moab::NestedRefine Class Reference
#include <NestedRefine.hpp>
+ Collaboration diagram for moab::NestedRefine:
Classes
struct  codeperf
struct  intFEdge
 Helper. More...
struct  level_memory
struct  pmat
struct  refPatterns
 refPatterns More...
Public Member Functions
 NestedRefine (Core *impl, ParallelComm *comm=0, EntityHandle rset=0)
 ~NestedRefine ()
ErrorCode initialize ()
ErrorCode generate_mesh_hierarchy (int num_level, int *level_degrees, std::vector< EntityHandle > &level_sets, bool optimize=false)
 Generate a mesh hierarchy.
ErrorCode get_connectivity (EntityHandle ent, int level, std::vector< EntityHandle > &conn)
 Given an entity and its level, return its connectivity.
ErrorCode get_coordinates (EntityHandle *verts, int num_verts, int level, double *coords)
 Given a vector of vertices and their level, return its coordinates.
ErrorCode get_adjacencies (const EntityHandle source_entity, const unsigned int target_dimension, std::vector< EntityHandle > &target_entities)
 Get the adjacencies associated with an entity.
ErrorCode child_to_parent (EntityHandle child, int child_level, int parent_level, EntityHandle *parent)
ErrorCode parent_to_child (EntityHandle parent, int parent_level, int child_level, std::vector< EntityHandle > &children)
ErrorCode vertex_to_entities_up (EntityHandle vertex, int vert_level, int parent_level, std::vector< EntityHandle > &incident_entities)
ErrorCode vertex_to_entities_down (EntityHandle vertex, int vert_level, int child_level, std::vector< EntityHandle > &incident_entities)
ErrorCode get_vertex_duplicates (EntityHandle vertex, int level, EntityHandle &dupvertex)
bool is_entity_on_boundary (const EntityHandle &entity)
ErrorCode exchange_ghosts (std::vector< EntityHandle > &lsets, int num_glayers)
ErrorCode update_special_tags (int level, EntityHandle &lset)
Public Attributes
codeperf timeall
Protected Member Functions
int get_index_from_degree (int degree)
ErrorCode estimate_hm_storage (EntityHandle set, int level_degree, int cur_level, int hmest[4])
ErrorCode create_hm_storage_single_level (EntityHandle *set, int cur_level, int estL[4])
ErrorCode generate_hm (int *level_degrees, int num_level, EntityHandle *hm_set, bool optimize)
ErrorCode construct_hm_entities (int cur_level, int deg)
ErrorCode construct_hm_1D (int cur_level, int deg)
ErrorCode construct_hm_1D (int cur_level, int deg, EntityType type, std::vector< EntityHandle > &trackverts)
ErrorCode construct_hm_2D (int cur_level, int deg)
ErrorCode construct_hm_2D (int cur_level, int deg, EntityType type, std::vector< EntityHandle > &trackvertsC_edg, std::vector< EntityHandle > &trackvertsF)
ErrorCode construct_hm_3D (int cur_level, int deg)
ErrorCode subdivide_cells (EntityType type, int cur_level, int deg)
ErrorCode subdivide_tets (int cur_level, int deg)
ErrorCode copy_vertices_from_prev_level (int cur_level)
ErrorCode count_subentities (EntityHandle set, int cur_level, int *nedges, int *nfaces)
ErrorCode get_octahedron_corner_coords (int cur_level, int deg, EntityHandle *vbuffer, double *ocoords)
int find_shortest_diagonal_octahedron (int cur_level, int deg, EntityHandle *vbuffer)
int get_local_vid (EntityHandle vid, EntityHandle ent, int level)
ErrorCode update_tracking_verts (EntityHandle cid, int cur_level, int deg, std::vector< EntityHandle > &trackvertsC_edg, std::vector< EntityHandle > &trackvertsC_face, EntityHandle *vbuffer)
ErrorCode reorder_indices (int cur_level, int deg, EntityHandle cell, int lfid, EntityHandle sib_cell, int sib_lfid, int index, int *id_sib)
ErrorCode reorder_indices (int deg, EntityHandle *face1_conn, EntityHandle *face2_conn, int nvF, std::vector< int > &lemap, std::vector< int > &vidx, int *leorient=NULL)
ErrorCode reorder_indices (int deg, int nvF, int comb, int *childfid_map)
ErrorCode reorder_indices (EntityHandle *face1_conn, EntityHandle *face2_conn, int nvF, int *conn_map, int &comb, int *orient=NULL)
ErrorCode get_lid_inci_child (EntityType type, int deg, int lfid, int leid, std::vector< int > &child_ids, std::vector< int > &child_lvids)
ErrorCode print_maps_1D (int level)
ErrorCode print_maps_2D (int level, EntityType type)
ErrorCode print_maps_3D (int level, EntityType type)
ErrorCode compute_coordinates (int cur_level, int deg, EntityType type, EntityHandle *vbuffer, int vtotal, double *corner_coords, std::vector< int > &vflag, int nverts_prev)
ErrorCode update_local_ahf (int deg, EntityType type, EntityHandle *vbuffer, EntityHandle *ent_buffer, int etotal)
ErrorCode update_local_ahf (int deg, EntityType type, int pat_id, EntityHandle *vbuffer, EntityHandle *ent_buffer, int etotal)
ErrorCode update_global_ahf (EntityType type, int cur_level, int deg, std::vector< int > *pattern_ids=NULL)
ErrorCode update_global_ahf_1D (int cur_level, int deg)
ErrorCode update_global_ahf_1D_sub (int cur_level, int deg)
ErrorCode update_ahf_1D (int cur_level)
ErrorCode update_global_ahf_2D (int cur_level, int deg)
ErrorCode update_global_ahf_2D_sub (int cur_level, int deg)
ErrorCode update_global_ahf_3D (int cur_level, int deg, std::vector< int > *pattern_ids=NULL)
bool is_vertex_on_boundary (const EntityHandle &entity)
bool is_edge_on_boundary (const EntityHandle &entity)
bool is_face_on_boundary (const EntityHandle &entity)
bool is_cell_on_boundary (const EntityHandle &entity)
Protected Attributes
CorembImpl
ParallelCommpcomm
HalfFacetRepahf
CpuTimertm
EntityHandle _rset
Range _inverts
Range _inedges
Range _infaces
Range _incells
EntityType elementype
int meshdim
int nlevels
int level_dsequence [MAX_LEVELS]
std::map< int, int > deg_index
bool hasghost
level_memory level_mesh [MAX_LEVELS]
Static Protected Attributes
static const refPatterns refTemplates [9][MAX_DEGREE]
 refPatterns
static const intFEdge intFacEdg [2][2]
static const pmat permutation [2]
Detailed Description
Examples:
LaplacianSmoother.cpp.
Definition at line 34 of file NestedRefine.hpp.
moab::NestedRefine::NestedRefine ( Core impl,
ParallelComm comm = 0,
EntityHandle  rset = 0
Definition at line 24 of file NestedRefine.cpp.
References moab::error(), ErrorCode, moab::ParallelComm::get_pcomm(), initialize(), MB_SUCCESS, mbImpl, and pcomm.
    : mbImpl( impl ), pcomm( comm ), _rset( rset )
    ErrorCode error;
    assert( NULL != impl );
#ifdef MOAB_HAVE_MPI
    // Get the Parallel Comm instance to prepare all new sets to work in parallel
    // in case the user did not provide any arguments
    if( !comm ) pcomm = moab::ParallelComm::get_pcomm( mbImpl, 0 );
#endif
    error = initialize();
    if( error != MB_SUCCESS )
        std::cout << "Error initializing NestedRefine\n" << std::endl;
        exit( 1 );
Definition at line 43 of file NestedRefine.cpp.
References ahf, and tm.
#ifdef MOAB_HAVE_AHF
    ahf = NULL;
#else
    delete ahf;
#endif
    delete tm;
Member Function Documentation
ErrorCode moab::NestedRefine::child_to_parent ( EntityHandle  child,
int  child_level,
int  parent_level,
EntityHandle parent
Given an entity from a certain level, it returns a pointer to its parent at the requested parent level. NOTE: This query does not support vertices.
Parameters:
childEntityHandle of the entity whose parent is requested
child_levelMesh level where the child exists
parent_levelMesh level from which parent is requested
parentPointer to the parent in the requested parent_level
Definition at line 234 of file NestedRefine.cpp.
References _incells, _inedges, _infaces, get_index_from_degree(), level_dsequence, level_mesh, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBHEX, mbImpl, MBQUAD, MBTET, MBTRI, MBVERTEX, refTemplates, moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_edge, moab::NestedRefine::level_memory::start_face, moab::NestedRefine::refPatterns::total_new_ents, and moab::Core::type_from_handle().
Referenced by vertex_to_entities_up().
    assert( ( child_level > 0 ) && ( child_level > parent_level ) );
    EntityType type = mbImpl->type_from_handle( child );
    assert( type != MBVERTEX );
    int child_index;
    if( type == MBEDGE )
        child_index = child - level_mesh[child_level - 1].start_edge;
    else if( type == MBTRI || type == MBQUAD )
        child_index = child - level_mesh[child_level - 1].start_face;
    else if( type == MBTET || type == MBHEX )
        child_index = child - level_mesh[child_level - 1].start_cell;
    else
        MB_SET_ERR( MB_FAILURE, "Requesting parent for unsupported entity type" );
    int parent_index;
    int l = child_level - parent_level;
    for( int i = 0; i < l; i++ )
        int d       = get_index_from_degree( level_dsequence[child_level - i - 1] );
        int nch     = refTemplates[type - 1][d].total_new_ents;
        child_index = child_index / nch;
    parent_index = child_index;
        if( parent_level > 0 )
            *parent = level_mesh[parent_level - 1].start_edge + parent_index;
        else
            *parent = _inedges[parent_index];
            *parent = level_mesh[parent_level - 1].start_face + parent_index;
        else
            *parent = _infaces[parent_index];
            *parent = level_mesh[parent_level - 1].start_cell + parent_index;
        else
            *parent = _incells[parent_index];
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::compute_coordinates ( int  cur_level,
int  deg,
EntityType  type,
EntityHandle vbuffer,
int  vtotal,
double *  corner_coords,
std::vector< int > &  vflag,
int  nverts_prev
) [protected]
Definition at line 1730 of file NestedRefine.cpp.
References _incells, _infaces, moab::Range::begin(), moab::NestedRefine::level_memory::coordinates, get_index_from_degree(), level_mesh, MB_SUCCESS, MBHEX, mbImpl, MBPRISM, MBQUAD, MBTET, MBTRI, refTemplates, moab::NestedRefine::level_memory::start_vertex, moab::Core::type_from_handle(), and moab::NestedRefine::refPatterns::vert_nat_coord.
Referenced by construct_hm_2D(), subdivide_cells(), and subdivide_tets().
    EntityHandle vstart = level_mesh[cur_level].start_vertex;
    int d               = get_index_from_degree( deg );
    if( type == MBTRI )
        double xi, eta, N[3];
        int findex = mbImpl->type_from_handle( *( _infaces.begin() ) ) - 1;
        for( int i = 3; i < vtotal; i++ )
            if( vflag[vbuffer[i] - vstart - nverts_prev] ) continue;
            xi   = refTemplates[findex][d].vert_nat_coord[i - 3][0];
            eta  = refTemplates[findex][d].vert_nat_coord[i - 3][1];
            N[0] = 1 - xi - eta;
            N[1] = xi;
            N[2] = eta;
            double x = 0, y = 0, z = 0;
            for( int j = 0; j < 3; j++ )
                x += N[j] * corner_coords[3 * j];
                y += N[j] * corner_coords[3 * j + 1];
                z += N[j] * corner_coords[3 * j + 2];
            level_mesh[cur_level].coordinates[0][vbuffer[i] - vstart] = x;
            level_mesh[cur_level].coordinates[1][vbuffer[i] - vstart] = y;
            level_mesh[cur_level].coordinates[2][vbuffer[i] - vstart] = z;
            vflag[vbuffer[i] - vstart - nverts_prev]                  = 1;
    else if( type == MBQUAD )
        double xi, eta, N[4];
        for( int i = 4; i < vtotal; i++ )
            xi   = refTemplates[findex][d].vert_nat_coord[i - 4][0];
            eta  = refTemplates[findex][d].vert_nat_coord[i - 4][1];
            N[0] = ( 1 - xi ) * ( 1 - eta ) / 4;
            N[1] = ( 1 + xi ) * ( 1 - eta ) / 4;
            N[2] = ( 1 + xi ) * ( 1 + eta ) / 4, N[3] = ( 1 - xi ) * ( 1 + eta ) / 4;
            for( int j = 0; j < 4; j++ )
    else if( type == MBTET )
        double xi, eta, mu, N[4];
        int cindex = mbImpl->type_from_handle( *( _incells.begin() ) ) - 1;
            xi  = refTemplates[cindex][d].vert_nat_coord[i - 4][0];
            eta = refTemplates[cindex][d].vert_nat_coord[i - 4][1];
            mu  = refTemplates[cindex][d].vert_nat_coord[i - 4][2];
            N[0] = 1 - xi - eta - mu;
            N[1] = xi;
            N[2] = eta, N[3] = mu;
    else if( type == MBPRISM )
        double xi, eta, mu, N[6];
        for( int i = 6; i < vtotal; i++ )
            xi  = refTemplates[cindex][d].vert_nat_coord[i - 6][0];
            eta = refTemplates[cindex][d].vert_nat_coord[i - 6][1];
            mu  = refTemplates[cindex][d].vert_nat_coord[i - 6][2];
            N[0] = ( 1 - xi - eta ) * ( 1 - mu ), N[1] = xi * ( 1 - mu ), N[2] = eta * ( 1 - mu ),
            N[3] = ( 1 - xi - eta ) * ( 1 + mu ), N[4] = xi * ( 1 + mu ), N[5] = eta * ( 1 + mu );
            for( int j = 0; j < 6; j++ )
    else if( type == MBHEX )
        double xi, eta, mu, N[8];
        double d1, d2, d3, s1, s2, s3;
        for( int i = 8; i < vtotal; i++ )
            xi  = refTemplates[cindex][d].vert_nat_coord[i - 8][0];
            eta = refTemplates[cindex][d].vert_nat_coord[i - 8][1];
            mu  = refTemplates[cindex][d].vert_nat_coord[i - 8][2];
            d1   = 1 - xi;
            d2   = 1 - eta;
            d3   = 1 - mu;
            s1   = 1 + xi;
            s2   = 1 + eta;
            s3   = 1 + mu;
            N[0] = ( d1 * d2 * d3 ) / 8;
            N[1] = ( s1 * d2 * d3 ) / 8;
            N[2] = ( s1 * s2 * d3 ) / 8;
            N[3] = ( d1 * s2 * d3 ) / 8;
            N[4] = ( d1 * d2 * s3 ) / 8;
            N[5] = ( s1 * d2 * s3 ) / 8;
            N[6] = ( s1 * s2 * s3 ) / 8;
            N[7] = ( d1 * s2 * s3 ) / 8;
            for( int j = 0; j < 8; j++ )
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::construct_hm_1D ( int  cur_level,
int  deg
) [protected]
Definition at line 804 of file NestedRefine.cpp.
References _inedges, _inverts, moab::Range::begin(), moab::NestedRefine::level_memory::coordinates, moab::NestedRefine::level_memory::edge_conn, moab::NestedRefine::refPatterns::ents_conn, moab::error(), ErrorCode, get_connectivity(), get_index_from_degree(), moab::Range::index(), level_mesh, MB_CHK_ERR, MB_SUCCESS, MBEDGE, moab::NestedRefine::level_memory::num_edges, moab::NestedRefine::level_memory::num_verts, refTemplates, moab::Range::size(), moab::NestedRefine::level_memory::start_edge, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::NestedRefine::refPatterns::total_new_verts, update_global_ahf(), update_local_ahf(), and moab::NestedRefine::refPatterns::vert_nat_coord.
Referenced by construct_hm_2D(), construct_hm_entities(), subdivide_cells(), and subdivide_tets().
    ErrorCode error;
    int nverts_prev, nents_prev;
    if( cur_level )
        nverts_prev = level_mesh[cur_level - 1].num_verts;
        nents_prev  = level_mesh[cur_level - 1].num_edges;
    else
        nverts_prev = _inverts.size();
        nents_prev  = _inedges.size();
    int vtotal = 2 + refTemplates[0][d].total_new_verts;
    std::vector< EntityHandle > vbuffer( vtotal );
    std::vector< EntityHandle > conn;
    int count_nents = 0;
    int count_verts = nverts_prev;
    // Step 1: Create the subentities via refinement of the previous mesh
    for( int eid = 0; eid < nents_prev; eid++ )
        conn.clear();
        // EntityHandle of the working edge
        EntityHandle edge;
        if( cur_level )
            edge = level_mesh[cur_level - 1].start_edge + eid;
        else
            edge = _inedges[eid];  // Makes the assumption initial mesh is contiguous in memory
        error = get_connectivity( edge, cur_level, conn );MB_CHK_ERR( error );
        // Add the vertex handles to vbuffer for the current level for the working edge
        // Since the old vertices are copied first, their local indices do not change as new levels
        // are added. Clearly the local indices of the new vertices introduced in the current level
        // is still the same when the old vertices are copied. Thus, there is no need to explicitly
        // store another map between the old and duplicates in the subsequent levels. The second
        // part in the following sum is the local index in the previous level.
        // Add the corners to the vbuffer first.
        for( int i = 0; i < (int)conn.size(); i++ )
            if( cur_level )
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( conn[i] - level_mesh[cur_level - 1].start_vertex );
            else
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( conn[i] - *_inverts.begin() );
        // Adding rest of the entityhandles to working buffer for vertices.
        int num_new_verts = refTemplates[0][d].total_new_verts;
        for( int i = 0; i < num_new_verts; i++ )
            vbuffer[i + 2] = level_mesh[cur_level].start_vertex + count_verts;
            count_verts += 1;
        // Use the template to obtain the subentities
        int id1, id2;
        int etotal = refTemplates[0][d].total_new_ents;
        std::vector< EntityHandle > ent_buffer( etotal );
        for( int i = 0; i < etotal; i++ )
            id1                                                      = refTemplates[0][d].ents_conn[i][0];
            id2                                                      = refTemplates[0][d].ents_conn[i][1];
            level_mesh[cur_level].edge_conn[2 * ( count_nents )]     = vbuffer[id1];
            level_mesh[cur_level].edge_conn[2 * ( count_nents ) + 1] = vbuffer[id2];
            ent_buffer[i]                                            = level_mesh[cur_level].start_edge + count_nents;
            count_nents += 1;
        error = update_local_ahf( deg, MBEDGE, &vbuffer[0], &ent_buffer[0], etotal );MB_CHK_ERR( error );
        // Compute the coordinates of the new vertices: Linear interpolation
        int idx;
        double xi;
            xi  = refTemplates[0][d].vert_nat_coord[i][0];
            idx = vbuffer[i + 2] - level_mesh[cur_level].start_vertex;  // index of new vertex in current level
            if( cur_level )
                id1 = conn[0] - level_mesh[cur_level - 1].start_vertex;  // index of old end vertices in current level
                id2 = conn[1] - level_mesh[cur_level - 1].start_vertex;
            else
                id1 = _inverts.index( conn[0] );
                id2 = _inverts.index( conn[1] );
            level_mesh[cur_level].coordinates[0][idx] =
                ( 1 - xi ) * level_mesh[cur_level].coordinates[0][id1] + xi * level_mesh[cur_level].coordinates[0][id2];
            level_mesh[cur_level].coordinates[1][idx] =
                ( 1 - xi ) * level_mesh[cur_level].coordinates[1][id1] + xi * level_mesh[cur_level].coordinates[1][id2];
            level_mesh[cur_level].coordinates[2][idx] =
                ( 1 - xi ) * level_mesh[cur_level].coordinates[2][id1] + xi * level_mesh[cur_level].coordinates[2][id2];
    error = update_global_ahf( MBEDGE, cur_level, deg );MB_CHK_ERR( error );
    return MB_SUCCESS;
int  deg,
EntityType  type,
std::vector< EntityHandle > &  trackverts
) [protected]
Definition at line 917 of file NestedRefine.cpp.
References _incells, _inedges, _infaces, _inverts, ahf, moab::Range::begin(), dim, moab::HalfFacetRep::LocalMaps3D::e2v, moab::NestedRefine::level_memory::edge_conn, moab::NestedRefine::refPatterns::ents_conn, moab::error(), ErrorCode, get_connectivity(), get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_up_adjacencies_2d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::Range::index(), moab::HalfFacetRep::lConnMap2D, moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, MBTRI, moab::HalfFacetRep::LocalMaps2D::next, moab::NestedRefine::level_memory::num_edges, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::NestedRefine::refPatterns::nv_edge, refTemplates, moab::Range::size(), moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_edge, moab::NestedRefine::level_memory::start_face, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::NestedRefine::refPatterns::total_new_verts, update_global_ahf_1D_sub(), and update_local_ahf().
    ErrorCode error;
    int nedges_prev;
    if( cur_level )
        nedges_prev = level_mesh[cur_level - 1].num_edges;
    else
        nedges_prev = _inedges.size();
    int nve    = refTemplates[0][d].nv_edge;
    int ne = 0, dim = 0, index = 0;
        index = type - 2;
        ne    = ahf->lConnMap2D[index].num_verts_in_face;
        dim   = 2;
        index = ahf->get_index_in_lmap( *( _incells.begin() ) );
        ne    = ahf->lConnMap3D[index].num_edges_in_cell;
        dim   = 3;
    std::vector< EntityHandle > adjents, econn, fconn;
    std::vector< int > leids;
    // Loop over all the edges and gather the vertices to be used for refinement
    for( int eid = 0; eid < nedges_prev; eid++ )
        adjents.clear();
        leids.clear();
        econn.clear();
        fconn.clear();
        for( int i = 0; i < vtotal; i++ )
            vbuffer[i] = 0;
            ent_buffer[i] = 0;
        EntityHandle edge;
        if( cur_level )
        else
        error = get_connectivity( edge, cur_level, econn );MB_CHK_ERR( error );
        for( int i = 0; i < (int)econn.size(); i++ )
            if( cur_level )
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( econn[i] - level_mesh[cur_level - 1].start_vertex );
            else
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( econn[i] - *_inverts.begin() );
        int fid = -1, lid = -1, idx1 = -1, idx2 = -1;
        if( dim == 2 )
            error = ahf->get_up_adjacencies_2d( edge, adjents, &leids );MB_CHK_ERR( error );
            if( cur_level )
                fid = adjents[0] - level_mesh[cur_level - 1].start_face;
            else
                fid = _infaces.index( adjents[0] );
            lid  = leids[0];
            idx1 = lid;
            idx2 = ahf->lConnMap2D[index].next[lid];
        else if( dim == 3 )
            error = ahf->get_up_adjacencies_edg_3d( edge, adjents, &leids );MB_CHK_ERR( error );
            if( cur_level )
                fid = adjents[0] - level_mesh[cur_level - 1].start_cell;
            else
                fid = _incells.index( adjents[0] );
            lid  = leids[0];
            idx1 = ahf->lConnMap3D[index].e2v[lid][0];
            idx2 = ahf->lConnMap3D[index].e2v[lid][1];
        error = get_connectivity( adjents[0], cur_level, fconn );MB_CHK_ERR( error );
        bool orient = false;
        if( ( fconn[idx1] == econn[0] ) && ( fconn[idx2] == econn[1] ) ) orient = true;
        if( orient )
            for( int j = 0; j < nve; j++ )
                vbuffer[j + 2] = trackverts[fid * ne * nve + nve * lid + j];
        else
                vbuffer[( nve - j - 1 ) + 2] = trackverts[fid * ne * nve + nve * lid + j];
        int id1, id2;
            count_nents += 1;
    error = update_global_ahf_1D_sub( cur_level, deg );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::construct_hm_2D ( int  cur_level,
int  deg
) [protected]
Definition at line 1048 of file NestedRefine.cpp.
References _inedges, _infaces, _inverts, ahf, moab::Range::begin(), compute_coordinates(), construct_hm_1D(), moab::Range::empty(), moab::NestedRefine::refPatterns::ents_conn, moab::error(), ErrorCode, moab::NestedRefine::level_memory::face_conn, get_connectivity(), get_coordinates(), get_index_from_degree(), moab::HalfFacetRep::get_up_adjacencies_2d(), moab::HalfFacetRep::lConnMap2D, level_mesh, MB_CHK_ERR, MB_SUCCESS, mbImpl, moab::NestedRefine::level_memory::num_faces, moab::NestedRefine::level_memory::num_verts, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::NestedRefine::refPatterns::nv_edge, refTemplates, moab::Range::size(), moab::NestedRefine::level_memory::start_face, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::NestedRefine::refPatterns::total_new_verts, moab::Core::type_from_handle(), update_global_ahf(), update_local_ahf(), and moab::NestedRefine::refPatterns::vert_on_edges.
Referenced by construct_hm_entities(), subdivide_cells(), and subdivide_tets().
    ErrorCode error;
    if( cur_level )
        nents_prev  = level_mesh[cur_level - 1].num_faces;
    else
        nents_prev  = _infaces.size();
    // Create some book-keeping arrays over the old mesh to avoid introducing duplicate vertices and
    // calculating vertices more than once.
    EntityType ftype = mbImpl->type_from_handle( *_infaces.begin() );
    int nepf         = ahf->lConnMap2D[ftype - 2].num_verts_in_face;
    int findex       = ftype - 1;
    int tnv    = refTemplates[findex][d].total_new_verts;
    int vtotal = nepf + tnv;
    int etotal = refTemplates[findex][d].total_new_ents;
    int nve = refTemplates[findex][d].nv_edge;
    std::vector< EntityHandle > trackvertsF( nents_prev * nepf * nve, 0 );
    int cur_nverts = level_mesh[cur_level].num_verts;
    std::vector< int > flag_verts( cur_nverts - nverts_prev, 0 );
    int count_nverts = nverts_prev;
    std::vector< EntityHandle > conn, cur_conn;
    for( int fid = 0; fid < nents_prev; fid++ )
        conn.clear();
        cur_conn.clear();
            vbuffer[i] = 0;
            ent_buffer[i] = 0;
        // EntityHandle of the working face
        EntityHandle face;
        if( cur_level )
            face = level_mesh[cur_level - 1].start_face + fid;
        else
            face = _infaces[fid];
        error = get_connectivity( face, cur_level, conn );MB_CHK_ERR( error );
        // Step 1: Add vertices from the current level for the working face that will be used for
        // subdivision.
        // Add the corners to vbuffer
            if( cur_level )
            else
            cur_conn.push_back( vbuffer[i] );
        // Gather vertices already added to tracking array due to refinement of the sibling faces
        for( int i = 0; i < nepf; i++ )
                int id      = refTemplates[findex][d].vert_on_edges[i][j];
                vbuffer[id] = trackvertsF[fid * nve * nepf + nve * i + j];
        // Add the remaining vertex handles to vbuffer for the current level for the working face
        for( int i = 0; i < tnv; i++ )
            if( !vbuffer[i + nepf] )
                vbuffer[i + nepf] = level_mesh[cur_level].start_vertex + count_nverts;
                count_nverts += 1;
        // Step 2: Create the subentities using the template and the vbuffer
        int idx;
            for( int k = 0; k < nepf; k++ )
                idx                                                     = refTemplates[findex][d].ents_conn[i][k];
                level_mesh[cur_level].face_conn[nepf * count_nents + k] = vbuffer[idx];
            ent_buffer[i] = level_mesh[cur_level].start_face + count_nents;
            count_nents += 1;
        // Step 3: Update the local AHF maps
        error = update_local_ahf( deg, ftype, &vbuffer[0], &ent_buffer[0], etotal );MB_CHK_ERR( error );
        // Step 4: Add the new vertices to the tracking array
        int id;
            // Add the vertices to trackvertsF for fid
                trackvertsF[fid * nepf * nve + nve * i + j] = vbuffer[id];
            std::vector< EntityHandle > sibfids;
            std::vector< int > sibleids;
            std::vector< int > siborient;
            // Add the vertices to trackvertsF for siblings of fid, if any.
            error = ahf->get_up_adjacencies_2d( face, i, false, sibfids, &sibleids, &siborient );MB_CHK_ERR( error );
            if( !sibfids.size() ) continue;
            for( int s = 0; s < (int)sibfids.size(); s++ )
                int sibid;
                if( cur_level )
                    sibid = sibfids[s] - level_mesh[cur_level - 1].start_face;
                else
                    sibid = sibfids[s] - *_infaces.begin();
                if( siborient[s] )  // Same half-edge direction as the current half-edge
                        trackvertsF[sibid * nepf * nve + nve * sibleids[s] + j] = vbuffer[id];
                else
                        id = refTemplates[findex][d].vert_on_edges[i][nve - j - 1];
        // Step 5: Compute the coordinates of the new vertices, avoids computing more than once via
        // the flag_verts array.
        std::vector< double > corner_coords( nepf * 3 );
        error = get_coordinates( &cur_conn[0], nepf, cur_level + 1, &corner_coords[0] );MB_CHK_ERR( error );
        error = compute_coordinates( cur_level, deg, ftype, &vbuffer[0], vtotal, &corner_coords[0], flag_verts,
                                     nverts_prev );MB_CHK_ERR( error );
    // Step 6: Update the global maps
    error = update_global_ahf( ftype, cur_level, deg );MB_CHK_ERR( error );
    // Step 7: If edges exists, refine them.
    if( !_inedges.empty() )
        error = construct_hm_1D( cur_level, deg, ftype, trackvertsF );MB_CHK_ERR( error );
    return MB_SUCCESS;
int  deg,
EntityType  type,
std::vector< EntityHandle > &  trackvertsC_edg,
std::vector< EntityHandle > &  trackvertsF
) [protected]
Definition at line 1223 of file NestedRefine.cpp.
References _incells, _inedges, _infaces, _inverts, ahf, moab::Range::begin(), moab::HalfFacetRep::LocalMaps3D::e2v, moab::NestedRefine::level_memory::edge_conn, moab::NestedRefine::refPatterns::ents_conn, moab::error(), ErrorCode, moab::HalfFacetRep::LocalMaps3D::f2leid, moab::NestedRefine::level_memory::face_conn, get_connectivity(), get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_up_adjacencies_face_3d(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::NestedRefine::intFEdge::ieconn, moab::Range::index(), intFacEdg, moab::HalfFacetRep::lConnMap2D, moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps2D::next, moab::NestedRefine::intFEdge::nie, moab::NestedRefine::level_memory::num_edges, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::NestedRefine::level_memory::num_faces, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::NestedRefine::refPatterns::nv_edge, moab::NestedRefine::refPatterns::nv_face, refTemplates, reorder_indices(), moab::Range::size(), moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_face, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::NestedRefine::refPatterns::total_new_verts, update_ahf_1D(), update_global_ahf_2D_sub(), update_local_ahf(), moab::NestedRefine::refPatterns::vert_on_edges, and moab::NestedRefine::refPatterns::vert_on_faces.
    ErrorCode error;
    EntityType ftype = MBTRI;
    if( type == MBHEX ) ftype = MBQUAD;
    int cidx   = ahf->get_index_in_lmap( *( _incells.begin() ) );
    int nepc = ahf->lConnMap3D[cidx].num_edges_in_cell;
    int nfpc = ahf->lConnMap3D[cidx].num_faces_in_cell;
    int nvf    = refTemplates[findex][d].nv_face;
    std::vector< EntityHandle > adjents, fconn, cconn;
    int nents_prev, ecount;
    if( cur_level )
        ecount     = level_mesh[cur_level - 1].num_edges * refTemplates[MBEDGE - 1][d].total_new_ents;
    else
        ecount     = _inedges.size() * refTemplates[MBEDGE - 1][d].total_new_ents;
    for( int it = 0; it < nents_prev; it++ )
        fconn.clear();
        cconn.clear();
        adjents.clear();
        leids.clear();
            vbuffer[i] = 0;
            ent_buffer[i] = 0;
        EntityHandle face;
        if( cur_level )
            face = level_mesh[cur_level - 1].start_face + it;
        else
            face = _infaces[it];
        error = get_connectivity( face, cur_level, fconn );MB_CHK_ERR( error );
        // Add the new handles for old connectivity in the buffer
        for( int i = 0; i < (int)fconn.size(); i++ )
            if( cur_level )
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( fconn[i] - level_mesh[cur_level - 1].start_vertex );
            else
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( fconn[i] - *_inverts.begin() );
        // Add handles for vertices on edges and faces from the already refined cell
        int fid, lid;
        error = ahf->get_up_adjacencies_face_3d( face, adjents, &leids );MB_CHK_ERR( error );
        if( cur_level )
        else
        lid = leids[0];
        error = get_connectivity( adjents[0], cur_level, cconn );MB_CHK_ERR( error );
        // Find the orientation w.r.t the half-face and then add vertices properly.
        std::vector< EntityHandle > fac_conn( nepf );
        std::vector< EntityHandle > lfac_conn( nepf );
        for( int j = 0; j < nepf; j++ )
            fac_conn[j]  = fconn[j];
            int id       = ahf->lConnMap3D[cidx].hf2v[lid][j];
            lfac_conn[j] = cconn[id];
        std::vector< int > le_idx, indices;
        error = reorder_indices( deg, &fac_conn[0], &lfac_conn[0], nepf, le_idx, indices );MB_CHK_ERR( error );
        // Add the existing vertices on edges of the already refined cell to the vbuffer
            int id  = le_idx[j];                              // Corresponding local edge
            int idx = ahf->lConnMap3D[cidx].f2leid[lid][id];  // Local edge in the cell
            // Get the orientation of the local edge of the face wrt the corresponding local edge in
            // the cell
            bool eorient = false;
            int fnext    = ahf->lConnMap2D[ftype - 2].next[j];
            int idx1     = ahf->lConnMap3D[cidx].e2v[idx][0];
            int idx2     = ahf->lConnMap3D[cidx].e2v[idx][1];
            if( ( fconn[j] == cconn[idx1] ) && ( fconn[fnext] == cconn[idx2] ) ) eorient = true;
            if( eorient )
                for( int k = 0; k < nve; k++ )
                    int ind      = refTemplates[findex][d].vert_on_edges[j][k];
                    vbuffer[ind] = trackvertsE[fid * nepc * nve + nve * idx + k];
            else
                    int ind      = refTemplates[findex][d].vert_on_edges[j][nve - k - 1];
        // Add the existing vertices on the face of the refine cell to vbuffer
        if( nvf )
            for( int k = 0; k < nvf; k++ )
                int ind      = refTemplates[findex][d].vert_on_faces[0][k];
                vbuffer[ind] = trackvertsF[fid * nfpc * nvf + nvf * lid + indices[k] - 1];
        // Create the subentities using the template and the vbuffer
                int idx                                                 = refTemplates[findex][d].ents_conn[i][k];
            count_nents += 1;
        // Create the interior edges
        int id1, id2;
        int ne = intFacEdg[ftype - 2][d].nie;
        for( int i = 0; i < ne; i++ )
            id1                                                 = intFacEdg[ftype - 2][d].ieconn[i][0];
            id2                                                 = intFacEdg[ftype - 2][d].ieconn[i][1];
            level_mesh[cur_level].edge_conn[2 * ( ecount )]     = vbuffer[id1];
            level_mesh[cur_level].edge_conn[2 * ( ecount ) + 1] = vbuffer[id2];
            ecount += 1;
    error = update_global_ahf_2D_sub( cur_level, deg );MB_CHK_ERR( error );
    // Step 7: Update the hf-maps for the edges
    error = update_ahf_1D( cur_level );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::construct_hm_3D ( int  cur_level,
int  deg
) [protected]
Definition at line 1405 of file NestedRefine.cpp.
References _incells, moab::Range::begin(), moab::error(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, mbImpl, MBTET, subdivide_cells(), subdivide_tets(), and moab::Core::type_from_handle().
Referenced by construct_hm_entities().
    ErrorCode error;
    EntityType type = mbImpl->type_from_handle( *( _incells.begin() ) );
    if( type == MBTET )
        error = subdivide_tets( cur_level, deg );MB_CHK_ERR( error );
    else
        error = subdivide_cells( type, cur_level, deg );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::construct_hm_entities ( int  cur_level,
int  deg
) [protected]
Definition at line 783 of file NestedRefine.cpp.
References ahf, construct_hm_1D(), construct_hm_2D(), construct_hm_3D(), moab::CURVE, moab::error(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, moab::SURFACE, moab::SURFACE_MIXED, and moab::HalfFacetRep::thismeshtype.
Referenced by generate_hm().
    ErrorCode error;
    // Generate mesh for current level by refining previous level.
    if( ahf->thismeshtype == CURVE )
        error = construct_hm_1D( cur_level, deg );MB_CHK_ERR( error );
    else if( ahf->thismeshtype == SURFACE || ahf->thismeshtype == SURFACE_MIXED )
        error = construct_hm_2D( cur_level, deg );MB_CHK_ERR( error );
    else
        error = construct_hm_3D( cur_level, deg );MB_CHK_ERR( error );
    return MB_SUCCESS;
Definition at line 4165 of file NestedRefine.cpp.
References _inverts, moab::NestedRefine::level_memory::coordinates, moab::error(), ErrorCode, moab::Core::get_coords(), level_mesh, MB_CHK_ERR, MB_SUCCESS, mbImpl, moab::NestedRefine::level_memory::num_verts, and moab::Range::size().
    ErrorCode error;
    if( cur_level )
        int nverts_prev = level_mesh[cur_level - 1].num_verts;
        for( int i = 0; i < nverts_prev; i++ )
            level_mesh[cur_level].coordinates[0][i] = level_mesh[cur_level - 1].coordinates[0][i];
            level_mesh[cur_level].coordinates[1][i] = level_mesh[cur_level - 1].coordinates[1][i];
            level_mesh[cur_level].coordinates[2][i] = level_mesh[cur_level - 1].coordinates[2][i];
    else  // Copy the vertices from the input mesh
        int nverts_in = _inverts.size();
        std::vector< double > vcoords( 3 * nverts_in );
        error = mbImpl->get_coords( _inverts, &vcoords[0] );MB_CHK_ERR( error );
        for( int i = 0; i < nverts_in; i++ )
            level_mesh[cur_level].coordinates[0][i] = vcoords[3 * i];
            level_mesh[cur_level].coordinates[1][i] = vcoords[3 * i + 1];
            level_mesh[cur_level].coordinates[2][i] = vcoords[3 * i + 2];
    return MB_SUCCESS;
    // To add: Map from old vertices to new duplicates: NOT NEEDED
ErrorCode moab::NestedRefine::count_subentities ( EntityHandle  set,
int  cur_level,
int *  nedges,
int *  nfaces
) [protected]
Definition at line 4520 of file NestedRefine.cpp.
References _incells, _inedges, _infaces, ahf, moab::HalfFacetRep::count_subentities(), moab::error(), ErrorCode, moab::Core::get_entities_by_dimension(), MB_CHK_ERR, MB_SUCCESS, and mbImpl.
Referenced by estimate_hm_storage().
    ErrorCode error;
    if( cur_level >= 0 )
        Range edges, faces, cells;
        error = mbImpl->get_entities_by_dimension( set, 1, edges );MB_CHK_ERR( error );
        error = mbImpl->get_entities_by_dimension( set, 2, faces );MB_CHK_ERR( error );
        error = mbImpl->get_entities_by_dimension( set, 3, cells );MB_CHK_ERR( error );
        error = ahf->count_subentities( edges, faces, cells, nedges, nfaces );MB_CHK_ERR( error );
    else
        error = ahf->count_subentities( _inedges, _infaces, _incells, nedges, nfaces );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::create_hm_storage_single_level ( EntityHandle set,
int  cur_level,
int  estL[4]
) [protected]
Definition at line 624 of file NestedRefine.cpp.
References _incells, _infaces, moab::Core::add_entities(), ahf, moab::ReadUtilIface::assign_ids(), moab::Range::begin(), moab::NestedRefine::level_memory::cells, moab::Core::create_meshset(), moab::NestedRefine::level_memory::edges, moab::error(), ErrorCode, moab::NestedRefine::level_memory::faces, moab::ReadUtilIface::get_element_connect(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_mesh_type(), moab::ReadUtilIface::get_node_coords(), GLOBAL_ID_TAG_NAME, moab::HalfFacetRep::lConnMap2D, moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MBEDGE, mbImpl, MESHSET_SET, moab::NestedRefine::level_memory::num_cells, moab::NestedRefine::level_memory::num_edges, moab::NestedRefine::level_memory::num_faces, moab::NestedRefine::level_memory::num_verts, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::Interface::query_interface(), moab::HalfFacetRep::resize_hf_maps(), moab::Core::tag_get_handle(), moab::HalfFacetRep::thismeshtype, moab::Core::type_from_handle(), moab::HalfFacetRep::update_entity_ranges(), and moab::NestedRefine::level_memory::verts.
    // Obtain chunks of memory for the current level. Add them to a particular meshset.
    EntityHandle set_handle;
    ErrorCode error = mbImpl->create_meshset( MESHSET_SET, set_handle );MB_CHK_SET_ERR( error, "Cannot create mesh for the current level" );
    *set = set_handle;
    ReadUtilIface* read_iface;
    error = mbImpl->query_interface( read_iface );MB_CHK_ERR( error );
    // Vertices
    error = read_iface->get_node_coords( 3, estL[0], 0, level_mesh[cur_level].start_vertex,
                                         level_mesh[cur_level].coordinates );MB_CHK_ERR( error );
    level_mesh[cur_level].num_verts = estL[0];
    Range newverts( level_mesh[cur_level].start_vertex, level_mesh[cur_level].start_vertex + estL[0] - 1 );
    error = mbImpl->add_entities( *set, newverts );MB_CHK_ERR( error );
    level_mesh[cur_level].verts = newverts;
    Tag gidtag;
    error = mbImpl->tag_get_handle( GLOBAL_ID_TAG_NAME, gidtag );MB_CHK_ERR( error );
    error = read_iface->assign_ids( gidtag, newverts, level_mesh[cur_level].start_vertex );MB_CHK_ERR( error );
    // Edges
    if( estL[1] )
        error = read_iface->get_element_connect( estL[1], 2, MBEDGE, 0, level_mesh[cur_level].start_edge,
                                                 level_mesh[cur_level].edge_conn );MB_CHK_ERR( error );
        level_mesh[cur_level].num_edges = estL[1];
        Range newedges( level_mesh[cur_level].start_edge, level_mesh[cur_level].start_edge + estL[1] - 1 );
        error = mbImpl->add_entities( *set, newedges );MB_CHK_ERR( error );
        level_mesh[cur_level].edges = newedges;
    else
        level_mesh[cur_level].num_edges = 0;
    // Faces
    if( estL[2] )
        EntityType type = mbImpl->type_from_handle( *( _infaces.begin() ) );
        int nvpf        = ahf->lConnMap2D[type - 2].num_verts_in_face;
        error           = read_iface->get_element_connect( estL[2], nvpf, type, 0, level_mesh[cur_level].start_face,
                                                           level_mesh[cur_level].face_conn );MB_CHK_ERR( error );
        level_mesh[cur_level].num_faces = estL[2];
        Range newfaces( level_mesh[cur_level].start_face, level_mesh[cur_level].start_face + estL[2] - 1 );
        error = mbImpl->add_entities( *set, newfaces );MB_CHK_ERR( error );
        level_mesh[cur_level].faces = newfaces;
    else
        level_mesh[cur_level].num_faces = 0;
    // Cells
    if( estL[3] )
        int index       = ahf->get_index_in_lmap( *_incells.begin() );
        int nvpc        = ahf->lConnMap3D[index].num_verts_in_cell;
        error           = read_iface->get_element_connect( estL[3], nvpc, type, 0, level_mesh[cur_level].start_cell,
                                                           level_mesh[cur_level].cell_conn );MB_CHK_ERR( error );
        level_mesh[cur_level].num_cells = estL[3];
        Range newcells( level_mesh[cur_level].start_cell, level_mesh[cur_level].start_cell + estL[3] - 1 );
        error = mbImpl->add_entities( *set, newcells );MB_CHK_ERR( error );
        level_mesh[cur_level].cells = newcells;
    else
        level_mesh[cur_level].num_cells = 0;
    // Resize the ahf maps
    error = ahf->resize_hf_maps( level_mesh[cur_level].start_vertex, level_mesh[cur_level].num_verts,
                                 level_mesh[cur_level].start_edge, level_mesh[cur_level].num_edges,
                                 level_mesh[cur_level].start_face, level_mesh[cur_level].num_faces,
                                 level_mesh[cur_level].start_cell, level_mesh[cur_level].num_cells );MB_CHK_ERR( error );
    error = ahf->update_entity_ranges( *set );MB_CHK_ERR( error );
    // If the mesh type changes, then update the member variable in ahf to use the applicable
    // adjacency matrix
    MESHTYPE nwmesh = ahf->get_mesh_type( level_mesh[cur_level].num_verts, level_mesh[cur_level].num_edges,
                                          level_mesh[cur_level].num_faces, level_mesh[cur_level].num_cells );MB_CHK_ERR( error );
    if( ahf->thismeshtype != nwmesh ) ahf->thismeshtype = nwmesh;
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::estimate_hm_storage ( EntityHandle  set,
int  level_degree,
int  cur_level,
int  hmest[4]
) [protected]
Definition at line 564 of file NestedRefine.cpp.
References _incells, _inedges, _infaces, _inverts, moab::Range::begin(), count_subentities(), moab::error(), ErrorCode, get_index_from_degree(), intFacEdg, level_mesh, MB_CHK_ERR, MB_SUCCESS, MBEDGE, mbImpl, meshdim, moab::NestedRefine::intFEdge::nie, moab::NestedRefine::level_memory::num_cells, moab::NestedRefine::level_memory::num_edges, moab::NestedRefine::level_memory::num_faces, moab::NestedRefine::level_memory::num_verts, moab::NestedRefine::refPatterns::nv_cell, moab::NestedRefine::refPatterns::nv_edge, moab::NestedRefine::refPatterns::nv_face, refTemplates, moab::Range::size(), moab::NestedRefine::level_memory::start_face, moab::NestedRefine::refPatterns::total_new_ents, and moab::Core::type_from_handle().
    ErrorCode error;
    // Obtain the size of input mesh.
    int nverts_prev, nedges_prev, nfaces_prev, ncells_prev;
    if( cur_level )
        nfaces_prev = level_mesh[cur_level - 1].num_faces;
        ncells_prev = level_mesh[cur_level - 1].num_cells;
    else
        nfaces_prev = _infaces.size();
        ncells_prev = _incells.size();
    // Estimate mesh size of current level mesh.
    int nedges = 0, nfaces = 0;
    error = count_subentities( set, cur_level - 1, &nedges, &nfaces );MB_CHK_ERR( error );
    int d      = get_index_from_degree( level_degree );
    int nverts = refTemplates[MBEDGE - 1][d].nv_edge * nedges;
    hmest[0]   = nverts_prev + nverts;
    hmest[1]   = nedges_prev * refTemplates[MBEDGE - 1][d].total_new_ents;
    hmest[2]   = 0;
    hmest[3]   = 0;
    int findex, cindex;
    if( nfaces_prev != 0 )
        EntityHandle start_face;
        if( cur_level )
            start_face = level_mesh[cur_level - 1].start_face;
        else
            start_face = *_infaces.begin();
        findex   = mbImpl->type_from_handle( start_face ) - 1;
        hmest[2] = nfaces_prev * refTemplates[findex][d].total_new_ents;
        if( meshdim == 2 ) hmest[0] += refTemplates[findex][d].nv_face * nfaces_prev;
        if( meshdim == 3 ) hmest[1] += nfaces_prev * intFacEdg[findex - 1][d].nie;
    if( ncells_prev != 0 )
        hmest[3] = ncells_prev * refTemplates[cindex][d].total_new_ents;
        hmest[0] += refTemplates[cindex][d].nv_face * nfaces;
        hmest[0] += refTemplates[cindex][d].nv_cell * ncells_prev;
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::exchange_ghosts ( std::vector< EntityHandle > &  lsets,
int  num_glayers
Examples:
Definition at line 454 of file NestedRefine.cpp.
References moab::Core::add_entities(), moab::error(), ErrorCode, moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_tags(), moab::Core::get_adjacencies(), moab::Core::get_connectivity(), moab::Core::get_entities_by_dimension(), GLOBAL_ID_TAG_NAME, hasghost, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, meshdim, pcomm, and moab::Interface::UNION.
Referenced by main().
    ErrorCode error;
    if( hasghost ) return MB_SUCCESS;
    hasghost = true;
    error = pcomm->exchange_ghost_cells( meshdim, 0, num_glayers, 0, true, false );MB_CHK_ERR( error );
        Range empty_range;
        error = pcomm->exchange_tags( GLOBAL_ID_TAG_NAME, empty_range );MB_CHK_ERR( error );
        // error = pcomm->assign_global_ids(lsets[i], 0, 1, false, true, false);MB_CHK_ERR(error);
#else
    MB_SET_ERR( MB_FAILURE, "Requesting ghost layers for a serial mesh" );
#endif
    Range* lverts = new Range[lsets.size()];
    Range* lents  = new Range[lsets.size()];
    for( size_t i = 0; i < lsets.size(); i++ )
        error = mbImpl->get_entities_by_dimension( lsets[i], meshdim, lents[i] );MB_CHK_ERR( error );
        error = mbImpl->get_connectivity( lents[i], lverts[i] );MB_CHK_ERR( error );
        for( int gl = 0; gl < num_glayers; gl++ )
            error = mbImpl->get_adjacencies( lverts[i], meshdim, false, lents[i], Interface::UNION );MB_CHK_ERR( error );
        error = mbImpl->add_entities( lsets[i], lverts[i] );MB_CHK_ERR( error );
        error = mbImpl->add_entities( lsets[i], lents[i] );MB_CHK_ERR( error );
    delete[] lverts;
    delete[] lents;
    return MB_SUCCESS;
int moab::NestedRefine::find_shortest_diagonal_octahedron ( int  cur_level,
int  deg,
) [protected]
Definition at line 4580 of file NestedRefine.cpp.
References moab::error(), ErrorCode, get_octahedron_corner_coords(), length(), MB_SET_ERR, and MB_SUCCESS.
Referenced by subdivide_tets().
    ErrorCode error;
    double coords[18];
    error = get_octahedron_corner_coords( cur_level, deg, vbuffer, coords );
    if( error != MB_SUCCESS ) MB_SET_ERR( MB_FAILURE, "Error in obtaining octahedron corner coordinates" );
    int diag_map[6] = { 1, 3, 2, 4, 5, 0 };
    double length   = std::numeric_limits< double >::max();
    int diag = 0;
    double x, y, z;
    x = y = z = 0;
    for( int d = 0; d < 3; d++ )
        int id1     = diag_map[2 * d];
        int id2     = diag_map[2 * d + 1];
        x           = coords[3 * id1] - coords[3 * id2];
        y           = coords[3 * id1 + 1] - coords[3 * id2 + 1];
        z           = coords[3 * id1 + 2] - coords[3 * id2 + 2];
        double dlen = sqrt( x * x + y * y + z * z );
        if( dlen < length )
            length = dlen;
            diag   = d + 1;
    return diag;
ErrorCode moab::NestedRefine::generate_hm ( int *  level_degrees,
int  num_level,
EntityHandle hm_set,
bool  optimize
) [protected]
Definition at line 715 of file NestedRefine.cpp.
References _rset, construct_hm_entities(), copy_vertices_from_prev_level(), create_hm_storage_single_level(), moab::error(), ErrorCode, estimate_hm_storage(), GLOBAL_ID_TAG_NAME, MB_CHK_ERR, MB_SUCCESS, mbImpl, nlevels, pcomm, moab::ParallelComm::size(), moab::Core::tag_get_handle(), moab::CpuTimer::time_elapsed(), timeall, tm, moab::NestedRefine::codeperf::tm_refine, moab::NestedRefine::codeperf::tm_resolve, and moab::NestedRefine::codeperf::tm_total.
Referenced by generate_mesh_hierarchy().
    ErrorCode error;
    Tag gidtag;
    nlevels = num_level;
    timeall.tm_total   = 0;
    timeall.tm_refine  = 0;
    timeall.tm_resolve = 0;
    for( int l = 0; l < num_level; l++ )
        double tstart;
        tstart = tm->time_elapsed();
        // Estimate storage
        int hmest[4] = { 0, 0, 0, 0 };
        EntityHandle set;
        if( l )
            set = hm_set[l - 1];
        else
            set = _rset;
        error = estimate_hm_storage( set, level_degrees[l], l, hmest );MB_CHK_ERR( error );
        // Create arrays for storing the current level
        error = create_hm_storage_single_level( &hm_set[l], l, hmest );MB_CHK_ERR( error );
        // Copy the old vertices along with their coordinates
        error = copy_vertices_from_prev_level( l );MB_CHK_ERR( error );
        // Create the new entities and new vertices
        error = construct_hm_entities( l, level_degrees[l] );MB_CHK_ERR( error );
        timeall.tm_refine += tm->time_elapsed() - tstart;
        // Go into parallel communication
        if( !optimize )
            if( pcomm && ( pcomm->size() > 1 ) )
                double tpstart = tm->time_elapsed();
                error          = resolve_shared_ents_parmerge( l, hm_set[l] );MB_CHK_ERR( error );
                timeall.tm_resolve += tm->time_elapsed() - tpstart;
#endif
    if( optimize )
            error          = resolve_shared_ents_opt( hm_set, nlevels );MB_CHK_ERR( error );
            timeall.tm_resolve = tm->time_elapsed() - tpstart;
#endif
    timeall.tm_total = timeall.tm_refine + timeall.tm_resolve;
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::generate_mesh_hierarchy ( int  num_level,
std::vector< EntityHandle > &  level_sets,
bool  optimize = false
Given a mesh, generate a sequence of meshes via uniform refinement. The inputs are: a) an array(level_degrees) storing the degrees which will be used to refine the previous level mesh to generate a new level and b) the total number of levels(should be same length as that of the array in a). Each mesh level in the hierarchy are stored in different meshsets whose handles are returned after the hierarchy generation. These handles can be used to work with a specific mesh level.
Parameters:
level_degreesInteger array storing the degrees used in each level.
num_levelThe total number of levels in the hierarchy.
hm_setEntityHandle STL vector that returns the handles of the sets created for each mesh level.
Examples:
Definition at line 114 of file NestedRefine.cpp.
References _rset, moab::error(), ErrorCode, generate_hm(), level_dsequence, MB_CHK_ERR, MB_SUCCESS, meshdim, and nlevels.
    assert( num_level > 0 );
    ErrorCode error;
    std::vector< moab::EntityHandle > hmsets( num_level );
    if( meshdim <= 2 )
        for( int i = 0; i < num_level; i++ )
            assert( ( level_degrees[i] == 2 ) || ( level_degrees[i] == 3 ) || ( level_degrees[i] == 5 ) );
            level_dsequence[i] = level_degrees[i];
    else
            assert( ( level_degrees[i] == 2 ) || ( level_degrees[i] == 3 ) );
    error = generate_hm( level_degrees, num_level, &hmsets[0], optimize );MB_CHK_ERR( error );
    // copy the entity handles
    level_sets.resize( num_level + 1 );
    level_sets[0] = _rset;
        level_sets[i + 1] = hmsets[i];
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::get_adjacencies ( const EntityHandle  source_entity,
std::vector< EntityHandle > &  target_entities
Given an entity of dimension d, gather all the adjacent D dimensional entities where D >, = , < d .
Parameters:
source_entityEntityHandle to which adjacent entities have to be found.
target_dimensionInt Dimension of the desired adjacent entities.
target_entitiesVector in which the adjacent EntityHandle are returned.
Definition at line 223 of file NestedRefine.cpp.
References ahf, moab::error(), ErrorCode, moab::HalfFacetRep::get_adjacencies(), MB_CHK_ERR, and MB_SUCCESS.
    ErrorCode error;
    error = ahf->get_adjacencies( source_entity, target_dimension, target_entities );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::get_connectivity ( EntityHandle  ent,
int  level,
std::vector< EntityHandle > &  conn
Given an entity at a certain level, it finds the connectivity via direct access to a stored internal pointer to the memory to connectivity sequence for the given level.
Parameters:
entEntityHandle of the entity
levelInteger level of the entity for which connectivity is requested
connstd::vector returning the connectivity of the entity
Definition at line 153 of file NestedRefine.cpp.
References _incells, ahf, moab::Range::begin(), moab::NestedRefine::level_memory::cell_conn, moab::error(), ErrorCode, moab::NestedRefine::level_memory::face_conn, moab::Core::get_connectivity(), moab::HalfFacetRep::get_index_in_lmap(), moab::ID_FROM_HANDLE(), moab::HalfFacetRep::lConnMap2D, moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBHEX, mbImpl, MBQUAD, MBTET, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_edge, moab::NestedRefine::level_memory::start_face, and moab::Core::type_from_handle().
Referenced by construct_hm_1D(), construct_hm_2D(), get_local_vid(), reorder_indices(), subdivide_cells(), subdivide_tets(), update_global_ahf_1D_sub(), update_global_ahf_2D(), and update_global_ahf_2D_sub().
    ErrorCode error;
    EntityType type = mbImpl->type_from_handle( ent );
    EntityHandle start_ent;
    if( !conn.empty() ) conn.clear();
    if( level > 0 )
            conn.reserve( 2 );
            start_ent       = level_mesh[level - 1].start_edge;
            EntityID offset = ID_FROM_HANDLE( ent ) - ID_FROM_HANDLE( start_ent );
            conn.push_back( level_mesh[level - 1].edge_conn[2 * offset] );
            conn.push_back( level_mesh[level - 1].edge_conn[2 * offset + 1] );
            int num_corners = ahf->lConnMap2D[type - 2].num_verts_in_face;
            conn.reserve( num_corners );
            start_ent       = level_mesh[level - 1].start_face;
            for( int i = 0; i < num_corners; i++ )
                conn.push_back( level_mesh[level - 1].face_conn[num_corners * offset + i] );
            int num_corners = ahf->lConnMap3D[index].num_verts_in_cell;
            start_ent       = level_mesh[level - 1].start_cell;
                conn.push_back( level_mesh[level - 1].cell_conn[num_corners * offset + i] );
        else
            MB_SET_ERR( MB_FAILURE, "Requesting connectivity for an unsupported entity type" );
    else
        error = mbImpl->get_connectivity( &ent, 1, conn );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::get_coordinates ( EntityHandle verts,
int  num_verts,
int  level,
double *  coords
Given a vector of vertices at a certain level, it finds the coordinates via direct access to a stored internal pointer to the memory to coordinate sequence for the given level.
Parameters:
vertsstd::vector of the entity handles of the vertices
num_vertsThe number of vertices
coordsdouble pointer returning the coordinates of the vertices
Definition at line 200 of file NestedRefine.cpp.
References moab::NestedRefine::level_memory::coordinates, moab::error(), ErrorCode, moab::Core::get_coords(), moab::ID_FROM_HANDLE(), level_mesh, MB_CHK_ERR, MB_SUCCESS, and mbImpl.
    if( level > 0 )
        EntityID vstart = ID_FROM_HANDLE( level_mesh[level - 1].start_vertex );
        for( int i = 0; i < num_verts; i++ )
            const EntityHandle& vid = verts[i];
            EntityID offset         = ID_FROM_HANDLE( vid ) - vstart;
            coords[3 * i]           = level_mesh[level - 1].coordinates[0][offset];
            coords[3 * i + 1]       = level_mesh[level - 1].coordinates[1][offset];
            coords[3 * i + 2]       = level_mesh[level - 1].coordinates[2][offset];
    else
        ErrorCode error;
        error = mbImpl->get_coords( verts, num_verts, coords );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::get_lid_inci_child ( EntityType  type,
int  deg,
int  lfid,
int  leid,
std::vector< int > &  child_ids,
std::vector< int > &  child_lvids
) [protected]
Definition at line 3985 of file NestedRefine.cpp.
References _incells, ahf, moab::Range::begin(), moab::NestedRefine::refPatterns::ents_conn, moab::NestedRefine::refPatterns::ents_on_pent, get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::lConnMap3D, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::NestedRefine::refPatterns::nv_edge, and refTemplates.
    // int lv0 = ahf->lConnMap3D[index].e2v[leid][0];
    //  int lv1 = ahf->lConnMap3D[index].e2v[leid][1];
    int nv  = refTemplates[type - 1][d].nv_edge;
    int nch = refTemplates[type - 1][d].ents_on_pent[lfid][0];
    for( int i = 0; i < nch; i++ )
        int id = refTemplates[type - 1][d].ents_on_pent[lfid][i + 1] - 1;
        for( int j = 0; j < nvpc; j++ )
            int lv = refTemplates[type - 1][d].ents_conn[id][j];
            for( int k = 0; k < nv; k++ )
                if( lv == refTemplates[type - 1][d].vert_on_edges[leid][k] )
                    child_ids.push_back( id );
                    child_lvids.push_back( j );
    return MB_SUCCESS;
int moab::NestedRefine::get_local_vid ( EntityHandle  vid,
EntityHandle  ent,
int  level
) [protected]
Definition at line 4612 of file NestedRefine.cpp.
References moab::error(), ErrorCode, get_connectivity(), MB_SET_ERR, and MB_SUCCESS.
Referenced by update_global_ahf_1D(), update_global_ahf_1D_sub(), update_global_ahf_2D(), update_global_ahf_2D_sub(), and update_global_ahf_3D().
    ErrorCode error;
    // Given a vertex, find its local id in the given entity
    error = get_connectivity( ent, level + 1, conn );
    if( error != MB_SUCCESS ) MB_SET_ERR( MB_FAILURE, "Error in getting connectivity of the requested entity" );
    int lid = -1;
        if( conn[i] == vid )
            lid = i;
            break;
    if( lid < 0 ) MB_SET_ERR( MB_FAILURE, "Error in getting local vertex id in the given entity" );
    return lid;
ErrorCode moab::NestedRefine::get_octahedron_corner_coords ( int  cur_level,
int  deg,
double *  ocoords
) [protected]
Definition at line 4544 of file NestedRefine.cpp.
References moab::NestedRefine::level_memory::coordinates, level_mesh, MB_SUCCESS, and moab::NestedRefine::level_memory::start_vertex.
Referenced by find_shortest_diagonal_octahedron().
    int lid[6] = { 0, 0, 0, 0, 0, 0 };
    if( deg == 2 )
        lid[0] = 5;
        lid[1] = 8;
        lid[2] = 9;
        lid[3] = 6;
        lid[4] = 4;
        lid[5] = 7;
    else if( deg == 3 )
        lid[0] = 19;
        lid[1] = 16;
        lid[2] = 18;
        lid[3] = 9;
        lid[4] = 4;
        lid[5] = 10;
    for( int i = 0; i < 6; i++ )
        EntityHandle vid   = vbuffer[lid[i]];
        ocoords[3 * i]     = level_mesh[cur_level].coordinates[0][vid - vstart];
        ocoords[3 * i + 1] = level_mesh[cur_level].coordinates[1][vid - vstart];
        ocoords[3 * i + 2] = level_mesh[cur_level].coordinates[2][vid - vstart];
    return MB_SUCCESS;
Definition at line 425 of file NestedRefine.cpp.
References _inverts, moab::Range::begin(), level_mesh, MB_SET_ERR, MB_SUCCESS, moab::Range::size(), and moab::NestedRefine::level_memory::start_vertex.
    if( ( vertex - *_inverts.begin() ) > _inverts.size() )
        MB_SET_ERR( MB_FAILURE, "Requesting duplicates for non-coarse vertices" );
    dupvertex = level_mesh[level - 1].start_vertex + ( vertex - *_inverts.begin() );
    return MB_SUCCESS;
Definition at line 53 of file NestedRefine.cpp.
References _incells, _inedges, _infaces, _inverts, _rset, moab::Core::a_half_facet_rep(), ahf, moab::HalfFacetRep::check_mixed_entity_type(), deg_index, elementype, moab::Range::empty(), moab::error(), ErrorCode, moab::HalfFacetRep::get_entity_ranges(), hasghost, moab::HalfFacetRep::initialize(), MB_CHK_ERR, MB_MEMORY_ALLOCATION_FAILED, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBHEX, mbImpl, MBPOLYGON, MBTET, meshdim, pcomm, tm, and moab::Core::type_from_handle().
Referenced by NestedRefine().
    ErrorCode error;
    tm = new CpuTimer();
    if( !tm ) return MB_MEMORY_ALLOCATION_FAILED;
    ahf = mbImpl->a_half_facet_rep();
#else
    ahf = new HalfFacetRep( mbImpl, pcomm, _rset, true );
    if( !ahf ) return MB_MEMORY_ALLOCATION_FAILED;
#endif
    // Check for mixed entity type
    bool chk_mixed = ahf->check_mixed_entity_type();
    if( chk_mixed ) MB_SET_ERR( MB_NOT_IMPLEMENTED, "Encountered a mesh with mixed entity types" );
    error = ahf->initialize();MB_CHK_ERR( error );
    error = ahf->get_entity_ranges( _inverts, _inedges, _infaces, _incells );MB_CHK_ERR( error );
    // Check for supported entity type
    if( !_incells.empty() )
        EntityType type = mbImpl->type_from_handle( _incells[0] );
        if( type != MBTET && type != MBHEX )
            MB_SET_ERR( MB_FAILURE, "Not supported 3D entity types: MBPRISM, MBPYRAMID, MBKNIFE, MBPOLYHEDRON" );
        meshdim    = 3;
        elementype = type;
    else if( !_infaces.empty() )
        EntityType type = mbImpl->type_from_handle( _infaces[0] );
        if( type == MBPOLYGON ) MB_SET_ERR( MB_FAILURE, "Not supported 2D entity type: POLYGON" );
        meshdim    = 2;
        elementype = type;
    else if( !_inedges.empty() )
        meshdim    = 1;
        elementype = MBEDGE;
    else
        MB_SET_ERR( MB_NOT_IMPLEMENTED, "Encountered a mixed-dimensional or invalid mesh" );
    // Initialize std::map to get indices of degrees.
    deg_index[2] = 0;
    deg_index[3] = 1;
    deg_index[5] = 2;
    // Set ghost flag to false
    hasghost = false;
    return MB_SUCCESS;
bool moab::NestedRefine::is_cell_on_boundary ( const EntityHandle entity) [protected]
Definition at line 4138 of file NestedRefine.cpp.
References _incells, ahf, moab::Range::begin(), elementype, ErrorCode, moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::lConnMap3D, MB_CHK_ERR, MB_SET_ERR, meshdim, and moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell.
Referenced by is_entity_on_boundary().
    if( meshdim != 3 )
        MB_SET_ERR( MB_FAILURE, "Requesting boundary information for a cell entity type on a curve or surface mesh" );
    bool is_border = false;
    int nfpc       = ahf->lConnMap3D[index].num_faces_in_cell;
    EntityHandle sibents[6];
    int siblids[6];
    ErrorCode error = ahf->get_sibling_map( elementype, entity, &sibents[0], &siblids[0], nfpc );MB_CHK_ERR( error );
    for( int i = 0; i < nfpc; i++ )
        if( sibents[i] == 0 )
            is_border = true;
            break;
    return is_border;
bool moab::NestedRefine::is_edge_on_boundary ( const EntityHandle entity) [protected]
Definition at line 4053 of file NestedRefine.cpp.
References ahf, moab::HalfFacetRep::LocalMaps3D::e2hf, elementype, moab::error(), ErrorCode, moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::get_up_adjacencies_2d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::HalfFacetRep::lConnMap3D, MB_CHK_ERR, MBEDGE, meshdim, and moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell.
    ErrorCode error;
    if( meshdim == 1 )  // The edge has a vertex on the boundary in the curve mesh
        EntityHandle sibents[2];
        int siblids[2];
        error = ahf->get_sibling_map( MBEDGE, entity, &sibents[0], &siblids[0], 2 );MB_CHK_ERR( error );
        for( int i = 0; i < 2; i++ )
                is_border = true;
                break;
    else if( meshdim == 2 )  // The edge is on the boundary of the 2d mesh
        std::vector< EntityHandle > adjents;
        error = ahf->get_up_adjacencies_2d( entity, adjents );MB_CHK_ERR( error );
        if( adjents.size() == 1 ) is_border = true;
    else if( meshdim == 3 )  // The edge is part of a face on the boundary of the 3d mesh
        error = ahf->get_up_adjacencies_edg_3d( entity, adjents, &leids );MB_CHK_ERR( error );
        assert( !adjents.empty() );
        int index = ahf->get_index_in_lmap( adjents[0] );
        int nhf   = ahf->lConnMap3D[index].num_faces_in_cell;
        for( int i = 0; i < (int)adjents.size(); i++ )
            int siblids[6];
            error = ahf->get_sibling_map( elementype, adjents[0], &sibents[0], &siblids[0], nhf );MB_CHK_ERR( error );
            for( int k = 0; k < 2; k++ )
                int hf = ahf->lConnMap3D[index].e2hf[leids[0]][k];
                if( sibents[hf] == 0 )
                    is_border = true;
                    break;
    return is_border;
Given an entity at a certain level, it returns a boolean value true if it lies on the domain boundary.
Parameters:
entity
Definition at line 435 of file NestedRefine.cpp.
References is_cell_on_boundary(), is_edge_on_boundary(), is_face_on_boundary(), is_vertex_on_boundary(), MB_SET_ERR, MBEDGE, MBHEX, mbImpl, MBQUAD, MBTET, MBTRI, MBVERTEX, and moab::Core::type_from_handle().
    EntityType type = mbImpl->type_from_handle( entity );
    if( type == MBVERTEX )
        is_border = is_vertex_on_boundary( entity );
    else if( type == MBEDGE )
        is_border = is_edge_on_boundary( entity );
        is_border = is_face_on_boundary( entity );
        is_border = is_cell_on_boundary( entity );
    else
        MB_SET_ERR( MB_FAILURE, "Requesting boundary information for unsupported entity type" );
    return is_border;
bool moab::NestedRefine::is_face_on_boundary ( const EntityHandle entity) [protected]
Definition at line 4106 of file NestedRefine.cpp.
References ahf, elementype, moab::error(), ErrorCode, moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::get_up_adjacencies_face_3d(), moab::HalfFacetRep::lConnMap2D, MB_CHK_ERR, MB_SET_ERR, meshdim, and moab::HalfFacetRep::LocalMaps2D::num_verts_in_face.
    ErrorCode error;
    if( meshdim == 1 )
        MB_SET_ERR( MB_FAILURE, "Requesting boundary information for a face entity type on a curve mesh" );
    else if( meshdim == 2 )  // The face has a local edge on the boundary of the 2d mesh
        EntityHandle sibents[4];
        int siblids[4];
        int nepf = ahf->lConnMap2D[elementype - 2].num_verts_in_face;
        error    = ahf->get_sibling_map( elementype, entity, &sibents[0], &siblids[0], nepf );MB_CHK_ERR( error );
                is_border = true;
                break;
    else if( meshdim == 3 )  // The face lies on the boundary of the 3d mesh
        error = ahf->get_up_adjacencies_face_3d( entity, adjents );MB_CHK_ERR( error );
    return is_border;
bool moab::NestedRefine::is_vertex_on_boundary ( const EntityHandle entity) [protected]
Boundary extraction functions Given a vertex at a certain level, it returns a boolean value true if it lies on the domain boundary. Note: This is a specialization of the NestedRefine::is_entity_on_boundary function and applies only to vertex queries.
Parameters:
entity
Definition at line 4026 of file NestedRefine.cpp.
References _incells, ahf, moab::Range::begin(), elementype, moab::error(), ErrorCode, moab::HalfFacetRep::get_incident_map(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::lConnMap2D, moab::HalfFacetRep::lConnMap3D, MB_CHK_ERR, MB_SET_ERR, MBEDGE, MBHEX, MBQUAD, MBTET, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, and moab::HalfFacetRep::LocalMaps2D::num_verts_in_face.
    ErrorCode error;
    EntityHandle sibents[27];
    int siblids[27];
    std::vector< EntityHandle > ent;
    std::vector< int > lid;
    int nhf;
    if( elementype == MBEDGE )
        nhf = 2;
    else if( ( elementype == MBTRI ) || ( elementype == MBQUAD ) )
        nhf = ahf->lConnMap2D[elementype - 2].num_verts_in_face;
    else if( ( elementype == MBTET ) || ( elementype == MBHEX ) )
        int idx = ahf->get_index_in_lmap( *_incells.begin() );
        nhf     = ahf->lConnMap3D[idx].num_faces_in_cell;
    else
        MB_SET_ERR( MB_FAILURE, "Requesting vertex boundary information for an unsupported entity type" );
    error = ahf->get_incident_map( elementype, vertex, ent, lid );MB_CHK_ERR( error );
    error = ahf->get_sibling_map( elementype, ent[0], &sibents[0], &siblids[0], nhf );MB_CHK_ERR( error );
    return ( sibents[lid[0]] == 0 );
ErrorCode moab::NestedRefine::parent_to_child ( EntityHandle  parent,
int  parent_level,
int  child_level,
std::vector< EntityHandle > &  children
Given an entity from a certain level, it returns a std::vector of all its children from the requested child level. NOTE: This query does not support vertices.
Parameters:
parentEntityHandle of the entity whose children in subsequent level is requested
parent_levelMesh level where the parent exists
child_levelMesh level from which its children are requested
childrenVector containing all childrens from the requested child_level
Definition at line 285 of file NestedRefine.cpp.
References _incells, _inedges, _infaces, child, get_index_from_degree(), moab::Range::index(), level_dsequence, level_mesh, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBHEX, mbImpl, MBQUAD, MBTET, MBTRI, MBVERTEX, refTemplates, moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_edge, moab::NestedRefine::level_memory::start_face, moab::NestedRefine::refPatterns::total_new_ents, and moab::Core::type_from_handle().
Referenced by update_special_tags(), and vertex_to_entities_down().
    EntityType type = mbImpl->type_from_handle( parent );
    int parent_index;
            parent_index = parent - level_mesh[parent_level - 1].start_edge;
        else
            parent_index = _inedges.index( parent );
            parent_index = parent - level_mesh[parent_level - 1].start_face;
        else
            parent_index = _infaces.index( parent );
            parent_index = parent - level_mesh[parent_level - 1].start_cell;
        else
            parent_index = _incells.index( parent );
    else
        MB_SET_ERR( MB_FAILURE, "Requesting children for unsupported entity type" );
    int start, end;
    start = end = parent_index;
    for( int i = parent_level; i < child_level; i++ )
        int d   = get_index_from_degree( level_dsequence[i] );
        start   = start * nch;
        end     = end * nch + nch - 1;
    int num_child = end - start;
    children.reserve( num_child );
    for( int i = start; i <= end; i++ )
        EntityHandle child;
            child = level_mesh[child_level - 1].start_edge + i;
            child = level_mesh[child_level - 1].start_face + i;
            child = level_mesh[child_level - 1].start_cell + i;
        children.push_back( child );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::print_maps_1D ( int  level) [protected]
ErrorCode moab::NestedRefine::print_maps_2D ( int  level,
EntityType  type
) [protected]
ErrorCode moab::NestedRefine::print_maps_3D ( int  level,
EntityType  type
) [protected]
ErrorCode moab::NestedRefine::reorder_indices ( int  cur_level,
int  deg,
EntityHandle  cell,
int  lfid,
EntityHandle  sib_cell,
int  sib_lfid,
int  index,
int *  id_sib
) [protected]
Definition at line 4322 of file NestedRefine.cpp.
References _incells, ahf, moab::Range::begin(), moab::NestedRefine::pmat::comb, moab::error(), ErrorCode, get_connectivity(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, moab::HalfFacetRep::lConnMap3D, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::NestedRefine::pmat::num_comb, and permutation.
Referenced by construct_hm_2D(), update_global_ahf_3D(), and update_tracking_verts().
    // Reorders the indices of either vertices or children cell local ids to match with order of the
    // given cell and a local face. index = 0 : vertices,
    //           = 1 : face
    assert( deg == 2 || deg == 3 );
    ErrorCode error;
    int nvF = ahf->lConnMap3D[idx].hf2v_num[lfid];
    int nco = permutation[nvF - 3].num_comb;
    if( !index && ( ( nvF == 3 && deg == 3 ) || ( nvF == 4 && deg == 2 ) ) )
        id_sib[0] = 1;
    else
        // Get connectivity of the cell and its sibling cell
        std::vector< EntityHandle > conn, sib_conn;
        error = get_connectivity( cell, cur_level, conn );MB_CHK_ERR( error );
        error = get_connectivity( sib_cell, cur_level, sib_conn );MB_CHK_ERR( error );
        // Get the connectivity of the local face in the cell and its sibling
        std::vector< EntityHandle > lface( nvF );
        std::vector< EntityHandle > lface_sib( nvF );
        for( int i = 0; i < nvF; i++ )
            int id   = ahf->lConnMap3D[idx].hf2v[lfid][i];
            lface[i] = conn[id];
            id           = ahf->lConnMap3D[idx].hf2v[sib_lfid][i];
            lface_sib[i] = sib_conn[id];
        // Find the combination
        int c = 0;
        for( int i = 0; i < nco; i++ )
            int count = 0;
            for( int j = 0; j < nvF; j++ )
                int id = permutation[nvF - 3].comb[i][j];
                if( lface[j] == lface_sib[id] ) count += 1;
            if( count == nvF )
                c = i;
                break;
        if( c > nco ) MB_SET_ERR( MB_FAILURE, "Getting a combination number more than currently supported" );
        // Get the ordered indices
        if( ( ( !index ) && ( nvF == 4 ) && ( deg == 3 ) ) || ( deg == 2 ) )
            for( int i = 0; i < 4; i++ )
                id_sib[i] = permutation[nvF - 3].porder2[c][i];
        else
            for( int i = 0; i < 9; i++ )
                id_sib[i] = permutation[nvF - 3].porder3[c][i];
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::reorder_indices ( int  deg,
EntityHandle face1_conn,
EntityHandle face2_conn,
int  nvF,
std::vector< int > &  lemap,
std::vector< int > &  vidx,
int *  leorient = NULL
) [protected]
Definition at line 4402 of file NestedRefine.cpp.
References moab::NestedRefine::pmat::comb, MB_SET_ERR, MB_SUCCESS, moab::NestedRefine::pmat::num_comb, moab::NestedRefine::pmat::orient, permutation, and moab::NestedRefine::pmat::porder2.
    // Given the connectivities of two faces, get the permuted indices w.r.t first face.
    // Step 1: First find the orientation
    int c   = 0;
        int count = 0;
            if( face1_conn[j] == face2_conn[id] ) count += 1;
        if( count == nvF )
            c = i;
            break;
    // Add the corresponding local edges
    lemap.reserve( nvF );
        lemap.push_back( permutation[nvF - 3].lemap[c][i] );
    if( leorient ) leorient[0] = permutation[nvF - 3].orient[c];
    if( nvF == 3 && deg == 2 ) return MB_SUCCESS;
    if( ( nvF == 3 && deg == 3 ) || ( nvF == 4 && deg == 2 ) )
        vidx.push_back( 1 );
    else if( nvF == 4 && deg == 3 )
            vidx.push_back( permutation[nvF - 3].porder2[c][i] );
    return MB_SUCCESS;
int  nvF,
int  comb,
int *  childfid_map
) [protected]
Definition at line 4455 of file NestedRefine.cpp.
References MB_SUCCESS, and permutation.
    // Given connectivities of two faces and a degree, get the permuted indices of the children
    // faces w.r.t first face.
    if( deg == 2 )
            childfid_map[i] = permutation[nvF - 3].porder2[comb][i];
    else
            childfid_map[i] = permutation[nvF - 3].porder3[comb][i];
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::reorder_indices ( EntityHandle face1_conn,
int  nvF,
int *  conn_map,
int &  comb,
int *  orient = NULL
) [protected]
Definition at line 4477 of file NestedRefine.cpp.
References moab::NestedRefine::pmat::comb, MB_SET_ERR, MB_SUCCESS, moab::NestedRefine::pmat::num_comb, moab::NestedRefine::pmat::orient, and permutation.
    // Step 1: First find the combination
    int c   = 0;
        int count = 0;
        if( count == nvF )
            c = i;
            break;
    comb = c;
    if( orient ) orient[0] = permutation[nvF - 3].orient[c];
        conn_map[j] = permutation[nvF - 3].comb[c][j];
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::subdivide_cells ( EntityType  type,
int  cur_level,
int  deg
) [protected]
Definition at line 1421 of file NestedRefine.cpp.
References _incells, _infaces, _inverts, ahf, moab::Range::begin(), moab::NestedRefine::level_memory::cell_conn, compute_coordinates(), construct_hm_1D(), construct_hm_2D(), moab::Range::empty(), moab::NestedRefine::refPatterns::ents_conn, moab::error(), ErrorCode, get_connectivity(), get_coordinates(), get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_SUCCESS, moab::NestedRefine::level_memory::num_cells, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::NestedRefine::level_memory::num_verts, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::NestedRefine::refPatterns::nv_edge, moab::NestedRefine::refPatterns::nv_face, refTemplates, moab::Range::size(), moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::NestedRefine::refPatterns::total_new_verts, update_global_ahf(), update_local_ahf(), update_tracking_verts(), moab::NestedRefine::refPatterns::vert_on_edges, and moab::NestedRefine::refPatterns::vert_on_faces.
Referenced by construct_hm_3D().
    ErrorCode error;
    if( cur_level )
        nents_prev  = level_mesh[cur_level - 1].num_cells;
    else
        nents_prev  = _incells.size();
    // Create some book-keeping arrays over the parent mesh to avoid introducing duplicate vertices
    int cindex  = type - 1;
    int d       = get_index_from_degree( deg );
    int ne      = refTemplates[cindex][d].nv_edge;
    int nvf     = refTemplates[cindex][d].nv_face;
    int nvtotal = refTemplates[cindex][d].total_new_verts;
    int index = ahf->get_index_in_lmap( *( _incells.begin() ) );
    int nepc  = ahf->lConnMap3D[index].num_edges_in_cell;
    int vtotal = nvpc + nvtotal;
    std::vector< EntityHandle > trackvertsC_edg( nepc * ne * nents_prev, 0 );
    std::vector< EntityHandle > trackvertsC_face( nfpc * nvf * nents_prev, 0 );
    int count_ents   = 0;
    for( int cid = 0; cid < nents_prev; cid++ )
        conn.clear();
        cur_conn.clear();
            vbuffer[i] = 0;
        // EntityHandle of the working cell
        EntityHandle cell;
        if( cur_level )
            cell = level_mesh[cur_level - 1].start_cell + cid;
        else
            cell = _incells[cid];
        // subdivision.
            if( cur_level )
            else
        // Gather vertices already added to tracking array due to refinement of the sibling cells
        for( int i = 0; i < nepc; i++ )
            for( int j = 0; j < ne; j++ )
                int idx      = refTemplates[cindex][d].vert_on_edges[i][j];
                vbuffer[idx] = trackvertsC_edg[cid * nepc * ne + ne * i + j];
        // Add remaining new vertex handles
            for( int j = 0; j < nvf; j++ )
                int idx      = refTemplates[cindex][d].vert_on_faces[i][j];
                vbuffer[idx] = trackvertsC_face[cid * nfpc * nvf + nvf * i + j];
        // Add the remaining vertex handles to vbuffer for the current level for the working cell
        for( int i = 0; i < nvtotal; i++ )
            if( !vbuffer[i + nvpc] )
                vbuffer[i + nvpc] = level_mesh[cur_level].start_vertex + count_nverts;
                count_nverts += 1;
        // Step 2: Use the template to obtain the subentities. The coordinates and local ahf maps
        // are also constructed. Connectivity of the children
        int etotal = refTemplates[type - 1][d].total_new_ents;
            for( int k = 0; k < nvpc; k++ )
                int idx                                                = refTemplates[type - 1][d].ents_conn[i][k];
                level_mesh[cur_level].cell_conn[nvpc * count_ents + k] = vbuffer[idx];
            ent_buffer[i] = level_mesh[cur_level].start_cell + count_ents;
            count_ents += 1;
        // Step 3: Update local ahf maps
        error = update_local_ahf( deg, type, &vbuffer[0], &ent_buffer[0], etotal );MB_CHK_ERR( error );
        // Step 4: Update tracking information
        error = update_tracking_verts( cell, cur_level, deg, trackvertsC_edg, trackvertsC_face, &vbuffer[0] );MB_CHK_ERR( error );
        // Step 5: Coordinates of the new vertices
        std::vector< double > corner_coords( nvpc * 3 );
        error = get_coordinates( &cur_conn[0], nvpc, cur_level + 1, &corner_coords[0] );MB_CHK_ERR( error );
        error = compute_coordinates( cur_level, deg, type, &vbuffer[0], vtotal, &corner_coords[0], flag_verts,
    // error = ahf->print_tags(3);
    error = update_global_ahf( type, cur_level, deg );MB_CHK_ERR( error );
    // Step 7: If edges exists, refine them as well.
    if( level_mesh[cur_level].num_edges != 0 )
        error = construct_hm_1D( cur_level, deg, type, trackvertsC_edg );MB_CHK_ERR( error );
    // Step 8: If faces exists, refine them as well.
        error = construct_hm_2D( cur_level, deg, type, trackvertsC_edg, trackvertsC_face );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::subdivide_tets ( int  cur_level,
int  deg
) [protected]
Definition at line 1573 of file NestedRefine.cpp.
References _incells, _infaces, _inverts, ahf, moab::Range::begin(), moab::NestedRefine::level_memory::cell_conn, compute_coordinates(), construct_hm_1D(), construct_hm_2D(), moab::Range::empty(), moab::NestedRefine::refPatterns::ents_conn, moab::error(), ErrorCode, find_shortest_diagonal_octahedron(), get_connectivity(), get_coordinates(), get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_SUCCESS, MBTET, moab::NestedRefine::level_memory::num_cells, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::NestedRefine::level_memory::num_verts, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::NestedRefine::refPatterns::nv_edge, moab::NestedRefine::refPatterns::nv_face, refTemplates, moab::Range::size(), moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::NestedRefine::refPatterns::total_new_verts, update_global_ahf(), update_local_ahf(), update_tracking_verts(), moab::NestedRefine::refPatterns::vert_on_edges, and moab::NestedRefine::refPatterns::vert_on_faces.
    ErrorCode error;
    int nverts_prev, nents_prev;
    if( cur_level )
    else
        nverts_prev = _inverts.size();
    EntityType type = MBTET;
    // Create vertex buffer
    std::vector< EntityHandle > vbuffer( vtotal );
    // Create book-keeping arrays over the parent mesh to avoid introducing duplicate vertices
    std::vector< int > cell_patterns( nents_prev, 0 );
    int count_ents   = 0;
    // Step 1: Create the subentities via refinement of the previous mesh
        conn.clear();
        cur_conn.clear();
            vbuffer[i] = 0;
        EntityHandle cell;
        if( cur_level )
        else
        // subdivision.
        for( int i = 0; i < (int)conn.size(); i++ )
            if( cur_level )
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( conn[i] - level_mesh[cur_level - 1].start_vertex );
            else
                vbuffer[i] = level_mesh[cur_level].start_vertex + ( conn[i] - *_inverts.begin() );
                count_nverts += 1;
        // Step 2: Coordinates of the new vertices
        // Step 3: Choose the tet refine pattern to be used for this tet
        int diag           = find_shortest_diagonal_octahedron( cur_level, deg, &vbuffer[0] );
        int pat_id         = diag + 2;
        cell_patterns[cid] = pat_id;
        // Step 4: Use the template to obtain the subentities. The coordinates and local ahf maps
        int etotal = refTemplates[pat_id][d].total_new_ents;
        std::vector< EntityHandle > ent_buffer( etotal );
        for( int i = 0; i < etotal; i++ )
                int idx                                                = refTemplates[pat_id][d].ents_conn[i][k];
            count_ents += 1;
        // Step 5: Update local ahf maps
        error = update_local_ahf( deg, MBTET, pat_id, &vbuffer[0], &ent_buffer[0], etotal );MB_CHK_ERR( error );
        // Step 6: Update tracking information
    // Step 7: Update the global maps
    //  error = update_global_ahf(cur_level, deg, cell_patterns); MB_CHK_ERR(error);
    error = update_global_ahf( type, cur_level, deg, &cell_patterns );MB_CHK_ERR( error );
    // Step 8: If edges exists, refine them as well.
    // Step 9: If faces exists, refine them as well.
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_global_ahf ( EntityType  type,
int  cur_level,
int  deg,
std::vector< int > *  pattern_ids = NULL
) [protected]
Definition at line 3113 of file NestedRefine.cpp.
References moab::error(), ErrorCode, MB_CHK_ERR, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, MBTRI, update_global_ahf_1D(), update_global_ahf_2D(), and update_global_ahf_3D().
Referenced by construct_hm_1D(), construct_hm_2D(), subdivide_cells(), and subdivide_tets().
    ErrorCode error;
    // Get the number of half-facets and number of children of each type
        assert( pattern_ids == NULL );
        error = update_global_ahf_1D( cur_level, deg );MB_CHK_ERR( error );
    else if( type == MBTRI || type == MBQUAD )
        error = update_global_ahf_2D( cur_level, deg );MB_CHK_ERR( error );
    else if( type == MBHEX )
        error = update_global_ahf_3D( cur_level, deg );MB_CHK_ERR( error );
    else if( type == MBTET )
        assert( pattern_ids != NULL );
        error = update_global_ahf_3D( cur_level, deg, pattern_ids );MB_CHK_ERR( error );
    else
        MB_SET_ERR( MB_NOT_IMPLEMENTED, "Requesting AHF update for an unsupported mesh entity type" );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_global_ahf_1D ( int  cur_level,
int  deg
) [protected]
Definition at line 3153 of file NestedRefine.cpp.
References _inedges, _inverts, ahf, moab::Range::begin(), moab::NestedRefine::refPatterns::ents_on_pent, moab::error(), ErrorCode, moab::HalfFacetRep::get_incident_map(), get_index_from_degree(), get_local_vid(), moab::HalfFacetRep::get_sibling_map(), level_mesh, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, MBEDGE, moab::NestedRefine::level_memory::num_edges, moab::NestedRefine::level_memory::num_verts, refTemplates, moab::HalfFacetRep::set_incident_map(), moab::HalfFacetRep::set_sibling_map(), moab::Range::size(), moab::NestedRefine::level_memory::start_edge, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, and moab::NestedRefine::refPatterns::v2hf.
Referenced by update_global_ahf().
    ErrorCode error;
    int nhf, nchilds, nverts_prev, nents_prev;
    nhf     = 2;
    nchilds = refTemplates[0][d].total_new_ents;
    if( cur_level )
        nents_prev  = level_mesh[cur_level - 1].num_edges;
    else
        nents_prev  = _inedges.size();
    std::vector< EntityHandle > inci_ent, child_ents;
    std::vector< int > inci_lid, child_lids;
    // Update the vertex to half-facet maps for duplicate vertices
        inci_ent.clear();
        inci_lid.clear();
        child_ents.clear();
        child_lids.clear();
        // Vertex id in the previous mesh and the current one
        EntityHandle vid;
        if( cur_level )
            vid = level_mesh[cur_level - 1].start_vertex + i;
        else
            vid = _inverts[i];
        EntityHandle cur_vid = level_mesh[cur_level].start_vertex + i;
        // Get the incident half-vert in the previous mesh
        error = ahf->get_incident_map( MBEDGE, vid, inci_ent, inci_lid );MB_CHK_ERR( error );
        // Obtain the corresponding incident child in the current mesh
        int lvid = get_local_vid( vid, inci_ent[0], cur_level - 1 );
        if( lvid < 0 ) MB_SET_ERR( MB_FAILURE, "did not find local vertex ix " );
        int chid = refTemplates[0][d].v2hf[lvid][0] - 1;
        int pid;
        if( cur_level )
            pid = inci_ent[0] - level_mesh[cur_level - 1].start_edge;
        else
            pid = inci_ent[0] - *_inedges.begin();
        int ind = nchilds * pid;
        child_ents.push_back( level_mesh[cur_level].start_edge + ind + chid );
        child_lids.push_back( refTemplates[0][d].v2hf[lvid][1] );
        error = ahf->set_incident_map( MBEDGE, cur_vid, child_ents, child_lids );MB_CHK_ERR( error );
    // Update the sibling half-facet maps across entities
    for( int i = 0; i < nents_prev; i++ )
        EntityHandle ent;
        if( cur_level )
            ent = level_mesh[cur_level - 1].start_edge + i;
        else
            ent = _inedges[i];
        std::vector< EntityHandle > sib_entids( nhf );
        std::vector< int > sib_lids( nhf );
        error = ahf->get_sibling_map( MBEDGE, ent, &sib_entids[0], &sib_lids[0], nhf );MB_CHK_ERR( error );
        int id, idx;
        for( int l = 0; l < nhf; l++ )
            if( !sib_entids[l] ) continue;
            // Find the child incident on the half-facet
            id                     = refTemplates[0][d].ents_on_pent[l][1] - 1;
            idx                    = nchilds * i;
            EntityHandle child_ent = level_mesh[cur_level].start_edge + idx + id;
            int ch_lid             = l;
            // Find the sibling of the child
            std::vector< EntityHandle > sib_childs( nhf );
            std::vector< int > sib_chlids( nhf );
            error = ahf->get_sibling_map( MBEDGE, child_ent, &sib_childs[0], &sib_chlids[0], nhf );MB_CHK_ERR( error );
            // If the sibling already exists, dont do anything
            if( sib_childs[ch_lid] ) continue;
            // Get the correponding child of the sibling of the current parent
            int psib;
            if( cur_level )
                psib = sib_entids[l] - level_mesh[cur_level - 1].start_edge;
            else
                psib = sib_entids[l] - *_inedges.begin();
            int plid = sib_lids[l];
            id  = refTemplates[0][d].ents_on_pent[plid][1] - 1;
            idx = nchilds * psib;
            EntityHandle psib_child = level_mesh[cur_level].start_edge + idx + id;
            int psib_chlid          = plid;
            // Set the siblings
            sib_childs[ch_lid] = psib_child;
            sib_chlids[ch_lid] = psib_chlid;
            error = ahf->set_sibling_map( MBEDGE, child_ent, &sib_childs[0], &sib_chlids[0], nhf );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_global_ahf_1D_sub ( int  cur_level,
int  deg
) [protected]
Definition at line 3273 of file NestedRefine.cpp.
References _inedges, _inverts, ahf, moab::Range::begin(), moab::NestedRefine::refPatterns::ents_on_pent, moab::error(), ErrorCode, get_connectivity(), moab::HalfFacetRep::get_incident_map(), get_index_from_degree(), get_local_vid(), moab::HalfFacetRep::get_sibling_map(), level_mesh, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, MBEDGE, moab::NestedRefine::level_memory::num_edges, refTemplates, moab::HalfFacetRep::set_incident_map(), moab::HalfFacetRep::set_sibling_map(), moab::Range::size(), moab::NestedRefine::level_memory::start_edge, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, and moab::NestedRefine::refPatterns::v2hf.
Referenced by construct_hm_1D().
    ErrorCode error;
    int nhf, nchilds, nents_prev;
    nhf     = 2;
    if( cur_level )
    else
    std::vector< EntityHandle > conn;
        EntityHandle ent;
        if( cur_level )
        else
            ent = _inedges[i];
        // Set incident hv maps
        conn.clear();
        error = get_connectivity( ent, cur_level, conn );MB_CHK_ERR( error );
        for( int j = 0; j < 2; j++ )
            inci_ent.clear();
            inci_lid.clear();
            child_ents.clear();
            child_lids.clear();
            // Get the entityhandle of the vertex from previous level in the current level
            EntityHandle cur_vid;
            if( cur_level )
                cur_vid = level_mesh[cur_level].start_vertex + ( conn[j] - level_mesh[cur_level - 1].start_vertex );
            else
                cur_vid = level_mesh[cur_level].start_vertex + ( conn[j] - *_inverts.begin() );
            // Obtain the incident half-facet. If exists, then no need to assign another
            error = ahf->get_incident_map( MBEDGE, cur_vid, inci_ent, inci_lid );MB_CHK_ERR( error );
            if( inci_ent[0] != 0 ) continue;
            // Get the incident half-facet on the old vertex
            error = ahf->get_incident_map( MBEDGE, conn[j], inci_ent, inci_lid );MB_CHK_ERR( error );
            int lvid = get_local_vid( conn[j], inci_ent[0], cur_level - 1 );
            int pid;
            if( cur_level )
            else
        int id, idx;
            idx                    = nchilds * i;
            int ch_lid             = l;
            int psib;
            if( cur_level )
            else
            // Set the siblings
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_global_ahf_2D ( int  cur_level,
int  deg
) [protected]
Definition at line 3408 of file NestedRefine.cpp.
References _infaces, _inverts, ahf, moab::Range::begin(), moab::NestedRefine::refPatterns::ents_on_pent, moab::error(), ErrorCode, get_connectivity(), moab::HalfFacetRep::get_incident_map(), get_index_from_degree(), get_local_vid(), moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::lConnMap2D, level_mesh, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, moab::HalfFacetRep::LocalMaps2D::next, moab::NestedRefine::level_memory::num_faces, moab::NestedRefine::level_memory::num_verts, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, refTemplates, moab::HalfFacetRep::set_incident_map(), moab::HalfFacetRep::set_sibling_map(), moab::Range::size(), moab::NestedRefine::level_memory::start_face, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::Core::type_from_handle(), and moab::NestedRefine::refPatterns::v2hf.
    ErrorCode error;
    EntityType type = mbImpl->type_from_handle( *_infaces.begin() );
    nhf     = ahf->lConnMap2D[type - 2].num_verts_in_face;
    nchilds = refTemplates[type - 1][d].total_new_ents;
    if( cur_level )
        nents_prev  = level_mesh[cur_level - 1].num_faces;
    else
        nents_prev  = _infaces.size();
    // Update the vertex to half-edge maps for old/duplicate vertices
        inci_ent.clear();
        inci_lid.clear();
        child_ents.clear();
        child_lids.clear();
        EntityHandle vid;
        if( cur_level )
        else
            vid = _inverts[i];
        error = ahf->get_incident_map( type, vid, inci_ent, inci_lid );MB_CHK_ERR( error );
        for( int j = 0; j < (int)inci_ent.size(); j++ )
            int lvid = get_local_vid( vid, inci_ent[j], cur_level - 1 );
            int chid = refTemplates[type - 1][d].v2hf[lvid][0] - 1;
            int pid;
            if( cur_level )
                pid = inci_ent[j] - level_mesh[cur_level - 1].start_face;
            else
                pid = inci_ent[j] - *_infaces.begin();
            child_ents.push_back( level_mesh[cur_level].start_face + ind + chid );
            child_lids.push_back( refTemplates[type - 1][d].v2hf[lvid][1] );
        error = ahf->set_incident_map( type, cur_vid, child_ents, child_lids );MB_CHK_ERR( error );
    EntityHandle fedge[2];
        EntityHandle ent;
        if( cur_level )
            ent = level_mesh[cur_level - 1].start_face + i;
        else
            ent = _infaces[i];
        std::vector< EntityHandle > fid_conn;
        error = get_connectivity( ent, cur_level, fid_conn );
        if( MB_SUCCESS != error ) return error;
        error = ahf->get_sibling_map( type, ent, &sib_entids[0], &sib_lids[0], nhf );MB_CHK_ERR( error );
        int id, idx;
            int nidx = ahf->lConnMap2D[type - 2].next[l];
            fedge[0] = fid_conn[l];
            fedge[1] = fid_conn[nidx];
            EntityHandle sfid = sib_entids[l];
            int slid          = sib_lids[l];
            error = get_connectivity( sfid, cur_level, conn );
            bool orient = true;
            nidx        = ahf->lConnMap2D[type - 2].next[slid];
            if( ( fedge[1] == conn[slid] ) && ( fedge[0] == conn[nidx] ) ) orient = false;
            if( orient ) assert( ( fedge[0] == conn[slid] ) && ( fedge[1] == conn[nidx] ) );
            // Find the childrens incident on the half-facet
            int nch = refTemplates[type - 1][d].ents_on_pent[l][0];
            idx     = nchilds * i;
            // Loop over all the incident childrens
            for( int k = 0; k < nch; k++ )
                id                     = refTemplates[type - 1][d].ents_on_pent[l][k + 1] - 1;
                EntityHandle child_ent = level_mesh[cur_level].start_face + idx + id;
                int child_lid          = l;
                EntityHandle child_sibent;
                int child_siblid;
                error = ahf->get_sibling_map( type, child_ent, child_lid, child_sibent, child_siblid );MB_CHK_ERR( error );
                if( child_sibent != 0 ) continue;
                int psib;
                if( cur_level )
                    psib = sfid - level_mesh[cur_level - 1].start_face;
                else
                    psib = sfid - *_infaces.begin();
                int plid = slid;
                if( orient )
                    id = refTemplates[type - 1][d].ents_on_pent[plid][k + 1] - 1;
                else
                    id = refTemplates[type - 1][d].ents_on_pent[plid][nch - k] - 1;
                int sidx = nchilds * psib;
                EntityHandle psib_child = level_mesh[cur_level].start_face + sidx + id;
                // Set the siblings
                error = ahf->set_sibling_map( type, child_ent, child_lid, psib_child, psib_chlid );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_global_ahf_2D_sub ( int  cur_level,
int  deg
) [protected]
Definition at line 3562 of file NestedRefine.cpp.
References _infaces, _inverts, ahf, moab::Range::begin(), moab::NestedRefine::refPatterns::ents_on_pent, moab::error(), ErrorCode, get_connectivity(), moab::HalfFacetRep::get_incident_map(), get_index_from_degree(), get_local_vid(), moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::lConnMap2D, level_mesh, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, moab::HalfFacetRep::LocalMaps2D::next, moab::NestedRefine::level_memory::num_faces, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, refTemplates, moab::HalfFacetRep::set_incident_map(), moab::HalfFacetRep::set_sibling_map(), moab::Range::size(), moab::NestedRefine::level_memory::start_face, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::Core::type_from_handle(), and moab::NestedRefine::refPatterns::v2hf.
Referenced by construct_hm_2D().
    ErrorCode error;
    if( cur_level )
    else
        EntityHandle ent;
        if( cur_level )
        else
            ent = _infaces[i];
        // Set incident half-edges
        for( int j = 0; j < nhf; j++ )
            inci_ent.clear();
            inci_lid.clear();
            child_ents.clear();
            child_lids.clear();
            if( cur_level )
                cur_vid = level_mesh[cur_level].start_vertex + ( fid_conn[j] - level_mesh[cur_level - 1].start_vertex );
            else
                cur_vid = level_mesh[cur_level].start_vertex + ( fid_conn[j] - *_inverts.begin() );
            error = ahf->get_incident_map( type, cur_vid, inci_ent, inci_lid );MB_CHK_ERR( error );
            error = ahf->get_incident_map( type, fid_conn[j], inci_ent, inci_lid );MB_CHK_ERR( error );
            for( int k = 0; k < (int)inci_ent.size(); k++ )
                int lvid = get_local_vid( fid_conn[j], inci_ent[k], cur_level - 1 );
                int pid;
                if( cur_level )
                    pid = inci_ent[k] - level_mesh[cur_level - 1].start_face;
                else
                    pid = inci_ent[k] - *_infaces.begin();
        // Set sibling half-edges
        int id, idx;
            error = get_connectivity( sfid, cur_level, conn );MB_CHK_ERR( error );
            assert( (int)conn.size() > nidx && (int)conn.size() > slid );
            bool orient = true;
            idx     = nchilds * i;
                int child_lid          = l;
                int child_siblid;
                int psib;
                if( cur_level )
                else
                int plid = slid;
                if( orient )
                else
                // Set the siblings
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_global_ahf_3D ( int  cur_level,
int  deg,
) [protected]
Definition at line 3712 of file NestedRefine.cpp.
References _incells, _inverts, ahf, moab::Range::begin(), moab::NestedRefine::level_memory::cells, moab::HalfFacetRep::check_nonmanifold_vertices(), moab::HalfFacetRep::LocalMaps3D::e2v, moab::NestedRefine::refPatterns::ents_on_pent, moab::NestedRefine::refPatterns::ents_on_vedge, moab::error(), ErrorCode, moab::Core::get_connectivity(), moab::HalfFacetRep::get_incident_map(), get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), get_local_vid(), moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::get_up_adjacencies_edg_3d_comp(), moab::Range::index(), moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MBTET, moab::NestedRefine::level_memory::num_cells, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::NestedRefine::level_memory::num_verts, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::NestedRefine::refPatterns::nv_edge, refTemplates, reorder_indices(), moab::HalfFacetRep::set_incident_map(), moab::HalfFacetRep::set_sibling_map(), moab::Range::size(), moab::NestedRefine::level_memory::start_cell, moab::NestedRefine::level_memory::start_vertex, moab::NestedRefine::refPatterns::total_new_ents, moab::Core::type_from_handle(), and moab::NestedRefine::refPatterns::v2hf.
    ErrorCode error;
    int nvpc, ne, nhf, nchilds, nverts_prev, nents_prev;
    EntityType type = mbImpl->type_from_handle( *_incells.begin() );
    ne      = ahf->lConnMap3D[index].num_edges_in_cell;
    if( cur_level )
    else
    // Step 1: Update the V2HF maps for old/duplicate vertices
        inci_ent.clear();
        inci_lid.clear();
        child_ents.clear();
        child_lids.clear();
        EntityHandle vid;
        if( cur_level )
        else
            vid = _inverts[i];
            int pid;
            if( cur_level )
                pid = inci_ent[j] - level_mesh[cur_level - 1].start_cell;
            else
                pid = inci_ent[j] - *_incells.begin();
            //  EntityHandle child_ent = level_mesh[cur_level].start_cell + ind+chid ;
            // int child_lid = refTemplates[type-1][d].v2hf[lvid][1];
            child_ents.push_back( level_mesh[cur_level].start_cell + ind + chid );
    //  error = ahf->determine_incident_halffaces( level_mesh[cur_level].cells);MB_CHK_ERR(error);
    // Step 2: Update SIBHFS maps
        EntityHandle ent;
        if( cur_level )
            ent = level_mesh[cur_level - 1].start_cell + i;
        else
            ent = _incells[i];
        int id, idx;
            // Get the number of children incident on this half-face
            int pat_id;
            if( type == MBTET )
                pat_id = ( *pattern_ids )[i];
            else
                pat_id = type - 1;
            int nch = refTemplates[pat_id][d].ents_on_pent[l][0];
            // Get the order of children indices incident on this half-face
            std::vector< int > id_sib( nch );
                id_sib[k] = 0;
            error = reorder_indices( cur_level, deg, ent, l, sib_entids[l], sib_lids[l], 1, &id_sib[0] );MB_CHK_ERR( error );
            // Get the parent index of the sibling cell
            int psib;
            if( cur_level )
                psib = sib_entids[l] - level_mesh[cur_level - 1].start_cell;
            else
                psib = sib_entids[l] - *_incells.begin();
            int sibpat_id;
            if( type == MBTET )
                sibpat_id = ( *pattern_ids )[psib];
            else
                sibpat_id = type - 1;
            // Loop over all the childs incident on the working half-face
            idx = nchilds * i;
                id                     = refTemplates[pat_id][d].ents_on_pent[l][k + 1] - 1;
                EntityHandle child_ent = level_mesh[cur_level].start_cell + idx + id;
                int child_lid          = l;
                // Find the sibling of the working child
                int child_siblid;
                // We have already computed the order the children on incident corresponding to the
                // working half-face
                id = refTemplates[sibpat_id][d].ents_on_pent[plid][id_sib[k]] - 1;
                EntityHandle psib_child = level_mesh[cur_level].start_cell + sidx + id;
                // Set the siblings of children incident on current half-face
                // Set the sibling of the sibling of the children to the children
                error = ahf->set_sibling_map( type, psib_child, psib_chlid, child_ent, child_lid );MB_CHK_ERR( error );
        // Loop over edges to check if there are any non-manifold edges. If there are then the v2hfs
        // map should be updated for the new vertices on it.
        const EntityHandle* conn;
        error = mbImpl->get_connectivity( ent, conn, nvpc );MB_CHK_ERR( error );
        int nv = refTemplates[type - 1][d].nv_edge;  //#verts on each edge
        for( int l = 0; l < ne; l++ )
            id                   = ahf->lConnMap3D[index].e2v[l][0];
            EntityHandle v_start = conn[id];
            id                   = ahf->lConnMap3D[index].e2v[l][1];
            EntityHandle v_end   = conn[id];
            bool visited = false;
            std::vector< EntityHandle > inci_ent1, inci_ent2;
            std::vector< int > inci_lid1, inci_lid2;
            error = ahf->get_incident_map( type, v_start, inci_ent1, inci_lid1 );MB_CHK_ERR( error );
            error = ahf->get_incident_map( type, v_end, inci_ent2, inci_lid2 );MB_CHK_ERR( error );
            if( inci_ent1.size() > 1 && inci_ent2.size() > 1 )
                std::vector< EntityHandle > cell_comps;
                std::vector< int > leid_comps;
                error = ahf->get_up_adjacencies_edg_3d_comp( ent, l, cell_comps, &leid_comps );MB_CHK_ERR( error );
                int ncomps = cell_comps.size();
                std::vector< EntityHandle > edgverts;
                std::vector< EntityHandle > compchildents( nv * ncomps );
                std::vector< int > compchildlfids( nv * ncomps );
                for( int s = 0; s < nv * ncomps; s++ )
                    compchildents[s]  = 0;
                    compchildlfids[s] = 0;
                for( int j = 0; j < (int)cell_comps.size(); j++ )
                    int ind;
                    if( cur_level )
                        ind = level_mesh[cur_level - 1].cells.index( cell_comps[j] );
                    else
                        ind = _incells.index( cell_comps[j] );
                        int chid = refTemplates[type - 1][d].ents_on_vedge[leid_comps[j]][3 * k] - 1;
                        int lfid = refTemplates[type - 1][d].ents_on_vedge[leid_comps[j]][3 * k + 1];
                        int lvid = refTemplates[type - 1][d].ents_on_vedge[leid_comps[j]][3 * k + 2];
                        EntityHandle childcell = level_mesh[cur_level].start_cell + ind * nchilds + chid;
                        const EntityHandle* econn;
                        error = mbImpl->get_connectivity( childcell, econn, nvpc );MB_CHK_ERR( error );
                        EntityHandle vert = econn[lvid];
                        if( ahf->check_nonmanifold_vertices( type, vert ) )
                            visited = true;
                            break;
                        if( edgverts.empty() )
                            edgverts.push_back( vert );
                            compchildents[0]  = childcell;
                            compchildlfids[0] = lfid;
                        else
                            std::vector< EntityHandle >::iterator it;
                            it       = find( edgverts.begin(), edgverts.end(), vert );
                            int indx = it - edgverts.begin();
                            if( it == edgverts.end() )
                                compchildents[k * ncomps]  = childcell;
                                compchildlfids[k * ncomps] = lfid;
                            else
                                compchildents[indx * ncomps + j]  = childcell;
                                compchildlfids[indx * ncomps + j] = lfid;
                if( visited )
                    break;
                // Set the incident half-facet map
                    std::vector< EntityHandle > set_childents;
                    std::vector< int > set_childlfids;
                    for( int j = 0; j < ncomps; j++ )
                        set_childents.push_back( compchildents[k * ncomps + j] );
                        set_childlfids.push_back( compchildlfids[k * ncomps + j] );
                    error = ahf->set_incident_map( type, edgverts[k], set_childents, set_childlfids );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_local_ahf ( int  deg,
EntityType  type,
EntityHandle vbuffer,
EntityHandle ent_buffer,
int  etotal
) [protected]
Definition at line 3100 of file NestedRefine.cpp.
References moab::error(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, and MBTET.
    ErrorCode error;
    assert( type != MBTET );
    error = update_local_ahf( deg, type, type - 1, vbuffer, ent_buffer, etotal );MB_CHK_ERR( error );
    return MB_SUCCESS;
EntityType  type,
int  pat_id,
int  etotal
) [protected]
Definition at line 3005 of file NestedRefine.cpp.
References _incells, ahf, moab::Range::begin(), moab::NestedRefine::refPatterns::ents_opphfs, moab::error(), ErrorCode, moab::HalfFacetRep::get_incident_map(), get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_sibling_map(), moab::HalfFacetRep::lConnMap2D, moab::HalfFacetRep::lConnMap3D, MB_CHK_ERR, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, refTemplates, moab::HalfFacetRep::set_incident_map(), moab::HalfFacetRep::set_sibling_map(), moab::NestedRefine::refPatterns::total_new_verts, and moab::NestedRefine::refPatterns::v2hf.
    ErrorCode error;
    int nhf = 0, nv = 0, total_new_verts = 0;
        nhf             = 2;
        nv              = 2;
        total_new_verts = refTemplates[0][d].total_new_verts;
        nv              = nhf;
        total_new_verts = refTemplates[pat_id][d].total_new_verts;
    else if( type == MBTET || type == MBHEX )
        int index       = ahf->get_index_in_lmap( *_incells.begin() );
        nv              = ahf->lConnMap3D[index].num_verts_in_cell;
    for( int i = 0; i < total_new_verts; i++ )
        ent.clear();
        lid.clear();
        EntityHandle vid = vbuffer[i + nv];
        error            = ahf->get_incident_map( type, vid, ent, lid );MB_CHK_ERR( error );
        if( ent[0] ) continue;
        int id = refTemplates[pat_id][d].v2hf[i + nv][0] - 1;
        ent[0] = ent_buffer[id];
        lid[0] = refTemplates[pat_id][d].v2hf[i + nv][1];
        error = ahf->set_incident_map( type, vid, ent, lid );MB_CHK_ERR( error );
        error = ahf->get_sibling_map( type, ent_buffer[i], &sib_entids[0], &sib_lids[0], nhf );MB_CHK_ERR( error );
            if( sib_entids[l] ) continue;
            // Fill out the sibling values
            int id = refTemplates[pat_id][d].ents_opphfs[i][2 * l];
            if( id )
                sib_entids[l] = ent_buffer[id - 1];
                sib_lids[l]   = refTemplates[pat_id][d].ents_opphfs[i][2 * l + 1];
            else
                sib_entids[l] = 0;
                sib_lids[l]   = 0;
        error = ahf->set_sibling_map( type, ent_buffer[i], &sib_entids[0], &sib_lids[0], nhf );MB_CHK_ERR( error );
            if( sib_entids[l] )
                EntityHandle set_entid = ent_buffer[i];
                int set_lid            = l;
                error = ahf->set_sibling_map( type, sib_entids[l], sib_lids[l], set_entid, set_lid );MB_CHK_ERR( error );
    return MB_SUCCESS;
Definition at line 496 of file NestedRefine.cpp.
References _rset, moab::Core::add_entities(), moab::Range::begin(), moab::Range::clear(), DIRICHLET_SET_TAG_NAME, moab::Range::end(), moab::error(), ErrorCode, moab::Core::get_connectivity(), moab::Core::get_entities_by_handle(), moab::Core::get_entities_by_type_and_tag(), MATERIAL_SET_TAG_NAME, MB_CHK_ERR, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, MBVERTEX, NEUMANN_SET_TAG_NAME, nlevels, parent_to_child(), moab::Core::remove_entities(), moab::Core::tag_get_handle(), moab::Core::type_from_handle(), and vertex_to_entities_down().
    assert( level > 0 && level < nlevels + 1 );
    ErrorCode error;
    std::vector< Tag > mtags( 3 );
    error = mbImpl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mtags[0] );MB_CHK_ERR( error );
    error = mbImpl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mtags[1] );MB_CHK_ERR( error );
    error = mbImpl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mtags[2] );MB_CHK_ERR( error );
    for( int i = 0; i < 3; i++ )
        // Gather sets of a particular tag
        Range sets;
        error = mbImpl->get_entities_by_type_and_tag( _rset, MBENTITYSET, &mtags[i], NULL, 1, sets );MB_CHK_ERR( error );
        // Loop over all sets, gather entities in each set and add their children at all levels to
        // the set
        Range set_ents;
        Range::iterator set_it;
        std::vector< EntityHandle > childs;
        for( set_it = sets.begin(); set_it != sets.end(); ++set_it )
            // Get the entities in the set, recursively
            set_ents.clear();
            childs.clear();
            error = mbImpl->get_entities_by_handle( *set_it, set_ents, true );MB_CHK_ERR( error );
            // Gather child entities at the input level
            for( Range::iterator sit = set_ents.begin(); sit != set_ents.end(); sit++ )
                EntityType type = mbImpl->type_from_handle( *sit );
                    Range conn;
                    std::vector< EntityHandle > cents;
                    error = vertex_to_entities_down( *sit, 0, level, cents );MB_CHK_ERR( error );
                    error = mbImpl->get_connectivity( &cents[0], (int)cents.size(), conn, true );MB_CHK_ERR( error );
                    childs.insert( childs.end(), cents.begin(), cents.end() );
                else
                    error = parent_to_child( *sit, 0, level, childs );MB_CHK_ERR( error );
                std::sort( childs.begin(), childs.end() );
                childs.erase( std::unique( childs.begin(), childs.end() ), childs.end() );
                // Add child entities to tagged sets
                error = mbImpl->add_entities( *set_it, &childs[0], childs.size() );MB_CHK_ERR( error );
            // Remove the coarse entities
            error = mbImpl->remove_entities( *set_it, set_ents );MB_CHK_ERR( error );
            // Add
            error = mbImpl->add_entities( lset, &( *set_it ), 1 );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::update_tracking_verts ( EntityHandle  cid,
int  cur_level,
int  deg,
std::vector< EntityHandle > &  trackvertsC_edg,
std::vector< EntityHandle > &  trackvertsC_face,
) [protected]
Definition at line 4196 of file NestedRefine.cpp.
References _incells, ahf, moab::Range::begin(), moab::error(), ErrorCode, get_index_from_degree(), moab::HalfFacetRep::get_index_in_lmap(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::HalfFacetRep::get_up_adjacencies_face_3d(), moab::HalfFacetRep::lConnMap3D, level_mesh, MB_CHK_ERR, MB_SUCCESS, mbImpl, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::NestedRefine::refPatterns::nv_edge, moab::NestedRefine::refPatterns::nv_face, refTemplates, reorder_indices(), moab::NestedRefine::level_memory::start_cell, moab::Core::type_from_handle(), moab::NestedRefine::refPatterns::vert_on_edges, and moab::NestedRefine::refPatterns::vert_on_faces.
Referenced by subdivide_cells(), and subdivide_tets().
    // The vertices in the vbuffer are added to appropriate edges and faces of cells that are
    // incident on the working cell.
    ErrorCode error;
    EntityHandle cstart_prev;
    if( cur_level )
        cstart_prev = level_mesh[cur_level - 1].start_cell;
    else
        cstart_prev = *_incells.begin();
    EntityType cell_type = mbImpl->type_from_handle( cstart_prev );
    int cindex           = cell_type - 1;
    int nve = refTemplates[cindex][d].nv_edge;
    // Step 1: Add the vertices on an edge of the working cell to tracking array of incident cells.
        // Add the vertices to edges of the current cell
        for( int j = 0; j < nve; j++ )
            int id  = refTemplates[cindex][d].vert_on_edges[i][j];
            int idx = cid - cstart_prev;
            int aid = idx * nve * nepc + nve * i + j;
            if( !trackvertsC_edg[aid] ) trackvertsC_edg[aid] = vbuffer[id];
        // Obtain all the incident cells
        std::vector< EntityHandle > inc_cids;
        std::vector< int > inc_leids, inc_orient;
        error = ahf->get_up_adjacencies_edg_3d( cid, i, inc_cids, &inc_leids, &inc_orient );MB_CHK_ERR( error );
        if( inc_cids.size() == 1 ) continue;
        // Add the vertices to the edges of the incident cells
        for( int k = 0; k < (int)inc_cids.size(); k++ )
            if( inc_cids[k] == cid ) continue;
            int idx = inc_cids[k] - cstart_prev;
            if( inc_orient[k] )  // Same edge direction as the current edge
                    int aid = idx * nve * nepc + nve * inc_leids[k] + j;
            else
                    int id  = refTemplates[cindex][d].vert_on_edges[i][nve - j - 1];
    // Step 2: Add the vertices on a face of the working cell to tracking array of incident cells.
    if( nvf )
            // Add vertices to the tracking array of vertices on faces for the current cell
            std::vector< EntityHandle > face_vbuf( nvf, 0 );
                int id  = refTemplates[cindex][d].vert_on_faces[i][j];
                int aid = idx * nvf * nfpc + nvf * i + j;
                if( !trackvertsC_face[aid] ) trackvertsC_face[aid] = vbuffer[id];
                face_vbuf[j] = vbuffer[id];
            std::vector< EntityHandle > sib_cids;
            std::vector< int > sib_lfids;
            error = ahf->get_up_adjacencies_face_3d( cid, i, sib_cids, &sib_lfids );MB_CHK_ERR( error );
            if( sib_cids.size() == 1 ) continue;
            // Reorder the vertex local ids incident on the half-face
            std::vector< int > id_sib( nvf );
            for( int k = 0; k < nvf; k++ )
                id_sib[k] = 0;
            error = reorder_indices( cur_level, deg, sib_cids[1], sib_lfids[1], cid, i, 0, &id_sib[0] );MB_CHK_ERR( error );
            // Add vertices to the tracking array of vertices on faces for the sibling cell of the
            // current cell
                int idx = sib_cids[1] - cstart_prev;
                int aid = idx * nvf * nfpc + nvf * sib_lfids[1] + j;
                if( !trackvertsC_face[aid] ) trackvertsC_face[aid] = face_vbuf[id_sib[j] - 1];
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::vertex_to_entities_down ( EntityHandle  vertex,
int  vert_level,
int  child_level,
std::vector< EntityHandle > &  incident_entities
Given a vertex from a certain level, it returns a std::vector of all children entities of incident entities to vertex from any subsequent levels
Parameters:
vertexEntityHandle of the vertex
vert_levelMesh level of the vertex
child_levelMesh level from which child entities are requested
incident_entitiesVector containing entities from the child level
Definition at line 388 of file NestedRefine.cpp.
References ahf, moab::error(), ErrorCode, moab::HalfFacetRep::get_up_adjacencies_1d(), moab::HalfFacetRep::get_up_adjacencies_vert_2d(), moab::HalfFacetRep::get_up_adjacencies_vert_3d(), MB_CHK_ERR, MB_SUCCESS, meshdim, and parent_to_child().
Referenced by update_special_tags().
    assert( vert_level < child_level );
    ErrorCode error;
    // Step 1: Get the incident entities at the current level
    std::vector< EntityHandle > inents;
    if( meshdim == 1 )
        error = ahf->get_up_adjacencies_1d( vertex, inents );MB_CHK_ERR( error );
        error = ahf->get_up_adjacencies_vert_2d( vertex, inents );MB_CHK_ERR( error );
        error = ahf->get_up_adjacencies_vert_3d( vertex, inents );MB_CHK_ERR( error );
    // Step 2: Loop over all the incident entities at the current level and gather their parents
    for( int i = 0; i < (int)inents.size(); i++ )
        childs.clear();
        EntityHandle ent = inents[i];
        error            = parent_to_child( ent, vert_level, child_level, childs );MB_CHK_ERR( error );
        for( int j = 0; j < (int)childs.size(); j++ )
            incident_entities.push_back( childs[j] );
    return MB_SUCCESS;
ErrorCode moab::NestedRefine::vertex_to_entities_up ( EntityHandle  vertex,
int  vert_level,
int  parent_level,
Given a vertex from a certain level, it returns a std::vector of all entities from any previous levels that contains it.
Parameters:
parent_levelMesh level from which entities containing vertex is requested
incident_entitiesVector containing entities from the parent level incident on the vertex
Definition at line 348 of file NestedRefine.cpp.
References ahf, child_to_parent(), moab::error(), ErrorCode, moab::HalfFacetRep::get_up_adjacencies_1d(), moab::HalfFacetRep::get_up_adjacencies_vert_2d(), moab::HalfFacetRep::get_up_adjacencies_vert_3d(), MB_CHK_ERR, MB_SUCCESS, and meshdim.
    assert( vert_level > parent_level );
    ErrorCode error;
    if( meshdim == 1 )
        EntityHandle parent;
        error = child_to_parent( ent, vert_level, parent_level, &parent );MB_CHK_ERR( error );
        incident_entities.push_back( parent );
    // Step 3: Sort and remove duplicates
    std::sort( incident_entities.begin(), incident_entities.end() );
    incident_entities.erase( std::unique( incident_entities.begin(), incident_entities.end() ),
    return MB_SUCCESS;
Member Data Documentation
std::map< int, int > moab::NestedRefine::deg_index [protected]
Definition at line 180 of file NestedRefine.hpp.
Referenced by get_index_from_degree(), and initialize().
bool moab::NestedRefine::hasghost [protected]
Definition at line 181 of file NestedRefine.hpp.
Referenced by exchange_ghosts(), and initialize().
Initial value:
    { { 3, { { 3, 4 }, { 4, 5 }, { 5, 3 } } },
      { 9, { { 8, 3 }, { 3, 9 }, { 9, 4 }, { 4, 5 }, { 5, 9 }, { 9, 8 }, { 7, 9 }, { 9, 6 }, { 6, 7 } } } },
    { { 4, { { 4, 8 }, { 7, 8 }, { 8, 6 }, { 8, 5 } } },
      { 12,
        { { 4, 12 },
          { 12, 15 },
          { 15, 9 },
          { 5, 13 },
          { 13, 14 },
          { 14, 8 },
          { 11, 12 },
          { 12, 13 },
          { 13, 6 },
          { 10, 15 },
          { 15, 14 },
          { 14, 7 } } } } }
Definition at line 241 of file NestedRefine.hpp.
Referenced by construct_hm_2D(), and estimate_hm_storage().
int moab::NestedRefine::nlevels [protected]
Definition at line 178 of file NestedRefine.hpp.
Referenced by generate_hm(), generate_mesh_hierarchy(), and update_special_tags().
Definition at line 333 of file NestedRefine.hpp.
Referenced by reorder_indices().
Definition at line 166 of file NestedRefine.hpp.
Referenced by generate_hm(), and main().
Definition at line 172 of file NestedRefine.hpp.
Referenced by generate_hm(), initialize(), and ~NestedRefine().
List of all members.
