moab::GmshUtil Class Reference
General data about GMsh files for use by read and write code. More...
#include <GmshUtil.hpp>
+ Collaboration diagram for moab::GmshUtil:
Static Public Member Functions
static int get_gmsh_type (EntityType type, unsigned num_nodes)
 Get the Gmsh type corresponding to a tuple of the MOAB type and number of nodes. num_nodes is ignored for MBPOLYGON type. Returns -1 for unsupported types.
Static Public Attributes
static const GmshElemType gmshElemTypes []
 Gmsh types, indexed by Gmsh type number. For unused Gmsh type numbers, mb_type will be MBMAXTYPE.
static const unsigned numGmshElemType = sizeof( GmshUtil::gmshElemTypes ) / sizeof( GmshUtil::gmshElemTypes[0] )
 Length of gmshElemTypes.
Detailed Description
Author:
Jason Kraftcheck
Definition at line 43 of file GmshUtil.hpp.
Member Function Documentation
int moab::GmshUtil::get_gmsh_type ( EntityType  type,
unsigned  num_nodes
) [static]
Definition at line 102 of file GmshUtil.cpp.
References gmshElemTypes, moab::MAX_NODES, moab::mb_to_gmsh_type, moab::GmshElemType::mb_type, and MBMAXTYPE.
Referenced by moab::WriteGmsh::write_file().
    if( num_nodes >= (unsigned)MAX_NODES ) return -1;
    int idx = mb_to_gmsh_type[type][num_nodes];
    if( !idx ) return -1;
    return gmshElemTypes[idx].mb_type == MBMAXTYPE ? -1 : idx;
Member Data Documentation
Definition at line 49 of file GmshUtil.hpp.
Referenced by get_gmsh_type(), moab::ReadGmsh::load_file(), and moab::WriteGmsh::write_file().
const unsigned moab::GmshUtil::numGmshElemType = sizeof( GmshUtil::gmshElemTypes ) / sizeof( GmshUtil::gmshElemTypes[0] ) [static]
Definition at line 52 of file GmshUtil.hpp.
Referenced by moab::ReadGmsh::load_file().
List of all members.
