moab::OrientedBoxTreeTool::Op Class Reference
Implement this and pass instance to preorder_traverse. More...
#include <OrientedBoxTreeTool.hpp>
+ Inheritance diagram for moab::OrientedBoxTreeTool::Op:
Public Member Functions
virtual ErrorCode visit (EntityHandle node, int depth, bool &descend)=0
 Visit a node in the tree during a traversal.
virtual ErrorCode leaf (EntityHandle node)=0
 Process a leaf node during tree traversal.
virtual ~Op ()
Detailed Description
This interface may be implemented and an instance passed to preorder_traverse to define some operation to do when traversing the tree.
Definition at line 492 of file OrientedBoxTreeTool.hpp.
Definition at line 47 of file OrientedBoxTreeTool.cpp.
Member Function Documentation
virtual ErrorCode moab::OrientedBoxTreeTool::Op::visit ( EntityHandle  node,
int  depth,
bool &  descend
) [pure virtual]
This method is called for each node in the tree visited during a pre-order traversal.
Parameters:
nodeThe EntityHandle for the entity set for the tree node.
depthThe current depth in the tree.
descendOutput: if false, traversal will skip children of the current node, or if the current node is a leaf, the 'leaf' method will not be called.
Implemented in moab::TreeNodePrinter, moab::TreeLayoutPrinter, moab::RayIntersectSets, moab::RayIntersector, TriStats, and TriCounter.
Referenced by moab::OrientedBoxTreeTool::preorder_traverse().
List of all members.
