moab::GQT_IntRegCtxt Member List
This is the complete list of members for moab::GQT_IntRegCtxt, including all inherited members.
add_intersection(EntityHandle set, EntityHandle tri, double dist, OrientedBoxTreeTool::IntersectSearchWindow &search_win)moab::GQT_IntRegCtxt [private]
add_mode1_intersection(EntityHandle set, EntityHandle facet, double dist, OrientedBoxTreeTool::IntersectSearchWindow &search_win)moab::GQT_IntRegCtxt [private]
append_intersection(EntityHandle set, EntityHandle facet, double dist)moab::GQT_IntRegCtxt [private]
desiredOrientmoab::GQT_IntRegCtxt [private]
edge_node_piercing_intersect(const EntityHandle tri, const CartVect &ray_direction, const GeomUtil::intersection_type int_type, const std::vector< EntityHandle > &close_tris, const std::vector< int > &close_senses, const Interface *MBI, std::vector< EntityHandle > *neighborhood_tris=0)moab::GQT_IntRegCtxt [private]
facetsmoab::OrientedBoxTreeTool::IntRegCtxt [protected]
geomVolmoab::GQT_IntRegCtxt [private]
get_facets()moab::OrientedBoxTreeTool::IntRegCtxt [inline]
get_intersections()moab::OrientedBoxTreeTool::IntRegCtxt [inline]
get_sets()moab::OrientedBoxTreeTool::IntRegCtxt [inline]
getDesiredOrient()moab::GQT_IntRegCtxt [inline, virtual]
GQT_IntRegCtxt(OrientedBoxTreeTool *obbtool, const double ray_point[3], const double ray_dir[3], double tolerance, int min_tolerance_intersections, const EntityHandle *root_set, const EntityHandle *geom_volume, const Tag *sense_tag, const int *desired_orient, const std::vector< EntityHandle > *prev_facets)moab::GQT_IntRegCtxt [inline]
in_neighborhoods(const EntityHandle tri)moab::GQT_IntRegCtxt [private]
in_prevFacets(const EntityHandle tri)moab::GQT_IntRegCtxt [private]
intersectionsmoab::OrientedBoxTreeTool::IntRegCtxt [protected]
minTolIntmoab::GQT_IntRegCtxt [private]
neighborhoodmoab::GQT_IntRegCtxt [private]
neighborhoodsmoab::GQT_IntRegCtxt [private]
prevFacetsmoab::GQT_IntRegCtxt [private]
ray_directionmoab::GQT_IntRegCtxt [private]
ray_originmoab::GQT_IntRegCtxt [private]
register_intersection(EntityHandle set, EntityHandle triangle, double distance, OrientedBoxTreeTool::IntersectSearchWindow &, GeomUtil::intersection_type int_type)moab::GQT_IntRegCtxt [virtual]
rootSetmoab::GQT_IntRegCtxt [private]
senseTagmoab::GQT_IntRegCtxt [private]
set_intersection(int len_idx, EntityHandle set, EntityHandle facet, double dist)moab::GQT_IntRegCtxt [private]
setsmoab::OrientedBoxTreeTool::IntRegCtxt [protected]
tolmoab::GQT_IntRegCtxt [private]
toolmoab::GQT_IntRegCtxt [private]
update_orient(EntityHandle set, int *surfTriOrient)moab::GQT_IntRegCtxt [virtual]
