moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer > Class Template Reference
#include <bvh_tree.hpp>
+ Collaboration diagram for moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >:
Public Types
typedef _Entity_handles Entity_handles
typedef _Box Box
typedef _Moab Moab
typedef _Parametrizer Parametrizer
typedef Entity_handles::value_type Entity_handle
Public Member Functions
 Bvh_tree (Entity_handles &_entities, Moab &_moab, Box &_bounding_box, Parametrizer &_entity_contains)
 Bvh_tree (Self &s)
template<typename Box >
std::size_t bucket_index (const Box &box, const Box &interval, const std::size_t dim) const
template<typename Iterator , typename Bounding_box , typename Buckets >
void establish_buckets (const Iterator begin, const Iterator end, const Bounding_box &interval, Buckets &buckets) const
template<typename Box , typename Iterator >
std::size_t set_interval (Box &interval, const Iterator begin, const Iterator end) const
template<typename Splits , typename Buckets , typename Split_data >
void initialize_splits (Splits &splits, const Buckets &buckets, const Split_data &data) const
template<typename Iterator , typename Split_data >
void order_elements (const Iterator &begin, const Iterator &end, const Split_data &data) const
void median_order (const Iterator &begin, const Iterator &end, Split_data &data) const
template<typename Splits , typename Split_data >
void choose_best_split (const Splits &splits, Split_data &data) const
void find_split (const Iterator &begin, const Iterator &end, Split_data &data) const
template<typename Vector , typename Result >
Result & find (const Vector &point, const double tol, Result &result) const
template<typename Vector >
Entity_handle bruteforce_find (const Vector &point, const double tol) const
Private Types
typedef Bvh_tree
_Parametrizer >
Self
typedef std::pair< Box,
Entity_handle
Leaf_element
typedef _bvh::_Node< Box,
Entity_handle
Node
typedef std::vector< NodeNodes
Private Member Functions
template<typename Iterator >
int build_tree (const Iterator begin, const Iterator end, const int index, const Box &box, const int depth=0)
template<typename Vector , typename Node_index , typename Result >
Result & _find_point (const Vector &point, const Node_index &index, const double tol, Result &result) const
Private Attributes
const Entity_handlesentity_handles_
Nodes tree_
Moabmoab
Box bounding_box
Parametrizerentity_contains
Detailed Description
template<typename _Entity_handles, typename _Box, typename _Moab, typename _Parametrizer>
class moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >
Definition at line 152 of file bvh_tree.hpp.
Member Typedef Documentation
template<typename _Entity_handles , typename _Box , typename _Moab , typename _Parametrizer >
typedef _Box moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Box
Definition at line 157 of file bvh_tree.hpp.
typedef Entity_handles::value_type moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Entity_handle
Definition at line 160 of file bvh_tree.hpp.
typedef _Entity_handles moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Entity_handles
Definition at line 156 of file bvh_tree.hpp.
typedef std::pair< Box, Entity_handle > moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Leaf_element [private]
Definition at line 165 of file bvh_tree.hpp.
typedef _Moab moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Moab
Definition at line 158 of file bvh_tree.hpp.
typedef _bvh::_Node< Box, Entity_handle > moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Node [private]
Definition at line 166 of file bvh_tree.hpp.
typedef std::vector< Node > moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Nodes [private]
Definition at line 167 of file bvh_tree.hpp.
typedef _Parametrizer moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Parametrizer
Definition at line 159 of file bvh_tree.hpp.
typedef Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer > moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Self [private]
Definition at line 164 of file bvh_tree.hpp.
moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Bvh_tree ( Entity_handles _entities,
Moab _moab,
Box _bounding_box,
Parametrizer _entity_contains
) [inline]
Definition at line 171 of file bvh_tree.hpp.
References moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::bounding_box, moab::common_tree::box_contains_box(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::build_tree(), moab::common_tree::construct_element_map(), moab::common_tree::construct_ordering(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::entity_handles_, moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::moab, and moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::tree_.
        : entity_handles_( _entities ), tree_(), moab( _moab ), bounding_box( _bounding_box ),
          entity_contains( _entity_contains )
        typedef typename Entity_handles::iterator Entity_handle_iterator;
        typedef ct::_Element_data< const _Box, double > Element_data;
        typedef typename std::tr1::unordered_map< Entity_handle, Element_data > Entity_map;
        typedef typename Entity_map::iterator Entity_map_iterator;
        typedef std::vector< Entity_map_iterator > Vector;
        // a fully balanced tree will have 2*_entities.size()
        // which is one doubling away..
        tree_.reserve( entity_handles_.size() );
        Entity_map entity_map( entity_handles_.size() );
        ct::construct_element_map( entity_handles_, entity_map, bounding_box, moab );
#ifdef BVH_TREE_DEBUG
        for( Entity_map_iterator i = entity_map.begin(); i != entity_map.end(); ++i )
            if( !box_contains_box( bounding_box, i->second.first, 0 ) )
                std::cerr << "BB:" << bounding_box << "EB:" << i->second.first << std::endl;
                std::exit( -1 );
#endif
        //_bounding_box = bounding_box;
        Vector entity_ordering;
        construct_ordering( entity_map, entity_ordering );
        // We only build nonempty trees
        if( entity_ordering.size() )
            // initially all bits are set
            tree_.push_back( Node() );
            const int depth = build_tree( entity_ordering.begin(), entity_ordering.end(), 0, bounding_box );
            typedef typename Nodes::iterator Node_iterator;
            typedef typename Node::Entities::iterator Entity_iterator;
            std::set< Entity_handle > entity_handles;
            for( Node_iterator i = tree_.begin(); i != tree_.end(); ++i )
                for( Entity_iterator j = i->entities.begin(); j != i->entities.end(); ++j )
                    entity_handles.insert( j->second );
            if( entity_handles.size() != entity_handles_.size() )
                std::cout << "Entity Handle Size Mismatch!" << std::endl;
            typedef typename Entity_handles::iterator Entity_iterator_;
            for( Entity_iterator_ i = entity_handles_.begin(); i != entity_handles_.end(); ++i )
                if( entity_handles.find( *i ) == entity_handles.end() )
                    std::cout << "Tree is missing an entity! " << std::endl;
#endif
            std::cout << "max tree depth: " << depth << std::endl;
moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Bvh_tree ( Self s) [inline]
Definition at line 234 of file bvh_tree.hpp.
        : entity_handles_( s.entity_handles_ ), tree_( s.tree_ ), moab( s.moab ), bounding_box( s.bounding_box ),
          entity_contains( s.entity_contains )
Member Function Documentation
Result& moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::_find_point ( const Vector &  point,
const Node_index &  index,
const double  tol,
Result &  result
) const [inline, private]
Definition at line 679 of file bvh_tree.hpp.
References moab::common_tree::box_contains_point(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::entity_contains, moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::moab, and moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::tree_.
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::find().
        typedef typename Node::Entities::const_iterator Entity_iterator;
        const Node& node = tree_[index];
        if( node.dim == 3 )
            for( Entity_iterator i = node.entities.begin(); i != node.entities.end(); ++i )
                if( ct::box_contains_point( i->first, point, tol ) )
                    const std::pair< bool, Vector > r = entity_contains( moab, i->second, point );
                    if( r.first )
                        return result = std::make_pair( i->second, r.second );
            result = Result( 0, point );
            return result;
        // the extra tol here considers the case where
        // 0 < Rmin - Lmax < 2tol
        if( ( node.Lmax + tol ) < ( node.Rmin - tol ) )
            if( point[node.dim] <= ( node.Lmax + tol ) )
                return _find_point( point, node.child, tol, result );
            else if( point[node.dim] >= ( node.Rmin - tol ) )
                return _find_point( point, node.child + 1, tol, result );
            return result;  // point lies in empty space.
        // Boxes overlap
        // left of Rmin, you must be on the left
        // we can't be sure about the boundaries since the boxes overlap
        // this was a typo in the paper which caused pain.
        if( point[node.dim] < ( node.Rmin - tol ) )
            // if you are on the right Lmax, you must be on the right
        else if( point[node.dim] > ( node.Lmax + tol ) )
        /* pg5 of paper
         * However, instead of always traversing either subtree
         * first (e.g. left always before right), we first traverse
         * the subtree whose bounding plane has the larger distance to the
         * sought point. This results in less overall traversal, and the correct
         * cell is identified more quickly.
        // Sofar all testing confirms that this 'heuristic' is
        // significantly slower.
        // I conjecture this is because it gets improperly
        // branch predicted..
        // bool dir = (point[ node.dim] - node.Rmin) <=
        //              (node.Lmax - point[ node.dim]);
        bool dir = false;
        _find_point( point, node.child + dir, tol, result );
        if( result.first == 0 )
            return _find_point( point, node.child + ( !dir ), tol, result );
        return result;
Entity_handle moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::bruteforce_find ( const Vector &  point,
const double  tol
) const [inline]
Definition at line 761 of file bvh_tree.hpp.
        typedef typename Vector::const_iterator Point_iterator;
        typedef typename Nodes::value_type Node;
        typedef typename Nodes::const_iterator Node_iterator;
            if( i->dim == 3 )
                    if( ct::box_contains_point( j->first, point, tol ) )
                        const std::pair< bool, Vector > result = entity_contains( moab, j->second, point );
                        if( result.first )
                            return j->second;
        return 0;
std::size_t moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::bucket_index ( const Box box,
const Box interval,
) const [inline]
Definition at line 247 of file bvh_tree.hpp.
References center(), dim, length(), and NUM_BUCKETS.
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::establish_buckets(), and moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::order_elements().
        const double min    = interval.min[dim];
        const double length = ( interval.max[dim] - min ) / NUM_BUCKETS;
        const double center = ( ( box.max[dim] + box.min[dim] ) / 2.0 ) - min;
#ifdef BVH_SHOW_INDEX
        std::cout << "[ " << min << " , " << interval.max[dim] << " ]" << std::endl;
        std::cout << "[ " << box.min[dim] << " , " << box.max[dim] << " ]" << std::endl;
        std::cout << "Length of bucket" << length << std::endl;
        std::cout << "Center: " << ( box.max[dim] + box.min[dim] ) / 2.0 << std::endl;
        std::cout << "Distance of center from min:  " << center << std::endl;
        std::cout << "ratio: " << center / length << std::endl;
        std::cout << "index: " << std::ceil( center / length ) - 1 << std::endl;
#endif
#endif
        return std::ceil( center / length ) - 1;
int moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::build_tree ( const Iterator  begin,
const Iterator  end,
const int  index,
const Box box,
const int  depth = 0
) [inline, private]
Definition at line 639 of file bvh_tree.hpp.
References moab::common_tree::assign_entities(), moab::common_tree::box_contains_box(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::find_split(), SMAX, and moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::tree_.
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::Bvh_tree().
        for( Iterator i = begin; i != end; ++i )
            if( !box_contains_box( box, ( *i )->second.first, 0 ) )
                std::cerr << "depth: " << depth << std::endl;
                std::cerr << "BB:" << box << "EB:" << ( *i )->second.first << std::endl;
                std::exit( -1 );
#endif
        const std::size_t total_num_elements = std::distance( begin, end );
        // logic for splitting conditions
        if( total_num_elements > SMAX )
            _bvh::_Split_data data;
            data.bounding_box = box;
            find_split( begin, end, data );
            // assign data to node
            node.Lmax  = data.Lmax;
            node.Rmin  = data.Rmin;
            node.dim   = data.dim;
            node.child = tree_.size();
            // insert left, right children;
            const int left_depth  = build_tree( begin, begin + data.nl, node.child, data.left_box, depth + 1 );
            const int right_depth = build_tree( begin + data.nl, end, node.child + 1, data.right_box, depth + 1 );
            return std::max( left_depth, right_depth );
        node.dim = 3;
        ct::assign_entities( node.entities, begin, end );
        return depth;
void moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::choose_best_split ( const Splits &  splits,
Split_data &  data
) const [inline]
Definition at line 498 of file bvh_tree.hpp.
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::find_split().
        typedef typename Splits::const_iterator List_iterator;
        typedef typename List_iterator::value_type::const_iterator Split_iterator;
        typedef typename Split_iterator::value_type Split;
        std::vector< Split > best_splits;
        typedef typename _bvh::Split_comparator< Split > Comparator;
        Comparator compare;
        for( List_iterator i = splits.begin(); i != splits.end(); ++i )
            Split_iterator j = std::min_element( i->begin(), i->end(), compare );
            best_splits.push_back( *j );
        data = *std::min_element( best_splits.begin(), best_splits.end(), compare );
void moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::establish_buckets ( const Iterator  begin,
const Iterator  end,
const Bounding_box &  interval,
Buckets &  buckets
) const [inline]
Definition at line 267 of file bvh_tree.hpp.
References moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::bounding_box, moab::common_tree::box_contains_box(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::bucket_index(), dim, NUM_DIM, and moab::common_tree::update_bounding_box().
        // put each element into its bucket
            const Bounding_box& box = ( *i )->second.first;
            for( std::size_t dim = 0; dim < NUM_DIM; ++dim )
                const std::size_t index = bucket_index( box, interval, dim );
                _bvh::_Bucket& bucket   = buckets[dim][index];
                if( bucket.size > 0 )
                    ct::update_bounding_box( bucket.bounding_box, box );
                else
                    bucket.bounding_box = box;
                bucket.size++;
        Bounding_box elt_union = ( *begin )->second.first;
            ct::update_bounding_box( elt_union, box );
                if( !box_contains_box( bucket.bounding_box, box ) )
                    std::cerr << "Buckets not covering elements!" << std::endl;
        if( !box_contains_box( elt_union, interval ) )
            std::cout << "element union: " << std::endl << elt_union;
            std::cout << "intervals: " << std::endl << interval;
            std::cout << "union of elts does not contain original box!" << std::endl;
        if( !box_contains_box( interval, elt_union ) )
            std::cout << "original box does not contain union of elts" << std::endl;
            std::cout << interval << std::endl;
            std::cout << elt_union << std::endl;
        typedef typename Buckets::value_type Bucket_list;
        typedef typename Bucket_list::const_iterator Bucket_iterator;
        for( std::size_t d = 0; d < NUM_DIM; ++d )
            std::vector< std::size_t > nonempty;
            const Bucket_list& buckets_ = buckets[d];
            std::size_t j               = 0;
            for( Bucket_iterator i = buckets_.begin(); i != buckets_.end(); ++i, ++j )
                if( i->size > 0 )
                    nonempty.push_back( j );
            Bounding_box test_box = buckets_[nonempty.front()].bounding_box;
            for( std::size_t i = 0; i < nonempty.size(); ++i )
                ct::update_bounding_box( test_box, buckets_[nonempty[i]].bounding_box );
            if( !box_contains_box( test_box, interval ) )
                std::cout << "union of buckets in dimension: " << d << "does not contain original box!" << std::endl;
            if( !box_contains_box( interval, test_box ) )
                std::cout << "original box does "
                          << "not contain union of buckets"
                          << "in dimension: " << d << std::endl;
                std::cout << test_box << std::endl;
#endif
Result& moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::find ( const Vector &  point,
const double  tol,
Result &  result
) const [inline]
Definition at line 752 of file bvh_tree.hpp.
References moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::_find_point().
        return _find_point( point, 0, tol, result );
void moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::find_split ( const Iterator &  begin,
const Iterator &  end,
Split_data &  data
) const [inline]
Definition at line 515 of file bvh_tree.hpp.
References moab::common_tree::box_contains_box(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::choose_best_split(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::establish_buckets(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::initialize_splits(), left_box, moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::median_order(), NUM_BUCKETS, NUM_DIM, NUM_SPLITS, moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::order_elements(), right_box, and moab::common_tree::update_bounding_box().
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::build_tree().
        typedef typename Iterator::value_type Map_iterator;
        typedef typename Map_iterator::value_type::second_type Box_data;
        typedef typename Box_data::first_type _Bounding_box;  // Note, not global typedef moab::common_tree::Box<
                                                              // double> Bounding_box;
        typedef typename std::vector< Split_data > Split_list;
        typedef typename std::vector< Split_list > Splits;
        typedef typename Splits::iterator Split_iterator;
        typedef typename std::vector< _bvh::_Bucket > Bucket_list;
        typedef typename std::vector< Bucket_list > Buckets;
        Buckets buckets( NUM_DIM, Bucket_list( NUM_BUCKETS ) );
        Splits splits( NUM_DIM, Split_list( NUM_SPLITS, data ) );
        const _Bounding_box interval = data.bounding_box;
        establish_buckets( begin, end, interval, buckets );
        initialize_splits( splits, buckets, data );
        choose_best_split( splits, data );
        const bool use_median = ( 0 == data.nl ) || ( data.nr == 0 );
        if( !use_median )
            order_elements( begin, end, data );
        else
            median_order( begin, end, data );
        bool seen_one = false, issue = false;
        bool first_left = true, first_right = true;
        std::size_t count_left = 0, count_right = 0;
        typename Split_data::Box left_box, right_box;
            double order = ( *i )->second.second;
            if( order != 0 && order != 1 )
                std::cerr << "Invalid order element !";
                std::cerr << order << std::endl;
                std::exit( -1 );
            if( order == 1 )
                seen_one = 1;
                count_right++;
                if( first_right )
                    right_box   = ( *i )->second.first;
                    first_right = false;
                else
                    ct::update_bounding_box( right_box, ( *i )->second.first );
                if( !box_contains_box( data.right_box, ( *i )->second.first ) )
                    if( !issue )
                        std::cerr << "Bounding right box issue!" << std::endl;
                    issue = true;
            if( order == 0 )
                count_left++;
                if( first_left )
                    left_box   = ( *i )->second.first;
                    first_left = false;
                else
                    ct::update_bounding_box( left_box, ( *i )->second.first );
                if( !box_contains_box( data.left_box, ( *i )->second.first ) )
                    if( !issue )
                        std::cerr << "Bounding left box issue!" << std::endl;
                    issue = true;
                if( seen_one )
                    std::cerr << "Invalid ordering!" << std::endl;
                    std::cout << ( *( i - 1 ) )->second.second << order << std::endl;
                    exit( -1 );
        if( !box_contains_box( left_box, data.left_box ) )
            std::cout << "left elts do not contain left box" << std::endl;
        if( !box_contains_box( data.left_box, left_box ) )
            std::cout << "left box does not contain left elts" << std::endl;
        if( !box_contains_box( right_box, data.right_box ) )
            std::cout << "right elts do not contain right box" << std::endl;
        if( !box_contains_box( data.right_box, right_box ) )
            std::cout << "right box do not contain right elts" << std::endl;
        if( count_left != data.nl || count_right != data.nr )
            std::cerr << "counts are off!" << std::endl;
            std::cerr << "total: " << std::distance( begin, end ) << std::endl;
            std::cerr << "Dim: " << data.dim << std::endl;
            std::cerr << data.Lmax << " , " << data.Rmin << std::endl;
            std::cerr << "Right box: " << std::endl << data.right_box << "Left box: " << std::endl << data.left_box;
            std::cerr << "supposed to be: " << data.nl << " " << data.nr << std::endl;
            std::cerr << "accountant says: " << count_left << " " << count_right << std::endl;
            std::exit( -1 );
#endif
void moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::initialize_splits ( Splits &  splits,
const Buckets &  buckets,
const Split_data &  data
) const [inline]
Definition at line 380 of file bvh_tree.hpp.
References moab::common_tree::box_contains_box(), NUM_DIM, moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::set_interval(), and moab::common_tree::update_bounding_box().
        typedef typename Bucket_list::value_type Bucket;
        typedef typename Splits::value_type Split_list;
        typedef typename Split_list::value_type Split;
        typedef typename Split_list::iterator Split_iterator;
            const Split_iterator splits_begin = splits[d].begin();
            const Split_iterator splits_end   = splits[d].end();
            const Bucket_iterator left_begin  = buckets[d].begin();
            const Bucket_iterator _end        = buckets[d].end();
            Bucket_iterator left_end          = buckets[d].begin() + 1;
            for( Split_iterator s = splits_begin; s != splits_end; ++s, ++left_end )
                s->nl = set_interval( s->left_box, left_begin, left_end );
                if( s->nl == 0 )
                    s->left_box        = data.bounding_box;
                    s->left_box.max[d] = s->left_box.min[d];
                s->nr = set_interval( s->right_box, left_end, _end );
                if( s->nr == 0 )
                    s->right_box        = data.bounding_box;
                    s->right_box.min[d] = s->right_box.max[d];
                s->Lmax  = s->left_box.max[d];
                s->Rmin  = s->right_box.min[d];
                s->split = std::distance( splits_begin, s );
                s->dim   = d;
                typename Split::Box test_box = s->left_box;
                ct::update_bounding_box( test_box, s->right_box );
                if( !box_contains_box( data.bounding_box, test_box ) )
                    std::cout << "nr: " << s->nr << std::endl;
                    std::cout << "Test box: " << std::endl << test_box;
                    std::cout << "Left box: " << std::endl << s->left_box;
                    std::cout << "Right box: " << std::endl << s->right_box;
                    std::cout << "Interval: " << std::endl << data.bounding_box;
                    std::cout << "Split boxes larger than bb" << std::endl;
                if( !box_contains_box( test_box, data.bounding_box ) )
                    std::cout << "bb larger than union "
                              << "of split boxes" << std::endl;
#endif
void moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::median_order ( const Iterator &  begin,
Split_data &  data
) const [inline]
Definition at line 451 of file bvh_tree.hpp.
References moab::common_tree::box_contains_box(), center(), moab::common_tree::compute_box_center(), and moab::common_tree::update_bounding_box().
            const double center   = compute_box_center( ( *i )->second.first, data.dim );
            ( *i )->second.second = center;
        std::sort( begin, end, _bvh::Iterator_comparator< Map_iterator >() );
        const std::size_t total = std::distance( begin, end );
        Iterator middle         = begin + ( total / 2 );
        double middle_center    = ( *middle )->second.second;
        middle_center += ( *( ++middle ) )->second.second;
        middle_center /= 2.0;
        data.split = middle_center;
        data.nl    = std::distance( begin, middle ) + 1;
        data.nr    = total - data.nl;
        middle++;
        data.left_box  = ( *begin )->second.first;
        data.right_box = ( *middle )->second.first;
        for( Iterator i = begin; i != middle; ++i )
            ( *i )->second.second = 0;
            update_bounding_box( data.left_box, ( *i )->second.first );
        for( Iterator i = middle; i != end; ++i )
            ( *i )->second.second = 1;
            update_bounding_box( data.right_box, ( *i )->second.first );
        data.Rmin = data.right_box.min[data.dim];
        data.Lmax = data.left_box.max[data.dim];
        typename Split_data::Box test_box = data.left_box;
        ct::update_bounding_box( test_box, data.right_box );
            std::cerr << "MEDIAN: BB Does not contain splits" << std::endl;
            std::cerr << "MEDIAN: splits do not contain BB" << std::endl;
#endif
void moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::order_elements ( const Iterator &  begin,
) const [inline]
Definition at line 439 of file bvh_tree.hpp.
References moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::bucket_index().
            const int index       = bucket_index( ( *i )->second.first, data.bounding_box, data.dim );
            ( *i )->second.second = ( index <= data.split ) ? 0 : 1;
std::size_t moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::set_interval ( Box interval,
const Iterator  end
) const [inline]
Definition at line 355 of file bvh_tree.hpp.
References moab::GeomUtil::first(), and moab::common_tree::update_bounding_box().
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::initialize_splits().
        bool first        = true;
        std::size_t count = 0;
        for( Iterator b = begin; b != end; ++b )
            const Box& box = b->bounding_box;
            count += b->size;
            if( b->size != 0 )
                if( first )
                    interval = box;
                    first    = false;
                else
                    ct::update_bounding_box( interval, box );
        return count;
Member Data Documentation
Box moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::bounding_box [private]
Parametrizer& moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::entity_contains [private]
const Entity_handles& moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::entity_handles_ [private]
Moab& moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::moab [private]
List of all members.
