moab::FileOptions Class Reference
Parse options string passed to file IO routines. More...
#include <FileOptions.hpp>
+ Collaboration diagram for moab::FileOptions:
Public Member Functions
 FileOptions (const char *option_string)
 FileOptions (const FileOptions &copy)
FileOptionsoperator= (const FileOptions &copy)
 ~FileOptions ()
ErrorCode get_null_option (const char *name) const
 Check for option with no value.
ErrorCode get_toggle_option (const char *name, bool default_value, bool &value) const
 Check for option with boolean (true/false, yes/no) value.
ErrorCode get_int_option (const char *name, int &value) const
 Check for option with an integer value.
ErrorCode get_int_option (const char *name, int default_val, int &value) const
 Check for option with an integer value. Accept option with no value.
ErrorCode get_real_option (const char *name, double &value) const
 Check for option with a double value.
ErrorCode get_str_option (const char *name, std::string &value) const
 Check for option with any value.
ErrorCode get_option (const char *name, std::string &value) const
 Check for option.
ErrorCode match_option (const char *name, const char *const *values, int &index) const
 Check the string value of an option.
ErrorCode match_option (const char *name, const char *value) const
 Check if an option matches a string value.
ErrorCode get_ints_option (const char *name, std::vector< int > &values) const
 Check for option for which the value is a list of ints.
ErrorCode get_reals_option (const char *name, std::vector< double > &values) const
 Check for option for which the value is a list of doubles.
ErrorCode get_strs_option (const char *name, std::vector< std::string > &values) const
 Check for option for which the value is a list of strings.
unsigned size () const
bool empty () const
void get_options (std::vector< std::string > &list) const
bool all_seen () const
void mark_all_seen () const
ErrorCode get_unseen_option (std::string &value) const
Private Member Functions
ErrorCode get_option (const char *name, const char *&value) const
 Check for option.
Static Private Member Functions
static bool compare (const char *name, const char *option)
Private Attributes
char * mData
std::vector< const char * > mOptions
std::vector< bool > mSeen
Detailed Description
This is a utility class used by file-IO-related code to parse the options string passed to Core::load_file and Core::write_file
Examples:
VisTags.cpp.
Definition at line 37 of file FileOptions.hpp.
moab::FileOptions::FileOptions ( const char *  option_string)
Definition at line 38 of file FileOptions.cpp.
References moab::DEFAULT_SEPARATOR, mData, mOptions, mSeen, and moab::strempty().
                                          : mData( 0 )
    // if option string is null, just return
    if( !str ) return;
    // check if alternate separator is specified
    char separator[2] = { DEFAULT_SEPARATOR, '\0' };
    if( *str == DEFAULT_SEPARATOR )
        ++str;
        if( strempty( str ) ) return;
        separator[0] = *str;
        ++str;
    // don't bother allocating copy of input string if
    // input string is empty.
    if( !strempty( str ) )
        // tokenize at separator character
        mData = strdup( str );
        for( char* i = strtok( mData, separator ); i; i = strtok( 0, separator ) )
            if( !strempty( i ) )  // skip empty strings
                mOptions.push_back( i );
    mSeen.resize( mOptions.size(), false );
Definition at line 67 of file FileOptions.cpp.
References mData, mOptions, and mSeen.
                                                  : mData( 0 ), mOptions( copy.mOptions.size() )
    if( !copy.mOptions.empty() )
        const char* last   = copy.mOptions.back();
        const char* endptr = last + strlen( last ) + 1;
        size_t len         = endptr - copy.mData;
        mData              = (char*)malloc( len );
        memcpy( mData, copy.mData, len );
        for( size_t i = 0; i < mOptions.size(); ++i )
            mOptions[i] = mData + ( copy.mOptions[i] - copy.mData );
    mSeen = copy.mSeen;
Definition at line 106 of file FileOptions.cpp.
References mData.
    free( mData );
Member Function Documentation
Check if all options have been looked at
Definition at line 377 of file FileOptions.cpp.
References mSeen.
Referenced by moab::AdaptiveKDTree::build_tree(), moab::BVHTree::build_tree(), and moab::Core::load_file().
    return std::find( mSeen.begin(), mSeen.end(), false ) == mSeen.end();
bool moab::FileOptions::compare ( const char *  name,
const char *  option
) [static, private]
Case-insensitive compare of name with option value.
Definition at line 357 of file FileOptions.cpp.
References moab::strempty().
Referenced by get_option(), and match_option().
    while( !strempty( name ) && toupper( *name ) == toupper( *option ) )
        ++name;
        ++option;
    // match if name matched option for length of name,
    // and option either matched entirely or matches up to
    // and equals sign.
    return strempty( name ) && ( strempty( option ) || *option == '=' );
bool moab::FileOptions::empty ( ) const [inline]
true if no options
Definition at line 212 of file FileOptions.hpp.
        return mOptions.empty();
ErrorCode moab::FileOptions::get_int_option ( const char *  name,
int &  value
) const
Check for an option with an integer value
Parameters:
nameThe option name
valueOutput. The value.
Returns:
- MB_SUCCESS if option is found
  • MB_TYPE_OUT_OF_RANGE if options is found, but does not have an integer value
  • MB_ENTITY_NOT_FOUND if option is not found.
Definition at line 119 of file FileOptions.cpp.
References ErrorCode, get_option(), MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, and moab::strempty().
Referenced by moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::ReadParallel::load_file(), moab::ReadMCNP5::load_file(), moab::Core::load_file(), moab::Tqdcfr::load_file(), moab::WriteHDF5Parallel::parallel_create_file(), moab::Tree::parse_common_options(), moab::BVHTree::parse_options(), moab::AdaptiveKDTree::parse_options(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), moab::ReadCGM::set_options(), moab::ReadHDF5::set_up_read(), moab::WriteSmf::write_file(), moab::WriteVtk::write_file(), moab::WriteGmsh::write_file(), moab::WriteSTL::write_file(), and moab::WriteHDF5::write_file().
    const char* s;
    ErrorCode rval = get_option( name, s );
    if( MB_SUCCESS != rval ) return rval;
    // empty string
    if( strempty( s ) ) return MB_TYPE_OUT_OF_RANGE;
    // parse value
    char* endptr;
    long int pval = strtol( s, &endptr, 0 );
    if( !strempty( endptr ) )  // syntax error
    // check for overflow (parsing long int, returning int)
    value = pval;
    if( pval != (long int)value ) return MB_TYPE_OUT_OF_RANGE;
    return MB_SUCCESS;
int  default_val,
int &  value
) const
Check for an option with an integer value. If the option is found but has no value specified, then pass back the user-specified default value.
: This function will not pass back the default_val, but will instead return MB_ENTITY_NOT_FOUND if the option is not specified at all. The default value is returned only when the option is specified, but is specified w/out a value.
Parameters:
nameThe option name
default_valThe default value for the option.
Returns:
  • MB_TYPE_OUT_OF_RANGE if options is found but has a value that cannot be parsed as an int
Definition at line 141 of file FileOptions.cpp.
    const char* s;
    // empty string
    if( strempty( s ) )
        value = default_val;
        return MB_SUCCESS;
    // parse value
    char* endptr;
    value = pval;
    return MB_SUCCESS;
ErrorCode moab::FileOptions::get_ints_option ( const char *  name,
std::vector< int > &  values
) const
Check for an option which is an int list. The value is expected to be a comma-separated list of int ranges, where an int range can be either a single integer value or a range of integer values separated by a dash ('-').
Parameters:
nameThe option name
valuesOutput. The list of integer values.
Returns:
  • MB_TYPE_OUT_OF_RANGE if options is found, but does not contain an ID list
Definition at line 167 of file FileOptions.cpp.
References EATSPACE, ErrorCode, get_option(), MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, and moab::strempty().
Referenced by moab::ReadParallel::load_file(), moab::ReadNC::parse_options(), and moab::WriteNC::parse_options().
    const char* s;
    // empty string
    // parse values
    while( !strempty( s ) )
        char* endptr;
        long int sval = strtol( s, &endptr, 0 );
#define EATSPACE( a )                                             \
    while( ( *( a ) == ' ' || *( a ) == ',' ) && !strempty( a ) ) \
        ( a )++;
        EATSPACE( endptr );
        long int eval = sval;
        if( *endptr == '-' )
            endptr++;
            s    = endptr;
            eval = strtol( s, &endptr, 0 );
            EATSPACE( endptr );
        int value = sval;
        if( sval != (long int)value ) return MB_TYPE_OUT_OF_RANGE;
        value = eval;
        if( eval != (long int)value ) return MB_TYPE_OUT_OF_RANGE;
        for( int i = sval; i <= eval; i++ )
            values.push_back( i );
        s = endptr;
    return MB_SUCCESS;
ErrorCode moab::FileOptions::get_null_option ( const char *  name) const
Check for an option w/out a value.
Parameters:
nameThe option name
Returns:
  • MB_TYPE_OUT_OF_RANGE if options is found, but has value
Definition at line 111 of file FileOptions.cpp.
Referenced by moab::ReadParallel::load_file(), moab::ReadHDF5::load_file(), moab::ReadSTL::load_file(), moab::Tqdcfr::load_file(), moab::ReadMCNP5::load_one_file(), moab::WriteHDF5Parallel::parallel_create_file(), moab::ReadDamsel::parse_options(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), moab::ReadCGM::set_options(), moab::ReadHDF5::set_up_read(), moab::WriteVtk::write_file(), moab::WriteSTL::write_file(), moab::WriteHDF5::write_file(), moab::WriteNCDF::write_file(), and moab::WriteHDF5::write_file_impl().
    const char* s;
    return strempty( s ) ? MB_SUCCESS : MB_TYPE_OUT_OF_RANGE;
ErrorCode moab::FileOptions::get_option ( const char *  name,
std::string &  value
) const
Check for option.
Check for an option
Parameters:
nameThe option name
valueThe option value, or an empty string if no value.
Returns:
MB_SUCCESS or MB_ENTITY_NOT_FOUND
Definition at line 282 of file FileOptions.cpp.
References ErrorCode, and MB_SUCCESS.
Referenced by get_int_option(), get_ints_option(), get_null_option(), get_real_option(), get_reals_option(), get_str_option(), get_strs_option(), moab::ReadParallel::load_file(), moab::ReadVtk::load_file(), moab::ReadSmf::load_file(), moab::Core::load_file(), moab::ReadHDF5::load_file_partial(), match_option(), and moab::ReadTetGen::open_file().
    const char* s;
    value = s;
    return MB_SUCCESS;
const char *&  value
) const [private]
Check for option.
Check for an option
Parameters:
nameThe option name
Returns:
Definition at line 292 of file FileOptions.cpp.
References compare(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, mOptions, and mSeen.
    std::vector< const char* >::const_iterator i;
    for( i = mOptions.begin(); i != mOptions.end(); ++i )
        const char* opt = *i;
        if( compare( name, opt ) )
            value = opt + strlen( name );
            // if compare returned true, next char after option
            // name must be either the null char or an equals symbol.
            if( *value == '=' ) ++value;
            mSeen[i - mOptions.begin()] = true;
            return MB_SUCCESS;
    return MB_ENTITY_NOT_FOUND;
void moab::FileOptions::get_options ( std::vector< std::string > &  list) const
Get list of options
Definition at line 370 of file FileOptions.cpp.
References mOptions.
    list.clear();
    list.resize( mOptions.size() );
    std::copy( mOptions.begin(), mOptions.end(), list.begin() );
ErrorCode moab::FileOptions::get_real_option ( const char *  name,
double &  value
) const
Check for an option with a double value
Parameters:
nameThe option name
Returns:
  • MB_TYPE_OUT_OF_RANGE if options is found, but does not have a double value
Definition at line 234 of file FileOptions.cpp.
Referenced by moab::ReadParallel::load_file(), moab::Tree::parse_common_options(), moab::AdaptiveKDTree::parse_options(), and moab::ReadCGM::set_options().
    const char* s;
    // empty string
    // parse value
    char* endptr;
    value = strtod( s, &endptr );
    return MB_SUCCESS;
ErrorCode moab::FileOptions::get_reals_option ( const char *  name,
std::vector< double > &  values
) const
Check for an option which is a double list. The value is expected to be a comma-separated list of double values
Parameters:
nameThe option name
valuesOutput. The list of double values.
Returns:
Definition at line 210 of file FileOptions.cpp.
Referenced by moab::ReadNC::parse_options(), and moab::WriteNC::parse_options().
    const char* s;
    // empty string
    // parse values
        char* endptr;
        double sval = strtod( s, &endptr );
        EATSPACE( endptr );
        values.push_back( sval );
        s = endptr;
    return MB_SUCCESS;
ErrorCode moab::FileOptions::get_str_option ( const char *  name,
std::string &  value
) const
Check for an option with any value.
Parameters:
nameThe option name
Returns:
  • MB_TYPE_OUT_OF_RANGE if options is found, but does not have a value
Definition at line 272 of file FileOptions.cpp.
Referenced by moab::NCHelperHOMME::create_mesh(), moab::ReadParallel::load_file(), moab::ReadTetGen::load_file(), moab::ReadNCDF::load_file(), moab::Tqdcfr::load_file(), moab::WriteHDF5Parallel::parallel_create_file(), moab::Tree::parse_common_options(), moab::ReadHDF5::set_up_read(), and moab::ReadNCDF::update().
    const char* s;
    value = s;
    return MB_SUCCESS;
ErrorCode moab::FileOptions::get_strs_option ( const char *  name,
std::vector< std::string > &  values
) const
Check for an option which is a string list. The value is expected to be a comma-separated list of string values, with no embedded spaces or commas.
Parameters:
nameThe option name
valuesOutput. The list of string values.
Returns:
  • MB_TYPE_OUT_OF_RANGE if options is found, but does not contain a string list
Examples:
VisTags.cpp.
Definition at line 252 of file FileOptions.cpp.
Referenced by main(), moab::ReadNC::parse_options(), and moab::WriteNC::parse_options().
    const char* s;
    // empty string
    // parse values
    char separator[3] = { ' ', ',', '\0' };
    char* tmp_str     = strdup( s );
    for( char* i = strtok( tmp_str, separator ); i; i = strtok( 0, separator ) )
            values.push_back( std::string( i ) );
    free( tmp_str );
    return MB_SUCCESS;
ErrorCode moab::FileOptions::get_toggle_option ( const char *  name,
bool  default_value,
bool &  value
) const
Check for an option with a true/false value. Allowable values are "true", "false", "yes", "no", "1", "0", "on", "off".
Parameters:
nameThe option name
default_valueThe value to return if the option is not specified.
valueThe resulting value. This argument is set to the passed default value if the option is not found.
Returns:
- MB_TYPE_OUT_OF_RANGE if options is found, but has an invalid value
  • MB_SUCCESS otherwise
Definition at line 333 of file FileOptions.cpp.
References ErrorCode, match_option(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, and MB_TYPE_OUT_OF_RANGE.
Referenced by moab::Tree::parse_common_options(), moab::AdaptiveKDTree::parse_options(), and moab::ReadHDF5::set_up_read().
    static const char* values[] = { "true", "yes", "1", "on", "false", "no", "0", "off", 0 };
    const int num_true          = 4;
    int index;
    ErrorCode result = match_option( name, values, index );
    if( result == MB_SUCCESS )
        value = index < num_true;
    else if( result == MB_ENTITY_NOT_FOUND )
        value  = default_value;
        result = MB_SUCCESS;
    else
        result = MB_TYPE_OUT_OF_RANGE;
    return result;
ErrorCode moab::FileOptions::get_unseen_option ( std::string &  value) const
Get first unseen option
Definition at line 388 of file FileOptions.cpp.
References MB_ENTITY_NOT_FOUND, MB_SUCCESS, mOptions, and mSeen.
Referenced by moab::Core::load_file().
    std::vector< bool >::iterator i = std::find( mSeen.begin(), mSeen.end(), false );
    if( i == mSeen.end() )
        name.clear();
    const char* opt = mOptions[i - mSeen.begin()];
    const char* end = strchr( opt, '=' );
    name            = end ? std::string( opt, end - opt ) : std::string( opt );
    return MB_SUCCESS;
Mark all options as seen. USed for non-root procs during bcast-delete read
Definition at line 382 of file FileOptions.cpp.
References mOptions, and mSeen.
Referenced by moab::ReadParallel::load_file(), moab::ReadCGNS::process_options(), and moab::ReadTemplate::process_options().
    mSeen.clear();
    mSeen.resize( mOptions.size(), true );
ErrorCode moab::FileOptions::match_option ( const char *  name,
const char *const *  values,
int &  index
) const
Check which of a list of possible values a string option contains.
Parameters:
nameThe option name
valuesA NULL-terminated array of C-style strings enumerating the possible option values.
indexOutput: The index into values for the option value.
Returns:
MB_SUCCESS if matched name and value. MB_ENTITY_NOT_FOUND if the option was not specified MB_FAILURE if the option value is not in the input values array.
Definition at line 320 of file FileOptions.cpp.
References compare(), ErrorCode, get_option(), and MB_SUCCESS.
Referenced by get_toggle_option(), moab::ReadParallel::load_file(), moab::ReadHDF5::load_file_partial(), match_option(), moab::ReadDamsel::parse_options(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), moab::ReadCGM::set_options(), moab::ReadHDF5::set_up_read(), and moab::WriteHDF5::write_file_impl().
    const char* optval;
    ErrorCode rval = get_option( name, optval );
    for( index = 0; values[index]; ++index )
        if( compare( optval, values[index] ) ) return MB_SUCCESS;
    index = -1;
    return MB_FAILURE;
const char *  value
) const
Check if the value for an option is the passed string.
Parameters:
nameThe option name
valueThe expected value.
Returns:
MB_SUCCESS if matched name and value. MB_ENTITY_NOT_FOUND if the option was not specified MB_FAILURE if the option value doesn't match the passed string/
Definition at line 313 of file FileOptions.cpp.
References match_option().
    int idx;
    const char* array[] = { value, NULL };
    return match_option( name, array, idx );
FileOptions & moab::FileOptions::operator= ( const FileOptions copy)
Definition at line 82 of file FileOptions.cpp.
    // Check for self-assignment
    if( this == &copy ) return *this;
    free( mData );
    mData = 0;
    mOptions.resize( copy.mOptions.size() );
    mSeen = copy.mSeen;
    return *this;
unsigned moab::FileOptions::size ( ) const [inline]
number of options
Definition at line 206 of file FileOptions.hpp.
        return mOptions.size();
Member Data Documentation
char* moab::FileOptions::mData [private]
Definition at line 239 of file FileOptions.hpp.
Referenced by FileOptions(), operator=(), and ~FileOptions().
std::vector< const char* > moab::FileOptions::mOptions [private]
std::vector< bool > moab::FileOptions::mSeen [mutable, private]
List of all members.
