moab::NCWriteHOMME Class Reference
#include <NCWriteHOMME.hpp>
+ Inheritance diagram for moab::NCWriteHOMME:
+ Collaboration diagram for moab::NCWriteHOMME:
Public Member Functions
 NCWriteHOMME (WriteNC *writeNC, int fileId, const FileOptions &opts, EntityHandle fileSet)
virtual ~NCWriteHOMME ()
Private Member Functions
virtual ErrorCode collect_mesh_info ()
 Implementation of NCWriteHelper::collect_mesh_info()
virtual ErrorCode collect_variable_data (std::vector< std::string > &var_names, std::vector< int > &tstep_nums)
 Collect data for specified variables.
virtual ErrorCode write_nonset_variables (std::vector< WriteNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Implementation of NCWriteHelper::write_nonset_variables()
Detailed Description
Definition at line 17 of file NCWriteHOMME.hpp.
moab::NCWriteHOMME::NCWriteHOMME ( WriteNC writeNC,
int  fileId,
const FileOptions opts,
) [inline]
Definition at line 20 of file NCWriteHOMME.hpp.
        : UcdNCWriteHelper( writeNC, fileId, opts, fileSet )
Definition at line 13 of file NCWriteHOMME.cpp.
    // TODO Auto-generated destructor stub
Member Function Documentation
Implements moab::NCWriteHelper.
Definition at line 18 of file NCWriteHOMME.cpp.
References moab::NCWriteHelper::_fileSet, moab::NCWriteHelper::_writeNC, moab::WriteNC::dimLens, moab::WriteNC::dimNames, moab::Range::empty(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_dimension(), moab::WriteNC::isParallel, moab::NCWriteHelper::levDim, moab::UcdNCWriteHelper::localGidVertsOwned, moab::NCWriteHelper::localVertsOwned, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, moab::WriteNC::mbImpl, moab::WriteNC::mGlobalIdTag, moab::NCWriteHelper::nLevels, moab::NCWriteHelper::nTimeSteps, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::size(), moab::Interface::tag_get_data(), and moab::NCWriteHelper::tDim.
    Interface*& mbImpl                   = _writeNC->mbImpl;
    std::vector< std::string >& dimNames = _writeNC->dimNames;
    std::vector< int >& dimLens          = _writeNC->dimLens;
    Tag& mGlobalIdTag                    = _writeNC->mGlobalIdTag;
    ErrorCode rval;
    // Look for time dimension
    std::vector< std::string >::iterator vecIt;
    if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() )
        tDim = vecIt - dimNames.begin();
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'time' dimension" );
    nTimeSteps = dimLens[tDim];
    // Get number of levels
    if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "lev" ) ) != dimNames.end() )
        levDim = vecIt - dimNames.begin();
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'lev' dimension" );
    nLevels = dimLens[levDim];
    // Get local vertices
    rval = mbImpl->get_entities_by_dimension( _fileSet, 0, localVertsOwned );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" );
    assert( !localVertsOwned.empty() );
#ifdef MOAB_HAVE_MPI
    bool& isParallel = _writeNC->isParallel;
    if( isParallel )
        ParallelComm*& myPcomm = _writeNC->myPcomm;
        int rank               = myPcomm->proc_config().proc_rank();
        int procs              = myPcomm->proc_config().proc_size();
        if( procs > 1 )
#ifndef NDEBUG
            unsigned int num_local_verts = localVertsOwned.size();
#endif
            rval = myPcomm->filter_pstatus( localVertsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned vertices in current set" );
            // Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set
            // Verify that not all local vertices are owned by the last processor
            if( procs - 1 == rank )
                assert( "PARALLEL_RESOLVE_SHARED_ENTS option is set" && localVertsOwned.size() < num_local_verts );
#endif
    std::vector< int > gids( localVertsOwned.size() );
    rval = mbImpl->tag_get_data( mGlobalIdTag, localVertsOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local vertices" );
    // Get localGidVertsOwned
    std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVertsOwned ) );
    return MB_SUCCESS;
ErrorCode moab::NCWriteHOMME::collect_variable_data ( std::vector< std::string > &  var_names,
std::vector< int > &  tstep_nums
) [private, virtual]
Reimplemented from moab::NCWriteHelper.
Definition at line 81 of file NCWriteHOMME.cpp.
References moab::NCWriteHelper::_writeNC, moab::WriteNC::VarData::entLoc, moab::WriteNC::ENTLOCSET, moab::WriteNC::ENTLOCVERT, moab::WriteNC::VarData::has_tsteps, moab::UcdNCWriteHelper::localGidVertsOwned, MB_SET_ERR, MB_SUCCESS, moab::WriteNC::VarData::numLev, moab::Range::size(), moab::WriteNC::VarData::sz, moab::NCWriteHelper::tDim, moab::WriteNC::VarData::varDims, moab::WriteNC::varInfo, moab::WriteNC::VarData::writeCounts, and moab::WriteNC::VarData::writeStarts.
    NCWriteHelper::collect_variable_data( var_names, tstep_nums );
    std::map< std::string, WriteNC::VarData >& varInfo = _writeNC->varInfo;
    for( size_t i = 0; i < var_names.size(); i++ )
        std::string varname                                     = var_names[i];
        std::map< std::string, WriteNC::VarData >::iterator vit = varInfo.find( varname );
        if( vit == varInfo.end() ) MB_SET_ERR( MB_FAILURE, "Can't find variable " << varname );
        WriteNC::VarData& currentVarData = vit->second;
#ifndef NDEBUG
        std::vector< int >& varDims = currentVarData.varDims;
#endif
        // Skip set variables, which were already processed in
        // NCWriteHelper::collect_variable_data()
        if( WriteNC::ENTLOCSET == currentVarData.entLoc ) continue;
        // Set up writeStarts and writeCounts (maximum number of dimensions is 3)
        currentVarData.writeStarts.resize( 3 );
        currentVarData.writeCounts.resize( 3 );
        unsigned int dim_idx = 0;
        // First: time
        if( currentVarData.has_tsteps )
            // Non-set variables with timesteps
            // 3 dimensions like (time, lev, ncol)
            // 2 dimensions like (time, ncol)
            assert( 3 == varDims.size() || 2 == varDims.size() );
            // Time should be the first dimension
            assert( tDim == varDims[0] );
            currentVarData.writeStarts[dim_idx] = 0;  // This value is timestep dependent, will be set later
            currentVarData.writeCounts[dim_idx] = 1;
            dim_idx++;
        else
            // Non-set variables without timesteps
            // 2 dimensions like (lev, ncol)
            // 1 dimension like (ncol)
            assert( 2 == varDims.size() || 1 == varDims.size() );
        // Next: lev
        if( currentVarData.numLev > 0 )
            // Non-set variables with levels
            currentVarData.writeCounts[dim_idx] = currentVarData.numLev;
            dim_idx++;
        else
            // Non-set variables without levels
        // Finally: ncol
        switch( currentVarData.entLoc )
            case WriteNC::ENTLOCVERT:
                // Vertices
                // Start from the first localGidVerts
                // Actually, this will be reset later for writing
                currentVarData.writeStarts[dim_idx] = localGidVertsOwned[0] - 1;
                currentVarData.writeCounts[dim_idx] = localGidVertsOwned.size();
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << varname );
        dim_idx++;
        // Get variable size
        currentVarData.sz = 1;
        for( std::size_t idx = 0; idx < dim_idx; idx++ )
            currentVarData.sz *= currentVarData.writeCounts[idx];
    return MB_SUCCESS;
ErrorCode moab::NCWriteHOMME::write_nonset_variables ( std::vector< WriteNC::VarData > &  vdatas,
Definition at line 175 of file NCWriteHOMME.cpp.
References moab::NCWriteHelper::_fileId, moab::NCWriteHelper::_writeNC, moab::WriteNC::VarData::entLoc, moab::WriteNC::ENTLOCVERT, ErrorCode, moab::WriteNC::VarData::has_tsteps, moab::UcdNCWriteHelper::jik_to_kji_stride(), moab::UcdNCWriteHelper::localGidVertsOwned, moab::NCWriteHelper::localVertsOwned, MB_CHK_SET_ERR, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, moab::WriteNC::mbImpl, NCDF_SIZE, NCFUNCAP, moab::WriteNC::VarData::numLev, moab::Range::pair_begin(), moab::Range::pair_end(), moab::Range::psize(), moab::Range::size(), t, moab::Interface::tag_get_data(), moab::NCWriteHelper::tDim, moab::WriteNC::VarData::varDataType, moab::WriteNC::VarData::varDims, moab::WriteNC::VarData::varId, moab::WriteNC::VarData::varName, moab::WriteNC::VarData::varTags, moab::WriteNC::VarData::writeCounts, and moab::WriteNC::VarData::writeStarts.
    int success;
    int num_local_verts_owned = localVertsOwned.size();
    // For each indexed variable tag, write a time step data
    for( unsigned int i = 0; i < vdatas.size(); i++ )
        WriteNC::VarData& variableData = vdatas[i];
        // Assume this variable is on vertices for the time being
        switch( variableData.entLoc )
                // Vertices
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << variableData.varName );
        unsigned int num_timesteps;
        unsigned int ncol_idx = 0;
        if( variableData.has_tsteps )
            num_timesteps = tstep_nums.size();
            ncol_idx++;
        else
            num_timesteps = 1;
        unsigned int num_lev;
        if( variableData.numLev > 0 )
            num_lev = variableData.numLev;
            ncol_idx++;
        else
            num_lev = 1;
        // At each timestep, we need to transpose tag format (ncol, lev) back
        // to NC format (lev, ncol) for writing
        for( unsigned int t = 0; t < num_timesteps; t++ )
            // We will write one time step, and count will be one; start will be different
            // Use tag_get_data instead of tag_iterate to copy tag data, as localVertsOwned
            // might not be contiguous. We should also transpose for level so that means
            // deep copy for transpose
            if( tDim == variableData.varDims[0] ) variableData.writeStarts[0] = t;  // This is start for time
            std::vector< double > tag_data( num_local_verts_owned * num_lev );
            ErrorCode rval = mbImpl->tag_get_data( variableData.varTags[t], localVertsOwned, &tag_data[0] );MB_CHK_SET_ERR( rval, "Trouble getting tag data on owned vertices" );
#ifdef MOAB_HAVE_PNETCDF
            size_t nb_writes = localGidVertsOwned.psize();
            std::vector< int > requests( nb_writes ), statuss( nb_writes );
            size_t idxReq = 0;
#endif
            // Now transpose and write copied tag data
            // Use nonblocking put (request aggregation)
            switch( variableData.varDataType )
                case NC_DOUBLE: {
                    std::vector< double > tmpdoubledata( num_local_verts_owned * num_lev );
                    if( num_lev > 1 )
                        // Transpose (ncol, lev) back to (lev, ncol)
                        // Note, num_local_verts_owned is not used by jik_to_kji_stride()
                        jik_to_kji_stride( num_local_verts_owned, 1, num_lev, &tmpdoubledata[0], &tag_data[0],
                                           localGidVertsOwned );
                    size_t indexInDoubleArray = 0;
                    size_t ic                 = 0;
                    for( Range::pair_iterator pair_iter = localGidVertsOwned.pair_begin();
                         pair_iter != localGidVertsOwned.pair_end(); ++pair_iter, ic++ )
                        EntityHandle starth                = pair_iter->first;
                        EntityHandle endh                  = pair_iter->second;
                        variableData.writeStarts[ncol_idx] = (NCDF_SIZE)( starth - 1 );
                        variableData.writeCounts[ncol_idx] = (NCDF_SIZE)( endh - starth + 1 );
                        // Do a partial write, in each subrange
                        // Wait outside this loop
                        success =
                            NCFUNCREQP( _vara_double )( _fileId, variableData.varId, &( variableData.writeStarts[0] ),
                                                        &( variableData.writeCounts[0] ),
                                                        &( tmpdoubledata[indexInDoubleArray] ), &requests[idxReq++] );
#else
                        success = NCFUNCAP(
                                            &( variableData.writeCounts[0] ), &( tmpdoubledata[indexInDoubleArray] ) );
#endif
                        if( success )
                                        "Failed to write double data in a loop for variable " << variableData.varName );
                        // We need to increment the index in double array for the
                        // next subrange
                        indexInDoubleArray += ( endh - starth + 1 ) * num_lev;
                    assert( ic == localGidVertsOwned.psize() );
                    success = ncmpi_wait_all( _fileId, requests.size(), &requests[0], &statuss[0] );
                    if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
#endif
                    break;
                default:
                    MB_SET_ERR( MB_NOT_IMPLEMENTED, "Writing non-double data is not implemented yet" );
    return MB_SUCCESS;
List of all members.
