XYRectangleTest Class Reference
+ Inheritance diagram for XYRectangleTest:
+ Collaboration diagram for XYRectangleTest:
Public Member Functions
void setUp ()
void tearDown ()
 XYRectangleTest ()
void test_snap_to ()
void test_normal_at ()
void test_closest_point ()
void test_domain_DoF ()
Private Member Functions
 CPPUNIT_TEST_SUITE (XYRectangleTest)
 CPPUNIT_TEST (test_snap_to)
 CPPUNIT_TEST (test_normal_at)
 CPPUNIT_TEST (test_closest_point)
 CPPUNIT_TEST (test_domain_DoF)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
vector< double > vertCoords
vector< double > invertCoords
vector< int > fixedFlags
vector< unsigned long > triConn
vector< unsigned long > invertConn
ArrayMesh myMesh
XYRectangle myDomain
std::vector< double > mCoords
std::vector< int > mFlags
Detailed Description
Definition at line 45 of file XYRectangleTest.cpp.
Definition at line 69 of file XYRectangleTest.cpp.
Member Function Documentation
Definition at line 140 of file XYRectangleTest.cpp.
Definition at line 240 of file XYRectangleTest.cpp.
References MBMesquite::arrptr(), ASSERT_NO_ERROR, and CPPUNIT_ASSERT_VECTORS_EQUAL.
    MsqError err;
    std::vector< Mesh::ElementHandle > elems;
    myMesh.get_all_elements( elems, err );
    ASSERT_NO_ERROR( err );
    for( size_t i = 0; i < elems.size(); ++i )
        std::vector< Mesh::VertexHandle > verts;
        std::vector< size_t > junk;
        MsqVertex coords;
        myMesh.elements_get_attached_vertices( &elems[i], 1, verts, junk, err );
        myMesh.vertices_get_coordinates( arrptr( verts ), &coords, 1, err );
        Vector3D offset( coords + Vector3D( 0, 0, 3 ) ), closest, norm;
        myDomain.closest_point( elems[i], offset, closest, norm, err );
        CPPUNIT_ASSERT_VECTORS_EQUAL( coords, closest, 1e-6 );
        CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), norm, 1e-6 );
Definition at line 273 of file XYRectangleTest.cpp.
References MBMesquite::arrptr(), ASSERT_NO_ERROR, CPPUNIT_ASSERT_EQUAL, and dof().
    MsqError err;
    myMesh.get_all_vertices( verts, err );
    std::vector< MsqVertex > coords( verts.size() );
    myMesh.vertices_get_coordinates( arrptr( verts ), arrptr( coords ), verts.size(), err );
    for( size_t i = 0; i < coords.size(); ++i )
        unsigned short exp = dof( coords[i] );
        unsigned short act = 100;
        myDomain.domain_DoF( &verts[i], &act, 1, err );
        CPPUNIT_ASSERT_EQUAL( exp, act );
Definition at line 218 of file XYRectangleTest.cpp.
    MsqError err;
    std::vector< Mesh::VertexHandle > vertices;
    myMesh.get_all_vertices( vertices, err );
    std::vector< MsqVertex > coords( vertices.size() );
    myMesh.vertices_get_coordinates( arrptr( vertices ), arrptr( coords ), vertices.size(), err );
    std::vector< Vector3D > normals( vertices.size() );
    std::copy( coords.begin(), coords.end(), normals.begin() );
    myDomain.vertex_normal_at( arrptr( vertices ), arrptr( normals ), vertices.size(), err );
    for( size_t i = 0; i < normals.size(); ++i )
        CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), normals[i], 1e-6 );
Definition at line 164 of file XYRectangleTest.cpp.
References MBMesquite::arrptr(), ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_VECTORS_EQUAL, and snap_to().
    MsqError err;
    Vector3D off, exp, act;
    const Vector3D d1( 0.1, 0.1, 0.0 );
    const Vector3D d2( 0.0, 0.2, 0.0 );
    const Vector3D d3( 0.3, 0.0, 0.0 );
    const Vector3D d4( 0.0, 0.0, 5.0 );
    const Vector3D d5( 0.5, 0.5, 0.5 );
    CPPUNIT_ASSERT( !verts.empty() );
        off = coords[i] + d1;
        exp = snap_to( coords[i], off );
        act = off;
        myDomain.snap_to( verts[i], act );
        CPPUNIT_ASSERT_VECTORS_EQUAL( exp, act, 1e-6 );
        off = coords[i] + d2;
        act = off;
        off = coords[i] + d3;
        act = off;
        off = coords[i] + d4;
        act = off;
        off = coords[i] + d5;
        act = off;
Member Data Documentation
vector< int > XYRectangleTest::fixedFlags [private]
Definition at line 56 of file XYRectangleTest.cpp.
vector< unsigned long > XYRectangleTest::invertConn [private]
Definition at line 57 of file XYRectangleTest.cpp.
vector< double > XYRectangleTest::invertCoords [private]
Definition at line 55 of file XYRectangleTest.cpp.
std::vector< double > XYRectangleTest::mCoords [private]
Definition at line 61 of file XYRectangleTest.cpp.
std::vector< int > XYRectangleTest::mFlags [private]
Definition at line 62 of file XYRectangleTest.cpp.
Definition at line 60 of file XYRectangleTest.cpp.
Definition at line 59 of file XYRectangleTest.cpp.
vector< unsigned long > XYRectangleTest::triConn [private]
vector< double > XYRectangleTest::vertCoords [private]
List of all members.
