarDomain.cpp.
void MBMesquite::XYPlanarDomain::vertex_normal_at ( const Mesh::VertexHandle handles,
Vector3D  coordinates[],
unsigned  count,
MsqError err
) const [virtual]
Returns normals for a domain.
Parameters:
handlesThe domain evaluated is the one in which this mesh entity is constrained.
coordinatesAs input, a list of positions at which to evaluate the domain. As output, the resulting domain normals.
countThe length of the coordinates array.
Definition at line 54 of file XYPlanarDomain.cpp.
    for( unsigned i = 0; i < count; ++i )
        coords[i] = Vector3D( 0.0, 0.0, 1.0 );
List of all members.
