moab::EntitySequence Member List
This is the complete list of members for moab::EntitySequence, including all inherited members.
append_entities(EntityID count)moab::EntitySequence [protected]
create_data_subset(EntityHandle start_handle, EntityHandle end_handle, int num_sequence_arrays, unsigned const *bytes_per_element) const moab::EntitySequence [protected]
create_data_subset(EntityHandle start_handle, EntityHandle end_handle) const =0moab::EntitySequence [pure virtual]
data() const moab::EntitySequence [inline]
data(SequenceData *ptr)moab::EntitySequence [inline]
end_handle() const moab::EntitySequence [inline]
endHandlemoab::EntitySequence [private]
EntitySequence(EntityHandle h)moab::EntitySequence [inline, protected]
EntitySequence(EntitySequence &split_from, EntityHandle here)moab::EntitySequence [inline, protected]
EntitySequence(EntityHandle start, EntityID count, SequenceData *dat)moab::EntitySequence [inline]
get_const_memory_use(unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const =0moab::EntitySequence [pure virtual]
get_per_entity_memory_use(EntityHandle first, EntityHandle last) const moab::EntitySequence [virtual]
merge(EntitySequence &other)moab::EntitySequence [virtual]
pop_back(EntityID count)moab::EntitySequence [virtual]
pop_front(EntityID count)moab::EntitySequence [virtual]
prepend_entities(EntityID count)moab::EntitySequence [protected]
sequenceDatamoab::EntitySequence [private]
size() const moab::EntitySequence [inline]
split(EntityHandle here)=0moab::EntitySequence [pure virtual]
start_handle() const moab::EntitySequence [inline]
startHandlemoab::EntitySequence [private]
type() const moab::EntitySequence [inline]
using_entire_data() const moab::EntitySequence
values_per_entity() const moab::EntitySequence [virtual]
~EntitySequence()moab::EntitySequence [inline, virtual]
