moab::BSPTree Class Reference
BSP tree, for sorting and searching entities spatially. More...
#include <BSPTree.hpp>
+ Collaboration diagram for moab::BSPTree:
Classes
struct  Plane
 struct to store a plane More...
Public Types
enum  Axis { X = 0, Y = 1, Z = 2 }
 Enumerate split plane directions. More...
Public Member Functions
 BSPTree (Interface *iface, const char *tagname=0, unsigned meshset_creation_flags=MESHSET_SET)
 BSPTree (Interface *iface, bool destroy_created_trees, const char *tagname=0, unsigned meshset_creation_flags=MESHSET_SET)
 ~BSPTree ()
ErrorCode get_split_plane (EntityHandle node, Plane &plane)
 Get split plane for tree node.
ErrorCode set_split_plane (EntityHandle node, const Plane &plane)
 Set split plane for tree node.
ErrorCode get_tree_box (EntityHandle root_node, double corner_coords[8][3])
 Get bounding box for entire tree.
ErrorCode get_tree_box (EntityHandle root_node, double corner_coords[24])
ErrorCode set_tree_box (EntityHandle root_node, const double box_min[3], const double box_max[3])
 Set bounding box for entire tree.
ErrorCode set_tree_box (EntityHandle root_node, const double corner_coords[8][3])
ErrorCode create_tree (const double box_min[3], const double box_max[3], EntityHandle &root_handle)
 Create tree root node.
ErrorCode create_tree (const double corner_coords[8][3], EntityHandle &root_handle)
ErrorCode create_tree (EntityHandle &root_handle)
ErrorCode find_all_trees (Range &results)
 Find all tree roots.
ErrorCode delete_tree (EntityHandle root_handle)
 Destroy a tree.
Interfacemoab ()
ErrorCode get_tree_iterator (EntityHandle tree_root, BSPTreeIter &result)
 Get iterator for tree.
ErrorCode get_tree_end_iterator (EntityHandle tree_root, BSPTreeIter &result)
 Get iterator at right-most ('last') leaf.
ErrorCode split_leaf (BSPTreeIter &leaf, Plane plane)
 Split leaf of tree Updates iterator location to point to first new leaf node.
ErrorCode split_leaf (BSPTreeIter &leaf, Plane plane, EntityHandle &left_child, EntityHandle &right_child)
ErrorCode split_leaf (BSPTreeIter &leaf, Plane plane, const Range &left_entities, const Range &right_entities)
ErrorCode split_leaf (BSPTreeIter &leaf, Plane plane, const std::vector< EntityHandle > &left_entities, const std::vector< EntityHandle > &right_entities)
ErrorCode merge_leaf (BSPTreeIter &iter)
 Merge the leaf pointed to by the current iterator with it's sibling. If the sibling is not a leaf, multiple merges may be done.
ErrorCode leaf_containing_point (EntityHandle tree_root, const double point[3], EntityHandle &leaf_out)
 Get leaf containing input position.
ErrorCode leaf_containing_point (EntityHandle tree_root, const double xyz[3], BSPTreeIter &result)
 Get iterator at leaf containing input position.
Static Public Member Functions
static double epsilon ()
Private Member Functions
ErrorCode init_tags (const char *tagname=0)
Private Attributes
InterfacembInstance
Tag planeTag
Tag rootTag
unsigned meshSetFlags
bool cleanUpTrees
std::vector< EntityHandlecreatedTrees
Detailed Description
Definition at line 42 of file BSPTree.hpp.
Member Enumeration Documentation
Enumerator:
X
Y
Z
Definition at line 69 of file BSPTree.hpp.
        X = 0,
        Y = 1,
        Z = 2
moab::BSPTree::BSPTree ( Interface iface,
const char *  tagname = 0,
unsigned  meshset_creation_flags = MESHSET_SET
Definition at line 109 of file BSPTree.cpp.
References init_tags().
    : mbInstance( mb ), meshSetFlags( set_flags ), cleanUpTrees( false )
    init_tags( tagname );
Definition at line 115 of file BSPTree.cpp.
    : mbInstance( mb ), meshSetFlags( set_flags ), cleanUpTrees( destroy_created_trees )
Definition at line 121 of file BSPTree.cpp.
References cleanUpTrees, createdTrees, delete_tree(), ErrorCode, MB_SUCCESS, moab(), rootTag, and moab::Interface::tag_get_by_ptr().
    if( !cleanUpTrees ) return;
    while( !createdTrees.empty() )
        EntityHandle tree = createdTrees.back();
        // make sure this is a tree (rather than some other, stale handle)
        const void* data_ptr = 0;
        ErrorCode rval       = moab()->tag_get_by_ptr( rootTag, &tree, 1, &data_ptr );
        if( MB_SUCCESS == rval ) rval = delete_tree( tree );
        if( MB_SUCCESS != rval ) createdTrees.pop_back();
Member Function Documentation
ErrorCode moab::BSPTree::create_tree ( const double  box_min[3],
Definition at line 203 of file BSPTree.cpp.
References moab::corners_from_box().
Referenced by create_tree().
    double corners[8][3];
    corners_from_box( box_min, box_max, corners );
    return create_tree( corners, root_handle );
ErrorCode moab::BSPTree::create_tree ( const double  corner_coords[8][3],
Definition at line 186 of file BSPTree.cpp.
References moab::Interface::create_meshset(), createdTrees, moab::Interface::delete_entities(), ErrorCode, MB_SUCCESS, meshSetFlags, moab(), and set_tree_box().
    ErrorCode rval = moab()->create_meshset( meshSetFlags, root_handle );
    if( MB_SUCCESS != rval ) return rval;
    rval = set_tree_box( root_handle, corners );
        moab()->delete_entities( &root_handle, 1 );
        root_handle = 0;
        return rval;
    createdTrees.push_back( root_handle );
    return MB_SUCCESS;
Definition at line 179 of file BSPTree.cpp.
References create_tree().
    const double min[3] = { -HUGE_VAL, -HUGE_VAL, -HUGE_VAL };
    const double max[3] = { HUGE_VAL, HUGE_VAL, HUGE_VAL };
    return create_tree( min, max, root_handle );
Destroy a tree.
Definition at line 210 of file BSPTree.cpp.
References children, createdTrees, moab::Interface::delete_entities(), ErrorCode, moab::Interface::get_child_meshsets(), MB_SUCCESS, moab(), rootTag, and moab::Interface::tag_delete_data().
Referenced by ~BSPTree().
    ErrorCode rval;
    std::vector< EntityHandle > children, dead_sets, current_sets;
    current_sets.push_back( root_handle );
    while( !current_sets.empty() )
        EntityHandle set = current_sets.back();
        current_sets.pop_back();
        dead_sets.push_back( set );
        rval = moab()->get_child_meshsets( set, children );
        std::copy( children.begin(), children.end(), std::back_inserter( current_sets ) );
        children.clear();
    rval = moab()->tag_delete_data( rootTag, &root_handle, 1 );
    createdTrees.erase( std::remove( createdTrees.begin(), createdTrees.end(), root_handle ), createdTrees.end() );
    return moab()->delete_entities( &dead_sets[0], dead_sets.size() );
static double moab::BSPTree::epsilon ( ) [inline, static]
Definition at line 54 of file BSPTree.hpp.
Referenced by moab::BSPTreeBoxIter::side_on_plane(), and moab::BSPTreeBoxIter::splits().
        return 1e-6;
Definition at line 234 of file BSPTree.cpp.
References moab::Interface::get_entities_by_type_and_tag(), MBENTITYSET, moab(), and rootTag.
    return moab()->get_entities_by_type_and_tag( 0, MBENTITYSET, &rootTag, 0, 1, results );
ErrorCode moab::BSPTree::get_tree_box ( EntityHandle  root_node,
Definition at line 169 of file BSPTree.cpp.
References moab(), rootTag, and moab::Interface::tag_get_data().
Referenced by moab::BSPTreeIter::calculate_polyhedron(), moab::BSPTreeBoxIter::initialize(), and moab::BSPTreeIter::intersect_ray().
    return moab()->tag_get_data( rootTag, &root_handle, 1, corners );
Definition at line 174 of file BSPTree.cpp.
Definition at line 246 of file BSPTree.cpp.
References ErrorCode, moab::BSPTreeIter::initialize(), MB_SUCCESS, moab::BSPTreeIter::RIGHT, and moab::BSPTreeIter::step_to_first_leaf().
    ErrorCode rval = iter.initialize( this, root );
    return iter.step_to_first_leaf( BSPTreeIter::RIGHT );
Definition at line 239 of file BSPTree.cpp.
References ErrorCode, moab::BSPTreeIter::initialize(), moab::BSPTreeIter::LEFT, MB_SUCCESS, and moab::BSPTreeIter::step_to_first_leaf().
    return iter.step_to_first_leaf( BSPTreeIter::LEFT );
ErrorCode moab::BSPTree::init_tags ( const char *  tagname = 0) [private]
Definition at line 93 of file BSPTree.cpp.
References ErrorCode, MB_BSP_TREE_DEFAULT_TAG_NAME, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_DOUBLE, moab(), planeTag, rootTag, and moab::Interface::tag_get_handle().
Referenced by BSPTree().
    if( !tagname ) tagname = MB_BSP_TREE_DEFAULT_TAG_NAME;
    std::string rootname( tagname );
    rootname += "_box";
    ErrorCode rval = moab()->tag_get_handle( tagname, 4, MB_TYPE_DOUBLE, planeTag, MB_TAG_CREAT | MB_TAG_DENSE );
        planeTag = 0;
    else
        rval = moab()->tag_get_handle( rootname.c_str(), 24, MB_TYPE_DOUBLE, rootTag, MB_TAG_CREAT | MB_TAG_SPARSE );
    if( MB_SUCCESS != rval ) rootTag = 0;
    return rval;
ErrorCode moab::BSPTree::leaf_containing_point ( EntityHandle  tree_root,
EntityHandle leaf_out
Does not take into account global bounding box of tree.
  • Therefore there is always one leaf containing the point.
  • If caller wants to account for global bounding box, then caller can test against that box and not call this method at all if the point is outside the box, as there is no leaf containing the point in that case.
Definition at line 1135 of file BSPTree.cpp.
References moab::BSPTree::Plane::above(), children, ErrorCode, moab::Interface::get_child_meshsets(), get_split_plane(), MB_SUCCESS, and moab().
    std::vector< EntityHandle > children;
    Plane plane;
    EntityHandle node = tree_root;
    ErrorCode rval    = moab()->get_child_meshsets( node, children );
    while( !children.empty() )
        rval = get_split_plane( node, plane );
        node = children[plane.above( point )];
        children.clear();
    leaf_out = node;
    return MB_SUCCESS;
BSPTreeIter result
Returns MB_ENTITY_NOT_FOUND if point is not within bounding box of tree.
Definition at line 1156 of file BSPTree.cpp.
References moab::BSPTree::Plane::above(), moab::BSPTreeIter::childVect, moab::BSPTreeIter::down(), ErrorCode, moab::Interface::get_child_meshsets(), get_split_plane(), moab::BSPTreeIter::handle(), moab::BSPTreeIter::initialize(), MB_SUCCESS, and moab().
    ErrorCode rval;
    rval = iter.initialize( this, root, point );
    for( ;; )
        iter.childVect.clear();
        rval = moab()->get_child_meshsets( iter.handle(), iter.childVect );
        if( MB_SUCCESS != rval || iter.childVect.empty() ) return rval;
        Plane plane;
        rval = get_split_plane( iter.handle(), plane );
        rval = iter.down( plane, ( BSPTreeIter::Direction )( plane.above( point ) ) );
Definition at line 325 of file BSPTree.cpp.
References moab::Interface::add_entities(), moab::BSPTreeIter::childVect, moab::Range::clear(), moab::Interface::delete_entities(), moab::BSPTreeIter::depth(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::BSPTreeIter::handle(), MB_CHK_ERR, MB_SUCCESS, moab(), moab::Interface::remove_child_meshset(), and moab::BSPTreeIter::up().
    ErrorCode rval;
    if( iter.depth() == 1 )  // at root
        return MB_FAILURE;
    // Move iter to parent
    iter.up();
    // Get sets to merge
    EntityHandle parent = iter.handle();
    rval = moab()->get_child_meshsets( parent, iter.childVect );
    // Remove child links
    moab()->remove_child_meshset( parent, iter.childVect[0] );
    moab()->remove_child_meshset( parent, iter.childVect[1] );
    std::vector< EntityHandle > stack( iter.childVect );
    // Get all entities from children and put them in parent
    Range range;
    while( !stack.empty() )
        EntityHandle h = stack.back();
        stack.pop_back();
        range.clear();
        rval = moab()->get_entities_by_handle( h, range );
        rval = moab()->add_entities( parent, range );
        rval = moab()->get_child_meshsets( h, iter.childVect );MB_CHK_ERR( rval );
        if( !iter.childVect.empty() )
            moab()->remove_child_meshset( h, iter.childVect[0] );
            moab()->remove_child_meshset( h, iter.childVect[1] );
            stack.push_back( iter.childVect[0] );
            stack.push_back( iter.childVect[1] );
        rval = moab()->delete_entities( &h, 1 );
    return MB_SUCCESS;
Definition at line 136 of file BSPTree.cpp.
References moab::BSPTree::Plane::coeff, moab::Util::is_finite(), moab(), moab::BSPTree::Plane::norm, planeTag, and moab::Interface::tag_set_data().
Referenced by split_leaf().
    // check for unit-length normal
    const double lensqr = p.norm[0] * p.norm[0] + p.norm[1] * p.norm[1] + p.norm[2] * p.norm[2];
    if( fabs( lensqr - 1.0 ) < std::numeric_limits< double >::epsilon() )
        return moab()->tag_set_data( planeTag, &node, 1, &p );
    const double inv_len = 1.0 / sqrt( lensqr );
    Plane p2( p );
    p2.norm[0] *= inv_len;
    p2.norm[1] *= inv_len;
    p2.norm[2] *= inv_len;
    p2.coeff *= inv_len;
    // check for zero-length normal
    if( !Util::is_finite( p2.norm[0] + p2.norm[1] + p2.norm[2] + p2.coeff ) ) return MB_FAILURE;
    // store plane
    return moab()->tag_set_data( planeTag, &node, 1, &p2 );
ErrorCode moab::BSPTree::set_tree_box ( EntityHandle  root_node,
Definition at line 157 of file BSPTree.cpp.
    return set_tree_box( root_handle, corners );
Definition at line 164 of file BSPTree.cpp.
References moab(), rootTag, and moab::Interface::tag_set_data().
    return moab()->tag_set_data( rootTag, &root_handle, 1, corners );
Definition at line 280 of file BSPTree.cpp.
    EntityHandle left, right;
    return split_leaf( leaf, plane, left, right );
ErrorCode moab::BSPTree::split_leaf ( BSPTreeIter leaf,
Plane  plane,
EntityHandle left_child,
EntityHandle right_child
Definition at line 253 of file BSPTree.cpp.
References moab::Interface::add_child_meshset(), children, moab::Interface::create_meshset(), moab::Interface::delete_entities(), ErrorCode, moab::BSPTreeIter::handle(), moab::BSPTreeIter::LEFT, MB_SUCCESS, meshSetFlags, moab(), set_split_plane(), and moab::BSPTreeIter::step_to_first_leaf().
    ErrorCode rval;
    rval = moab()->create_meshset( meshSetFlags, left );
    rval = moab()->create_meshset( meshSetFlags, right );
        moab()->delete_entities( &left, 1 );
        return rval;
    if( MB_SUCCESS != set_split_plane( leaf.handle(), plane ) ||
        MB_SUCCESS != moab()->add_child_meshset( leaf.handle(), left ) ||
        MB_SUCCESS != moab()->add_child_meshset( leaf.handle(), right ) ||
        MB_SUCCESS != leaf.step_to_first_leaf( BSPTreeIter::LEFT ) )
        EntityHandle children[] = { left, right };
        moab()->delete_entities( children, 2 );
        return MB_FAILURE;
    return MB_SUCCESS;
Plane  plane,
const Range left_entities,
const Range right_entities
Definition at line 286 of file BSPTree.cpp.
References children, moab::Interface::delete_entities(), ErrorCode, moab::BSPTreeIter::handle(), MB_SUCCESS, moab(), moab::Interface::remove_child_meshset(), and split_leaf().
    EntityHandle left, right, parent = leaf.handle();
    ErrorCode rval = split_leaf( leaf, plane, left, right );
    if( MB_SUCCESS == moab()->add_entities( left, left_entities ) &&
        MB_SUCCESS == moab()->add_entities( right, right_entities ) &&
        MB_SUCCESS == moab()->clear_meshset( &parent, 1 ) )
        return MB_SUCCESS;
    moab()->remove_child_meshset( parent, left );
    moab()->remove_child_meshset( parent, right );
    return MB_FAILURE;
Plane  plane,
const std::vector< EntityHandle > &  left_entities,
const std::vector< EntityHandle > &  right_entities
Definition at line 304 of file BSPTree.cpp.
References moab::Interface::add_entities(), children, moab::Interface::clear_meshset(), moab::Interface::delete_entities(), ErrorCode, moab::BSPTreeIter::handle(), MB_SUCCESS, moab(), moab::Interface::remove_child_meshset(), and split_leaf().
    if( MB_SUCCESS == moab()->add_entities( left, &left_entities[0], left_entities.size() ) &&
        MB_SUCCESS == moab()->add_entities( right, &right_entities[0], right_entities.size() ) &&
        return MB_SUCCESS;
    return MB_FAILURE;
Member Data Documentation
Definition at line 48 of file BSPTree.hpp.
std::vector< EntityHandle > moab::BSPTree::createdTrees [private]
Definition at line 49 of file BSPTree.hpp.
Referenced by create_tree(), delete_tree(), and ~BSPTree().
Definition at line 45 of file BSPTree.hpp.
Referenced by moab().
unsigned moab::BSPTree::meshSetFlags [private]
Definition at line 47 of file BSPTree.hpp.
Referenced by create_tree(), and split_leaf().
Definition at line 46 of file BSPTree.hpp.
Referenced by get_split_plane(), init_tags(), and set_split_plane().
List of all members.
