MeshInterfaceTest Class Reference
+ Inheritance diagram for MeshInterfaceTest:
+ Collaboration diagram for MeshInterfaceTest:
Public Member Functions
 MeshInterfaceTest ()
void setUp ()
void tearDown ()
void test_get_geometric_dimension ()
void test_vertices ()
void test_vertex_is_fixed ()
void test_vertex_byte ()
void test_vertex_get_attached_elements ()
void test_elements ()
void test_elements_get_attached_vertices ()
void test_elements_get_topology ()
void test_element_get_attached_vertex_indices ()
Private Member Functions
 CPPUNIT_TEST_SUITE (MeshInterfaceTest)
 CPPUNIT_TEST (test_get_geometric_dimension)
 CPPUNIT_TEST (test_vertices)
 CPPUNIT_TEST (test_vertex_byte)
 CPPUNIT_TEST (test_vertex_get_attached_elements)
 CPPUNIT_TEST (test_elements)
 CPPUNIT_TEST (test_elements_get_attached_vertices)
 CPPUNIT_TEST (test_elements_get_topology)
 CPPUNIT_TEST (test_element_get_attached_vertex_indices)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
MBMesquite::MeshImplmMesh
std::vector
< MBMesquite::Mesh::VertexHandle
mConnectivity
std::vector
mVertices
std::vector
< MBMesquite::Mesh::ElementHandle
mElements
std::vector< size_t > mOffsets
MBMesquite::MsqError mErr
Detailed Description
Definition at line 56 of file MeshInterfaceTest.cpp.
Definition at line 83 of file MeshInterfaceTest.cpp.
: mMesh( 0 ) {}
Member Function Documentation
void MeshInterfaceTest::setUp ( ) [inline]
Definition at line 86 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, MBMesquite::MeshImpl::elements_get_attached_vertices(), MBMesquite::MeshImpl::get_all_elements(), mConnectivity, mElements, mErr, mMesh, mOffsets, mVertices, and MBMesquite::MeshImpl::read_vtk().
        // Read a VTK file -- 1 triangle flanked by 1 quad on each side (1 tri + 3 quads)
        mMesh = new MBMesquite::MeshImpl;
        mMesh->read_vtk( MESH_FILES_DIR "2D/vtk/mixed/untangled/hybrid_3quad_1tri.vtk", mErr );
        CPPUNIT_ASSERT( !mErr );
        // Get mesh data
        mMesh->get_all_elements( mElements, mErr );
        mMesh->elements_get_attached_vertices( arrptr( mElements ), mElements.size(), mConnectivity, mOffsets, mErr );
        // Construct list of vertices w/out duplicates from
        // connectivity list.
        std::vector< MBMesquite::Mesh::VertexHandle >::iterator new_end;
        mVertices = mConnectivity;
        std::sort( mVertices.begin(), mVertices.end() );
        new_end = std::unique( mVertices.begin(), mVertices.end() );
        mVertices.resize( new_end - mVertices.begin() );
void MeshInterfaceTest::tearDown ( ) [inline]
Definition at line 109 of file MeshInterfaceTest.cpp.
References MBMesquite::MsqError::clear(), mErr, and mMesh.
        delete mMesh;
        if( mErr ) cout << mErr << endl;
        mErr.clear();
Definition at line 341 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, MBMesquite::MeshImpl::elements_get_topologies(), mConnectivity, mElements, mErr, MBMesquite::MIXED, mMesh, mOffsets, tri_coords(), MBMesquite::TRIANGLE, and MBMesquite::MeshImpl::vertices_get_coordinates().
        // Find the index of the triangle
        MBMesquite::EntityTopology topo = Mesquite::MIXED;
        int tri_index                   = -1;
        while( topo != MBMesquite::TRIANGLE )
            ++tri_index;
            CPPUNIT_ASSERT( (unsigned)tri_index < mElements.size() );
            MBMesquite::Mesh::ElementHandle handle = mElements[tri_index];
            mMesh->elements_get_topologies( &handle, &topo, 1, mErr );
        // creates list with correct vertices coordinates for the triangle
        std::vector< Mesquite::Vector3D > correct_coords;
        correct_coords.push_back( Mesquite::Vector3D( 1., 0., 0. ) );
        correct_coords.push_back( Mesquite::Vector3D( 0., 1.732050807, 0. ) );
        correct_coords.push_back( Mesquite::Vector3D( -1., 0., 0. ) );
        // Creates same list from the mesh implementation
        std::vector< MBMesquite::MsqVertex > tri_coords( 3 );
        mMesh->vertices_get_coordinates( &mConnectivity[mOffsets[tri_index]], arrptr( tri_coords ), 3, mErr );
        // Makes sure both list contain the same elements (not necessarily in the same order).
        std::vector< Mesquite::Vector3D >::iterator correct_iter;
        std::vector< MBMesquite::MsqVertex >::iterator tri_iter;
        for( tri_iter = tri_coords.begin(); tri_iter != tri_coords.end(); ++tri_iter )
            for( correct_iter = correct_coords.begin(); correct_iter != correct_coords.end(); ++correct_iter )
                if( Mesquite::Vector3D::distance_between( *tri_iter, *correct_iter ) < 10e-4 ) break;
            // check if a match was found
            CPPUNIT_ASSERT( correct_iter != correct_coords.end() );
            // remove match from list
            correct_coords.erase( correct_iter );
        CPPUNIT_ASSERT( correct_coords.empty() );
Definition at line 268 of file MeshInterfaceTest.cpp.
References CPPUNIT_ASSERT_EQUAL, and mElements.
        CPPUNIT_ASSERT_EQUAL( 4, (int)mElements.size() );
Definition at line 273 of file MeshInterfaceTest.cpp.
References CPPUNIT_ASSERT, mConnectivity, mElements, mOffsets, and mVertices.
        const size_t nbElem = mElements.size();
        // checks we have 3 elements containing 4 vertices
        // and 1 element containing 3 vertices.
        int n3 = 0;
        int n4 = 0;
        size_t i;
        for( i = 0; i < nbElem; ++i )
            size_t nve = mOffsets[i + 1] - mOffsets[i];
            if( nve == 3 )
                ++n3;
            else if( nve == 4 )
                ++n4;
            else  // failure.
                CPPUNIT_ASSERT( false );
        CPPUNIT_ASSERT( n3 == 1 );  // 1 triangle
        CPPUNIT_ASSERT( n4 == 3 );  // 3 quads
        // Make sure CSR data is valid
        std::map< MBMesquite::Mesh::VertexHandle, int > vtx_repeated_occurence;
        for( i = 0; i < mVertices.size(); ++i )
            vtx_repeated_occurence[mVertices[i]] = 0;
        for( i = 0; i < mConnectivity.size(); ++i )
            ++vtx_repeated_occurence[mConnectivity[i]];
        for( i = 0; i < 9; ++i )
            CPPUNIT_ASSERT( vtx_repeated_occurence[mVertices[i]] <= 3 );
        // Makes sure CSR offsets are valid
        CPPUNIT_ASSERT( mOffsets[0] == 0 );
        CPPUNIT_ASSERT( mOffsets[1] >= 3 && mOffsets[1] <= 12 );
        CPPUNIT_ASSERT( mOffsets[2] >= 3 && mOffsets[2] <= 12 );
        CPPUNIT_ASSERT( mOffsets[3] >= 3 && mOffsets[3] <= 12 );
        CPPUNIT_ASSERT( mOffsets[4] == 15 );
Definition at line 314 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::MeshImpl::elements_get_topologies(), mElements, mErr, mMesh, MBMesquite::QUADRILATERAL, and MBMesquite::TRIANGLE.
        int nb_quads                      = 0;
        int nb_tri                        = 0;
        MBMesquite::EntityTopology* topos = new MBMesquite::EntityTopology[nbElem];
        mMesh->elements_get_topologies( arrptr( mElements ), topos, nbElem, mErr );
        for( size_t i = 0; i < nbElem; ++i )
            switch( topos[i] )
                case MBMesquite::TRIANGLE:
                    ++nb_tri;
                    break;
                case MBMesquite::QUADRILATERAL:
                    ++nb_quads;
                    break;
                default:
                    CPPUNIT_FAIL( "Topology should be quad or Hex only." );
        CPPUNIT_ASSERT_EQUAL( 1, nb_tri );
        CPPUNIT_ASSERT_EQUAL( 3, nb_quads );
        delete[] topos;
Definition at line 183 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, mErr, mMesh, mVertices, MBMesquite::MeshImpl::vertex_get_byte(), MBMesquite::MeshImpl::vertex_set_byte(), MBMesquite::MeshImpl::vertices_get_byte(), and MBMesquite::MeshImpl::vertices_set_byte().
        size_t nbVert = mVertices.size();
        size_t i;
        unsigned char* bytes = new unsigned char[nbVert];
        mMesh->vertices_get_byte( arrptr( mVertices ), bytes, nbVert, mErr );
        // Asserts all vertex bytes are initialised to 0.
        for( i = 0; i < nbVert; ++i )
            CPPUNIT_ASSERT( bytes[i] == 0 );
        // Test various vertex byte read / write routines.
        bytes[3] |= 4;
        mMesh->vertices_set_byte( arrptr( mVertices ), bytes, nbVert, mErr );
        mMesh->vertex_set_byte( mVertices[5], 8, mErr );
        unsigned char byte;
        mMesh->vertex_get_byte( mVertices[3], &byte, mErr );
        CPPUNIT_ASSERT( byte == 4 );
            if( i == 3 )
                CPPUNIT_ASSERT( bytes[i] == 4 );
            else if( i == 5 )
                CPPUNIT_ASSERT( bytes[i] == 8 );
            else
        delete[] bytes;
Definition at line 220 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, mErr, mMesh, mVertices, and MBMesquite::MeshImpl::vertices_get_attached_elements().
        size_t i;
        const size_t nbVert = mVertices.size();
        std::vector< MBMesquite::Mesh::ElementHandle > elements;
        std::vector< size_t > offsets;
        mMesh->vertices_get_attached_elements( arrptr( mVertices ), mVertices.size(), elements, offsets, mErr );
        CPPUNIT_ASSERT_EQUAL( offsets.size(), mVertices.size() + 1 );
        // checks we have 6 vertices contained in 1 element only
        // and 3 vertices contained in 3 elements.
        int n1 = 0;
        int n3 = 0;
        for( i = 1; i <= mVertices.size(); ++i )
            const size_t nev = offsets[i] - offsets[i - 1];
            if( nev == 1 )
                ++n1;
            else if( nev == 3 )
                ++n3;
            else  // failure.
        CPPUNIT_ASSERT( n1 == 6 );
        CPPUNIT_ASSERT( n3 == 3 );
        // gets the index of a vertex in a corner
        int one_corner_vertex_index = 0;
            const size_t nev = offsets[i + 1] - offsets[i];
            if( 1 == nev ) break;
        CPPUNIT_ASSERT( i < nbVert );
        one_corner_vertex_index = i;
        // retrieve the attached element.
        // This is a poor test.  We allow an element handle of zero,
        // and just testing that the function returned something isn't
        // that useful. - J.K.
        // MBMesquite::Mesh::ElementHandle elem=0;
        // mMesh->vertex_get_attached_elements(mVertices[one_corner_vertex_index], &elem, 1, mErr);
        // CPPUNIT_ASSERT(!mErr);
        // CPPUNIT_ASSERT(elem!=0);
Definition at line 169 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, fixed, mErr, mMesh, mVertices, and MBMesquite::MeshImpl::vertices_get_fixed_flag().
        bool correct_fixed[9] = { false, false, false, true, true, true, true, true, true };
        std::vector< bool > fixed;
        mMesh->vertices_get_fixed_flag( arrptr( mVertices ), fixed, 9, mErr );
        CPPUNIT_ASSERT_EQUAL( (size_t)8, fixed.size() );
        for( size_t i = 0; i < nbVert; ++i )
            CPPUNIT_ASSERT_EQUAL( correct_fixed[i], (bool)fixed[i] );
Definition at line 124 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, mErr, mMesh, mVertices, MBMesquite::Vector3D::set(), MBMesquite::MeshImpl::vertex_set_coordinates(), and MBMesquite::MeshImpl::vertices_get_coordinates().
        CPPUNIT_ASSERT_EQUAL( 9, (int)nbVert );
        MBMesquite::MsqVertex correct_coords[9], coords[9];
        correct_coords[0].set( 1, 0, 0 );
        correct_coords[1].set( 0, 1.732, 0 );
        correct_coords[2].set( -1, 0, 0 );
        correct_coords[3].set( -1, -2, 0 );
        correct_coords[4].set( 1, -2, 0 );
        correct_coords[5].set( 2.732, 1, 0 );
        correct_coords[6].set( 1.732, 2.732, 0 );
        correct_coords[7].set( -1.732, 2.732, 0 );
        correct_coords[8].set( -2.732, 1, 0 );
        mMesh->vertices_get_coordinates( arrptr( mVertices ), coords, nbVert, mErr );
            for( int j = 0; j < 3; ++j )
                CPPUNIT_ASSERT_DOUBLES_EQUAL( coords[i][j], correct_coords[i][j], .01 );
        coords[3].set( 2., 3., 4. );
        mMesh->vertex_set_coordinates( mVertices[3], coords[3], mErr );
        MBMesquite::MsqVertex coords_2;
        mMesh->vertices_get_coordinates( &mVertices[3], &coords_2, 1, mErr );
            CPPUNIT_ASSERT_DOUBLES_EQUAL( coords[3][j], coords_2[j], 1e-6 );
Member Data Documentation
List of all members.
