StreamRedirector Class Reference
Public Member Functions
 StreamRedirector ()
 ~StreamRedirector ()
void redirect ()
void restore ()
void clear ()
void print_stream_bytes (const char *prefix, string bytes)
void check_stream (const char *name, ostringstream &str, bool &result)
bool have_data ()
Public Attributes
ostringstream outstr
ostringstream errstr
ostringstream logstr
Private Attributes
streambuf * outbuf
streambuf * errbuf
streambuf * logbuf
Detailed Description
Definition at line 685 of file QualityAssessorTest.cpp.
Definition at line 692 of file QualityAssessorTest.cpp.
        outbuf = cout.rdbuf();
        errbuf = cerr.rdbuf();
        logbuf = clog.rdbuf();
Definition at line 699 of file QualityAssessorTest.cpp.
        restore();
Member Function Documentation
void StreamRedirector::check_stream ( const char *  name,
ostringstream &  str,
bool &  result
) [inline]
Definition at line 772 of file QualityAssessorTest.cpp.
        string s = str.str();
        if( s.empty() ) return;
        result = true;
        print_stream_bytes( name, s );
void StreamRedirector::clear ( ) [inline]
Definition at line 719 of file QualityAssessorTest.cpp.
        string empty;
        outstr.str( empty );
        errstr.str( empty );
        logstr.str( empty );
bool StreamRedirector::have_data ( ) [inline]
Definition at line 781 of file QualityAssessorTest.cpp.
Referenced by QualityAssessorTest::test_output_control().
        bool result = false;
        check_stream( "std::cout", outstr, result );
        check_stream( "std::cerr", errstr, result );
        check_stream( "std::clog", logstr, result );
        return result;
void StreamRedirector::print_stream_bytes ( const char *  prefix,
string  bytes
) [inline]
Definition at line 727 of file QualityAssessorTest.cpp.
        // fix output stream so we can use it to print results
        streambuf* sbuf = cout.rdbuf();
        cout.rdbuf( outbuf );
        cout << prefix << ": " << bytes.size() << " characters: ";
        for( string::iterator i = bytes.begin(); i != bytes.end(); ++i )
            if( isprint( *i ) || *i == ' ' )
                cout << *i;
            else
                switch( *i )
                    case '\a':
                        cout << "\\a";
                        break;
                    case '\b':
                        cout << "\\b";
                        break;
                    case '\t':
                        cout << "\\t";
                        break;
                    case '\n':
                        cout << "\\n";
                        break;
                    case '\v':
                        cout << "\\v";
                        break;
                    case '\f':
                        cout << "\\f";
                        break;
                    case '\r':
                        cout << "\\r";
                        break;
                    case '\0':
                        cout << "\\0";
                        break;
                    default:
                        cout << '\\' << setw( 3 ) << setfill( '0' ) << oct << *i;
                        break;
        cout << endl;
        // restore cout to incomming state
        cout.rdbuf( sbuf );
void StreamRedirector::redirect ( ) [inline]
Definition at line 704 of file QualityAssessorTest.cpp.
        clear();
        cout.rdbuf( outstr.rdbuf() );
        cerr.rdbuf( errstr.rdbuf() );
        clog.rdbuf( logstr.rdbuf() );
void StreamRedirector::restore ( ) [inline]
Definition at line 712 of file QualityAssessorTest.cpp.
        cerr.rdbuf( errbuf );
        clog.rdbuf( logbuf );
Member Data Documentation
streambuf * StreamRedirector::errbuf [private]
Definition at line 688 of file QualityAssessorTest.cpp.
ostringstream StreamRedirector::errstr
Definition at line 691 of file QualityAssessorTest.cpp.
streambuf * StreamRedirector::logbuf [private]
ostringstream StreamRedirector::logstr
streambuf* StreamRedirector::outbuf [private]
ostringstream StreamRedirector::outstr
List of all members.
