moab::ExoIIUtil Class Reference
#include <ExoIIUtil.hpp>
+ Inheritance diagram for moab::ExoIIUtil:
+ Collaboration diagram for moab::ExoIIUtil:
Public Member Functions
 ExoIIUtil (Interface *mdb)
 ~ExoIIUtil ()
virtual ExoIIElementType element_name_to_type (const char *name)
 given the element name, return the type
virtual ExoIIElementType get_element_type (EntityHandle entity, Tag mid_nodes_tag, Tag geom_dimension_tag, EntityType indiv_entity_type=MBMAXTYPE)
 get the element type of the entity; this entity can either be a meshset, in which case it will be assumed to be a material set meshset, or an individual entity.
virtual void has_mid_nodes (ExoIIElementType elem_type, int *array)
virtual int has_mid_nodes (ExoIIElementType elem_type, int dimension)
virtual int geometric_dimension (const ExoIIElementType elem_type)
 return the geometric dimension of the specified element type
virtual const char * element_type_name (ExoIIElementType type)
Static Public Member Functions
static ExoIIElementType static_element_name_to_type (const char *name)
static ExoIIElementType static_get_element_type (Interface *mdbImpl, const EntityHandle entity, const Tag mid_nodes_tag, const Tag geom_dimension_tag, const EntityType indiv_entity_type=MBMAXTYPE)
 get the element type of the entity; this entity can either be a meshset, in which case it will be assumed to be a material set meshset, or an individual entity. If a meshset, and indiv_entity_type is input, that type is used to start the search for the connectivity tag which determines how many vertices per entity are defined for that meshset
static ExoIIElementType get_element_type_from_num_verts (const int num_verts, const EntityType entity_type=MBMAXTYPE, const int dimension=3)
 given the number of vertices in an entity, and optionally the entity type and geometric dimension, return the corresponding exodusII element type; dimension defaults to 3 following TSTT convention
Static Public Attributes
static const EntityType ExoIIElementMBEntity []
 the MB entity type used for each element type
static const char * ElementTypeNames []
 names for all the element types that MB ExoII reader supports
static const int VerticesPerElement []
 number of vertices per element
static const int HasMidNodes [][4]
 HasMidNode[elem_type][dim] = 1 denotes that elem_type has mid-nodes on sub-entities of dimension dim.
static const int ElementGeometricDimension []
 geometric dimension of each element
Private Attributes
InterfacemMB
Detailed Description
Definition at line 33 of file ExoIIUtil.hpp.
Definition at line 39 of file ExoIIUtil.hpp.
: mMB( mdb ) {}
Definition at line 40 of file ExoIIUtil.hpp.
Member Function Documentation
virtual ExoIIElementType moab::ExoIIUtil::element_name_to_type ( const char *  name) [inline, virtual]
Implements moab::ExoIIInterface.
Definition at line 43 of file ExoIIUtil.hpp.
References static_element_name_to_type().
virtual const char* moab::ExoIIUtil::element_type_name ( ExoIIElementType  type) [inline, virtual]
Definition at line 77 of file ExoIIUtil.hpp.
References ElementTypeNames.
        return ElementTypeNames[type];
virtual int moab::ExoIIUtil::geometric_dimension ( const ExoIIElementType  elem_type) [inline, virtual]
Definition at line 72 of file ExoIIUtil.hpp.
References ElementGeometricDimension.
        return ElementGeometricDimension[elem_type];
virtual ExoIIElementType moab::ExoIIUtil::get_element_type ( EntityHandle  entity,
Tag  mid_nodes_tag,
EntityType  indiv_entity_type = MBMAXTYPE
) [inline, virtual]
Definition at line 51 of file ExoIIUtil.hpp.
References mMB, and static_get_element_type().
        return static_get_element_type( mMB, entity, mid_nodes_tag, geom_dimension_tag, indiv_entity_type );
ExoIIElementType moab::ExoIIUtil::get_element_type_from_num_verts ( const int  num_verts,
const EntityType  entity_type = MBMAXTYPE,
const int  dimension = 3
) [static]
Definition at line 300 of file ExoIIUtil.cpp.
References ElementGeometricDimension, moab::EXOII_MAX_ELEM_TYPE, moab::EXOII_POLYGON, moab::EXOII_POLYHEDRON, ExoIIElementMBEntity, MBMAXTYPE, MBPOLYGON, MBPOLYHEDRON, and VerticesPerElement.
Referenced by moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), and static_get_element_type().
    if( MBPOLYGON == entity_type && 2 == dimension ) return EXOII_POLYGON;
    if( MBPOLYHEDRON == entity_type && 3 == dimension ) return EXOII_POLYHEDRON;
    for( int i = 0; i < EXOII_MAX_ELEM_TYPE; i++ )
        if( ( entity_type == MBMAXTYPE || entity_type == ExoIIElementMBEntity[i] ) &&
            VerticesPerElement[i] == num_verts && ElementGeometricDimension[i] >= dimension )
            return (ExoIIElementType)i;
    return EXOII_MAX_ELEM_TYPE;
virtual void moab::ExoIIUtil::has_mid_nodes ( ExoIIElementType  elem_type,
int *  array
) [inline, virtual]
Definition at line 59 of file ExoIIUtil.hpp.
References HasMidNodes.
Referenced by static_get_element_type().
        array[0] = HasMidNodes[elem_type][0];
        array[1] = HasMidNodes[elem_type][1];
        array[2] = HasMidNodes[elem_type][2];
        array[3] = HasMidNodes[elem_type][3];
virtual int moab::ExoIIUtil::has_mid_nodes ( ExoIIElementType  elem_type,
int  dimension
) [inline, virtual]
Definition at line 67 of file ExoIIUtil.hpp.
        return HasMidNodes[elem_type][dimension];
Definition at line 218 of file ExoIIUtil.cpp.
References ElementTypeNames, and moab::EXOII_MAX_ELEM_TYPE.
Referenced by element_name_to_type(), moab::ReadNCDF::read_elements(), and moab::ReadNCDF::update().
    int i;
    for( i = 0; i < EXOII_MAX_ELEM_TYPE; i++ )
        if( strcmp( ElementTypeNames[i], name ) == 0 ) return (ExoIIElementType)i;
ExoIIElementType moab::ExoIIUtil::static_get_element_type ( Interface mdbImpl,
const EntityType  indiv_entity_type = MBMAXTYPE
) [static]
Definition at line 227 of file ExoIIUtil.cpp.
References moab::CN::Dimension(), ElementGeometricDimension, moab::EXOII_MAX_ELEM_TYPE, moab::EXOII_SPHERE, ExoIIElementMBEntity, moab::Interface::get_connectivity(), get_element_type_from_num_verts(), has_mid_nodes(), HasMidNodes, MB_SUCCESS, MBEDGE, MBENTITYSET, MBMAXTYPE, MBQUAD, MBTRI, MBVERTEX, moab::Interface::tag_get_data(), moab::Interface::type_from_handle(), and moab::CN::VerticesPerEntity().
Referenced by get_element_type().
    // branch based on what kind of entity we're looking at
    EntityType handle_type = mdbImpl->type_from_handle( entity );
    if( handle_type == MBENTITYSET )
        // it's a meshset - assume it's a block (check this?) and work off the midnodes tag
        // get the element type of the block; first, get the hasMidNodes tag, then convert to an exo
        // element type
        int has_mid_nodes[4];
        int dimension = -1;
        if( mdbImpl->tag_get_data( mid_nodes_tag, &entity, 1, has_mid_nodes ) != MB_SUCCESS )
            // no mid nodes tag - look for indiv entity type, and if it was input, output the
            // default number of vertices
            if( MBMAXTYPE != indiv_entity_type )
                // get dimension
                if( indiv_entity_type == MBQUAD || indiv_entity_type == MBTRI )
                    dimension = 3;  // want to ouput shells by default
                else if( indiv_entity_type == MBEDGE )
                    dimension = 2;
                else
                    dimension = CN::Dimension( indiv_entity_type );
                return get_element_type_from_num_verts( CN::VerticesPerEntity( indiv_entity_type ), indiv_entity_type,
                                                        dimension );
            else
        else
            // block meshset had midnodes tag - look for geometric dimension one too
            mdbImpl->tag_get_data( geom_dimension_tag, &entity, 1, &dimension );
            if( ( indiv_entity_type == MBMAXTYPE || indiv_entity_type == ExoIIElementMBEntity[i] ) &&
                has_mid_nodes[0] == HasMidNodes[i][0] && has_mid_nodes[1] == HasMidNodes[i][1] &&
                has_mid_nodes[2] == HasMidNodes[i][2] && has_mid_nodes[3] == HasMidNodes[i][3] &&
                ( -1 == dimension || ElementGeometricDimension[i] == dimension ) )
    else if( handle_type == MBVERTEX )
        // only have one type of entity for vertices...
        return EXOII_SPHERE;
    else
        std::vector< EntityHandle > tmp( 31 );
        mdbImpl->get_connectivity( &entity, 1, tmp, true );
        return get_element_type_from_num_verts( tmp.size(), indiv_entity_type );
        // it's a regular entity - look for a connectivity tag
    // if we've gotten here, we failed
    // return EXOII_MAX_ELEM_TYPE;
Member Data Documentation
Initial value:
    3,
    3,
    2, 2,
    2,
    3, 3,
    3,
    3, 3,
    3,
    3, 3, 3, 3,
    3,
    2, 2, 2, 2,
    2,
    3, 3, 3, 3,
    3,
    3, 3, 3, 3,
    3,
    3, 3, 3, 3, 3,
    3,
    3,
    3,
    3, 3, 3, 3,
    3,
    3,
    2,
    3,
    0
Definition at line 117 of file ExoIIUtil.hpp.
Referenced by geometric_dimension(), get_element_type_from_num_verts(), and static_get_element_type().
const char * moab::ExoIIUtil::ElementTypeNames [static]
Initial value:
 { "SPHERE",
                                              "SPRING",
                                              "BAR",
                                              "BAR2",
                                              "BAR3",
                                              "BEAM",
                                              "BEAM2",
                                              "BEAM3",
                                              "TRUSS",
                                              "TRUSS2",
                                              "TRUSS3",
                                              "TRI",
                                              "TRI3",
                                              "SHELL3",
                                              "TRI6",     "TRI7",     "QUAD",      "QUAD4",     "QUAD5",     "QUAD8",
                                              "QUAD9",    "SHELL",    "SHELL4",    "SHELL5",    "SHELL8",    "SHELL9",
                                              "TETRA",    "TETRA4",   "TET4",      "TETRA8",    "TETRA10",   "TETRA14",
                                              "PYRAMID",  "PYRAMID5", "PYRAMID10", "PYRAMID13", "PYRAMID18", "WEDGE",
                                              "KNIFE",    "HEX",      "HEX8",      "HEX9",      "HEX20",     "HEX27",
                                              "HEXSHELL",
                                              "nsided",
                                              "NFACED",
                                              "UNKNOWN" }
Definition at line 107 of file ExoIIUtil.hpp.
Referenced by element_type_name(), moab::WriteNCDF::initialize_exodus_file(), and static_element_name_to_type().
const int moab::ExoIIUtil::HasMidNodes [static]
Definition at line 114 of file ExoIIUtil.hpp.
Referenced by has_mid_nodes(), and static_get_element_type().
Definition at line 36 of file ExoIIUtil.hpp.
List of all members.
