moab::GeomQueryTool::RayHistory Class Reference
#include <GeomQueryTool.hpp>
+ Collaboration diagram for moab::GeomQueryTool::RayHistory:
Public Member Functions
void reset ()
void reset_to_last_intersection ()
void rollback_last_intersection ()
ErrorCode get_last_intersection (EntityHandle &last_facet_hit) const
int size () const
bool in_history (EntityHandle ent) const
void add_entity (EntityHandle ent)
Private Attributes
std::vector< EntityHandleprev_facets
Friends
class GeomQueryTool
Detailed Description
Definition at line 61 of file GeomQueryTool.hpp.
Member Function Documentation
Add entity to the RayHistory
Definition at line 734 of file GeomQueryTool.cpp.
    prev_facets.push_back( ent );
Get the last intersection in the RayHistory. This will return a null EntityHandle (0) if the history is empty.
Definition at line 716 of file GeomQueryTool.cpp.
References MB_ENTITY_NOT_FOUND, and MB_SUCCESS.
    if( prev_facets.size() > 0 )
        last_facet_hit = prev_facets.back();
        return MB_SUCCESS;
    else
        return MB_ENTITY_NOT_FOUND;
Returns:
Boolean indicating if this entity is in the RayHistory
Definition at line 729 of file GeomQueryTool.cpp.
    return std::find( prev_facets.begin(), prev_facets.end(), ent ) != prev_facets.end();
Clear this entire history-- logically equivalent to creating a new history, but probably more efficient.
Definition at line 696 of file GeomQueryTool.cpp.
References prev_facets.
    prev_facets.clear();
Clear the history up to the most recent intersection. This should be called when a ray changes direction at the site of a surface crossing, a situation that most commonly occurs at a reflecting boundary.
Definition at line 701 of file GeomQueryTool.cpp.
    if( prev_facets.size() > 1 )
        prev_facets[0] = prev_facets.back();
        prev_facets.resize( 1 );
Remove the most recent intersection. This allows a subsequent call along the same ray to return the same intersection.
Definition at line 711 of file GeomQueryTool.cpp.
    if( prev_facets.size() ) prev_facets.pop_back();
int moab::GeomQueryTool::RayHistory::size ( ) const [inline]
Returns:
the number of surface crossings currently represented by this ray history
Definition at line 93 of file GeomQueryTool.hpp.
            return prev_facets.size();
Friends And Related Function Documentation
friend class GeomQueryTool [friend]
Definition at line 111 of file GeomQueryTool.hpp.
Member Data Documentation
List of all members.
