moab::BSPTreeBoxIter Class Reference
Iterate over leaves of a BSPTree. More...
#include <BSPTree.hpp>
+ Inheritance diagram for moab::BSPTreeBoxIter:
+ Collaboration diagram for moab::BSPTreeBoxIter:
Classes
struct  Corners
Public Types
enum  SideBits {
  B0154 = 0x33, B1265 = 0x66, B2376 = 0xCC, B3047 = 0x99,
  B3210 = 0x0F, B4567 = 0xF0
 Faces of a hex : corner bitmap. More...
enum  XSect { MISS = 0, SPLIT = 1, NONHEX = -1 }
 test if a plane intersects the leaf box More...
Public Member Functions
 BSPTreeBoxIter ()
virtual ~BSPTreeBoxIter ()
virtual ErrorCode step (Direction direction)
 Advance the iterator either left or right in the tree Note: stepping past the end of the tree will invalidate the iterator. It will *not* work to subsequently step the other direction.
ErrorCode step ()
 Advance to next leaf Returns MB_ENTITY_NOT_FOUND if at end. Note: stepping past the end of the tree will invalidate the iterator. Calling back() will not work.
ErrorCode back ()
 Move back to previous leaf Returns MB_ENTITY_NOT_FOUND if at beginning. Note: stepping past the start of the tree will invalidate the iterator. Calling step() will not work.
ErrorCode get_box_corners (double coords[8][3]) const
 Get coordinates of box corners, in Exodus II hexahedral ordering.
double volume () const
 Get volume of leaf box.
XSect splits (const BSPTree::Plane &plane) const
bool intersects (const BSPTree::Plane &plane) const
bool intersect_ray (const double ray_point[3], const double ray_vect[3], double &t_enter, double &t_exit) const
 Find range of overlap between ray and leaf.
ErrorCode sibling_side (SideBits &side_out) const
 Return the side of the box bounding this tree node that is shared with the immediately adjacent sibling (the tree node that shares a common parent node with this node in the binary tree.)
ErrorCode get_neighbors (SideBits side, std::vector< BSPTreeBoxIter > &results, double epsilon=0.0) const
 Get adjacent leaf nodes on indicated side.
ErrorCode calculate_polyhedron (BSPTreePoly &polyhedron_out) const
 Calculate the convex polyhedron bounding this leaf.
Static Public Member Functions
static SideBits side_above_plane (const double hex_coords[8][3], const BSPTree::Plane &plane)
static SideBits side_on_plane (const double hex_coords[8][3], const BSPTree::Plane &plane)
static SideBits opposite_face (const SideBits &bits)
static ErrorCode face_corners (const SideBits face, const double hex_corners[8][3], double face_corners_out[4][3])
Protected Member Functions
virtual ErrorCode step_to_first_leaf (Direction direction)
virtual ErrorCode up ()
virtual ErrorCode down (const BSPTree::Plane &plane, Direction direction)
virtual ErrorCode initialize (BSPTree *tool, EntityHandle root, const double *point=0)
Private Attributes
double leafCoords [8][3]
std::vector< CornersstackData
Detailed Description
Definition at line 369 of file BSPTree.hpp.
Member Enumeration Documentation
Enumerator:
B0154
Face defined by corners {0,1,5,4}: 1st Exodus side.
B1265
Face defined by corners {1,2,6,5}: 2nd Exodus side.
B2376
Face defined by corners {2,3,7,6}: 3rd Exodus side.
B3047
Face defined by corners {3,0,4,7}: 4th Exodus side.
B3210
Face defined by corners {3,2,1,0}: 5th Exodus side.
B4567
Face defined by corners {4,5,6,7}: 6th Exodus side.
Definition at line 392 of file BSPTree.hpp.
        B0154 = 0x33,  //!< Face defined by corners {0,1,5,4}: 1st Exodus side
        B1265 = 0x66,  //!< Face defined by corners {1,2,6,5}: 2nd Exodus side
        B2376 = 0xCC,  //!< Face defined by corners {2,3,7,6}: 3rd Exodus side
        B3047 = 0x99,  //!< Face defined by corners {3,0,4,7}: 4th Exodus side
        B3210 = 0x0F,  //!< Face defined by corners {3,2,1,0}: 5th Exodus side
        B4567 = 0xF0   //!< Face defined by corners {4,5,6,7}: 6th Exodus side
Enumerator:
MISS
SPLIT
NONHEX
Definition at line 444 of file BSPTree.hpp.
        MISS   = 0,
        SPLIT  = 1,
        NONHEX = -1
Definition at line 388 of file BSPTree.hpp.
virtual moab::BSPTreeBoxIter::~BSPTreeBoxIter ( ) [inline, virtual]
Definition at line 389 of file BSPTree.hpp.
Member Function Documentation
Reimplemented from moab::BSPTreeIter.
Definition at line 432 of file BSPTree.hpp.
        return BSPTreeIter::back();
ErrorCode moab::BSPTreeBoxIter::calculate_polyhedron ( BSPTreePoly polyhedron_out) const [virtual]
Definition at line 1129 of file BSPTree.cpp.
References leafCoords, and moab::BSPTreePoly::set().
    const CartVect* ptr = reinterpret_cast< const CartVect* >( leafCoords );
    return poly_out.set( ptr );
ErrorCode moab::BSPTreeBoxIter::down ( const BSPTree::Plane plane,
Direction  direction
) [protected, virtual]
Definition at line 827 of file BSPTree.cpp.
References moab::BSPTreeIter::childVect, moab::BSPTreeBoxIter::Corners::coords, ErrorCode, moab::BSPTree::Plane::flip(), moab::Interface::get_child_meshsets(), leafCoords, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTree::moab(), moab::BSPTreeIter::mStack, moab::plane_cut_box(), moab::BSPTreeIter::RIGHT, stackData, and moab::BSPTreeIter::tool().
Referenced by get_neighbors().
    childVect.clear();
    ErrorCode rval = tool()->moab()->get_child_meshsets( mStack.back(), childVect );
    if( MB_SUCCESS != rval ) return rval;
    if( childVect.empty() ) return MB_ENTITY_NOT_FOUND;
    BSPTree::Plane plane( plane_ref );
    if( direction == RIGHT ) plane.flip();
    Corners clipped_face;
    rval = plane_cut_box( clipped_face.coords, leafCoords, plane );
    mStack.push_back( childVect[direction] );
    stackData.push_back( clipped_face );
    return MB_SUCCESS;
ErrorCode moab::BSPTreeBoxIter::face_corners ( const SideBits  face,
) [static]
Definition at line 587 of file BSPTree.cpp.
References B0154, B1265, B2376, B3047, B3210, B4567, moab::copy_coords(), and MB_SUCCESS.
ErrorCode moab::BSPTreeBoxIter::get_box_corners ( double  coords[8][3]) const
Definition at line 907 of file BSPTree.cpp.
References leafCoords, and MB_SUCCESS.
    memcpy( coords, leafCoords, 24 * sizeof( double ) );
    return MB_SUCCESS;
ErrorCode moab::BSPTreeBoxIter::get_neighbors ( SideBits  side,
std::vector< BSPTreeBoxIter > &  results,
double  epsilon = 0.0
) const
Parameters:
sideFace of box for which to retrieve neighbors
resultsList to which to append results. This function does *not* clear existing values in list.
epsilonTolerance on overlap. A positive value E will result in nodes that are separated by as much as E to be considered touching. A negative value -E will cause leaves that do not overlap by at least E to be considered non-overlapping. Amongst other things, this value can be used to control whether or not leaves adjacent at only their edges or corners are returned.
Definition at line 1024 of file BSPTree.cpp.
References moab::BSPTreeIter::childVect, moab::BSPTreeBoxIter::Corners::coords, down(), ErrorCode, face_corners(), moab::Interface::get_child_meshsets(), moab::BSPTree::get_split_plane(), moab::BSPTreeIter::handle(), leafCoords, moab::BSPTreeIter::LEFT, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTree::moab(), moab::Interface::num_child_meshsets(), opposite_face(), moab::BSPTreeIter::RIGHT, side_above_plane(), moab::BSPTree::Plane::signed_distance(), moab::BSPTreeIter::tool(), and up().
    EntityHandle tmp_handle;
    BSPTree::Plane plane;
    ErrorCode rval;
    int n;
    Corners face;
    rval = face_corners( side, leafCoords, face.coords );
    // Move up tree until we find the split that created the specified side.
    // Push the sibling at that level onto the iterator stack as
    // all neighbors will be rooted at that node.
    BSPTreeBoxIter iter( *this );  // temporary iterator (don't modifiy *this)
    for( ;; )
        tmp_handle = iter.handle();
        rval = iter.up();
        if( MB_SUCCESS != rval )  // reached root - no neighbors on that side
            return ( rval == MB_ENTITY_NOT_FOUND ) ? MB_SUCCESS : rval;
        iter.childVect.clear();
        rval = tool()->moab()->get_child_meshsets( iter.handle(), iter.childVect );
        rval = tool()->get_split_plane( iter.handle(), plane );
        SideBits s = side_above_plane( iter.leafCoords, plane );
        if( tmp_handle == iter.childVect[0] && s == side )
            rval = iter.down( plane, RIGHT );
            break;
        else if( tmp_handle == iter.childVect[1] && opposite_face( s ) == side )
            rval = iter.down( plane, LEFT );
            break;
    // now move down tree, searching for adjacent boxes
    std::vector< BSPTreeBoxIter > list;
    // loop over all potential paths to neighbors (until list is empty)
    for( ;; )
        // follow a single path to a leaf, append any other potential
        // paths to neighbors to 'list'
        for( ;; )
            rval = tool()->moab()->num_child_meshsets( iter.handle(), &n );
            // if leaf
            if( !n )
                results.push_back( iter );
                break;
            bool some_above = false, some_below = false;
            for( int i = 0; i < 4; ++i )
                double signed_d = plane.signed_distance( face.coords[i] );
                if( signed_d > -epsilon ) some_above = true;
                if( signed_d < epsilon ) some_below = true;
            if( some_above && some_below )
                list.push_back( iter );
                list.back().down( plane, RIGHT );
            else if( some_above )
            else if( some_below )
            else
                // tolerance issue -- epsilon to small? 2D box?
                return MB_FAILURE;
        if( list.empty() ) break;
        iter = list.back();
        list.pop_back();
    return MB_SUCCESS;
ErrorCode moab::BSPTreeBoxIter::initialize ( BSPTree tool,
EntityHandle  root,
const double *  point = 0
Definition at line 547 of file BSPTree.cpp.
References ErrorCode, moab::BSPTree::get_tree_box(), leafCoords, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::point_in_box(), stackData, and moab::BSPTreeIter::tool().
    ErrorCode rval = BSPTreeIter::initialize( tool_ptr, root );
    rval = tool()->get_tree_box( root, leafCoords );
    if( point && !point_in_box( leafCoords, point ) ) return MB_ENTITY_NOT_FOUND;
    stackData.resize( 1 );
    return MB_SUCCESS;
bool moab::BSPTreeBoxIter::intersect_ray ( const double  ray_point[3],
double &  t_enter,
double &  t_exit
) const [virtual]
Parameters:
ray_pointCoordinates of start point of ray
ray_vectDirectionion vector for ray such that the ray is defined by r(t) = ray_point + t * ray_vect for t > 0.
t_enterOutput: if return value is true, this value is the parameter location along the ray at which the ray entered the leaf. If return value is false, then this value is undefined.
t_exitOutput: if return value is true, this value is the parameter location along the ray at which the ray exited the leaf. If return value is false, then this value is undefined.
Returns:
true if ray intersects leaf, false otherwise.
Definition at line 1267 of file BSPTree.cpp.
References leafCoords, and moab::ray_intersect_halfspaces().
    BoxPlaneIter iter( this->leafCoords ), end;
    return ray_intersect_halfspaces( CartVect( ray_point ), CartVect( ray_vect ), iter, end, t_enter, t_exit );
bool moab::BSPTreeBoxIter::intersects ( const BSPTree::Plane plane) const
Definition at line 1001 of file BSPTree.cpp.
References moab::BSPTree::Plane::above(), and leafCoords.
    // test each corner relative to the plane
    unsigned count = 0;
    for( unsigned i = 0; i < 8u; ++i )
        count += plane.above( leafCoords[i] );
    return count > 0 && count < 8u;
static SideBits moab::BSPTreeBoxIter::opposite_face ( const SideBits bits) [inline, static]
Definition at line 406 of file BSPTree.hpp.
        return (SideBits)( ( ~bits ) & 0xFF );
Returns:
MB_ENTITY_NOT FOUND if root node. MB_FAILURE if internal error. MB_SUCCESS otherwise.
Definition at line 1010 of file BSPTree.cpp.
References ErrorCode, moab::BSPTree::get_split_plane(), leafCoords, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTreeIter::mStack, side_on_plane(), and moab::BSPTreeIter::tool().
    if( mStack.size() < 2 )  // at tree root
    EntityHandle parent = mStack[mStack.size() - 2];
    ErrorCode rval = tool()->get_split_plane( parent, plane );
    if( MB_SUCCESS != rval ) return MB_FAILURE;
    side_out = side_on_plane( leafCoords, plane );
    return MB_SUCCESS;
BSPTreeBoxIter::SideBits moab::BSPTreeBoxIter::side_above_plane ( const double  hex_coords[8][3],
) [static]
Definition at line 561 of file BSPTree.cpp.
References moab::BSPTree::Plane::above().
Referenced by get_neighbors(), and moab::plane_cut_box().
    unsigned result = 0;
        result |= plane.above( hex_coords[i] ) << i;
    return (BSPTreeBoxIter::SideBits)result;
BSPTreeBoxIter::SideBits moab::BSPTreeBoxIter::side_on_plane ( const double  hex_coords[8][3],
) [static]
Definition at line 569 of file BSPTree.cpp.
References moab::BSPTree::Plane::distance(), and moab::BSPTree::epsilon().
Referenced by moab::plane_uncut_box(), and sibling_side().
        bool on = plane.distance( hex_coords[i] ) <= BSPTree::epsilon();
        result |= on << i;
Definition at line 961 of file BSPTree.cpp.
References B0154, B1265, B2376, B3047, B3210, B4567, moab::BSPTree::epsilon(), leafCoords, MISS, NONHEX, moab::BSPTree::Plane::signed_distance(), and SPLIT.
        double d = plane.signed_distance( leafCoords[i] );
        // if corner is on plane, than intersection
        // will result in a degenerate hex
        if( fabs( d ) < BSPTree::epsilon() ) return NONHEX;
        // if mark vertices above plane
        if( d > 0.0 ) result |= 1 << i;
    switch( result )
            // if all vertices or no vertices above plane,
            // then plane doesn't intersect
        case 0:
        case 0xFF:
            return MISS;
            // if there are four vertices above the plane
            // and they compose a single face of the hex,
            // then the cut will result in two hexes
        case B0154:
        case B1265:
        case B2376:
        case B3047:
        case B3210:
        case B4567:
            return SPLIT;
            // otherwise intersects, but split would not result
            // in two hexahedrons
        default:
            return NONHEX;
Definition at line 846 of file BSPTree.cpp.
References moab::BSPTreeIter::childVect, moab::BSPTreeBoxIter::Corners::coords, ErrorCode, moab::BSPTree::Plane::flip(), moab::Interface::get_child_meshsets(), moab::BSPTree::get_split_plane(), leafCoords, moab::BSPTreeIter::LEFT, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTree::moab(), moab::BSPTreeIter::mStack, moab::plane_cut_box(), moab::plane_uncut_box(), stackData, step_to_first_leaf(), and moab::BSPTreeIter::tool().
    EntityHandle node, parent;
    ErrorCode rval;
    const Direction opposite = static_cast< Direction >( 1 - direction );
    // If stack is empty, then either this iterator is uninitialized
    // or we reached the end of the iteration (and return
    // MB_ENTITY_NOT_FOUND) already.
    if( mStack.empty() ) return MB_FAILURE;
    // Pop the current node from the stack.
    // The stack should then contain the parent of the current node.
    // If the stack is empty after this pop, then we've reached the end.
    node = mStack.back();
    mStack.pop_back();
    clipped_face = stackData.back();
    stackData.pop_back();
    while( !mStack.empty() )
        // Get data for parent entity
        parent = mStack.back();
        childVect.clear();
        rval = tool()->moab()->get_child_meshsets( parent, childVect );
        if( direction == LEFT ) plane.flip();
        // If we're at the left child
        if( childVect[opposite] == node )
            // change from box of left child to box of parent
            plane_uncut_box( clipped_face.coords, leafCoords, plane );
            // change from box of parent to box of right child
            plane.flip();
            // push right child on stack
            // descend to left-most leaf of the right child
            return step_to_first_leaf( opposite );
        // The current node is the right child of the parent,
        // continue up the tree.
        assert( childVect[direction] == node );
        plane.flip();
        node         = parent;
        mStack.pop_back();
Definition at line 423 of file BSPTree.hpp.
        return BSPTreeIter::step();
ErrorCode moab::BSPTreeBoxIter::step_to_first_leaf ( Direction  direction) [protected, virtual]
Definition at line 771 of file BSPTree.cpp.
References moab::BSPTreeIter::childVect, moab::BSPTreeBoxIter::Corners::coords, ErrorCode, moab::BSPTree::Plane::flip(), moab::Interface::get_child_meshsets(), moab::BSPTree::get_split_plane(), leafCoords, MB_SUCCESS, moab::BSPTree::moab(), moab::BSPTreeIter::mStack, moab::plane_cut_box(), moab::BSPTreeIter::RIGHT, stackData, and moab::BSPTreeIter::tool().
Referenced by step().
    ErrorCode rval;
    Corners clipped_corners;
    for( ;; )
        childVect.clear();
        if( childVect.empty() )  // leaf
            break;
        rval = tool()->get_split_plane( mStack.back(), plane );
        rval = plane_cut_box( clipped_corners.coords, leafCoords, plane );
        stackData.push_back( clipped_corners );
    return MB_SUCCESS;
ErrorCode moab::BSPTreeBoxIter::up ( ) [protected, virtual]
Definition at line 797 of file BSPTree.cpp.
References moab::BSPTreeBoxIter::Corners::coords, ErrorCode, moab::BSPTree::get_split_plane(), leafCoords, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTreeIter::mStack, moab::plane_uncut_box(), stackData, and moab::BSPTreeIter::tool().
    ErrorCode rval;
    if( mStack.size() == 1 ) return MB_ENTITY_NOT_FOUND;
    EntityHandle node    = mStack.back();
    Corners clipped_face = stackData.back();
    mStack.pop_back();
        mStack.push_back( node );
        return rval;
    rval = plane_uncut_box( clipped_face.coords, leafCoords, plane );
        return rval;
    return MB_SUCCESS;
double moab::BSPTreeBoxIter::volume ( ) const [virtual]
Definition at line 942 of file BSPTree.cpp.
References moab::cross(), moab::dot(), leafCoords, moab::subtr(), and moab::sum().
    // have planar sides, so use mid-face tripple product
    double f1[3], f2[3], f3[3], f4[3], f5[3], f6[3];
    sum( f1, leafCoords[0], leafCoords[1], leafCoords[4], leafCoords[5] );
    sum( f2, leafCoords[1], leafCoords[2], leafCoords[5], leafCoords[6] );
    sum( f3, leafCoords[2], leafCoords[3], leafCoords[6], leafCoords[7] );
    sum( f4, leafCoords[0], leafCoords[3], leafCoords[4], leafCoords[7] );
    sum( f5, leafCoords[0], leafCoords[1], leafCoords[2], leafCoords[3] );
    sum( f6, leafCoords[4], leafCoords[5], leafCoords[6], leafCoords[7] );
    double v13[3], v24[3], v65[3];
    subtr( v13, f1, f3 );
    subtr( v24, f2, f4 );
    subtr( v65, f6, f5 );
    double cr[3];
    cross( cr, v13, v24 );
    return ( 1. / 64 ) * dot( cr, v65 );
Member Data Documentation
std::vector< Corners > moab::BSPTreeBoxIter::stackData [private]
Definition at line 377 of file BSPTree.hpp.
Referenced by down(), initialize(), step(), step_to_first_leaf(), and up().
List of all members.
