TCTFauxOptimizer Class Reference
+ Inheritance diagram for TCTFauxOptimizer:
+ Collaboration diagram for TCTFauxOptimizer:
Public Member Functions
 TCTFauxOptimizer (double pertubation_amount)
virtual ~TCTFauxOptimizer ()
virtual std::string get_name () const
 Get string name for use in diagnostic and status output.
virtual PatchSetget_patch_set ()
virtual void initialize (PatchData &pd, MsqError &err)
virtual void initialize_mesh_iteration (PatchData &pd, MsqError &err)
virtual void optimize_vertex_positions (PatchData &pd, MsqError &err)
virtual void terminate_mesh_iteration (PatchData &pd, MsqError &err)
virtual void cleanup ()
int num_passes () const
bool should_have_terminated () const
Private Attributes
std::set< Mesh::VertexHandleculled
std::set< Mesh::VertexHandlevisited
std::vector< Mesh::VertexHandleall
VertexPatches mPatchSet
int numPasses
 count number of outer iterations
int perturbFrac
 perturb 1/perturbFrac of the free vertices
double mDelta
 distance to perturb vertices
Detailed Description
Definition at line 671 of file TerminationCriterionTest.cpp.
TCTFauxOptimizer::TCTFauxOptimizer ( double  pertubation_amount) [inline]
Definition at line 674 of file TerminationCriterionTest.cpp.
: mDelta( pertubation_amount ) {}
virtual TCTFauxOptimizer::~TCTFauxOptimizer ( ) [inline, virtual]
Definition at line 675 of file TerminationCriterionTest.cpp.
Member Function Documentation
virtual void TCTFauxOptimizer::cleanup ( ) [inline, virtual]
Implements MBMesquite::VertexMover.
Definition at line 688 of file TerminationCriterionTest.cpp.
        all.clear();
virtual std::string TCTFauxOptimizer::get_name ( ) const [inline, virtual]
Implements MBMesquite::Instruction.
Definition at line 676 of file TerminationCriterionTest.cpp.
        return "Optimizer for TerminationCriterionTest";
virtual PatchSet* TCTFauxOptimizer::get_patch_set ( ) [inline, virtual]
Implements MBMesquite::QualityImprover.
Definition at line 680 of file TerminationCriterionTest.cpp.
        return &mPatchSet;
void TCTFauxOptimizer::initialize ( PatchData pd,
MsqError err
) [virtual]
Definition at line 710 of file TerminationCriterionTest.cpp.
References CPPUNIT_ASSERT, fixed, MBMesquite::Mesh::get_all_vertices(), MBMesquite::PatchData::get_mesh(), MSQ_ERRRTN, and MBMesquite::Mesh::vertices_get_fixed_flag().
    CPPUNIT_ASSERT( all.empty() );
    culled.clear();
    visited.clear();
    numPasses = 1;
    pd.get_mesh()->get_all_vertices( all, err );MSQ_ERRRTN( err );
    std::vector< bool > fixed;
    pd.get_mesh()->vertices_get_fixed_flag( &all[0], fixed, all.size(), err );
    size_t w = 0;
    for( size_t r = 0; r < all.size(); ++r )
        if( !fixed[r] ) all[w++] = all[r];
    all.resize( w );MSQ_ERRRTN( err );
    perturbFrac = 1;
virtual void TCTFauxOptimizer::initialize_mesh_iteration ( PatchData pd,
MsqError err
) [inline, virtual]
Definition at line 685 of file TerminationCriterionTest.cpp.
int TCTFauxOptimizer::num_passes ( ) const [inline]
void TCTFauxOptimizer::optimize_vertex_positions ( PatchData pd,
MsqError err
) [virtual]
Definition at line 728 of file TerminationCriterionTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, MBMesquite::PatchData::get_vertex_handles_array(), MBMesquite::PatchData::move_vertex(), MBMesquite::PatchData::num_nodes(), and MBMesquite::sign.
    Mesh::VertexHandle free_vtx = pd.get_vertex_handles_array()[0];
    if( visited.insert( free_vtx ).second == false )
    {  // already visited this one
        // The inner termination criterion should include an iteration limit of 1.
        // So if we are seeing the same vertex again, this means that we *should*
        // be stating a new pass over the mesh.
        // We are presumably starting a new pass over the mesh.
        // Verify that we visisted all of the free, non-culled vertices
        for( size_t i = 0; i < all.size(); ++i )
            if( culled.find( all[i] ) == culled.end() )
                if( visited.find( all[i] ) == visited.end() )
                    std::ostringstream str;
                    str << "Did not visit vertex " << i << " (handle " << all[i] << ") in pass " << numPasses
                        << std::endl;
                    CPPUNIT_FAIL( str.str() );
        visited.clear();
        visited.insert( free_vtx );
        ++numPasses;
        // Check that we terminate when expected
        CPPUNIT_ASSERT( !should_have_terminated() );
        perturbFrac *= 2;  // for each pass, perturb half as many vertices
    // check that we are not visiting a culled vertex
    CPPUNIT_ASSERT( culled.find( free_vtx ) == culled.end() );
    size_t idx = std::find( all.begin(), all.end(), free_vtx ) - all.begin();
    CPPUNIT_ASSERT( idx < all.size() );  // not a free vertex????
    if( 0 == ( ( idx + 1 ) % perturbFrac ) )
        // perturb vertex
        double sign = numPasses % 2 == 0 ? 1 : -1;
        Vector3D delta( sign * mDelta, 0, 0 );
        pd.move_vertex( delta, 0, err );
        ASSERT_NO_ERROR( err );
        // any adjacent vertices should not be culled
        for( size_t i = 0; i < pd.num_nodes(); ++i )
            culled.erase( pd.get_vertex_handles_array()[i] );
    else
        // If we're not moving this vertex, then it should get culled
        culled.insert( free_vtx );
Definition at line 696 of file TerminationCriterionTest.cpp.
Referenced by TerminationCriterionTest::test_abs_vtx_movement_culling().
        return perturbFrac > (int)all.size();
virtual void TCTFauxOptimizer::terminate_mesh_iteration ( PatchData pd,
MsqError err
) [inline, virtual]
Definition at line 687 of file TerminationCriterionTest.cpp.
Member Data Documentation
std::vector< Mesh::VertexHandle > TCTFauxOptimizer::all [private]
Definition at line 703 of file TerminationCriterionTest.cpp.
Definition at line 702 of file TerminationCriterionTest.cpp.
double TCTFauxOptimizer::mDelta [private]
Definition at line 707 of file TerminationCriterionTest.cpp.
Definition at line 705 of file TerminationCriterionTest.cpp.
Definition at line 706 of file TerminationCriterionTest.cpp.
List of all members.
