MetisPartitioner Member List
This is the complete list of members for MetisPartitioner, including all inherited members.
assemble_graph(const int dimension, std::vector< double > &coords, std::vector< idx_t > &moab_ids, std::vector< idx_t > &adjacencies, std::vector< idx_t > &length, Range &elems)MetisPartitioner [private]
assemble_taggedents_graph(const int dimension, std::vector< double > &coords, std::vector< idx_t > &moab_ids, std::vector< idx_t > &adjacencies, std::vector< idx_t > &length, Range &elems, const char *aggregating_tag)MetisPartitioner [private]
assemble_taggedsets_graph(const int dimension, std::vector< double > &coords, std::vector< idx_t > &moab_ids, std::vector< idx_t > &adjacencies, std::vector< idx_t > &length, Range &elems, const char *aggregating_tag)MetisPartitioner [private]
assign_global_idsPartitionerBase< idx_t > [protected]
get_global_id_option()PartitionerBase< idx_t > [inline]
include_closure()MetisPartitioner [inline, virtual]
mbImplPartitionerBase< idx_t > [protected]
MetisPartitioner(Interface *impl=NULL, const bool use_coords=false)MetisPartitioner
newCommPartitionerBase< idx_t > [protected]
part_sets()PartitionerBase< idx_t > [inline]
part_sets() constPartitionerBase< idx_t > [inline]
partition_mesh(const idx_t nparts, const char *method, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const bool partition_tagged_sets=false, const bool partition_tagged_ents=false, const char *aggregating_tag=NULL, const bool print_time=false)MetisPartitioner [virtual]
partition_mesh_and_geometry(const double part_geom_mesh_size, const idx_t nparts, const char *zmethod, const char *other_method, double imbal_tol, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const int obj_weight=0, const int edge_weight=0, const bool part_surf=false, const bool ghost=false, const int projection_type=0, const bool recompute_rcb_box=false, const bool print_time=false)MetisPartitioner [inline, virtual]
PartitionerBase(Interface *impl=NULL, const bool use_coords=false)PartitionerBase< idx_t >
partSetsPartitionerBase< idx_t > [protected]
set_global_id_option(bool id_opt)PartitionerBase< idx_t > [inline]
useCoordsPartitionerBase< idx_t > [protected]
write_aggregationtag_partition(const idx_t nparts, Range &elems, const idx_t *assignment, const bool write_as_sets, const bool write_as_tags)MetisPartitioner
write_partition(const idx_t nparts, Range &elems, const idx_t *assignment, const bool write_as_sets, const bool write_as_tags)MetisPartitioner [virtual]
PartitionerBase< idx_t >::write_partition(const idx_tnparts, Range &elems, const idx_t *assignment, const bool write_as_sets, const bool write_as_tags)=0PartitionerBase< idx_t > [pure virtual]
~MetisPartitioner()MetisPartitioner [virtual]
~PartitionerBase()PartitionerBase< idx_t > [virtual]
