moab::MeshSet Class Reference
Class to implement entity set functionality. More...
#include <MeshSet.hpp>
+ Collaboration diagram for moab::MeshSet:
Classes
union  CompactList
 If the number of entities is less than 3, store the handles directly in the hnd member. Otherwise use the ptr member to hold the beginning and end of a dynamically allocated array. More...
struct  dim_test
struct  hdl_iter
struct  not_dim_test
struct  not_type_test
struct  type_test
Public Types
enum  Count { ZERO = 0, ONE = 1, TWO = 2, MANY = 3 }
 Possible values of mParentCount and mChildCount. More...
Public Member Functions
 MeshSet ()
 create an empty meshset
 MeshSet (unsigned flags)
 ~MeshSet ()
 destructor
ErrorCode set_flags (unsigned flags, EntityHandle my_handle, AEntityFactory *adjacencies)
const EntityHandleget_children (int &count_out) const
 get all children pointed to by this meshset
const EntityHandleget_parents (int &count_out) const
 get all parents pointed to by this meshset
int num_children () const
 return the number of children pointed to by this meshset
int num_parents () const
 return the number of parents pointed to by this meshset
int add_parent (EntityHandle parent)
 add a parent to this meshset; returns true if parent was added, 0 if it was already a parent of this meshset
int add_child (EntityHandle child)
 add a child to this meshset; returns true if child was added, 0 if it was already a child of this meshset
int remove_parent (EntityHandle parent)
 remove a parent from this meshset; returns true if parent was removed, 0 if it was not a parent of this meshset
int remove_child (EntityHandle child)
 remove a child from this meshset; returns true if child was removed, 0 if it was not a child of this meshset
unsigned flags () const
int tracking () const
 returns whether entities of meshsets know this meshset
int set () const
int ordered () const
int vector_based () const
ErrorCode replace_entities (EntityHandle my_handle, const EntityHandle *old_entities, const EntityHandle *new_entities, size_t num_entities, AEntityFactory *mAdjFact)
 replace one entity with another in the set (contents and parent/child lists); returns whether it was replaced or not
ErrorCode clear (EntityHandle myhandle, AEntityFactory *adjacencies)
ErrorCode clear_all (EntityHandle myhandle, AEntityFactory *adjacencies)
const EntityHandleget_contents (size_t &count_out) const
ErrorCode get_entities (std::vector< EntityHandle > &entities) const
ErrorCode get_entities (Range &entities) const
ErrorCode get_entities_by_type (EntityType entity_type, std::vector< EntityHandle > &entity_list) const
 get all entities in this MeshSet with the specified type
ErrorCode get_entities_by_type (EntityType type, Range &entity_list) const
unsigned int num_entities_by_type (EntityType type) const
 return the number of entities with the given type contained in this meshset
ErrorCode get_entities_by_dimension (int dimension, std::vector< EntityHandle > &entity_list) const
ErrorCode get_entities_by_dimension (int dimension, Range &entity_list) const
unsigned int num_entities_by_dimension (int dimension) const
ErrorCode get_non_set_entities (Range &range) const
bool contains_entities (const EntityHandle *entities, int num_entities, const int op) const
ErrorCode subtract (const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies)
 subtract/intersect/unite meshset_2 from/with/into meshset_1; modifies meshset_1
ErrorCode intersect (const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode unite (const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode add_entities (const EntityHandle *entity_handles, const int num_entities, EntityHandle my_handle, AEntityFactory *adjacencies)
 add these entities to this meshset
ErrorCode add_entities (const Range &entities, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode remove_entities (const Range &entities, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode remove_entities (const EntityHandle *entities, const int num_entities, EntityHandle my_handle, AEntityFactory *adjacencies)
 remove these entities from this meshset
unsigned int num_entities () const
 return the number of entities contained in this meshset
bool empty () const
unsigned long get_memory_use () const
Static Public Member Functions
static int DIM_FROM_HANDLE (EntityHandle h)
static EntityHandle FIRST_OF_DIM (int dim)
static EntityHandle LAST_OF_DIM (int dim)
Protected Member Functions
ErrorCode convert (unsigned flags, EntityHandle my_handle, AEntityFactory *adj)
ErrorCode create_adjacencies (EntityHandle myhandle, AEntityFactory *adjacencies)
ErrorCode remove_adjacencies (EntityHandle myhandle, AEntityFactory *adjacencies)
ErrorCode insert_entity_vector (const EntityHandle *vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode insert_entity_ranges (const EntityHandle *range_vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode insert_entity_ranges (const Range &range, EntityHandle my_h, AEntityFactory *adj)
ErrorCode remove_entity_vector (const EntityHandle *vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode remove_entity_ranges (const EntityHandle *range_vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode remove_entity_ranges (const Range &range, EntityHandle my_h, AEntityFactory *adj)
Private Attributes
unsigned char mFlags
 Meshset propery flags.
unsigned mParentCount: 2
 If less than MANY, the number of parents stored inline in parentMeshSets.hnd. If MANY, then parentMeshSets.ptr contains array begin and end pointers for a dynamically allocated array of parent handles.
unsigned mChildCount: 2
 If less than MANY, the number of children stored inline in childMeshSets.hnd. If MANY, then childMeshSets.ptr contains array begin and end pointers for a dynamically allocated array of child handles.
unsigned mContentCount: 2
 If less than MANY, the number of children stored inline in contentList.hnd. If MANY, then contentList.ptr contains array begin and end pointers for a dynamically allocated array..
CompactList parentMeshSets
 Storage for data lists.
CompactList childMeshSets
CompactList contentList
Detailed Description
Author:
Jason Kraftcheck <[email protected]>
Definition at line 26 of file MeshSet.hpp.
Member Enumeration Documentation
Enumerator:
ZERO
ONE
TWO
MANY
Definition at line 211 of file MeshSet.hpp.
        ZERO = 0,
        ONE  = 1,
        TWO  = 2,
        MANY = 3
moab::MeshSet::MeshSet ( ) [inline]
Definition at line 393 of file MeshSet.hpp.
moab::MeshSet::MeshSet ( unsigned  flags) [inline]
Definition at line 396 of file MeshSet.hpp.
    : mFlags( (unsigned char)flg ), mParentCount( ZERO ), mChildCount( ZERO ), mContentCount( ZERO )
Member Function Documentation
Definition at line 244 of file MeshSet.cpp.
References childMeshSets, moab::insert_in_vector(), and mChildCount.
Referenced by moab::Core::add_child_meshset(), moab::Core::add_child_meshsets(), and moab::Core::add_parent_child().
    int result  = 0;
    mChildCount = insert_in_vector( (Count)mChildCount, childMeshSets, child, result );
    return result;
ErrorCode moab::MeshSet::add_entities ( const EntityHandle entity_handles,
AEntityFactory adjacencies
) [inline]
Definition at line 858 of file MeshSet.hpp.
References insert_entity_vector().
Referenced by replace_entities().
    return insert_entity_vector( entity_handles, num_ents, my_handle, adjacencies );
ErrorCode moab::MeshSet::add_entities ( const Range entities,
) [inline]
Definition at line 867 of file MeshSet.hpp.
References insert_entity_ranges().
    return insert_entity_ranges( entities, my_handle, adjacencies );
Definition at line 238 of file MeshSet.cpp.
References moab::insert_in_vector(), mParentCount, and parentMeshSets.
Referenced by moab::Core::add_parent_child(), moab::Core::add_parent_meshset(), and moab::Core::add_parent_meshsets().
    int result   = 0;
    mParentCount = insert_in_vector( (Count)mParentCount, parentMeshSets, parent, result );
    return result;
ErrorCode moab::MeshSet::clear ( EntityHandle  myhandle,
) [inline]
Clear *contents* of set (not parents or children)
Definition at line 459 of file MeshSet.hpp.
References contentList, MANY, MB_SUCCESS, mContentCount, moab::MeshSet::CompactList::ptr, remove_adjacencies(), tracking(), and ZERO.
Referenced by clear_all(), and intersect().
    if( tracking() ) remove_adjacencies( myhandle, adjacencies );
    if( mContentCount == MANY ) free( contentList.ptr[0] );
    mContentCount = ZERO;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::clear_all ( EntityHandle  myhandle,
) [inline]
Clear all set lists (contents, parents, and children)
Definition at line 467 of file MeshSet.hpp.
References childMeshSets, clear(), ErrorCode, MANY, mChildCount, mParentCount, parentMeshSets, moab::MeshSet::CompactList::ptr, and ZERO.
    ErrorCode rval = clear( myhandle, adjacencies );
    if( mChildCount == MANY ) free( childMeshSets.ptr[0] );
    mChildCount = ZERO;
    if( mParentCount == MANY ) free( parentMeshSets.ptr[0] );
    mParentCount = ZERO;
    return rval;
bool moab::MeshSet::contains_entities ( const EntityHandle entities,
int  num_entities,
const int  op
) const [inline]
Test of meshset contains some or all of passed entities
Parameters:
entitiesArray of entities
num_entitiesLength of array of entities.
op- Interface::UNION : Test if set contains any of the input entities
Definition at line 812 of file MeshSet.hpp.
References get_contents(), moab::Interface::INTERSECT, and vector_based().
    size_t count;
    const EntityHandle* const ptr = get_contents( count );
    const EntityHandle* const end = ptr + count;
    size_t found_count            = 0;
    if( vector_based() )
        for( int i = 0; i < num_ents; ++i )
            if( std::find( ptr, end, entities[i] ) < end ) ++found_count;
    else
        assert( 0 == count % 2 );
            const unsigned long idx = std::lower_bound( ptr, end, entities[i] ) - ptr;
            if( idx < count && ( idx % 2 != 0 || ptr[idx] == entities[i] ) ) ++found_count;
    return found_count >= ( ( Interface::INTERSECT == op ) ? (unsigned)num_ents : 1u );
ErrorCode moab::MeshSet::convert ( unsigned  flags,
AEntityFactory adj
) [protected]
Convert for changing flag values
Definition at line 268 of file MeshSet.cpp.
References contentList, moab::convert_to_ranges(), create_adjacencies(), ErrorCode, get_contents(), MB_SUCCESS, mContentCount, MESHSET_TRACK_OWNER, mFlags, num_entities(), remove_adjacencies(), and moab::resize_compact_list().
Referenced by set_flags().
    ErrorCode rval = MB_SUCCESS;
    if( ( mFlags & MESHSET_TRACK_OWNER ) && !( flg & MESHSET_TRACK_OWNER ) )
        rval = remove_adjacencies( my_handle, adj );
    else if( !( mFlags & MESHSET_TRACK_OWNER ) && ( flg & MESHSET_TRACK_OWNER ) )
        rval = create_adjacencies( my_handle, adj );
    if( MB_SUCCESS != rval ) return rval;
    if( !( mFlags & MESHSET_ORDERED ) && ( flg & MESHSET_ORDERED ) )
        size_t datalen;
        EntityHandle* data = get_contents( datalen );
        if( datalen )
            std::vector< EntityHandle > list( datalen );
            memcpy( &list[0], data, datalen * sizeof( EntityHandle ) );
            int num_ents  = num_entities();
            Count count   = (Count)mContentCount;
            data          = resize_compact_list( count, contentList, num_ents );
            mContentCount = count;
            assert( list.size() % 2 == 0 );
            std::vector< EntityHandle >::iterator i = list.begin();
            while( i != list.end() )
                EntityHandle h = *i;
                ++i;
                EntityHandle e = *i;
                ++i;
                for( ; h <= e; ++h )
                    *data = h;
                    ++data;
    else if( ( mFlags & MESHSET_ORDERED ) && !( flg & MESHSET_ORDERED ) )
        size_t datalen;
        if( datalen )
            std::vector< EntityHandle > ranges;
            convert_to_ranges( data, datalen, ranges );
            data          = resize_compact_list( count, contentList, ranges.size() );
            memcpy( data, &ranges[0], ranges.size() * sizeof( EntityHandle ) );
    return MB_SUCCESS;
ErrorCode moab::MeshSet::create_adjacencies ( EntityHandle  myhandle,
) [protected]
Add explicit adjacencies from all contained entities to this (i.e. convert to tracking)
Definition at line 323 of file MeshSet.cpp.
References moab::AEntityFactory::add_adjacency(), ErrorCode, get_contents(), MB_SUCCESS, moab::AEntityFactory::remove_adjacency(), and vector_based().
Referenced by convert().
    size_t count;
        for( const EntityHandle* i = ptr; i != end; ++i )
            rval = adj->add_adjacency( *i, my_handle, false );
                for( const EntityHandle* j = ptr; j != i; ++j )
                    adj->remove_adjacency( *j, my_handle );
                return rval;
    else
        for( const EntityHandle* i = ptr; i != end; i += 2 )
            for( EntityHandle h = i[0]; h <= i[1]; ++h )
                rval = adj->add_adjacency( h, my_handle, false );
                    for( EntityHandle j = i[0]; j < h; ++j )
                        adj->remove_adjacency( j, my_handle );
                    for( const EntityHandle* j = ptr; j != i; j += 2 )
                        for( EntityHandle k = j[0]; k <= j[1]; ++k )
                            adj->remove_adjacency( k, my_handle );
                    return rval;
    return MB_SUCCESS;
bool moab::MeshSet::empty ( ) const [inline]
Definition at line 167 of file MeshSet.hpp.
References mContentCount, and ZERO.
        return mContentCount == ZERO;
static EntityHandle moab::MeshSet::FIRST_OF_DIM ( int  dim) [inline, static]
Get smallest possible handle with specified dimension (first handle for first type of dimension)
Definition at line 257 of file MeshSet.hpp.
References moab::GeomUtil::first(), moab::FIRST_HANDLE(), and moab::CN::TypeDimensionMap.
Referenced by get_entities_by_dimension(), and num_entities_by_dimension().
unsigned moab::MeshSet::flags ( ) const [inline]
Definition at line 66 of file MeshSet.hpp.
References mFlags.
        return mFlags;
const EntityHandle * moab::MeshSet::get_children ( int &  count_out) const [inline]
Definition at line 422 of file MeshSet.hpp.
References childMeshSets, moab::MeshSet::CompactList::hnd, MANY, mChildCount, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::get_children(), and moab::MeshSetSequence::get_parent_child_meshsets().
    count_out = mChildCount;
    if( count_out < MANY ) return childMeshSets.hnd;
    count_out = childMeshSets.ptr[1] - childMeshSets.ptr[0];
    return childMeshSets.ptr[0];
EntityHandle * moab::MeshSet::get_contents ( size_t &  count_out) [inline]
Get contents data array. NOTE: this may not contain what you expect if not vector_based
Definition at line 491 of file MeshSet.hpp.
References contentList, moab::MeshSet::CompactList::hnd, MANY, mContentCount, and moab::MeshSet::CompactList::ptr.
        count_out = contentList.ptr[1] - contentList.ptr[0];
        return contentList.ptr[0];
    else
        count_out = mContentCount;
        return contentList.hnd;
ErrorCode moab::MeshSet::get_entities ( std::vector< EntityHandle > &  entities) const [inline]
Get entities contained in set
Definition at line 505 of file MeshSet.hpp.
References get_contents(), MB_SUCCESS, and vector_based().
Referenced by moab::MeshSetSequence::get_entities(), get_entities_by_type(), and intersect().
    size_t count;
    const EntityHandle* ptr = get_contents( count );
        size_t old_size = entities.size();
        entities.resize( count + old_size );
        std::copy( ptr, ptr + count, entities.begin() + old_size );
    else
        assert( count % 2 == 0 );
        for( size_t i = 0; i < count; i += 2 )
            std::copy( hdl_iter( ptr[i] ), hdl_iter( ptr[i + 1] + 1 ), std::back_inserter( entities ) );
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities ( Range entities) const [inline]
Definition at line 524 of file MeshSet.hpp.
References moab::Range::begin(), get_contents(), moab::Range::insert(), MB_SUCCESS, and vector_based().
    size_t count;
        std::copy( ptr, ptr + count, range_inserter( entities ) );
    else
        Range::iterator in = entities.begin();
            in = entities.insert( in, ptr[i], ptr[i + 1] );
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities_by_dimension ( int  dimension,
std::vector< EntityHandle > &  entity_list
) const [inline]
Definition at line 670 of file MeshSet.hpp.
References DIM_FROM_HANDLE(), FIRST_OF_DIM(), get_contents(), LAST_OF_DIM(), MB_SUCCESS, and vector_based().
Referenced by moab::MeshSetSequence::get_dimension().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, std::back_inserter( entity_list ), not_dim_test( dimension ) );
    else
        size_t idx = std::lower_bound( ptr, ptr + count, FIRST_OF_DIM( dimension ) ) - ptr;
        if( idx < count && DIM_FROM_HANDLE( ptr[idx] ) == dimension )
            if( idx % 2 )
            {  // only part of first block is of type
                std::copy( hdl_iter( FIRST_OF_DIM( dimension ) ), hdl_iter( ptr[idx] + 1 ),
                           std::back_inserter( entity_list ) );
                ++idx;
            for( ; idx < count; idx += 2 )
                if( DIM_FROM_HANDLE( ptr[idx + 1] ) == dimension )  // whole block is of type
                    std::copy( hdl_iter( ptr[idx] ), hdl_iter( ptr[idx + 1] + 1 ), std::back_inserter( entity_list ) );
                else
                    if( DIM_FROM_HANDLE( ptr[idx] ) == dimension )  // part of last block is of type
                        std::copy( hdl_iter( ptr[idx] ), hdl_iter( LAST_OF_DIM( dimension ) ),
                    break;
    return MB_SUCCESS;
Range entity_list
) const [inline]
Definition at line 707 of file MeshSet.hpp.
References moab::Range::begin(), DIM_FROM_HANDLE(), FIRST_OF_DIM(), get_contents(), moab::Range::insert(), LAST_OF_DIM(), MB_SUCCESS, and vector_based().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, range_inserter( entity_list ), not_dim_test( dimension ) );
    else
        Range::iterator in = entity_list.begin();
            if( idx % 2 )
                in = entity_list.insert( in, FIRST_OF_DIM( dimension ), ptr[idx] );
                ++idx;
                    in = entity_list.insert( in, ptr[idx], ptr[idx + 1] );
                else
                        entity_list.insert( in, ptr[idx], LAST_OF_DIM( dimension ) );
                    break;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities_by_type ( EntityType  entity_type,
) const [inline]
Definition at line 543 of file MeshSet.hpp.
References moab::FIRST_HANDLE(), get_contents(), get_entities(), moab::LAST_HANDLE(), MB_SUCCESS, MBMAXTYPE, moab::TYPE_FROM_HANDLE(), and vector_based().
Referenced by moab::MeshSetSequence::get_contained_sets(), moab::MeshSetSequence::get_type(), and moab::MeshSetSequence::recursive_get_sets().
    size_t count;
    if( MBMAXTYPE == type )
        return get_entities( entity_list );
    else if( vector_based() )
        std::remove_copy_if( ptr, ptr + count, std::back_inserter( entity_list ), not_type_test( type ) );
    else
        size_t idx = std::lower_bound( ptr, ptr + count, FIRST_HANDLE( type ) ) - ptr;
        if( idx < count && TYPE_FROM_HANDLE( ptr[idx] ) == type )
            if( idx % 2 )
                std::copy( hdl_iter( FIRST_HANDLE( type ) ), hdl_iter( ptr[idx] + 1 ),
                ++idx;
                if( TYPE_FROM_HANDLE( ptr[idx + 1] ) == type )  // whole block is of type
                else
                    if( TYPE_FROM_HANDLE( ptr[idx] ) == type )  // part of last block is of type
                        std::copy( hdl_iter( ptr[idx] ), hdl_iter( LAST_HANDLE( type ) ),
                    break;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities_by_type ( EntityType  type,
Range entity_list
) const [inline]
Definition at line 584 of file MeshSet.hpp.
References moab::Range::begin(), moab::FIRST_HANDLE(), get_contents(), get_entities(), moab::Range::insert(), moab::LAST_HANDLE(), MB_SUCCESS, MBMAXTYPE, moab::TYPE_FROM_HANDLE(), and vector_based().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, range_inserter( entity_list ), not_type_test( type ) );
    else
            if( idx % 2 )
                in = entity_list.insert( in, FIRST_HANDLE( type ), ptr[idx] );
                ++idx;
                else
                        entity_list.insert( in, ptr[idx], LAST_HANDLE( type ) );
                    break;
    return MB_SUCCESS;
unsigned long moab::MeshSet::get_memory_use ( ) const
Definition at line 1279 of file MeshSet.cpp.
References childMeshSets, contentList, MANY, mChildCount, mContentCount, mParentCount, parentMeshSets, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::get_per_entity_memory_use().
    unsigned long result = 0;
    if( mParentCount == MANY ) result += parentMeshSets.ptr[1] - parentMeshSets.ptr[0];
    if( mChildCount == MANY ) result += childMeshSets.ptr[1] - childMeshSets.ptr[0];
    if( mContentCount == MANY ) result += contentList.ptr[1] - contentList.ptr[0];
    return sizeof( EntityHandle ) * result;
Definition at line 785 of file MeshSet.hpp.
References moab::Range::begin(), get_contents(), moab::Range::insert(), moab::LAST_HANDLE(), MB_SUCCESS, MBENTITYSET, moab::TYPE_FROM_HANDLE(), and vector_based().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, range_inserter( range ), type_test( MBENTITYSET ) );
    else
        Range::iterator in = range.begin();
        for( size_t idx = 0; idx < count; idx += 2 )
            if( TYPE_FROM_HANDLE( ptr[idx + 1] ) != MBENTITYSET )
                in = range.insert( in, ptr[idx], ptr[idx + 1] );
            else
                if( TYPE_FROM_HANDLE( ptr[idx] ) != MBENTITYSET )
                    in = range.insert( in, ptr[idx], LAST_HANDLE( MBENTITYSET - 1 ) );
                break;
    return MB_SUCCESS;
const EntityHandle * moab::MeshSet::get_parents ( int &  count_out) const [inline]
Definition at line 432 of file MeshSet.hpp.
References moab::MeshSet::CompactList::hnd, MANY, mParentCount, parentMeshSets, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::get_parent_child_meshsets(), and moab::MeshSetSequence::get_parents().
    count_out = mParentCount;
    if( count_out < MANY ) return parentMeshSets.hnd;
    count_out = parentMeshSets.ptr[1] - parentMeshSets.ptr[0];
    return parentMeshSets.ptr[0];
ErrorCode moab::MeshSet::insert_entity_ranges ( const EntityHandle range_vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Insert vector of handle range pairs into MeshSet
Definition at line 1052 of file MeshSet.cpp.
References contentList, ErrorCode, mContentCount, tracking(), and vector_based().
Referenced by add_entities(), and unite().
    typedef const std::pair< EntityHandle, EntityHandle >* pair_vect_t;
    pair_vect_t pair_vect = reinterpret_cast< pair_vect_t >( range_vect );
    MeshSet::Count count  = static_cast< MeshSet::Count >( mContentCount );
    ErrorCode rval;
    if( !vector_based() )
        rval = range_tool< pair_vect_t >::ranged_insert_entities( count, contentList, pair_vect, pair_vect + len / 2,
        my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< pair_vect_t >::vector_insert_entities( count, contentList, pair_vect, pair_vect + len / 2,
    return rval;
ErrorCode moab::MeshSet::insert_entity_ranges ( const Range range,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Insert Range of handles into MeshSet
Definition at line 1071 of file MeshSet.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), contentList, ErrorCode, mContentCount, tracking(), and vector_based().
    ErrorCode rval;
        rval = range_tool< Range::const_pair_iterator >::ranged_insert_entities(
            count, contentList, range.const_pair_begin(), range.const_pair_end(), my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< Range::const_pair_iterator >::vector_insert_entities(
    return rval;
ErrorCode moab::MeshSet::insert_entity_vector ( const EntityHandle vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Insert vector of handles into MeshSet
Definition at line 1196 of file MeshSet.cpp.
References contentList, moab::convert_to_ranges(), ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_insert_vector().
    ErrorCode rval;
        rval = vector_insert_vector( count, contentList, vect, len, my_h, tracking() ? adj : 0 );
    else
        std::vector< EntityHandle > rangevect;
        convert_to_ranges( vect, len, rangevect );
        pair_vect_t pair_vect = ( rangevect.empty() ) ? NULL : reinterpret_cast< pair_vect_t >( &rangevect[0] );
                             count, contentList, pair_vect, pair_vect + rangevect.size() / 2, my_h, tracking() ? adj : 0 );
    return rval;
ErrorCode moab::MeshSet::intersect ( const MeshSet meshset_2,
Definition at line 1118 of file MeshSet.cpp.
References clear(), ErrorCode, get_contents(), get_entities(), MB_SUCCESS, remove_entities(), remove_entity_ranges(), moab::subtract(), and vector_based().
Referenced by moab::Core::intersect_meshset().
    ErrorCode rval;
    if( !vector_based() && !other->vector_based() )
        size_t other_count             = 0;
        const EntityHandle* other_vect = other->get_contents( other_count );
        if( !other_count ) return clear( my_handle, adj );
        assert( 0 == other_count % 2 );
        std::vector< EntityHandle > compliment;
        compliment.reserve( other_count + 4 );
        if( *other_vect > 0 )
            compliment.push_back( 0 );
            compliment.push_back( *other_vect - 1 );
        ++other_vect;
        const EntityHandle* const other_end = other_vect + other_count - 2;
        for( ; other_vect < other_end; other_vect += 2 )
            compliment.push_back( other_vect[0] + 1 );
            compliment.push_back( other_vect[1] - 1 );
        if( *other_vect < ~(EntityHandle)0 )
            compliment.push_back( *other_vect + 1 );
            compliment.push_back( ~(EntityHandle)0 );
        return remove_entity_ranges( &compliment[0], compliment.size(), my_handle, adj );
    else
        Range my_ents, other_ents;
        rval = get_entities( my_ents );
        rval = other->get_entities( other_ents );
        return remove_entities( moab::subtract( my_ents, other_ents ), my_handle, adj );
static EntityHandle moab::MeshSet::LAST_OF_DIM ( int  dim) [inline, static]
Get largest possible handle with specified dimension (largest handle for last type of dimension)
Definition at line 264 of file MeshSet.hpp.
References moab::LAST_HANDLE(), and moab::CN::TypeDimensionMap.
        return LAST_HANDLE( CN::TypeDimensionMap[dim].second );
int moab::MeshSet::num_children ( ) const [inline]
Definition at line 442 of file MeshSet.hpp.
References childMeshSets, MANY, mChildCount, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::num_children().
    if( mChildCount < MANY )
        return mChildCount;
    else
        return childMeshSets.ptr[1] - childMeshSets.ptr[0];
unsigned int moab::MeshSet::num_entities ( ) const [inline]
Definition at line 888 of file MeshSet.hpp.
References get_contents(), and vector_based().
Referenced by convert(), moab::MeshSetSequence::num_entities(), and num_entities_by_type().
    size_t count;
    const EntityHandle* list = get_contents( count );
    if( vector_based() ) return count;
    int result                    = 0;
    const EntityHandle* const end = list + count;
    for( ; list < end; list += 2 )
        result += list[1] - list[0] + 1;
    return result;
unsigned int moab::MeshSet::num_entities_by_dimension ( int  dimension) const [inline]
Definition at line 744 of file MeshSet.hpp.
References DIM_FROM_HANDLE(), FIRST_OF_DIM(), get_contents(), LAST_OF_DIM(), and vector_based().
Referenced by moab::MeshSetSequence::num_dimension().
    unsigned int result;
    size_t count;
#ifndef __SUNPRO_CC
        result = std::count_if( ptr, ptr + count, dim_test( dimension ) );
#else
        std::count_if( ptr, ptr + count, dim_test( dimension ), result );
#endif
    else
        result     = 0;
            if( idx % 2 )
                result += ptr[idx] - FIRST_OF_DIM( dimension ) + 1;
                ++idx;
                    result += ptr[idx + 1] - ptr[idx] + 1;
                else
                        result += LAST_OF_DIM( dimension ) - ptr[idx] + 1;
                    break;
    return result;
unsigned int moab::MeshSet::num_entities_by_type ( EntityType  type) const [inline]
Definition at line 625 of file MeshSet.hpp.
References moab::FIRST_HANDLE(), get_contents(), moab::LAST_HANDLE(), MBMAXTYPE, num_entities(), moab::TYPE_FROM_HANDLE(), and vector_based().
Referenced by moab::MeshSetSequence::num_contained_sets(), and moab::MeshSetSequence::num_type().
    size_t count;
        return num_entities();
#ifndef __SUNPRO_CC
        result = std::count_if( ptr, ptr + count, type_test( type ) );
#else
        std::count_if( ptr, ptr + count, type_test( type ), result );
#endif
    else
        result     = 0;
            if( idx % 2 )
                result += ptr[idx] - FIRST_HANDLE( type ) + 1;
                ++idx;
                else
                        result += LAST_HANDLE( type ) - ptr[idx] + 1;
                    break;
    return result;
int moab::MeshSet::num_parents ( ) const [inline]
Definition at line 451 of file MeshSet.hpp.
References MANY, mParentCount, parentMeshSets, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::num_parents().
    if( mParentCount < MANY )
        return mParentCount;
    else
        return parentMeshSets.ptr[1] - parentMeshSets.ptr[0];
int moab::MeshSet::ordered ( ) const [inline]
Definition at line 79 of file MeshSet.hpp.
References mFlags.
Referenced by vector_based().
        return mFlags & MESHSET_ORDERED;
ErrorCode moab::MeshSet::remove_adjacencies ( EntityHandle  myhandle,
) [protected]
Remvoe explicit adjacencies from all contained entities to this (i.e. convert from tracking)
Definition at line 366 of file MeshSet.cpp.
References get_contents(), MB_SUCCESS, moab::AEntityFactory::remove_adjacency(), and vector_based().
Referenced by clear(), and convert().
    size_t count;
            adj->remove_adjacency( *i, my_handle );
    else
                adj->remove_adjacency( h, my_handle );
    return MB_SUCCESS;
Definition at line 257 of file MeshSet.cpp.
References childMeshSets, mChildCount, and moab::remove_from_vector().
Referenced by moab::Core::remove_child_meshset(), and moab::Core::remove_parent_child().
    int result  = 0;
    mChildCount = remove_from_vector( (Count)mChildCount, childMeshSets, child, result );
    return result;
ErrorCode moab::MeshSet::remove_entities ( const Range entities,
) [inline]
Definition at line 873 of file MeshSet.hpp.
References remove_entity_ranges().
Referenced by intersect(), and replace_entities().
    return remove_entity_ranges( entities, my_handle, adjacencies );
ErrorCode moab::MeshSet::remove_entities ( const EntityHandle entities,
) [inline]
Definition at line 879 of file MeshSet.hpp.
References remove_entity_vector().
    return remove_entity_vector( entities, num_ents, my_handle, adjacencies );
ErrorCode moab::MeshSet::remove_entity_ranges ( const EntityHandle range_vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Remove vector of handle range pairs from MeshSet
Definition at line 1085 of file MeshSet.cpp.
References contentList, ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_remove_ranges().
Referenced by intersect(), remove_entities(), and subtract().
    ErrorCode rval;
        rval = vector_remove_ranges( count, contentList, range_vect, len / 2, my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< pair_vect_t >::ranged_remove_entities( count, contentList, pair_vect, pair_vect + len / 2,
    return rval;
ErrorCode moab::MeshSet::remove_entity_ranges ( const Range range,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Remove Range of handles from MeshSet
Definition at line 1105 of file MeshSet.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), contentList, ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_remove_range().
    ErrorCode rval;
        rval = vector_remove_range( count, contentList, range, my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< Range::const_pair_iterator >::ranged_remove_entities(
    return rval;
ErrorCode moab::MeshSet::remove_entity_vector ( const EntityHandle vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Remove vector of handles from MeshSet
Definition at line 1215 of file MeshSet.cpp.
References contentList, moab::convert_to_ranges(), ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_remove_vector().
Referenced by remove_entities(), and subtract().
    ErrorCode rval;
        rval = vector_remove_vector( count, contentList, vect, len, my_h, tracking() ? adj : 0 );
    else
    return rval;
Definition at line 251 of file MeshSet.cpp.
References mParentCount, parentMeshSets, and moab::remove_from_vector().
Referenced by moab::Core::remove_parent_child(), and moab::Core::remove_parent_meshset().
    int result   = 0;
    mParentCount = remove_from_vector( (Count)mParentCount, parentMeshSets, parent, result );
    return result;
ErrorCode moab::MeshSet::replace_entities ( EntityHandle  my_handle,
const EntityHandle old_entities,
const EntityHandle new_entities,
AEntityFactory mAdjFact
Definition at line 1234 of file MeshSet.cpp.
References moab::AEntityFactory::add_adjacency(), add_entities(), ErrorCode, get_contents(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AEntityFactory::remove_adjacency(), remove_entities(), tracking(), and vector_based().
        ErrorCode result = MB_SUCCESS;
        size_t count;
        EntityHandle* vect           = get_contents( count );
        EntityHandle* const vect_end = vect + count;
        for( size_t i = 0; i < num_ents; ++i )
            EntityHandle* p = std::find( vect, vect_end, old_entities[i] );
            if( p == vect_end )
                result = MB_ENTITY_NOT_FOUND;
            else
                do
                    if( tracking() )
                        adjfact->remove_adjacency( *p, my_handle );
                        adjfact->add_adjacency( new_entities[i], my_handle, false );
                    *p = new_entities[i];
                    p  = std::find( p + 1, vect_end, old_entities[i] );
                } while( p != vect_end );
        return result;
    else
        ErrorCode r1 = remove_entities( old_entities, num_ents, my_handle, adjfact );
        ErrorCode r2 = add_entities( new_entities, num_ents, my_handle, adjfact );
        return ( MB_SUCCESS == r2 ) ? r1 : r2;
int moab::MeshSet::set ( ) const [inline]
Definition at line 75 of file MeshSet.hpp.
References MESHSET_SET, and mFlags.
        return mFlags & MESHSET_SET;
ErrorCode moab::MeshSet::set_flags ( unsigned  flags,
) [inline]
Definition at line 410 of file MeshSet.hpp.
References convert(), ErrorCode, MB_SUCCESS, mContentCount, mFlags, and ZERO.
    if( ZERO != mContentCount )
        ErrorCode result = convert( flg, my_handle, adjacencies );
        if( MB_SUCCESS != result ) return result;
    mFlags = (unsigned char)flg;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::subtract ( const MeshSet meshset_2,
) [inline]
Definition at line 837 of file MeshSet.hpp.
References get_contents(), remove_entity_ranges(), remove_entity_vector(), and vector_based().
Referenced by moab::Core::subtract_meshset().
    size_t count;
    const EntityHandle* const ptr = meshset_2->get_contents( count );
    if( meshset_2->vector_based() )
        return remove_entity_vector( ptr, count, my_handle, adjacencies );
    else
        return remove_entity_ranges( ptr, count, my_handle, adjacencies );
int moab::MeshSet::tracking ( ) const [inline]
Definition at line 71 of file MeshSet.hpp.
References MESHSET_TRACK_OWNER, and mFlags.
Referenced by clear(), insert_entity_ranges(), insert_entity_vector(), remove_entity_ranges(), remove_entity_vector(), and replace_entities().
        return mFlags & MESHSET_TRACK_OWNER;
ErrorCode moab::MeshSet::unite ( const MeshSet meshset_2,
) [inline]
Definition at line 847 of file MeshSet.hpp.
References get_contents(), insert_entity_ranges(), insert_entity_vector(), and vector_based().
Referenced by moab::Core::unite_meshset().
    size_t count;
        return insert_entity_vector( ptr, count, my_handle, adjacencies );
    else
        return insert_entity_ranges( ptr, count, my_handle, adjacencies );
Member Data Documentation
unsigned moab::MeshSet::mChildCount [private]
Definition at line 240 of file MeshSet.hpp.
Referenced by add_child(), clear_all(), get_children(), get_memory_use(), num_children(), remove_child(), and ~MeshSet().
unsigned moab::MeshSet::mContentCount [private]
Definition at line 244 of file MeshSet.hpp.
Referenced by clear(), convert(), empty(), get_contents(), get_memory_use(), insert_entity_ranges(), insert_entity_vector(), remove_entity_ranges(), remove_entity_vector(), set_flags(), and ~MeshSet().
unsigned char moab::MeshSet::mFlags [private]
Definition at line 230 of file MeshSet.hpp.
Referenced by convert(), flags(), ordered(), set(), set_flags(), and tracking().
unsigned moab::MeshSet::mParentCount [private]
Definition at line 235 of file MeshSet.hpp.
Referenced by add_parent(), clear_all(), get_memory_use(), get_parents(), num_parents(), remove_parent(), and ~MeshSet().
Definition at line 246 of file MeshSet.hpp.
List of all members.
