ZoltanPartitioner Class Reference
#include <ZoltanPartitioner.hpp>
+ Inheritance diagram for ZoltanPartitioner:
+ Collaboration diagram for ZoltanPartitioner:
Public Member Functions
 ZoltanPartitioner (Interface *impl=NULL, const bool use_coords=false, int argc=0, char **argv=NULL)
virtual ~ZoltanPartitioner ()
ErrorCode balance_mesh (const char *zmethod, const char *other_method, const bool write_as_sets=true, const bool write_as_tags=false)
virtual ErrorCode partition_mesh_and_geometry (const double part_geom_mesh_size, const int nparts, const char *zmethod, const char *other_method, double imbal_tol, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const int obj_weight=0, const int edge_weight=0, const bool part_surf=false, const bool ghost=false, const int projection_type=0, const bool recompute_rcb_box=false, const bool print_time=false)
virtual ErrorCode partition_mesh (const int nparts, const char *method, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const bool partition_tagged_sets=false, const bool partition_tagged_ents=false, const char *aggregating_tag=NULL, const bool print_time=false)
ErrorCode partition_inferred_mesh (EntityHandle sfileset, size_t num_parts, int part_dim=3, const bool write_as_sets=true, int projection_type=0)
virtual ErrorCode write_partition (const int nparts, Range &elems, const int *assignment, const bool write_as_sets, const bool write_as_tags)
ErrorCode repartition (std::vector< double > &x, std::vector< double > &y, std::vector< double > &z, int StartID, const char *zmethod, Range &localGIDs)
ErrorCode partition_owned_cells (Range &owned, std::multimap< int, int > &extraGraphEdges, std::map< int, int > procs, int &numNewPartitions, std::map< int, Range > &distribution, int met, std::vector< char > &ZoltanBuffer)
ErrorCode include_closure ()
void SetOCTPART_Parameters (const char *oct_method)
void SetPARMETIS_Parameters (const char *parmetis_method)
void SetHypergraph_Parameters (const char *phg_method)
void SetHSFC_Parameters ()
void SetRIB_Parameters ()
void SetRCB_Parameters (const bool recompute_rcb_box=false)
Private Member Functions
int mbGlobalSuccess (int rc)
void mbPrintGlobalResult (const char *s, int begin, int import, int exp, int change)
void mbShowError (int val, const char *s)
ErrorCode assemble_graph (const int dimension, std::vector< double > &coords, std::vector< int > &moab_ids, std::vector< int > &adjacencies, std::vector< int > &length, Range &elems, bool part_geom=false, const int projection_type=0)
void mbFinalizePoints (int npts, int numExport, ZOLTAN_ID_PTR exportLocalIDs, int *exportProcs, int **assignment)
int mbInitializePoints (int npts, double *pts, int *ids, int *adjs, int *length, double *obj_weights=NULL, double *edge_weights=NULL, int *parts=NULL, bool part_geom=false)
Private Attributes
Zoltan * myZZ
Range partSets
int myNumPts
int argcArg
char ** argvArg
Detailed Description
Definition at line 109 of file ZoltanPartitioner.hpp.
ZoltanPartitioner::ZoltanPartitioner ( Interface impl = NULL,
const bool  use_coords = false,
int  argc = 0,
char **  argv = NULL
Definition at line 71 of file ZoltanPartitioner.cpp.
    : PartitionerBase< int >( impl,
                              use_coords
#ifdef MOAB_HAVE_MPI
                              parcomm
#endif
      myZZ( NULL ), myNumPts( 0 ), argcArg( argc ), argvArg( argv )
#ifdef MOAB_HAVE_CGM
      gti( gqt )
#endif
Definition at line 99 of file ZoltanPartitioner.cpp.
References myZZ.
    if( NULL != myZZ ) delete myZZ;
Member Function Documentation
ErrorCode ZoltanPartitioner::assemble_graph ( const int  dimension,
std::vector< double > &  coords,
std::vector< int > &  moab_ids,
std::vector< int > &  adjacencies,
std::vector< int > &  length,
Range elems,
bool  part_geom = false,
const int  projection_type = 0
) [private]
Definition at line 801 of file ZoltanPartitioner.cpp.
References PartitionerBase< int >::assign_global_ids, moab::Range::begin(), moab::Range::clear(), moab::debug, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::MeshTopoUtil::get_average_position(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::globalId_tag(), moab::MAX_SUB_ENTITIES, MB_SUCCESS, PartitionerBase< int >::mbImpl, RR, moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by balance_mesh(), and partition_mesh_and_geometry().
    // assemble a graph with vertices equal to elements of specified dimension, edges
    // signified by list of other elements to which an element is connected
    // get the elements of that dimension
    ErrorCode result = mbImpl->get_entities_by_dimension( 0, dimension, elems );
    if( MB_SUCCESS != result || elems.empty() ) return result;
    // assign global ids
    if( assign_global_ids )
        EntityHandle rootset = 0;
        result               = mbpc->assign_global_ids( rootset, dimension, 1, true, true );RR;
    // now assemble the graph, calling MeshTopoUtil to get bridge adjacencies through d-1
    // dimensional neighbors
    MeshTopoUtil mtu( mbImpl );
    Range adjs;
    // can use a fixed-size array 'cuz the number of lower-dimensional neighbors is limited
    // by MBCN
    int neighbors[5 * MAX_SUB_ENTITIES];
    double avg_position[3];
    int moab_id;
    // get the global id tag handle
    Tag gid = mbImpl->globalId_tag();
    for( Range::iterator rit = elems.begin(); rit != elems.end(); ++rit )
        if( !part_geom )
            // get bridge adjacencies
            adjs.clear();
            result = mtu.get_bridge_adjacencies( *rit, ( dimension > 0 ? dimension - 1 : 3 ), dimension, adjs );RR;
            // get the graph vertex ids of those
            if( !adjs.empty() )
                assert( adjs.size() < 5 * MAX_SUB_ENTITIES );
                result = mbImpl->tag_get_data( gid, adjs, neighbors );RR;
            // copy those into adjacencies vector
            length.push_back( (int)adjs.size() );
            std::copy( neighbors, neighbors + adjs.size(), std::back_inserter( adjacencies ) );
        // get average position of vertices
        result = mtu.get_average_position( *rit, avg_position );RR;
        // get the graph vertex id for this element
        result = mbImpl->tag_get_data( gid, &( *rit ), 1, &moab_id );RR;
        // copy those into coords vector
        moab_ids.push_back( moab_id );
        // transform coordinates to spherical coordinates, if requested
        if( projection_type > 0 ) IntxUtils::transform_coordinates( avg_position, projection_type );
        std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) );
    if( debug )
        std::cout << "Length vector: " << std::endl;
        std::copy( length.begin(), length.end(), std::ostream_iterator< int >( std::cout, ", " ) );
        std::cout << std::endl;
        std::cout << "Adjacencies vector: " << std::endl;
        std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( std::cout, ", " ) );
        std::cout << "Moab_ids vector: " << std::endl;
        std::copy( moab_ids.begin(), moab_ids.end(), std::ostream_iterator< int >( std::cout, ", " ) );
        std::cout << "Coords vector: " << std::endl;
        std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( std::cout, ", " ) );
    return MB_SUCCESS;
ErrorCode ZoltanPartitioner::balance_mesh ( const char *  zmethod,
const char *  other_method,
const bool  write_as_sets = true,
const bool  write_as_tags = false
Definition at line 104 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, assemble_graph(), ErrorCode, length(), MB_SUCCESS, mbFinalizePoints(), mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), mbGlobalSuccess(), mbInitializePoints(), mbPrintGlobalResult(), myNumPts, myZZ, RR, SetHSFC_Parameters(), SetHypergraph_Parameters(), SetOCTPART_Parameters(), SetPARMETIS_Parameters(), SetRCB_Parameters(), SetRIB_Parameters(), and write_partition().
    if( !strcmp( zmethod, "RR" ) && !strcmp( zmethod, "RCB" ) && !strcmp( zmethod, "RIB" ) &&
        !strcmp( zmethod, "HSFC" ) && !strcmp( zmethod, "Hypergraph" ) && !strcmp( zmethod, "PHG" ) &&
        !strcmp( zmethod, "PARMETIS" ) && !strcmp( zmethod, "OCTPART" ) )
        std::cout << "ERROR node " << mbpc->proc_config().proc_rank() << ": Method must be "
                  << "RR, RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl;
        return MB_FAILURE;
    std::vector< double > pts;  // x[0], y[0], z[0], ... from MOAB
    std::vector< int > ids;     // point ids from MOAB
    std::vector< int > adjs, length;
    Range elems;
    // Get a mesh from MOAB and divide it across processors.
    ErrorCode result;
    if( mbpc->proc_config().proc_rank() == 0 )
        result = assemble_graph( 3, pts, ids, adjs, length, elems );RR;
    myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0] );
    // Initialize Zoltan.  This is a C call.  The simple C++ code
    // that creates Zoltan objects does not keep track of whether
    // Zoltan_Initialize has been called.
    float version;
    Zoltan_Initialize( argcArg, argvArg, &version );
    // Create Zoltan object.  This calls Zoltan_Create.
    if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() );
    if( NULL == zmethod || !strcmp( zmethod, "RCB" ) )
        SetRCB_Parameters();
    else if( !strcmp( zmethod, "RIB" ) )
        SetRIB_Parameters();
    else if( !strcmp( zmethod, "HSFC" ) )
        SetHSFC_Parameters();
    else if( !strcmp( zmethod, "Hypergraph" ) || !strcmp( zmethod, "PHG" ) )
        if( NULL == other_method )
            SetHypergraph_Parameters( "auto" );
        else
            SetHypergraph_Parameters( other_method );
    else if( !strcmp( zmethod, "PARMETIS" ) )
            SetPARMETIS_Parameters( "RepartGDiffusion" );
        else
            SetPARMETIS_Parameters( other_method );
    else if( !strcmp( zmethod, "OCTPART" ) )
            SetOCTPART_Parameters( "2" );
        else
            SetOCTPART_Parameters( other_method );
    // Call backs:
    myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL );
    myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL );
    myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL );
    myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL );
    myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL );
    myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL );
    // Perform the load balancing partitioning
    int changes;
    int numGidEntries;
    int numLidEntries;
    int numImport;
    ZOLTAN_ID_PTR importGlobalIds;
    ZOLTAN_ID_PTR importLocalIds;
    int* importProcs;
    int* importToPart;
    int numExport;
    ZOLTAN_ID_PTR exportGlobalIds;
    ZOLTAN_ID_PTR exportLocalIds;
    int* exportProcs;
    int* exportToPart;
    int rc = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, numImport, importGlobalIds, importLocalIds,
                                 importProcs, importToPart, numExport, exportGlobalIds, exportLocalIds, exportProcs,
                                 exportToPart );
    rc = mbGlobalSuccess( rc );
    if( !rc )
        mbPrintGlobalResult( "==============Result==============", myNumPts, numImport, numExport, changes );
    else
        return MB_FAILURE;
    // take results & write onto MOAB partition sets
    int* assignment;
    mbFinalizePoints( (int)ids.size(), numExport, exportLocalIds, exportProcs, &assignment );
        result = write_partition( mbpc->proc_config().proc_size(), elems, assignment, write_as_sets, write_as_tags );
        if( MB_SUCCESS != result ) return result;
        free( (int*)assignment );
    // Free the memory allocated for lists returned by LB_Parition()
    myZZ->LB_Free_Part( &importGlobalIds, &importLocalIds, &importProcs, &importToPart );
    myZZ->LB_Free_Part( &exportGlobalIds, &exportLocalIds, &exportProcs, &exportToPart );
    // Implementation note:  A Zoltan object contains an MPI communicator.
    //   When the Zoltan object is destroyed, it uses it's MPI communicator.
    //   So it is important that the Zoltan object is destroyed before
    //   the MPI communicator is destroyed.  To ensure this, dynamically
    //   allocate the Zoltan object, so you can explicitly destroy it.
    //   If you create a Zoltan object on the stack, it's destructor will
    //   be invoked atexit, possibly after the communicator's
    //   destructor.
    return MB_SUCCESS;
Implements PartitionerBase< int >.
Definition at line 733 of file ZoltanPartitioner.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::clear(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Range::find(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::intersect(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, PartitionerBase< int >::mbImpl, partSets, RR, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and smoab::UNION.
Referenced by main().
    ErrorCode result;
    Range ents;
    Range adjs;
    std::cout << "Adding closure..." << std::endl;
    for( Range::iterator rit = partSets.begin(); rit != partSets.end(); ++rit )
        // get the top-dimensional entities in the part
        result = mbImpl->get_entities_by_handle( *rit, ents, true );RR;
        if( ents.empty() ) continue;
        // get intermediate-dimensional adjs and add to set
        for( int d = mbImpl->dimension_from_handle( *ents.begin() ) - 1; d >= 1; d-- )
            adjs.clear();
            result = mbImpl->get_adjacencies( ents, d, false, adjs, Interface::UNION );RR;
            result = mbImpl->add_entities( *rit, adjs );RR;
        // now get vertices and add to set; only need to do for ents, not for adjs
        adjs.clear();
        result = mbImpl->get_adjacencies( ents, 0, false, adjs, Interface::UNION );RR;
        ents.clear();
    // now go over non-part entity sets, looking for contained entities
    Range sets, part_ents;
    result = mbImpl->get_entities_by_type( 0, MBENTITYSET, sets );RR;
    for( Range::iterator rit = sets.begin(); rit != sets.end(); ++rit )
        // skip parts
        if( partSets.find( *rit ) != partSets.end() ) continue;
        // get entities in this set, recursively
        ents.clear();
        // now check over all parts
        for( Range::iterator rit2 = partSets.begin(); rit2 != partSets.end(); ++rit2 )
            part_ents.clear();
            result = mbImpl->get_entities_by_handle( *rit2, part_ents, false );RR;
            Range int_range = intersect( ents, part_ents );
            if( !int_range.empty() )
                // non-empty intersection, add to part set
                result = mbImpl->add_entities( *rit2, &( *rit ), 1 );RR;
    // finally, mark all the part sets as having the closure
    Tag closure_tag;
    result =
        mbImpl->tag_get_handle( "INCLUDES_CLOSURE", 1, MB_TYPE_INTEGER, closure_tag, MB_TAG_SPARSE | MB_TAG_CREAT );RR;
    std::vector< int > closure_vals( partSets.size(), 1 );
    result = mbImpl->tag_set_data( closure_tag, partSets, &closure_vals[0] );RR;
    return MB_SUCCESS;
void ZoltanPartitioner::mbFinalizePoints ( int  npts,
int  numExport,
int *  exportProcs,
int **  assignment
) [private]
Definition at line 1982 of file ZoltanPartitioner.cpp.
References NumPoints.
Referenced by balance_mesh().
    int* MyAssignment;
    int i;
    int numPts;
    MPI_Status stat;
    int* recvA;
    /* assign pts to start */
        MyAssignment = (int*)malloc( sizeof( int ) * npts );
    else
        MyAssignment = (int*)malloc( sizeof( int ) * NumPoints );
    for( i = 0; i < NumPoints; i++ )
        MyAssignment[i] = mbpc->proc_config().proc_rank();
    for( i = 0; i < numExport; i++ )
        MyAssignment[exportLocalIDs[i]] = exportProcs[i];
        /* collect pts */
        recvA = MyAssignment + NumPoints;
        for( i = 1; i < (int)mbpc->proc_config().proc_size(); i++ )
            MPI_Recv( &numPts, 1, MPI_INT, i, 0x04, mbpc->comm(), &stat );
            MPI_Recv( recvA, numPts, MPI_INT, i, 0x05, mbpc->comm(), &stat );
            recvA += numPts;
        *assignment = MyAssignment;
    else
        MPI_Send( &NumPoints, 1, MPI_INT, 0, 0x04, mbpc->comm() );
        MPI_Send( MyAssignment, NumPoints, MPI_INT, 0, 0x05, mbpc->comm() );
        free( MyAssignment );
int ZoltanPartitioner::mbGlobalSuccess ( int  rc) [private]
Definition at line 2029 of file ZoltanPartitioner.cpp.
References fail(), and mbShowError().
    int fail = 0;
    unsigned int i;
    int* vals = (int*)malloc( mbpc->proc_config().proc_size() * sizeof( int ) );
    MPI_Allgather( &rc, 1, MPI_INT, vals, 1, MPI_INT, mbpc->comm() );
    for( i = 0; i < mbpc->proc_config().proc_size(); i++ )
        if( vals[i] != ZOLTAN_OK )
            if( 0 == mbpc->proc_config().proc_rank() )
                mbShowError( vals[i], "Result on process " );
            fail = 1;
    free( vals );
    return fail;
int ZoltanPartitioner::mbInitializePoints ( int  npts,
double *  pts,
int *  ids,
int *  adjs,
int *  length,
double *  obj_weights = NULL,
double *  edge_weights = NULL,
int *  parts = NULL,
) [private]
Definition at line 1862 of file ZoltanPartitioner.cpp.
References EdgeWeights, GlobalIds, length(), NborGlobalId, NborProcs, NumEdges, NumPoints, ObjWeights, Parts, Points, and moab::sum().
    unsigned int i;
    int j;
    int *numPts, *nborProcs = NULL;
    int sum, ptsPerProc, ptsAssigned, mySize;
    MPI_Status stat;
    double* sendPts;
    int* sendIds;
    int* sendEdges  = NULL;
    int* sendNborId = NULL;
    int* sendProcs;
        /* divide pts to start */
        numPts      = (int*)malloc( sizeof( int ) * mbpc->proc_config().proc_size() );
        ptsPerProc  = npts / mbpc->proc_config().proc_size();
        ptsAssigned = 0;
        for( i = 0; i < mbpc->proc_config().proc_size() - 1; i++ )
            numPts[i] = ptsPerProc;
            ptsAssigned += ptsPerProc;
        numPts[mbpc->proc_config().proc_size() - 1] = npts - ptsAssigned;
        mySize  = numPts[mbpc->proc_config().proc_rank()];
        sendPts = pts + ( 3 * numPts[0] );
        sendIds = ids + numPts[0];
        sum     = 0;  // possible no adjacency sent
        if( !part_geom )
            sendEdges = length + numPts[0];
            for( j = 0; j < numPts[0]; j++ )
                sum += length[j];
            sendNborId = adjs + sum;
            for( j = numPts[0]; j < npts; j++ )
                sum += length[j];
            nborProcs = (int*)malloc( sizeof( int ) * sum );
        for( j = 0; j < sum; j++ )
            if( ( i = adjs[j] / ptsPerProc ) < mbpc->proc_config().proc_size() )
                nborProcs[j] = i;
            else
                nborProcs[j] = mbpc->proc_config().proc_size() - 1;
        sendProcs = nborProcs + ( sendNborId - adjs );
        for( i = 1; i < mbpc->proc_config().proc_size(); i++ )
            MPI_Send( &numPts[i], 1, MPI_INT, i, 0x00, mbpc->comm() );
            MPI_Send( sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01, mbpc->comm() );
            MPI_Send( sendIds, numPts[i], MPI_INT, i, 0x03, mbpc->comm() );
            MPI_Send( sendEdges, numPts[i], MPI_INT, i, 0x06, mbpc->comm() );
            sum = 0;
            for( j = 0; j < numPts[i]; j++ )
                sum += sendEdges[j];
            MPI_Send( sendNborId, sum, MPI_INT, i, 0x07, mbpc->comm() );
            MPI_Send( sendProcs, sum, MPI_INT, i, 0x08, mbpc->comm() );
            sendPts += ( 3 * numPts[i] );
            sendIds += numPts[i];
            sendEdges += numPts[i];
            sendNborId += sum;
            sendProcs += sum;
        free( numPts );
    else
        MPI_Recv( &mySize, 1, MPI_INT, 0, 0x00, mbpc->comm(), &stat );
        pts    = (double*)malloc( sizeof( double ) * 3 * mySize );
        ids    = (int*)malloc( sizeof( int ) * mySize );
        length = (int*)malloc( sizeof( int ) * mySize );
        if( obj_weights != NULL ) obj_weights = (double*)malloc( sizeof( double ) * mySize );
        MPI_Recv( pts, 3 * mySize, MPI_DOUBLE, 0, 0x01, mbpc->comm(), &stat );
        MPI_Recv( ids, mySize, MPI_INT, 0, 0x03, mbpc->comm(), &stat );
        MPI_Recv( length, mySize, MPI_INT, 0, 0x06, mbpc->comm(), &stat );
        sum = 0;
        for( j = 0; j < mySize; j++ )
            sum += length[j];
        adjs = (int*)malloc( sizeof( int ) * sum );
        if( edge_weights != NULL ) edge_weights = (double*)malloc( sizeof( double ) * sum );
        MPI_Recv( adjs, sum, MPI_INT, 0, 0x07, mbpc->comm(), &stat );
        MPI_Recv( nborProcs, sum, MPI_INT, 0, 0x08, mbpc->comm(), &stat );
    Points       = pts;
    GlobalIds    = ids;
    NumPoints    = mySize;
    NumEdges     = length;
    NborGlobalId = adjs;
    NborProcs    = nborProcs;
    ObjWeights   = obj_weights;
    EdgeWeights  = edge_weights;
    Parts        = parts;
    return mySize;
void ZoltanPartitioner::mbPrintGlobalResult ( const char *  s,
int  begin,
int  import,
int  exp,
int  change
) [private]
Definition at line 2053 of file ZoltanPartitioner.cpp.
    unsigned int i;
    int* v1 = (int*)malloc( 4 * sizeof( int ) );
    int* v2 = NULL;
    int* v;
    v1[0] = begin;
    v1[1] = import;
    v1[2] = exp;
    v1[3] = change;
        v2 = (int*)malloc( 4 * mbpc->proc_config().proc_size() * sizeof( int ) );
    MPI_Gather( v1, 4, MPI_INT, v2, 4, MPI_INT, 0, mbpc->comm() );
        fprintf( stdout, "======%s======\n", s );
        for( i = 0, v = v2; i < mbpc->proc_config().proc_size(); i++, v += 4 )
            fprintf( stdout, "%u: originally had %d, import %d, exp %d, %s\n", i, v[0], v[1], v[2],
                     v[3] ? "a change of partitioning" : "no change" );
        fprintf( stdout, "==========================================\n" );
        fflush( stdout );
        free( v2 );
    free( v1 );
void ZoltanPartitioner::mbShowError ( int  val,
const char *  s
) [private]
Definition at line 2089 of file ZoltanPartitioner.cpp.
Referenced by mbGlobalSuccess().
    if( s ) printf( "%s ", s );
    switch( val )
        case ZOLTAN_OK:
            printf( "%d: SUCCESSFUL\n", mbpc->proc_config().proc_rank() );
            break;
        case ZOLTAN_WARN:
            printf( "%d: WARNING\n", mbpc->proc_config().proc_rank() );
            break;
        case ZOLTAN_FATAL:
            printf( "%d: FATAL ERROR\n", mbpc->proc_config().proc_rank() );
            break;
        case ZOLTAN_MEMERR:
            printf( "%d: MEMORY ALLOCATION ERROR\n", mbpc->proc_config().proc_rank() );
            break;
        default:
            printf( "%d: INVALID RETURN CODE\n", mbpc->proc_config().proc_rank() );
            break;
ErrorCode ZoltanPartitioner::partition_inferred_mesh ( EntityHandle  sfileset,
size_t  num_parts,
int  part_dim = 3,
Definition at line 356 of file ZoltanPartitioner.cpp.
References moab::Interface::add_entities(), moab::Interface::add_parent_child(), moab::Interface::create_meshset(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), MB_SUCCESS, MBENTITYSET, PartitionerBase< int >::mbImpl, MESHSET_SET, myZZ, moab::Interface::remove_entities(), RR, moab::Range::size(), moab::Interface::tag_set_data(), and smoab::UNION.
    ErrorCode result;
    moab::Range elverts;
    result = mbImpl->get_entities_by_dimension( sfileset, part_dim, elverts );RR;
    std::vector< double > elcoords( elverts.size() * 3 );
    result = mbImpl->get_coords( elverts, &elcoords[0] );RR;
    std::vector< std::vector< EntityHandle > > part_assignments( num_parts );
    int part, proc;
    // Loop over coordinates
    for( size_t iel = 0; iel < elverts.size(); iel++ )
        // Gather coordinates into temporary array
        double* ecoords = &elcoords[iel * 3];
        // do a projection if needed
        if( projection_type > 0 ) IntxUtils::transform_coordinates( ecoords, projection_type );
        // Compute the coordinate's part assignment
        myZZ->LB_Point_PP_Assign( ecoords, proc, part );
        // Store the part assignment in the return array
        part_assignments[part].push_back( elverts[iel] );
    // get the partition set tag
    Tag part_set_tag = mbpc->partition_tag();
    // If some entity sets exist, let us delete those first.
    if( write_as_sets )
        moab::Range oldpsets;
        result = mbImpl->get_entities_by_type_and_tag( sfileset, MBENTITYSET, &part_set_tag, NULL, 1, oldpsets,
        result = mbImpl->remove_entities( sfileset, oldpsets );RR;
    size_t nparts_assigned = 0;
    for( size_t partnum = 0; partnum < num_parts; ++partnum )
        std::vector< EntityHandle >& partvec = part_assignments[partnum];
        nparts_assigned += ( partvec.size() ? 1 : 0 );
        if( write_as_sets )
            EntityHandle partNset;
            result = mbImpl->create_meshset( moab::MESHSET_SET, partNset );RR;
            if( partvec.size() )
                result = mbImpl->add_entities( partNset, &partvec[0], partvec.size() );RR;
            result = mbImpl->add_parent_child( sfileset, partNset );RR;
            // part numbering should start from 0
            int ipartnum = (int)partnum;
            // assign partitions as a sparse tag by grouping elements under sets
            result = mbImpl->tag_set_data( part_set_tag, &partNset, 1, &ipartnum );RR;
        else
            /* assign as a dense vector to all elements
               allocate integer-size partitions */
            std::vector< int > assignment( partvec.size(),
                                           partnum );  // initialize all values to partnum
            result = mbImpl->tag_set_data( part_set_tag, &partvec[0], partvec.size(), &assignment[0] );RR;
    if( nparts_assigned != num_parts )
        std::cout << "WARNING: The inference yielded lesser number of parts (" << nparts_assigned
                  << ") than requested by user (" << num_parts << ").\n";
    return MB_SUCCESS;
ErrorCode ZoltanPartitioner::partition_mesh ( const int  nparts,
const char *  method,
const int  part_dim = 3,
const bool  write_as_tags = false,
const bool  partition_tagged_sets = false,
const bool  partition_tagged_ents = false,
const char *  aggregating_tag = NULL,
const bool  print_time = false
) [inline, virtual]
Definition at line 298 of file ZoltanPartitioner.hpp.
    return partition_mesh_and_geometry( -1.0, nparts, method, NULL, 1.03, part_dim, write_as_sets, write_as_tags, 0, 0,
                                        false, false, 0, false, print_time );
ErrorCode ZoltanPartitioner::partition_mesh_and_geometry ( const double  part_geom_mesh_size,
const int  nparts,
double  imbal_tol,
const int  obj_weight = 0,
const int  edge_weight = 0,
const bool  part_surf = false,
const bool  ghost = false,
const int  projection_type = 0,
const bool  recompute_rcb_box = false,
) [virtual]
Definition at line 443 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, assemble_graph(), moab::debug, moab::Range::empty(), entities, ErrorCode, moab::Interface::get_entities_by_dimension(), length(), MB_SUCCESS, mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), mbGetPart(), PartitionerBase< int >::mbImpl, mbInitializePoints(), myNumPts, myZZ, nparts, RR, SetHSFC_Parameters(), SetHypergraph_Parameters(), SetOCTPART_Parameters(), SetPARMETIS_Parameters(), SetRCB_Parameters(), SetRIB_Parameters(), moab::Range::size(), t, and write_partition().
    // should only be called in serial
    if( mbpc->proc_config().proc_size() != 1 )
        std::cout << "ZoltanPartitioner::partition_mesh_and_geometry must be called in serial." << std::endl;
        return MB_FAILURE;
    clock_t t = clock();
    if( NULL != zmethod && strcmp( zmethod, "RR" ) && strcmp( zmethod, "RCB" ) && strcmp( zmethod, "RIB" ) &&
        strcmp( zmethod, "HSFC" ) && strcmp( zmethod, "Hypergraph" ) && strcmp( zmethod, "PHG" ) &&
        strcmp( zmethod, "PARMETIS" ) && strcmp( zmethod, "OCTPART" ) )
                  << "RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl;
        return MB_FAILURE;
    bool part_geom = false;
    if( 0 == strcmp( zmethod, "RR" ) || 0 == strcmp( zmethod, "RCB" ) || 0 == strcmp( zmethod, "RIB" ) ||
        0 == strcmp( zmethod, "HSFC" ) )
        part_geom = true;       // so no adjacency / edges needed
    std::vector< int > adjs, length, parts;
    std::vector< double > obj_weights, edge_weights;
    Range elems;
    DLIList< RefEntity* > entities;
#endif
    // Get a mesh from MOAB and diide it across processors.
    ErrorCode result = MB_SUCCESS;
    // short-circuit everything if RR partition is requested
    if( !strcmp( zmethod, "RR" ) )
        if( part_geom_mesh_size < 0. )
            // get all elements
            result = mbImpl->get_entities_by_dimension( 0, part_dim, elems );RR;
            if( elems.empty() ) return MB_FAILURE;
            // make a trivial assignment vector
            std::vector< int > assign_vec( elems.size() );
            int num_per = elems.size() / nparts;
            int extra   = elems.size() % nparts;
            if( extra ) num_per++;
            int nstart = 0;
            for( int i = 0; i < nparts; i++ )
                if( i == extra ) num_per--;
                std::fill( &assign_vec[nstart], &assign_vec[nstart + num_per], i );
                nstart += num_per;
            result = write_partition( nparts, elems, &assign_vec[0], write_as_sets, write_as_tags );RR;
        else
            result = partition_round_robin( nparts );RR;
#endif
        return result;
    std::cout << "Assembling graph..." << std::endl;
        // if (!part_geom) {
        result = assemble_graph( part_dim, pts, ids, adjs, length, elems, part_geom, projection_type );RR;
    else
        result = assemble_graph( part_dim, pts, ids, adjs, length, obj_weights, edge_weights, parts, entities,
                                 part_geom_mesh_size, nparts );RR;
        if( debug )
            int n_ids = ids.size();
            entities.reset();
            int i_leng = 0;
            for( int i = 0; i < n_ids; i++ )
                std::cout << "graph_input_ids[" << i << "]=" << ids[i] << ",obj_weights=" << obj_weights[i]
                          << ",entity_id=" << entities.get_and_step()->id() << ",part=" << parts[i] << std::endl;
                for( int j = 0; j < length[i]; j++ )
                    std::cout << "adjs[" << j << "]=" << adjs[i_leng] << ",edge_weights=" << edge_weights[i_leng]
                              << std::endl;
                    i_leng++;
#endif
    if( print_time )
        std::cout << " time to assemble graph: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
        t = clock();
    double* o_wgt = NULL;
    double* e_wgt = NULL;
    if( obj_weights.size() > 0 ) o_wgt = &obj_weights[0];
    if( edge_weights.size() > 0 ) e_wgt = &edge_weights[0];
    myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0], o_wgt, e_wgt, &parts[0],
                                   part_geom );
    if( print_time )
        std::cout << " time to initialize points: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
        t = clock();
    float version;
    std::cout << "Initializing zoltan..." << std::endl;
        if( projection_type == 2 )
            SetRCB_Parameters( true );
        else
            SetRCB_Parameters( recompute_rcb_box );
        if( NULL == other_method || ( other_method[0] == '\0' ) )
        else
        if( imbal_tol )
            std::ostringstream str;
            str << imbal_tol;
            myZZ->Set_Param( "IMBALANCE_TOL", str.str().c_str() );  // no debug messages
        else
        else
    // set # requested partitions
    char buff[10];
    sprintf( buff, "%d", nparts );
    int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff );
    if( ZOLTAN_OK != retval ) return MB_FAILURE;
    // request only partition assignments
    retval = myZZ->Set_Param( "RETURN_LISTS", "PARTITION ASSIGNMENTS" );
    if( obj_weight > 0 )
        str << obj_weight;
        retval = myZZ->Set_Param( "OBJ_WEIGHT_DIM", str.str().c_str() );
    if( edge_weight > 0 )
        str << edge_weight;
        retval = myZZ->Set_Param( "EDGE_WEIGHT_DIM", str.str().c_str() );
    // Call backs:
    if( part_geom_mesh_size > 0. )
        myZZ->Set_Part_Multi_Fn( mbGetPart, NULL );
    int changes;
    int numGidEntries;
    int numLidEntries;
    int dumnum1;
    ZOLTAN_ID_PTR dum_local, dum_global;
    int *dum1, *dum2;
    int num_assign;
    ZOLTAN_ID_PTR assign_gid, assign_lid;
    int *assign_procs, *assign_parts;
    std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nparts
              << " processors..." << std::endl;
#ifndef NDEBUG
#if 0
  if (NULL == zmethod || !strcmp(zmethod, "RCB"))
    Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 1, 0, 0);
  if ( !strcmp(zmethod, "PHG"))
      Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 0, 1, 1);
#endif
#endif
    retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, dumnum1, dum_global, dum_local, dum1, dum2,
                                 num_assign, assign_gid, assign_lid, assign_procs, assign_parts );
    if( print_time )
        std::cout << " time to LB_partition " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
        t = clock();
    std::cout << "Saving partition information to MOAB..." << std::endl;
        result = write_partition( nparts, elems, assign_parts, write_as_sets, write_as_tags );
    else
        result = write_partition( nparts, entities, assign_parts, obj_weights, part_surf, ghost );
#endif
    if( print_time )
        std::cout << " time to write partition in memory " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
        t = clock();
    myZZ->LB_Free_Part( &assign_gid, &assign_lid, &assign_procs, &assign_parts );
    return MB_SUCCESS;
ErrorCode ZoltanPartitioner::partition_owned_cells ( Range owned,
std::multimap< int, int > &  extraGraphEdges,
int &  numNewPartitions,
std::map< int, Range > &  distribution,
int  met,
std::vector< char > &  ZoltanBuffer
Definition at line 2280 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, moab::Range::begin(), moab::Range::clear(), moab::Interface::dimension_from_handle(), EdgeWeights, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::MeshTopoUtil::get_average_position(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_coords(), moab::Interface::globalId_tag(), GlobalIds, length(), moab::MAX_SUB_ENTITIES, MB_CHK_ERR, MB_SUCCESS, mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), PartitionerBase< int >::mbImpl, MBVERTEX, myZZ, NborGlobalId, NborProcs, NumEdges, NumPoints, ObjWeights, Parts, Points, moab::Range::rbegin(), SetHypergraph_Parameters(), SetRCB_Parameters(), moab::Range::size(), moab::Interface::tag_get_data(), and moab::TYPE_FROM_HANDLE().
Referenced by moab::ParCommGraph::compute_partition().
    // start copy
    Range adjs;
    std::vector< int > adjacencies;
    ids.resize( primary.size() );
    std::vector< int > length;
    std::vector< double > coords;
    std::vector< int > nbor_proc;
    // by MBCN
    int neib_proc[5 * MAX_SUB_ENTITIES];
    int moab_id;
    int primaryDim = mbImpl->dimension_from_handle( *primary.rbegin() );
    ErrorCode rval = mbImpl->tag_get_data( gid, primary, &ids[0] );MB_CHK_ERR( rval );
    // mbpc is member in base class, PartitionerBase
    int rank = mbpc->rank();  // current rank , will be put on regular neighbors
    int i    = 0;
    for( Range::iterator rit = primary.begin(); rit != primary.end(); ++rit, i++ )
        EntityHandle cell = *rit;
        // get bridge adjacencies for each cell
        if( 1 == met )
            adjs.clear();
            rval = mtu.get_bridge_adjacencies( cell, ( primaryDim > 0 ? primaryDim - 1 : 3 ), primaryDim, adjs );MB_CHK_ERR( rval );
            if( !adjs.empty() )
                rval = mbImpl->tag_get_data( gid, adjs, neighbors );MB_CHK_ERR( rval );
            // if adjacent to neighbor partitions, add to the list
            int size_adjs = (int)adjs.size();
            moab_id       = ids[i];
            for( int k = 0; k < size_adjs; k++ )
                neib_proc[k] = rank;  // current rank
            if( extraGraphEdges.find( moab_id ) != extraGraphEdges.end() )
                // it means that the current cell is adjacent to a cell in another partition ; maybe
                // a few
                std::pair< std::multimap< int, int >::iterator, std::multimap< int, int >::iterator > ret;
                ret = extraGraphEdges.equal_range( moab_id );
                for( std::multimap< int, int >::iterator it = ret.first; it != ret.second; ++it )
                    int otherID          = it->second;
                    neighbors[size_adjs] = otherID;         // the id of the other cell, across partition
                    neib_proc[size_adjs] = procs[otherID];  // this is how we built this map, the cell id maps to
                                                            // what proc it came from
                    size_adjs++;
            length.push_back( size_adjs );
            std::copy( neighbors, neighbors + size_adjs, std::back_inserter( adjacencies ) );
            std::copy( neib_proc, neib_proc + size_adjs, std::back_inserter( nbor_proc ) );
        else if( 2 <= met )  // include 2 RCB or 3, RCB + gnomonic projection
            if( TYPE_FROM_HANDLE( cell ) == MBVERTEX )
                rval = mbImpl->get_coords( &cell, 1, avg_position );MB_CHK_ERR( rval );
            else
                rval = mtu.get_average_position( cell, avg_position );MB_CHK_ERR( rval );
            if( 3 <= met )
                IntxUtils::transform_coordinates( avg_position, 2 );  // 2 means gnomonic projection
#ifdef VERBOSE
    std::stringstream ff2;
    ff2 << "zoltanInput_" << mbpc->rank() << ".txt";
    std::ofstream ofs;
    ofs.open( ff2.str().c_str(), std::ofstream::out );
    ofs << "Length vector: " << std::endl;
    std::copy( length.begin(), length.end(), std::ostream_iterator< int >( ofs, ", " ) );
    ofs << std::endl;
    ofs << "Adjacencies vector: " << std::endl;
    std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( ofs, ", " ) );
    ofs << std::endl;
    ofs << "Moab_ids vector: " << std::endl;
    std::copy( ids.begin(), ids.end(), std::ostream_iterator< int >( ofs, ", " ) );
    ofs << std::endl;
    ofs << "Coords vector: " << std::endl;
    std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( ofs, ", " ) );
    ofs << std::endl;
    ofs.close();
#endif
    // these are static var in this file, and used in the callbacks
    Points = NULL;
    if( 1 != met ) Points = &coords[0];
    GlobalIds    = &ids[0];
    NumPoints    = (int)ids.size();
    NumEdges     = &length[0];
    NborGlobalId = &adjacencies[0];
    NborProcs    = &nbor_proc[0];
    ObjWeights   = NULL;
    EdgeWeights  = NULL;
    Parts        = NULL;
    float version;
    if( mbpc->rank() == 0 ) std::cout << "Initializing zoltan..." << std::endl;
    // old code
    if( met <= 4 )
        char buff[10];
        sprintf( buff, "%d", numNewPartitions );
        // request parts assignment
        retval = myZZ->Set_Param( "RETURN_LISTS", "PARTS" );
        // due to a bug in zoltan, if method is graph partitioning, do not pass coordinates!!
        if( 2 <= met )
            if( 3 <= met )
                SetRCB_Parameters( /*const bool recompute_rcb_box*/ true );  // recompute rcb box
            else
                SetRCB_Parameters( /*const bool recompute_rcb_box*/ false );  // recompute rcb box // is it faster ?
        else if( 1 == met )
        int changes;
        int numGidEntries;
        int numLidEntries;
        int num_import;
        ZOLTAN_ID_PTR import_global_ids, import_local_ids;
        int* import_procs;
        int* import_to_part;
        int num_export;
        ZOLTAN_ID_PTR export_global_ids, export_local_ids;
            std::cout << "Computing partition using method (1-graph, 2-geom):" << met << " for " << numNewPartitions
                      << " parts..." << std::endl;
#ifndef NDEBUG
#if 0
      static int counter=0; // it may be possible to call function multiple times in a simulation
      // give a way to not overwrite the files
      // it should work only with a modified version of Zoltan
      std::stringstream basename;
      if (1==met)
        basename << "phg_" << counter++;
        Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 0, 1, 0);
      else if (2==met)
        basename << "rcb_" << counter++;
        Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 1, 0, 0);
#endif
#endif
        retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, num_import, import_global_ids,
                                     import_local_ids, import_procs, import_to_part, num_export, export_global_ids,
                                     export_local_ids, assign_procs, assign_parts );
#ifdef VERBOSE
        std::stringstream ff3;
        ff3 << "zoltanOutput_" << mbpc->rank() << ".txt";
        std::ofstream ofs3;
        ofs3.open( ff3.str().c_str(), std::ofstream::out );
        ofs3 << " export elements on rank " << rank << " \n";
        ofs3 << "\t index \t gb_id \t local \t proc \t part \n";
        for( int k = 0; k < num_export; k++ )
            ofs3 << "\t" << k << "\t" << export_global_ids[k] << "\t" << export_local_ids[k] << "\t" << assign_procs[k]
                 << "\t" << assign_parts[k] << "\n";
        ofs3.close();
#endif
        // basically each local cell is assigned to a part
        // new code: if method == 4, we need to serialize, and send it to root of the coupler
        // here, we serialize it; sending it will happen in the calling method, where we have access to
        // the root of the coupler, which will store the buffer
        if( 4 == met )
            if( 0 == rank )
                size_t bufSize = myZZ->Serialize_Size();
                /* Then allocate  the buffer */
                ZoltanBuffer.resize( bufSize );
                int ierr = myZZ->Serialize( bufSize, &ZoltanBuffer[0] );
                if( ierr != 0 ) MB_CHK_ERR( MB_FAILURE );
        assert( num_export == (int)primary.size() );
        for( i = 0; i < num_export; i++ )
            EntityHandle cell = primary[export_local_ids[i]];
            distribution[assign_parts[i]].insert( cell );
        Zoltan::LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part );
        Zoltan::LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts );
        delete myZZ;
        myZZ = NULL;
    else if( 5 == met )
        // zoltan buffer is only on rank 0 right now
        // broadcast it first:
        size_t bufSize;
        if( rank == 0 ) bufSize = ZoltanBuffer.size();
        MPI_Bcast( (char*)&bufSize, sizeof( bufSize ), MPI_CHAR, 0, mbpc->comm() );
        if( 0 != rank ) ZoltanBuffer.resize( bufSize );
        MPI_Bcast( &ZoltanBuffer[0], bufSize, MPI_CHAR, 0, mbpc->comm() );
        // deserialize on each task
        int ierr = myZZ->Deserialize( ZoltanBuffer.size(), &ZoltanBuffer[0] );
        // use here the partitioning !!
        /* code in inferred partitions:
        part_assignments[part].push_back( elverts[iel] );*/
        i = 0;
            int proc = 0, part = 0;
            // coords are calculated in advance, contain the centers of the cells, maybe in gnomonic plane
            myZZ->LB_Point_PP_Assign( &coords[3 * i], proc, part );
            distribution[part].insert( cell );
        // TODO
        delete myZZ;
        myZZ = NULL;
    // clear arrays that were resized locally, to free up local memory
    std::vector< int >().swap( adjacencies );
    std::vector< int >().swap( ids );
    std::vector< int >().swap( length );
    std::vector< int >().swap( nbor_proc );
    std::vector< double >().swap( coords );
    return MB_SUCCESS;
ErrorCode ZoltanPartitioner::repartition ( std::vector< double > &  x,
std::vector< double > &  y,
std::vector< double > &  z,
int  StartID,
Range localGIDs
Definition at line 243 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, EdgeWeights, GlobalIds, MB_SUCCESS, mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), myZZ, NborGlobalId, NborProcs, NumEdges, NumPoints, ObjWeights, Parts, Points, SetHSFC_Parameters(), SetRCB_Parameters(), SetRIB_Parameters(), moab::subtract(), t, and moab::unite().
Referenced by moab::NCHelperScrip::create_mesh().
    int nprocs = mbpc->proc_config().proc_size();
    int rank   = mbpc->proc_config().proc_rank();
    // form pts and ids, as in assemble_graph
    pts.resize( x.size() * 3 );
    ids.resize( x.size() );
    for( size_t i = 0; i < x.size(); i++ )
        pts[3 * i]     = x[i];
        pts[3 * i + 1] = y[i];
        pts[3 * i + 2] = z[i];
        ids[i]         = StartID + (int)i;
    // do not get out until done!
    Points       = &pts[0];
    NumPoints    = (int)x.size();
    NumEdges     = NULL;
    NborGlobalId = NULL;
    NborProcs    = NULL;
    ObjWeights   = NULL;
    EdgeWeights  = NULL;
    Parts        = NULL;
    float version;
    if( rank == 0 ) std::cout << "Initializing zoltan..." << std::endl;
    char buff[10];
    sprintf( buff, "%d", nprocs );
    // request all, import and export
    retval = myZZ->Set_Param( "RETURN_LISTS", "ALL" );
    int changes;
    int numGidEntries;
    int numLidEntries;
    int num_import;
    int* import_procs;
    int num_export;
    if( rank == 0 )
        std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nprocs
    retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, num_import, import_global_ids, import_local_ids,
                                 import_procs, import_to_part, num_export, export_global_ids, export_local_ids,
    if( rank == 0 )
        t = clock();
    std::sort( import_global_ids, import_global_ids + num_import, std::greater< int >() );
    std::sort( export_global_ids, export_global_ids + num_export, std::greater< int >() );
    Range iniGids( (EntityHandle)StartID, (EntityHandle)StartID + x.size() - 1 );
    Range imported, exported;
    std::copy( import_global_ids, import_global_ids + num_import, range_inserter( imported ) );
    std::copy( export_global_ids, export_global_ids + num_export, range_inserter( exported ) );
    localGIDs = subtract( iniGids, exported );
    localGIDs = unite( localGIDs, imported );
    // Free data structures allocated by Zoltan::LB_Partition
    retval = myZZ->LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part );
    retval = myZZ->LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts );
    return MB_SUCCESS;
Definition at line 1810 of file ZoltanPartitioner.cpp.
References myZZ.
Referenced by balance_mesh(), partition_mesh_and_geometry(), and repartition().
    if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHilbert Space Filling Curve" << std::endl;
    // General parameters:
    myZZ->Set_Param( "DEBUG_LEVEL", "0" );   // no debug messages
    myZZ->Set_Param( "LB_METHOD", "HSFC" );  // perform Hilbert space filling curve
    // HSFC parameters:
    myZZ->Set_Param( "KEEP_CUTS", "1" );  // save decomposition
void ZoltanPartitioner::SetHypergraph_Parameters ( const char *  phg_method)
Definition at line 1823 of file ZoltanPartitioner.cpp.
References myZZ.
Referenced by balance_mesh(), partition_mesh_and_geometry(), and partition_owned_cells().
    if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHypergraph (or PHG): " << std::endl;
    myZZ->Set_Param( "LB_METHOD", "Hypergraph" );  // Hypergraph (or PHG)
    // Hypergraph (or PHG) parameters:
    myZZ->Set_Param( "PHG_COARSEPARTITION_METHOD", phg_method );  // CoarsePartitionMethod
void ZoltanPartitioner::SetOCTPART_Parameters ( const char *  oct_method)
Definition at line 1848 of file ZoltanPartitioner.cpp.
References myZZ.
    if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nOctree Partitioning: " << oct_method << std::endl;
    myZZ->Set_Param( "LB_METHOD", "OCTPART" );  // octree partitioning
    // OCTPART parameters:
    myZZ->Set_Param( "OCT_METHOD", oct_method );  // the SFC to be used
    myZZ->Set_Param( "OCT_OUTPUT_LEVEL", "3" );
void ZoltanPartitioner::SetPARMETIS_Parameters ( const char *  parmetis_method)
Definition at line 1835 of file ZoltanPartitioner.cpp.
References myZZ.
    if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nPARMETIS: " << parmetis_method << std::endl;
    myZZ->Set_Param( "LB_METHOD", "PARMETIS" );  // the ParMETIS library
    // PARMETIS parameters:
    myZZ->Set_Param( "PARMETIS_METHOD", parmetis_method );  // method in the library
void ZoltanPartitioner::SetRCB_Parameters ( const bool  recompute_rcb_box = false)
Definition at line 1779 of file ZoltanPartitioner.cpp.
References myZZ.
Referenced by balance_mesh(), partition_mesh_and_geometry(), partition_owned_cells(), and repartition().
    if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Coordinate Bisection" << std::endl;
    myZZ->Set_Param( "LB_METHOD", "RCB" );  // recursive coordinate bisection
    // myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" );  // recompute RCB box if needed ?
    // RCB parameters:
    myZZ->Set_Param( "RCB_OUTPUT_LEVEL", "1" );
    myZZ->Set_Param( "KEEP_CUTS", "1" );  // save decomposition so that we can infer partitions
    // myZZ->Set_Param("RCB_RECTILINEAR_BLOCKS", "1"); // don't split point on boundary
    if( recompute_rcb_box ) myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" );
Definition at line 1796 of file ZoltanPartitioner.cpp.
References myZZ.
    if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Inertial Bisection" << std::endl;
    myZZ->Set_Param( "LB_METHOD", "RIB" );  // Recursive Inertial Bisection
    // RIB parameters:
    myZZ->Set_Param( "AVERAGE_CUTS", "1" );
ErrorCode ZoltanPartitioner::write_partition ( const int  nparts,
Range elems,
const int *  assignment,
) [virtual]
Definition at line 1665 of file ZoltanPartitioner.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::clear(), moab::Interface::clear_meshset(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_handle(), moab::Range::insert(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, PartitionerBase< int >::mbImpl, MESHSET_SET, nparts, partSets, moab::Range::pop_back(), RR, moab::Range::size(), moab::Range::swap(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and smoab::UNION.
    ErrorCode result;
    Tag part_set_tag;
    int dum_id = -1, i;
    result     = mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_set_tag,
                                     MB_TAG_SPARSE | MB_TAG_CREAT, &dum_id );RR;
    // get any sets already with this tag, and clear them
    Range tagged_sets;
    result =
        mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &part_set_tag, NULL, 1, tagged_sets, Interface::UNION );RR;
    if( !tagged_sets.empty() )
        result = mbImpl->clear_meshset( tagged_sets );RR;
        if( !write_as_sets )
            result = mbImpl->tag_delete_data( part_set_tag, tagged_sets );RR;
    if( write_as_sets )
        // first, create partition sets and store in vector
        partSets.clear();
        if( nparts > (int)tagged_sets.size() )
            // too few partition sets - create missing ones
            int num_new = nparts - tagged_sets.size();
            for( i = 0; i < num_new; i++ )
                EntityHandle new_set;
                result = mbImpl->create_meshset( MESHSET_SET, new_set );RR;
                tagged_sets.insert( new_set );
        else if( nparts < (int)tagged_sets.size() )
            // too many partition sets - delete extras
            int num_del = tagged_sets.size() - nparts;
            for( i = 0; i < num_del; i++ )
                EntityHandle old_set = tagged_sets.pop_back();
                result               = mbImpl->delete_entities( &old_set, 1 );RR;
        // assign partition sets to vector
        partSets.swap( tagged_sets );
        // write a tag to those sets denoting they're partition sets, with a value of the
        // proc number
        int* dum_ids = new int[nparts];
        for( i = 0; i < nparts; i++ )
            dum_ids[i] = i;
        result = mbImpl->tag_set_data( part_set_tag, partSets, dum_ids );RR;
        // found out by valgrind when we run mbpart
        delete[] dum_ids;
        dum_ids = NULL;
        // assign entities to the relevant sets
        std::vector< EntityHandle > tmp_part_sets;
        // int N = (int)elems.size();
        std::copy( partSets.begin(), partSets.end(), std::back_inserter( tmp_part_sets ) );
        /*Range::reverse_iterator riter;
        for (i = N-1, riter = elems.rbegin(); riter != elems.rend(); ++riter, i--) {
          int assigned_part = assignment[i];
          part_ranges[assigned_part].insert(*riter);
          //result = mbImpl->add_entities(tmp_part_sets[assignment[i]], &(*rit), 1); RR;
        Range::iterator rit;
        for( i = 0, rit = elems.begin(); rit != elems.end(); ++rit, i++ )
            result = mbImpl->add_entities( tmp_part_sets[assignment[i]], &( *rit ), 1 );RR;
        /*for (i=0; i<nparts; i++)
          result = mbImpl->add_entities(tmp_part_sets[i], part_ranges[i]); RR;
        delete [] part_ranges;*/
        // check for empty sets, warn if there are any
        Range empty_sets;
        for( rit = partSets.begin(); rit != partSets.end(); ++rit )
            int num_ents = 0;
            result       = mbImpl->get_number_entities_by_handle( *rit, num_ents );
            if( MB_SUCCESS != result || !num_ents ) empty_sets.insert( *rit );
        if( !empty_sets.empty() )
            std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: ";
            for( rit = empty_sets.begin(); rit != empty_sets.end(); ++rit )
                std::cout << *rit << " ";
    if( write_as_tags )
        // allocate integer-size partitions
        result = mbImpl->tag_set_data( part_set_tag, elems, assignment );RR;
    return MB_SUCCESS;
Member Data Documentation
Definition at line 232 of file ZoltanPartitioner.hpp.
Reimplemented from PartitionerBase< int >.
Definition at line 230 of file ZoltanPartitioner.hpp.
Referenced by include_closure(), and write_partition().
List of all members.
