moab::BitTag Member List
This is the complete list of members for moab::BitTag, including all inherited members.
BitTag(const char *name, int size, const void *default_value)moab::BitTag [inline, private]
BitTag(const BitTag &)moab::BitTag [private]
check_valid_sizes(const int *sizes, int num_sizes) const moab::TagInfo
clear_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *value_ptr, int value_len=0)moab::BitTag [virtual]
clear_data(SequenceManager *seqman, Error *error_handler, const Range &entities, const void *value_ptr, int value_len=0)moab::BitTag [virtual]
create_tag(const char *name, int size, const void *default_value=0)moab::BitTag [static]
default_val() const moab::BitTag [inline, private]
ents_per_page() const moab::BitTag [inline, private]
equals_default_value(const void *data, int size=-1) const moab::TagInfo
find_entities_with_value(const SequenceManager *seqman, Error *error_handler, Range &output_entities, const void *value, int value_bytes=0, EntityType type=MBMAXTYPE, const Range *intersect_entities=0) const moab::BitTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void *data) const moab::BitTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const Range &entities, void *data) const moab::BitTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void **data_ptrs, int *data_lengths) const moab::BitTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const Range &entities, const void **data_ptrs, int *data_lengths) const moab::BitTag [virtual]
get_data_type() const moab::TagInfo [inline]
get_default_value() const moab::TagInfo [inline]
get_default_value_size() const moab::TagInfo [inline]
get_entities_with_bits(EntityType type, Range &entities, unsigned char bits) const moab::BitTag
get_entities_with_bits(const Range &range, EntityType type, Range &entities, unsigned char bits) const moab::BitTag
get_memory_use(const SequenceManager *seqman, unsigned long &total, unsigned long &per_entity) const moab::BitTag [virtual]
moab::TagInfo::get_memory_use() const moab::TagInfo [inline, protected]
get_name() const moab::TagInfo [inline]
get_size() const moab::TagInfo [inline]
get_storage_type() const moab::BitTag [virtual]
get_tagged(EntityType type, Container &entities) const moab::BitTag [inline, private]
get_tagged(Range::const_iterator begin, Range::const_iterator end, Container &entities) const moab::BitTag [inline, private]
get_tagged(Container &entities, EntityType type, const Range *intersect) const moab::BitTag [inline, private]
get_tagged_entities(const SequenceManager *seqman, Range &output_entities, EntityType type=MBMAXTYPE, const Range *intersect=0) const moab::BitTag [virtual]
is_tagged(const SequenceManager *, EntityHandle h) const moab::BitTag [virtual]
Ln2PageSize enum valuemoab::BitTag
num_tagged_entities(const SequenceManager *seqman, size_t &output_count, EntityType type=MBMAXTYPE, const Range *intersect=0) const moab::BitTag [virtual]
operator=(const BitTag &)moab::BitTag [private]
pageListmoab::BitTag [private]
pageShiftmoab::BitTag [private]
release_all_data(SequenceManager *seqman, Error *error_handler, bool delete_pending)moab::BitTag [virtual]
remove_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities)moab::BitTag [virtual]
remove_data(SequenceManager *seqman, Error *error_handler, const Range &entities)moab::BitTag [virtual]
requestedBitsPerEntitymoab::BitTag [private]
reserve(unsigned bits)moab::BitTag [private]
set_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *data)moab::BitTag [virtual]
set_data(SequenceManager *seqman, Error *error_handler, const Range &entities, const void *data)moab::BitTag [virtual]
set_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void const *const *data_ptrs, const int *data_lengths)moab::BitTag [virtual]
set_data(SequenceManager *seqman, Error *error_handler, const Range &entities, void const *const *data_ptrs, const int *data_lengths)moab::BitTag [virtual]
set_name(const std::string &name)moab::TagInfo [inline]
size_from_data_type(DataType t)moab::TagInfo [static]
storedBitsPerEntitymoab::BitTag [private]
tag_iterate(SequenceManager *seqman, Error *error_handler, Range::iterator &iter, const Range::iterator &end, void *&data_ptr, bool allocate=true)moab::BitTag [virtual]
TagInfo()moab::TagInfo [inline]
TagInfo(const char *name, int size, DataType type, const void *default_value, int default_value_size)moab::TagInfo
unpack(EntityHandle h, EntityType &type, size_t &page, int &offset) const moab::BitTag [inline, private]
validate_lengths(Error *error_handler, const int *lengths, size_t num_lengths) const moab::TagInfo
variable_length() const moab::TagInfo [inline]
~BitTag()moab::BitTag [virtual]
~TagInfo()moab::TagInfo [virtual]
