moab::LinearQuad Class Reference
#include <LinearQuad.hpp>
Static Public Member Functions
static ErrorCode evalFcn (const double *params, const double *field, const int ndim, const int num_tuples, double *work, double *result)
 Forward-evaluation of field at parametric coordinates.
static ErrorCode reverseEvalFcn (EvalFcn eval, JacobianFcn jacob, InsideFcn ins, const double *posn, const double *verts, const int nverts, const int ndim, const double iter_tol, const double inside_tol, double *work, double *params, int *is_inside)
 Reverse-evaluation of parametric coordinates at physical space position.
static ErrorCode normalFcn (const int ientDim, const int facet, const int nverts, const double *verts, double normal[])
 Evaluate the normal at a specified facet.
static ErrorCode jacobianFcn (const double *params, const double *verts, const int nverts, const int ndim, double *work, double *result)
 Evaluate the jacobian at a specified parametric position.
static ErrorCode integrateFcn (const double *field, const double *verts, const int nverts, const int ndim, const int num_tuples, double *work, double *result)
static int insideFcn (const double *params, const int ndim, const double tol)
 Function that returns whether or not the parameters are inside the natural space of the element.
static EvalSet eval_set ()
static bool compatible (EntityType tp, int numv, EvalSet &eset)
Static Protected Attributes
static const double corner [4][2] = { { -1, -1 }, { 1, -1 }, { 1, 1 }, { -1, 1 } }
static const double gauss [1][2] = { { 2.0, 0.0 } }
static const unsigned int corner_count = 4
static const unsigned int gauss_count = 1
Detailed Description
Definition at line 12 of file LinearQuad.hpp.
Member Function Documentation
static bool moab::LinearQuad::compatible ( EntityType  tp,
int  numv,
EvalSet eset
) [inline, static]
Definition at line 70 of file LinearQuad.hpp.
References eval_set(), and MBQUAD.
Referenced by moab::EvalSet::get_eval_set().
        if( tp == MBQUAD && numv == 4 )
            eset = eval_set();
            return true;
        else
            return false;
static EvalSet moab::LinearQuad::eval_set ( ) [inline, static]
Definition at line 65 of file LinearQuad.hpp.
Referenced by compatible().
ErrorCode moab::LinearQuad::evalFcn ( const double *  params,
const double *  field,
const int  ndim,
double *  work,
double *  result
) [static]
Definition at line 43 of file LinearQuad.cpp.
References corner, and MB_SUCCESS.
Referenced by integrateFcn().
    for( int i = 0; i < num_tuples; i++ )
        result[i] = 0.0;
    for( unsigned i = 0; i < 4; ++i )
        const double N_i = ( 1 + params[0] * corner[i][0] ) * ( 1 + params[1] * corner[i][1] );
        for( int j = 0; j < num_tuples; j++ )
            result[j] += N_i * field[i * num_tuples + j];
        result[i] *= 0.25;
    return MB_SUCCESS;
int moab::LinearQuad::insideFcn ( const double *  params,
const int  ndim,
const double  tol
) [static]
Definition at line 115 of file LinearQuad.cpp.
References moab::EvalSet::inside_function().
    return EvalSet::inside_function( params, ndim, tol );
ErrorCode moab::LinearQuad::integrateFcn ( const double *  field,
const double *  verts,
const int  nverts,
const int  ndim,
double *  work,
double *  result
) [static]
Definition at line 64 of file LinearQuad.cpp.
References moab::CartVect::array(), moab::Matrix3::determinant(), ErrorCode, evalFcn(), gauss, gauss_count, jacobianFcn(), and MB_SUCCESS.
    double tmp_result[4];
    ErrorCode rval = MB_SUCCESS;
        result[i] = 0.0;
    CartVect x;
    Matrix3 J;
    for( unsigned int j1 = 0; j1 < LinearQuad::gauss_count; ++j1 )
        x[0]      = LinearQuad::gauss[j1][1];
        double w1 = LinearQuad::gauss[j1][0];
        for( unsigned int j2 = 0; j2 < LinearQuad::gauss_count; ++j2 )
            x[1]      = LinearQuad::gauss[j2][1];
            double w2 = LinearQuad::gauss[j2][0];
            rval      = evalFcn( x.array(), field, ndim, num_tuples, NULL, tmp_result );
            if( MB_SUCCESS != rval ) return rval;
            rval = jacobianFcn( x.array(), verts, nverts, ndim, work, J[0] );
            double tmp_det = w1 * w2 * J.determinant();
                result[i] += tmp_result[i] * tmp_det;
    return MB_SUCCESS;
}  // LinearHex::integrate_vector()
ErrorCode moab::LinearQuad::jacobianFcn ( const double *  params,
const int  nverts,
const int  ndim,
double *  work,
double *  result
) [static]
Definition at line 18 of file LinearQuad.cpp.
    Matrix3* J = reinterpret_cast< Matrix3* >( result );
    *J         = Matrix3( 0.0 );
        const double xi_p     = 1 + params[0] * corner[i][0];
        const double eta_p    = 1 + params[1] * corner[i][1];
        const double dNi_dxi  = corner[i][0] * eta_p;
        const double dNi_deta = corner[i][1] * xi_p;
        ( *J )( 0, 0 ) += dNi_dxi * verts[i * 3 + 0];
        ( *J )( 1, 0 ) += dNi_dxi * verts[i * 3 + 1];
        ( *J )( 0, 1 ) += dNi_deta * verts[i * 3 + 0];
        ( *J )( 1, 1 ) += dNi_deta * verts[i * 3 + 1];
    ( *J ) *= 0.25;
    ( *J )( 2, 2 ) = 1.0; /* to make sure the Jacobian determinant is non-zero */
    return MB_SUCCESS;
}  // LinearQuad::jacobian()
ErrorCode moab::LinearQuad::normalFcn ( const int  ientDim,
const int  facet,
const int  nverts,
double  normal[]
) [static]
Definition at line 120 of file LinearQuad.cpp.
References moab::CN::ConnMap::conn, MB_SET_ERR, MB_SUCCESS, MBQUAD, and moab::CN::mConnectivityMap.
    // assert(facet <4 && ientDim == 1 && nverts==4);
    if( nverts != 4 ) MB_SET_ERR( MB_FAILURE, "Incorrect vertex count for passed quad :: expected value = 4" );
    if( ientDim != 1 ) MB_SET_ERR( MB_FAILURE, "Requesting normal for unsupported dimension :: expected value = 1 " );
    if( facet > 4 || facet < 0 ) MB_SET_ERR( MB_FAILURE, "Incorrect local edge id :: expected value = one of 0-3" );
    // Get the local vertex ids of  local edge
    int id0 = CN::mConnectivityMap[MBQUAD][ientDim - 1].conn[facet][0];
    int id1 = CN::mConnectivityMap[MBQUAD][ientDim - 1].conn[facet][1];
    // Find a vector along the edge
    double edge[3];
    for( int i = 0; i < 3; i++ )
        edge[i] = verts[3 * id1 + i] - verts[3 * id0 + i];
    // Find the normal of the face
    double x0[3], x1[3], fnrm[3];
        x0[i] = verts[3 * 1 + i] - verts[3 * 0 + i];
        x1[i] = verts[3 * 3 + i] - verts[3 * 0 + i];
    fnrm[0] = x0[1] * x1[2] - x1[1] * x0[2];
    fnrm[1] = x1[0] * x0[2] - x0[0] * x1[2];
    fnrm[2] = x0[0] * x1[1] - x1[0] * x0[1];
    // Find the normal of the edge as the cross product of edge and face normal
    double a   = edge[1] * fnrm[2] - fnrm[1] * edge[2];
    double b   = edge[2] * fnrm[0] - fnrm[2] * edge[0];
    double c   = edge[0] * fnrm[1] - fnrm[0] * edge[1];
    double nrm = sqrt( a * a + b * b + c * c );
    if( nrm > std::numeric_limits< double >::epsilon() )
        normal[0] = a / nrm;
        normal[1] = b / nrm;
        normal[2] = c / nrm;
    return MB_SUCCESS;
ErrorCode moab::LinearQuad::reverseEvalFcn ( EvalFcn  eval,
JacobianFcn  jacob,
InsideFcn  ins,
const double *  posn,
const int  nverts,
const int  ndim,
double *  work,
double *  params,
int *  is_inside
) [static]
Definition at line 98 of file LinearQuad.cpp.
References moab::EvalSet::evaluate_reverse().
    return EvalSet::evaluate_reverse( eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work, params,
                                      is_inside );
Member Data Documentation
const double moab::LinearQuad::corner = { { -1, -1 }, { 1, -1 }, { 1, 1 }, { -1, 1 } } [static, protected]
Definition at line 83 of file LinearQuad.hpp.
Referenced by evalFcn(), and jacobianFcn().
const unsigned int moab::LinearQuad::corner_count = 4 [static, protected]
Definition at line 85 of file LinearQuad.hpp.
const double moab::LinearQuad::gauss = { { 2.0, 0.0 } } [static, protected]
Definition at line 84 of file LinearQuad.hpp.
const unsigned int moab::LinearQuad::gauss_count = 1 [static, protected]
Definition at line 86 of file LinearQuad.hpp.
List of all members.
