moab::BVHTree::SplitData Class Reference
+ Collaboration diagram for moab::BVHTree::SplitData:
Public Member Functions
 SplitData ()
 SplitData (const SplitData &f)
SplitDataoperator= (const SplitData &f)
Public Attributes
unsigned int dim
unsigned int nl
unsigned int nr
double split
double Lmax
double Rmin
BoundBox boundingBox
BoundBox leftBox
BoundBox rightBox
Detailed Description
Definition at line 141 of file BVHTree.hpp.
Definition at line 144 of file BVHTree.hpp.
            : dim( UINT_MAX ), nl( UINT_MAX ), nr( UINT_MAX ), split( DBL_MAX ), Lmax( -DBL_MAX ), Rmin( DBL_MAX )
Definition at line 148 of file BVHTree.hpp.
            : dim( f.dim ), nl( f.nl ), nr( f.nr ), split( f.split ), Lmax( f.Lmax ), Rmin( f.Rmin ),
              boundingBox( f.boundingBox ), leftBox( f.leftBox ), rightBox( f.rightBox )
Member Function Documentation
SplitData& moab::BVHTree::SplitData::operator= ( const SplitData f) [inline]
Definition at line 157 of file BVHTree.hpp.
References boundingBox, dim, leftBox, Lmax, nl, nr, rightBox, Rmin, and split.
            dim         = f.dim;
            nl          = f.nl;
            nr          = f.nr;
            split       = f.split;
            Lmax        = f.Lmax;
            Rmin        = f.Rmin;
            boundingBox = f.boundingBox;
            leftBox     = f.leftBox;
            rightBox    = f.rightBox;
            return *this;
Member Data Documentation
List of all members.
