moab::ParCommGraph Class Reference
#include <ParCommGraph.hpp>
+ Collaboration diagram for moab::ParCommGraph:
Public Types
enum  TypeGraph { INITIAL_MIGRATE, COVERAGE, DOF_BASED }
Public Member Functions
virtual ~ParCommGraph ()
 ParCommGraph (MPI_Comm joincomm, MPI_Group group1, MPI_Group group2, int coid1, int coid2)
 collective constructor, will be called on all sender tasks and receiver tasks
 ParCommGraph (const ParCommGraph &)
 copy constructor will copy only the senders, receivers, compid1, etc
ErrorCode compute_trivial_partition (std::vector< int > &numElemsPerTaskInGroup1)
 Based on the number of elements on each task in group 1, partition for group 2, trivially.
ErrorCode pack_receivers_graph (std::vector< int > &packed_recv_array)
 pack information about receivers view of the graph, for future sending to receiver root
bool is_root_sender ()
bool is_root_receiver ()
int sender (int index)
int receiver (int index)
int get_component_id1 ()
int get_component_id2 ()
int get_context_id ()
void set_context_id (int other_id)
EntityHandle get_cover_set ()
void set_cover_set (EntityHandle cover)
ErrorCode split_owned_range (int sender_rank, Range &owned)
ErrorCode split_owned_range (Range &owned)
ErrorCode send_graph (MPI_Comm jcomm, std::vector< char > &zBuff)
ErrorCode send_graph_partition (ParallelComm *pco, MPI_Comm jcomm, std::vector< char > &zoltanBuffer)
ErrorCode send_mesh_parts (MPI_Comm jcomm, ParallelComm *pco, Range &owned)
ErrorCode receive_comm_graph (MPI_Comm jcomm, ParallelComm *pco, std::vector< int > &pack_array, std::vector< char > &zoltanBuffer)
ErrorCode receive_mesh (MPI_Comm jcomm, ParallelComm *pco, EntityHandle local_set, std::vector< int > &senders_local)
ErrorCode release_send_buffers ()
ErrorCode send_tag_values (MPI_Comm jcomm, ParallelComm *pco, Range &owned, std::vector< Tag > &tag_handles)
ErrorCode receive_tag_values (MPI_Comm jcomm, ParallelComm *pco, Range &owned, std::vector< Tag > &tag_handles)
const std::vector< int > & senders ()
const std::vector< int > & receivers ()
ErrorCode settle_send_graph (TupleList &TLcovIDs)
void SetReceivingAfterCoverage (std::map< int, std::set< int > > &idsFromProcs)
void settle_comm_by_ids (int comp, TupleList &TLBackToComp, std::vector< int > &valuesComp)
ErrorCode set_split_ranges (int comp, TupleList &TLBackToComp1, std::vector< int > &valuesComp1, int lenTag, Range &ents_of_interest, int type)
ErrorCode form_tuples_to_migrate_mesh (Interface *mb, TupleList &TLv, TupleList &TLc, int type, int lenTagType1)
ErrorCode form_mesh_from_tuples (Interface *mb, TupleList &TLv, TupleList &TLc, int type, int lenTagType1, EntityHandle fset, Range &primary_ents, std::vector< int > &values_entities)
ErrorCode compute_partition (ParallelComm *pco, Range &owned, int met, std::vector< char > &zoltanBuffer)
ErrorCode dump_comm_information (const std::string &prefix, int is_send, int verbose)
Private Member Functions
void find_group_ranks (MPI_Group group, MPI_Comm join, std::vector< int > &ranks)
 find ranks of a group with respect to an encompassing communicator
Private Attributes
MPI_Comm comm
std::vector< int > senderTasks
std::vector< int > receiverTasks
bool rootSender
bool rootReceiver
int rankInGroup1
int rankInGroup2
int rankInJoin
int joinSize
int compid1
int compid2
int context_id
EntityHandle cover_set
std::map< int, std::vector< int > > recv_graph
std::map< int, std::vector< int > > recv_sizes
std::map< int, std::vector< int > > sender_graph
std::map< int, std::vector< int > > sender_sizes
std::vector
< ParallelComm::Buffer * >
localSendBuffs
std::vector< int > comm_graph
std::vector< char > zBuff
std::map< int, Rangesplit_ranges
std::vector< MPI_Request > sendReqs
std::vector< int > corr_tasks
std::vector< int > corr_sizes
TypeGraph graph_type
std::map< int, std::vector< int > > involved_IDs_map
std::map< int, std::vector< int > > map_index
std::map< int, std::vector< int > > map_ptr
Detailed Description
Definition at line 55 of file ParCommGraph.hpp.
Member Enumeration Documentation
Enumerator:
INITIAL_MIGRATE
COVERAGE
DOF_BASED
Definition at line 58 of file ParCommGraph.hpp.
Definition at line 71 of file ParCommGraph.cpp.
    // TODO Auto-generated destructor stub
moab::ParCommGraph::ParCommGraph ( MPI_Comm  joincomm,
MPI_Group  group1,
MPI_Group  group2,
int  coid1,
int  coid2
Parameters:
[in]joincommjoint MPI communicator that covers both sender and receiver MPI groups
[in]group1MPI group formed with sender tasks; (sender usually loads the mesh in a migrate scenario)
[in]group2MPI group formed with receiver tasks; (receiver usually receives the mesh in a migrate scenario)
[in]coid1sender component unique identifier in a coupled application (in climate simulations could be the Atmosphere Comp id = 5 or Ocean Comp ID , 17)
[in]coid2receiver component unique identifier in a coupled application (it is usually the coupler, 2, in E3SM)
this graph will be formed on sender and receiver tasks, and, in principle, will hold info about how the local entities are distributed on the other side
Its major role is to help in migration of data, from component to the coupler and vice-versa; Each local entity has a corresponding task (or tasks) on the other side, to where the data needs to be sent
important data stored in ParCommGraph, immediately it is created
  • all sender and receiver tasks ids, with respect to the joint communicator
  • local rank in sender and receiver group (-1 if not part of the respective group)
  • rank in the joint communicator (from 0)
Definition at line 20 of file ParCommGraph.cpp.
References comm, context_id, cover_set, find_group_ranks(), graph_type, INITIAL_MIGRATE, joinSize, rankInGroup1, rankInGroup2, rankInJoin, receiverTasks, rootReceiver, rootSender, and senderTasks.
    : comm( joincomm ), compid1( coid1 ), compid2( coid2 )
    // find out the tasks from each group, in the joint communicator
    find_group_ranks( group1, comm, senderTasks );
    find_group_ranks( group2, comm, receiverTasks );
    rootSender = rootReceiver = false;
    rankInGroup1 = rankInGroup2 = rankInJoin = -1;  // not initialized, or not part of the group
    int mpierr = MPI_Group_rank( group1, &rankInGroup1 );
    if( MPI_SUCCESS != mpierr || rankInGroup1 == MPI_UNDEFINED ) rankInGroup1 = -1;
    mpierr = MPI_Group_rank( group2, &rankInGroup2 );
    if( MPI_SUCCESS != mpierr || rankInGroup2 == MPI_UNDEFINED ) rankInGroup2 = -1;
    mpierr = MPI_Comm_rank( comm, &rankInJoin );
    if( MPI_SUCCESS != mpierr )  // it should be a fatal error
        rankInJoin = -1;
    mpierr = MPI_Comm_size( comm, &joinSize );
        joinSize = -1;
    if( 0 == rankInGroup1 ) rootSender = true;
    if( 0 == rankInGroup2 ) rootReceiver = true;
    graph_type = INITIAL_MIGRATE;  // 0
    context_id = -1;
    cover_set  = 0;  // refers to nothing yet
Definition at line 52 of file ParCommGraph.cpp.
References comm, compid1, compid2, context_id, cover_set, graph_type, joinSize, rankInGroup1, rankInGroup2, rankInJoin, receiverTasks, rootReceiver, rootSender, and senderTasks.
    comm          = src.comm;
    senderTasks   = src.senderTasks;    // these are the sender tasks in joint comm
    receiverTasks = src.receiverTasks;  // these are all the receiver tasks in joint comm
    rootSender    = src.rootSender;
    rootReceiver  = src.rootReceiver;
    rankInGroup1  = src.rankInGroup1;
    rankInGroup2  = src.rankInGroup2;  // group 1 is sender, 2 is receiver
    rankInJoin    = src.rankInJoin;
    joinSize      = src.joinSize;
    compid1       = src.compid1;
    compid2       = src.compid2;
    graph_type    = src.graph_type;
    context_id    = src.context_id;
    cover_set     = src.cover_set;
    return;
Member Function Documentation
ErrorCode moab::ParCommGraph::compute_partition ( ParallelComm pco,
Range owned,
int  met,
std::vector< char > &  zoltanBuffer
Definition at line 1163 of file ParCommGraph.cpp.
References moab::Range::begin(), moab::ProcConfig::crystal_router(), moab::Core::dimension_from_handle(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), moab::Range::end(), ErrorCode, moab::Core::get_adjacencies(), moab::ParallelComm::get_moab(), moab::TupleList::get_n(), moab::ParallelComm::get_shared_entities(), moab::ParallelComm::get_sharing_data(), moab::Core::globalId_tag(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MAX_SHARING_PROCS, mb, MB_CHK_ERR, MB_SUCCESS, ZoltanPartitioner::partition_owned_cells(), moab::TupleList::print_to_file(), moab::ParallelComm::proc_config(), moab::ParallelComm::rank(), moab::Range::rbegin(), receiverTasks, rootSender, moab::Range::size(), split_ranges, moab::Range::subset_by_dimension(), moab::Core::tag_get_data(), moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vul_rd, and moab::TupleList::vul_wr.
    // we are on a task on sender, and need to compute a new partition;
    // primary cells need to be distributed to nb receivers tasks
    // first, we will use graph partitioner, with zoltan;
    // in the graph that we need to build, the first layer of ghosts is needed;
    // can we avoid that ? For example, we can find out from each boundary edge/face what is the
    // other cell (on the other side), then form the global graph, and call zoltan in parallel met 1
    // would be a geometric partitioner, and met 2 would be a graph partitioner for method 1 we do
    // not need any ghost exchange
    // find first edges that are shared
    if( owned.empty() )
        return MB_SUCCESS;  // nothing to do? empty partition is not allowed, maybe we should return
                            // error?
    Core* mb = (Core*)pco->get_moab();
    double t1, t2, t3;
    t1               = MPI_Wtime();
    int primaryDim   = mb->dimension_from_handle( *owned.rbegin() );
    int interfaceDim = primaryDim - 1;  // should be 1 or 2
    Range sharedEdges;
    ErrorCode rval;
    std::vector< int > shprocs( MAX_SHARING_PROCS );
    std::vector< EntityHandle > shhandles( MAX_SHARING_PROCS );
    Tag gidTag = mb->globalId_tag();
    int np;
    unsigned char pstatus;
    std::multimap< int, int > extraGraphEdges;
    // std::map<int, int> adjCellsId;
    std::map< int, int > extraCellsProc;
    // if method is 2, no need to do the exchange for adjacent cells across partition boundary
    // these maps above will be empty for method 2 (geometry)
    if( 1 == met )
        rval = pco->get_shared_entities( /*int other_proc*/ -1, sharedEdges, interfaceDim,
                                         /*const bool iface*/ true );MB_CHK_ERR( rval );
#ifdef VERBOSE
        std::cout << " on sender task " << pco->rank() << " number of shared interface cells " << sharedEdges.size()
                  << "\n";
#endif
        // find to what processors we need to send the ghost info about the edge
        // first determine the local graph; what elements are adjacent to each cell in owned range
        // cells that are sharing a partition interface edge, are identified first, and form a map
        TupleList TLe;                                     // tuple list for cells
        TLe.initialize( 2, 0, 1, 0, sharedEdges.size() );  // send to, id of adj cell, remote edge
        TLe.enableWriteAccess();
        std::map< EntityHandle, int > edgeToCell;  // from local boundary edge to adjacent cell id
        // will be changed after
        for( Range::iterator eit = sharedEdges.begin(); eit != sharedEdges.end(); eit++ )
            EntityHandle edge = *eit;
            // get the adjacent cell
            Range adjEnts;
            rval = mb->get_adjacencies( &edge, 1, primaryDim, false, adjEnts );MB_CHK_ERR( rval );
            if( adjEnts.size() > 0 )
                EntityHandle adjCell = adjEnts[0];
                int gid;
                rval = mb->tag_get_data( gidTag, &adjCell, 1, &gid );MB_CHK_ERR( rval );
                rval = pco->get_sharing_data( edge, &shprocs[0], &shhandles[0], pstatus, np );MB_CHK_ERR( rval );
                int n                = TLe.get_n();
                TLe.vi_wr[2 * n]     = shprocs[0];
                TLe.vi_wr[2 * n + 1] = gid;
                TLe.vul_wr[n]        = shhandles[0];  // the remote edge corresponding to shared edge
                edgeToCell[edge]     = gid;           // store the map between edge and local id of adj cell
                TLe.inc_n();
#ifdef VERBOSE
        std::stringstream ff2;
        ff2 << "TLe_" << pco->rank() << ".txt";
        TLe.print_to_file( ff2.str().c_str() );
#endif
        // send the data to the other processors:
        ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLe, 0 );
        // on receiver side, each local edge will have the remote cell adjacent to it!
        int ne = TLe.get_n();
        for( int i = 0; i < ne; i++ )
            int sharedProc         = TLe.vi_rd[2 * i];       // this info is coming from here, originally
            int remoteCellID       = TLe.vi_rd[2 * i + 1];   // this is the id of the remote cell, on sharedProc
            EntityHandle localCell = TLe.vul_rd[i];          // this is now local edge/face on this proc
            int localCellId        = edgeToCell[localCell];  // this is the local cell  adjacent to edge/face
            // now, we will need to add to the graph the pair <localCellId, remoteCellID>
            std::pair< int, int > extraAdj = std::make_pair( localCellId, remoteCellID );
            extraGraphEdges.insert( extraAdj );
            // adjCellsId [edgeToCell[localCell]] = remoteCellID;
            extraCellsProc[remoteCellID] = sharedProc;
#ifdef VERBOSE
            std::cout << "local ID " << edgeToCell[localCell] << " remote cell ID: " << remoteCellID << "\n";
#endif
    t2 = MPI_Wtime();
    if( rootSender ) std::cout << " time preparing the input for Zoltan:" << t2 - t1 << " seconds. \n";
        // so adj cells ids; need to call zoltan for parallel partition
#ifdef MOAB_HAVE_ZOLTAN
    ZoltanPartitioner* mbZTool = new ZoltanPartitioner( mb, pco );
    if( 1 <= met )  //  partition in zoltan, either graph or geometric partitioner
        std::map< int, Range > distribution;  // how to distribute owned elements by processors in receiving groups
        // in how many tasks do we want to be distributed?
        int numNewPartitions = (int)receiverTasks.size();
        Range primaryCells   = owned.subset_by_dimension( primaryDim );
        rval = mbZTool->partition_owned_cells( primaryCells, extraGraphEdges, extraCellsProc, numNewPartitions,
                                               distribution, met, zoltanBuffer );MB_CHK_ERR( rval );
        for( std::map< int, Range >::iterator mit = distribution.begin(); mit != distribution.end(); mit++ )
            int part_index = mit->first;
            assert( part_index < numNewPartitions );
            split_ranges[receiverTasks[part_index]] = mit->second;
    // delete now the partitioner
    delete mbZTool;
#endif
    t3 = MPI_Wtime();
    if( rootSender ) std::cout << " time spent by Zoltan " << t3 - t2 << " seconds. \n";
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::compute_trivial_partition ( std::vector< int > &  numElemsPerTaskInGroup1)
Operations: it is called on every receiver task; decides how are all elements distributed
Note: establish how many elements are sent from each task in group 1 to tasks in group 2 This call is usually made on a root / master process, and will construct local maps that are member data, which contain the communication graph, in both directions Also, number of elements migrated/exchanged between each sender/receiver
Parameters:
[in]numElemsPerTaskInGroup1(std::vector<int> &) number of elements on each sender task
Definition at line 98 of file ParCommGraph.cpp.
References MB_SUCCESS, receiverTasks, recv_graph, recv_sizes, sender_graph, sender_sizes, and senderTasks.
    recv_graph.clear();
    recv_sizes.clear();
    sender_graph.clear();
    sender_sizes.clear();
    if( numElemsPerTaskInGroup1.size() != senderTasks.size() )
        return MB_FAILURE;  // each sender has a number of elements that it owns
    // first find out total number of elements to be sent from all senders
    int total_elems = 0;
    std::vector< int > accum;
    accum.push_back( 0 );
    int num_senders = (int)senderTasks.size();
    for( size_t k = 0; k < numElemsPerTaskInGroup1.size(); k++ )
        total_elems += numElemsPerTaskInGroup1[k];
        accum.push_back( total_elems );
    int num_recv = ( (int)receiverTasks.size() );
    // in trivial partition, every receiver should get about total_elems/num_receivers elements
    int num_per_receiver = (int)( total_elems / num_recv );
    int leftover         = total_elems - num_per_receiver * num_recv;
    // so receiver k will receive  [starts[k], starts[k+1] ) interval
    std::vector< int > starts;
    starts.resize( num_recv + 1 );
    starts[0] = 0;
    for( int k = 0; k < num_recv; k++ )
        starts[k + 1] = starts[k] + num_per_receiver;
        if( k < leftover ) starts[k + 1]++;
    // each sender will send to a number of receivers, based on how the
    // arrays starts[0:num_recv] and accum[0:sendr] overlap
    int lastUsedReceiverRank = 0;  // first receiver was not treated yet
    for( int j = 0; j < num_senders; j++ )
        // we could start the receiver loop with the latest receiver that received from previous
        // sender
        for( int k = lastUsedReceiverRank; k < num_recv; k++ )
            // if overlap:
            if( starts[k] < accum[j + 1] && starts[k + 1] > accum[j] )
                recv_graph[receiverTasks[k]].push_back( senderTasks[j] );
                sender_graph[senderTasks[j]].push_back( receiverTasks[k] );
                // we still need to decide what is the overlap
                int sizeOverlap = 1;  // at least 1, for sure
                // 1
                if( starts[k] >= accum[j] )  // one end is starts[k]
                    if( starts[k + 1] >= accum[j + 1] )  // the other end is accum[j+1]
                        sizeOverlap = accum[j + 1] - starts[k];
                    else  //
                        sizeOverlap = starts[k + 1] - starts[k];
                else  // one end is accum[j]
                        sizeOverlap = accum[j + 1] - accum[j];
                    else
                        sizeOverlap = starts[k + 1] - accum[j];
                recv_sizes[receiverTasks[k]].push_back( sizeOverlap );  // basically, task k will receive from
        //   sender j, sizeOverlap elems
                sender_sizes[senderTasks[j]].push_back( sizeOverlap );
                if( starts[k] > accum[j + 1] )
                    lastUsedReceiverRank = k - 1;  // so next k loop will start a little higher, we
                                                   // probably finished with first few receivers (up
                                                   // to receiver lastUsedReceiverRank)
                    break;  // break the k loop, we distributed all elements from sender j to some
                            // receivers
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::dump_comm_information ( const std::string &  prefix,
int  is_send,
int  verbose
Definition at line 1635 of file ParCommGraph.cpp.
References COVERAGE, DOF_BASED, graph_type, INITIAL_MIGRATE, involved_IDs_map, MB_SUCCESS, rankInGroup1, rankInGroup2, rankInJoin, moab::Range::size(), and split_ranges.
    if( -1 != rankInGroup1 && 1 == is_send )  // it is a sender task
        std::ofstream dbfile;
        std::stringstream outf;
        outf << prefix << "_sender_" << rankInGroup1 << "_joint" << rankInJoin << "_type_" << (int)graph_type << ".txt";
        dbfile.open( outf.str().c_str() );
        if( graph_type == COVERAGE )
            for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin();
                 mit != involved_IDs_map.end(); mit++ )
                int receiver_proc        = mit->first;
                std::vector< int >& eids = mit->second;
                dbfile << "receiver: " << receiver_proc << " size:" << eids.size() << "\n";
                if( verbose >= 1 )
                    for( size_t i = 0; i < eids.size(); i++ )
                        dbfile << eids[i] << " ";
                        if( i % 20 == 19 ) dbfile << "\n";
                    dbfile << "\n";
        else if( graph_type == INITIAL_MIGRATE )  // just after migration
            for( std::map< int, Range >::iterator mit = split_ranges.begin(); mit != split_ranges.end(); mit++ )
                Range& eids       = mit->second;
        else if( graph_type == DOF_BASED )  // just after migration, or from computeGraph
                dbfile << "receiver: " << receiver_proc << " size:" << mit->second.size() << "\n";
        dbfile.close();
    if( -1 != rankInGroup2 && 0 == is_send )  // it is a receiver task
        outf << prefix << "_receiver_" << rankInGroup2 << "_joint" << rankInJoin << "_type_" << (int)graph_type
             << ".txt";
                int sender_proc          = mit->first;
                dbfile << "sender: " << sender_proc << " size:" << eids.size() << "\n";
                if( verbose >= 1 )
                    dbfile << "\n";
                dbfile << "receiver: " << sender_proc << " size:" << mit->second.size() << "\n";
        dbfile.close();
    return MB_SUCCESS;
void moab::ParCommGraph::find_group_ranks ( MPI_Group  group,
MPI_Comm  join,
std::vector< int > &  ranks
) [private]
Operations: Local, usually called on root process of the group
Parameters:
[in]joincomm(MPI_Comm)
[in]group(MPI_Group)
[out]ranks( std::vector<int>) ranks with respect to the joint communicator
Definition at line 79 of file ParCommGraph.cpp.
Referenced by ParCommGraph().
    MPI_Group global_grp;
    MPI_Comm_group( joincomm, &global_grp );
    int grp_size;
    MPI_Group_size( group, &grp_size );
    std::vector< int > rks( grp_size );
    ranks.resize( grp_size );
    for( int i = 0; i < grp_size; i++ )
        rks[i] = i;
    MPI_Group_translate_ranks( group, grp_size, &rks[0], global_grp, &ranks[0] );
    MPI_Group_free( &global_grp );
    return;
ErrorCode moab::ParCommGraph::form_mesh_from_tuples ( Interface mb,
TupleList TLv,
TupleList TLc,
int  type,
int  lenTagType1,
EntityHandle  fset,
Range primary_ents,
std::vector< int > &  values_entities
Definition at line 1425 of file ParCommGraph.cpp.
References moab::Interface::add_entities(), moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::TupleList::get_n(), moab::Interface::globalId_tag(), moab::Range::insert(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBPOLYGON, MBQUAD, MBTRI, moab::Range::size(), split_ranges, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::TupleList::vi_rd, and moab::TupleList::vr_rd.
    // might need to fill also the split_range things
    // we will always need GlobalID tag
    Tag gidtag = mb->globalId_tag();
    // for Type1, we need GLOBAL_DOFS tag;
    Tag gds;
    ErrorCode rval;
    std::vector< int > def_val( lenTagType1, 0 );
    if( type == 1 )
        // we may need to create this tag
        rval = mb->tag_get_handle( "GLOBAL_DOFS", lenTagType1, MB_TYPE_INTEGER, gds, MB_TAG_CREAT | MB_TAG_DENSE,
                                   &def_val[0] );MB_CHK_ERR( rval );
    std::map< int, EntityHandle > vertexMap;  //
    Range verts;
    // always form vertices and add them to the fset;
    int n = TLv.get_n();
    EntityHandle vertex;
    for( int i = 0; i < n; i++ )
        int gid = TLv.vi_rd[2 * i + 1];
        if( vertexMap.find( gid ) == vertexMap.end() )
            // need to form this vertex
            rval = mb->create_vertex( &( TLv.vr_rd[3 * i] ), vertex );MB_CHK_ERR( rval );
            vertexMap[gid] = vertex;
            verts.insert( vertex );
            rval = mb->tag_set_data( gidtag, &vertex, 1, &gid );MB_CHK_ERR( rval );
            // if point cloud,
        if( 2 == type )  // point cloud, add it to the split_ranges ?
            split_ranges[TLv.vi_rd[2 * i]].insert( vertexMap[gid] );
        // todo : when to add the values_entities ?
    rval = mb->add_entities( fset, verts );MB_CHK_ERR( rval );
    if( 2 == type )
        primary_ents = verts;
        values_entities.resize( verts.size() );  // just get the ids of vertices
        rval = mb->tag_get_data( gidtag, verts, &values_entities[0] );MB_CHK_ERR( rval );
        return MB_SUCCESS;
    n              = TLc.get_n();
    int size_tuple = 2 + ( ( type != 1 ) ? 0 : lenTagType1 ) + 1 + 10;  // 10 is the max number of vertices in cell
    EntityHandle new_element;
    Range cells;
    std::map< int, EntityHandle > cellMap;  // do no tcreate one if it already exists, maybe from other processes
        int from_proc  = TLc.vi_rd[size_tuple * i];
        int globalIdEl = TLc.vi_rd[size_tuple * i + 1];
        if( cellMap.find( globalIdEl ) == cellMap.end() )  // need to create the cell
            int current_index = 2;
            if( 1 == type ) current_index += lenTagType1;
            int nnodes = TLc.vi_rd[size_tuple * i + current_index];
            std::vector< EntityHandle > conn;
            conn.resize( nnodes );
            for( int j = 0; j < nnodes; j++ )
                conn[j] = vertexMap[TLc.vi_rd[size_tuple * i + current_index + j + 1]];
            EntityType entType = MBQUAD;
            if( nnodes > 4 ) entType = MBPOLYGON;
            if( nnodes < 4 ) entType = MBTRI;
            rval = mb->create_element( entType, &conn[0], nnodes, new_element );MB_CHK_SET_ERR( rval, "can't create new element " );
            cells.insert( new_element );
            cellMap[globalIdEl] = new_element;
            rval                = mb->tag_set_data( gidtag, &new_element, 1, &globalIdEl );MB_CHK_SET_ERR( rval, "can't set global id tag on cell " );
            if( 1 == type )
                // set the gds tag
                rval = mb->tag_set_data( gds, &new_element, 1, &( TLc.vi_rd[size_tuple * i + 2] ) );MB_CHK_SET_ERR( rval, "can't set gds tag on cell " );
        split_ranges[from_proc].insert( cellMap[globalIdEl] );
    rval = mb->add_entities( fset, cells );MB_CHK_ERR( rval );
    primary_ents = cells;
    if( 1 == type )
        values_entities.resize( lenTagType1 * primary_ents.size() );
        rval = mb->tag_get_data( gds, primary_ents, &values_entities[0] );MB_CHK_ERR( rval );
    else  // type == 3
        values_entities.resize( primary_ents.size() );  // just get the ids !
        rval = mb->tag_get_data( gidtag, primary_ents, &values_entities[0] );MB_CHK_ERR( rval );
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::form_tuples_to_migrate_mesh ( Interface mb,
TupleList TLv,
TupleList TLc,
int  type,
int  lenTagType1
Definition at line 1338 of file ParCommGraph.cpp.
References moab::Range::begin(), moab::TupleList::enableWriteAccess(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::TupleList::get_n(), moab::Interface::globalId_tag(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_CHK_ERR, MB_SUCCESS, moab::Range::size(), split_ranges, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::TupleList::vi_wr, and moab::TupleList::vr_wr.
    Tag gds;
    ErrorCode rval;
    if( type == 1 )
        rval = mb->tag_get_handle( "GLOBAL_DOFS", gds );
    // find vertices to be sent, for each of the split_ranges procs
    std::map< int, Range > verts_to_proc;
    int numv = 0, numc = 0;
    for( auto it = split_ranges.begin(); it != split_ranges.end(); it++ )
        int to_proc = it->first;
        Range verts;
        if( type != 2 )
            rval = mb->get_connectivity( it->second, verts );MB_CHK_ERR( rval );
            numc += (int)it->second.size();
        else
            verts = it->second;
        verts_to_proc[to_proc] = verts;
        numv += (int)verts.size();
    // first vertices:
    TLv.initialize( 2, 0, 0, 3, numv );  // to proc, GLOBAL ID, 3 real coordinates
    TLv.enableWriteAccess();
    // use the global id of vertices for connectivity
    for( auto it = verts_to_proc.begin(); it != verts_to_proc.end(); it++ )
        Range& verts = it->second;
        for( Range::iterator vit = verts.begin(); vit != verts.end(); ++vit )
            EntityHandle v   = *vit;
            int n            = TLv.get_n();  // current size of tuple list
            TLv.vi_wr[2 * n] = to_proc;      // send to processor
            rval = mb->tag_get_data( gidtag, &v, 1, &( TLv.vi_wr[2 * n + 1] ) );MB_CHK_ERR( rval );
            rval = mb->get_coords( &v, 1, &( TLv.vr_wr[3 * n] ) );MB_CHK_ERR( rval );
            TLv.inc_n();  // increment tuple list size
    if( type == 2 ) return MB_SUCCESS;  // no need to fill TLc
    // to proc, ID cell, gdstag, nbv, id conn,
    std::vector< int > gdvals;
    TLc.initialize( size_tuple, 0, 0, 0, numc );  // to proc, GLOBAL ID, 3 real coordinates
    TLc.enableWriteAccess();
        Range& cells = it->second;
        for( Range::iterator cit = cells.begin(); cit != cells.end(); ++cit )
            EntityHandle cell         = *cit;
            int n                     = TLc.get_n();  // current size of tuple list
            TLc.vi_wr[size_tuple * n] = to_proc;
            rval                      = mb->tag_get_data( gidtag, &cell, 1, &( TLc.vi_wr[size_tuple * n + 1] ) );MB_CHK_ERR( rval );
            if( 1 == type )
                rval = mb->tag_get_data( gds, &cell, 1, &( TLc.vi_wr[size_tuple * n + current_index] ) );MB_CHK_ERR( rval );
            // now get connectivity
            const EntityHandle* conn = NULL;
            int nnodes               = 0;
            rval                     = mb->get_connectivity( cell, conn, nnodes );MB_CHK_ERR( rval );
            // fill nnodes:
            TLc.vi_wr[size_tuple * n + current_index] = nnodes;
            rval = mb->tag_get_data( gidtag, conn, nnodes, &( TLc.vi_wr[size_tuple * n + current_index + 1] ) );MB_CHK_ERR( rval );
            TLc.inc_n();  // increment tuple list size
    return MB_SUCCESS;
Definition at line 153 of file ParCommGraph.hpp.
References compid1.
        return compid1;
Definition at line 157 of file ParCommGraph.hpp.
References compid2.
        return compid2;
Definition at line 162 of file ParCommGraph.hpp.
References context_id.
        return context_id;
Definition at line 171 of file ParCommGraph.hpp.
References cover_set.
        return cover_set;
Definition at line 138 of file ParCommGraph.hpp.
References rootReceiver.
        return rootReceiver;
Definition at line 133 of file ParCommGraph.hpp.
References rootSender.
Referenced by send_graph(), send_graph_partition(), and send_mesh_parts().
        return rootSender;
ErrorCode moab::ParCommGraph::pack_receivers_graph ( std::vector< int > &  packed_recv_array)
Operations: Local, called on root process of the senders group
Parameters:
[out]packed_recv_arraypacked data will be sent to the root of receivers, and distributed from there, and will have this information, for each receiver, concatenated receiver 1 task, number of senders for receiver 1, then sender tasks for receiver 1, receiver 2 task, number of senders for receiver 2, sender tasks for receiver 2, etc Note: only the root of senders will compute this, and send it over to the receiver root, which will distribute it over each receiver; We do not pack the sizes of data to be sent, only the senders for each of the receivers (could be of size O(n^2) , where n is the number of tasks ; but in general, it should be more like O(n) ). Each sender sends to a "finite" number of receivers, and each receiver receives from a finite number of senders). We need this info to decide how to set up the send/receive waiting game for non-blocking communication )
Definition at line 187 of file ParCommGraph.cpp.
References MB_SUCCESS, receiverTasks, recv_graph, and senders().
Referenced by send_graph().
    // it will basically look at local data, to pack communication graph, each receiver task will
    // have to post receives for each sender task that will send data to it; the array will be
    // communicated to root receiver, and eventually distributed to receiver tasks
     * packed_array will have receiver, number of senders, then senders, etc
    if( recv_graph.size() < receiverTasks.size() )
        // big problem, we have empty partitions in receive
        std::cout << " WARNING: empty partitions, some receiver tasks will receive nothing.\n";
    for( std::map< int, std::vector< int > >::iterator it = recv_graph.begin(); it != recv_graph.end(); it++ )
        int recv                    = it->first;
        std::vector< int >& senders = it->second;
        packed_recv_array.push_back( recv );
        packed_recv_array.push_back( (int)senders.size() );
        for( int k = 0; k < (int)senders.size(); k++ )
            packed_recv_array.push_back( senders[k] );
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::receive_comm_graph ( MPI_Comm  jcomm,
ParallelComm pco,
std::vector< int > &  pack_array,
Definition at line 370 of file ParCommGraph.cpp.
References moab::ParallelComm::comm(), MB_SUCCESS, rootReceiver, and sender().
    // first, receive from sender_rank 0, the communication graph (matrix), so each receiver
    // knows what data to expect
    MPI_Comm receive = pco->comm();
    int size_pack_array, ierr;
    MPI_Status status;
    if( rootReceiver )
        ierr = MPI_Probe( sender( 0 ), 20, jcomm, &status );
        if( 0 != ierr )
            std::cout << " MPI_Probe failure: " << ierr << "\n";
            return MB_FAILURE;
        // get the count of data received from the MPI_Status structure
        ierr = MPI_Get_count( &status, MPI_INT, &size_pack_array );
        if( 0 != ierr )
            std::cout << " MPI_Get_count failure: " << ierr << "\n";
            return MB_FAILURE;
#ifdef VERBOSE
        std::cout << " receive comm graph size: " << size_pack_array << "\n";
#endif
        pack_array.resize( size_pack_array );
        ierr = MPI_Recv( &pack_array[0], size_pack_array, MPI_INT, sender( 0 ), 20, jcomm, &status );
        if( 0 != ierr ) return MB_FAILURE;
#ifdef VERBOSE
        std::cout << " receive comm graph ";
        for( int k = 0; k < (int)pack_array.size(); k++ )
            std::cout << " " << pack_array[k];
        std::cout << "\n";
#endif
        // the last int tells if we have another receive to do or not (for  zoltan buffer)
        // look at the last value, to see if we receive zoltan buffer or not
        int semaphore = pack_array[size_pack_array - 1];
        if( 1 == semaphore )
            // expect zoltanBuffer, the difference is the tag; we still need the joint comm
            // the buffer was sent with a nonblocking send, from the root sender
            ierr = MPI_Probe( sender( 0 ), 30, jcomm, &status );  // blocking call, to get size
            if( 0 != ierr )
                return MB_FAILURE;
            int incoming_msg_size;
            MPI_Get_count( &status, MPI_CHAR, &incoming_msg_size );
            zoltanBuffer.resize( incoming_msg_size );
            ierr = MPI_Recv( &zoltanBuffer[0], incoming_msg_size, MPI_CHAR, sender( 0 ), 30, jcomm, &status );
            if( 0 != ierr )
                std::cout << " MPI_Recv failure: " << ierr << "\n";
                return MB_FAILURE;
    // now broadcast this whole array to all receivers, so they know what to expect
    ierr = MPI_Bcast( &size_pack_array, 1, MPI_INT, 0, receive );
    ierr = MPI_Bcast( &pack_array[0], size_pack_array, MPI_INT, 0, receive );
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::receive_mesh ( MPI_Comm  jcomm,
ParallelComm pco,
std::vector< int > &  senders_local
Definition at line 441 of file ParCommGraph.cpp.
References moab::Core::a_entity_factory(), moab::Interface::add_entities(), moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, buffer, corr_sizes, corr_tasks, moab::AEntityFactory::create_vert_elem_adjacencies(), moab::Range::empty(), moab::Range::end(), entities, ErrorCode, moab::Core::get_connectivity(), moab::ParallelComm::get_moab(), mb, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBVERTEX, moab::ParallelComm::Buffer::mem_ptr, moab::Range::merge(), moab::AEntityFactory::notify_create_entity(), rankInGroup2, rankInJoin, moab::ParallelComm::Buffer::reset_ptr(), moab::Range::size(), split_ranges, moab::Range::subset_by_dimension(), moab::Range::subset_by_type(), moab::subtract(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::ParallelComm::unpack_buffer(), moab::AEntityFactory::vert_elem_adjacencies(), and moab::Interface::write_file().
    ErrorCode rval;
    int ierr;
    MPI_Status status;
    // we also need to fill corresponding mesh info on the other side
    corr_tasks = senders_local;
    Range newEnts;
    Tag orgSendProcTag;  // this will be a tag set on the received mesh, with info about from what
                         // task / PE the
    // primary element came from, in the joint communicator ; this will be forwarded by coverage
    // mesh
    int defaultInt = -1;  // no processor, so it was not migrated from somewhere else
    rval           = pco->get_moab()->tag_get_handle( "orig_sending_processor", 1, MB_TYPE_INTEGER, orgSendProcTag,
                                            MB_TAG_DENSE | MB_TAG_CREAT, &defaultInt );MB_CHK_SET_ERR( rval, "can't create original sending processor tag" );
    if( !senders_local.empty() )
        for( size_t k = 0; k < senders_local.size(); k++ )
            int sender1 = senders_local[k];
            // first receive the size of the buffer using probe
                 * MPI_Probe(
                int source,
                int tag,
                MPI_Comm comm,
                MPI_Status* status)
            ierr = MPI_Probe( sender1, 2, jcomm, &status );
            if( 0 != ierr )
                std::cout << " MPI_Probe failure in ParCommGraph::receive_mesh " << ierr << "\n";
                return MB_FAILURE;
            int size_pack;
            ierr = MPI_Get_count( &status, MPI_CHAR, &size_pack );
            if( 0 != ierr )
                std::cout << " MPI_Get_count failure in ParCommGraph::receive_mesh  " << ierr << "\n";
                return MB_FAILURE;
            /* ierr = MPI_Recv (&size_pack, 1, MPI_INT, sender1, 1, jcomm, &status);
             if (0!=ierr) return MB_FAILURE;*/
            // now resize the buffer, then receive it
            ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_pack );
            // buffer->reserve(size_pack);
            ierr = MPI_Recv( buffer->mem_ptr, size_pack, MPI_CHAR, sender1, 2, jcomm, &status );
            if( 0 != ierr )
                std::cout << " MPI_Recv failure in ParCommGraph::receive_mesh " << ierr << "\n";
                return MB_FAILURE;
            // now unpack the buffer we just received
            Range entities;
            std::vector< std::vector< EntityHandle > > L1hloc, L1hrem;
            std::vector< std::vector< int > > L1p;
            std::vector< EntityHandle > L2hloc, L2hrem;
            std::vector< unsigned int > L2p;
            buffer->reset_ptr( sizeof( int ) );
            std::vector< EntityHandle > entities_vec( entities.size() );
            std::copy( entities.begin(), entities.end(), entities_vec.begin() );
            rval = pco->unpack_buffer( buffer->buff_ptr, false, -1, -1, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p,
                                       entities_vec );
            delete buffer;
            if( MB_SUCCESS != rval ) return rval;
            std::copy( entities_vec.begin(), entities_vec.end(), range_inserter( entities ) );
            // we have to add them to the local set
            rval = pco->get_moab()->add_entities( local_set, entities );
            // corr_sizes is the size of primary entities received
            Range verts              = entities.subset_by_dimension( 0 );
            Range local_primary_ents = subtract( entities, verts );
            if( local_primary_ents.empty() )
                // it is possible that all ents sent were vertices (point cloud)
                // then consider primary entities the vertices
                local_primary_ents = verts;
            else
                // set a tag with the original sender for the primary entity
                // will be used later for coverage mesh
                std::vector< int > orig_senders( local_primary_ents.size(), sender1 );
                rval = pco->get_moab()->tag_set_data( orgSendProcTag, local_primary_ents, &orig_senders[0] );
            corr_sizes.push_back( (int)local_primary_ents.size() );
            newEnts.merge( entities );
            // make these in split ranges
            split_ranges[sender1] = local_primary_ents;
#ifdef VERBOSE
            std::ostringstream partial_outFile;
            partial_outFile << "part_send_" << sender1 << "."
                            << "recv" << rankInJoin << ".vtk";
            // the mesh contains ghosts too, but they are not part of mat/neumann set
            // write in serial the file, to see what tags are missing
            std::cout << " writing from receiver " << rankInJoin << " from sender " << sender1
                      << " entities: " << entities.size() << std::endl;
            rval = pco->get_moab()->write_file( partial_outFile.str().c_str(), 0, 0, &local_set,
                                                1 );  // everything on local set received
#endif
    // make sure adjacencies are updated on the new elements
    if( newEnts.empty() )
        std::cout << "task:" << rankInGroup2 << " in receiver did not receive any entities \n";
    else
        // in order for the merging to work, we need to be sure that the adjacencies are updated
        // (created)
        Range local_verts        = newEnts.subset_by_type( MBVERTEX );
        newEnts                  = subtract( newEnts, local_verts );
        AEntityFactory* adj_fact = mb->a_entity_factory();
        if( !adj_fact->vert_elem_adjacencies() )
            adj_fact->create_vert_elem_adjacencies();
        else
            for( Range::iterator it = newEnts.begin(); it != newEnts.end(); ++it )
                EntityHandle eh          = *it;
                int num_nodes            = 0;
                rval                     = mb->get_connectivity( eh, conn, num_nodes );
                adj_fact->notify_create_entity( eh, conn, num_nodes );
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::receive_tag_values ( MPI_Comm  jcomm,
ParallelComm pco,
Range owned,
std::vector< Tag > &  tag_handles
Get the size of the specified tag in bytes
Definition at line 817 of file ParCommGraph.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, buffer, COVERAGE, DOF_BASED, moab::Range::end(), ErrorCode, moab::ParallelComm::get_moab(), moab::Core::globalId_tag(), graph_type, moab::Core::id_from_handle(), INITIAL_MIGRATE, involved_IDs_map, map_index, map_ptr, mb, MB_CHK_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, rankInJoin, moab::ParallelComm::Buffer::reset_ptr(), moab::Range::size(), split_ranges, moab::Core::tag_get_bytes(), moab::Core::tag_get_data(), moab::Core::tag_get_length(), and moab::Core::tag_set_data().
    // opposite to sending, we will use blocking receives
    int ierr;
    MPI_Status status;
    // basically, owned.size() needs to be equal to sum(corr_sizes)
    // get info about the tag size, type, etc
    //! Get the size of the specified tag in bytes
    ErrorCode rval;
    int total_bytes_per_entity = 0;
    std::vector< int > vect_bytes_per_tag;
#ifdef VERBOSE
    std::vector< int > tag_sizes;
#endif
    for( size_t i = 0; i < tag_handles.size(); i++ )
        int bytes_per_tag;
        rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval );
        total_bytes_per_entity += bytes_per_tag;
        vect_bytes_per_tag.push_back( bytes_per_tag );
#ifdef VERBOSE
        int tag_size;
        rval = mb->tag_get_length( tag_handles[i], tag_size );MB_CHK_ERR( rval );
        tag_sizes.push_back( tag_size );
#endif
        // std::map<int, Range> split_ranges;
        // rval = split_owned_range ( owned);MB_CHK_ERR ( rval );
        // use the buffers data structure to allocate memory for receiving the tags
        for( std::map< int, Range >::iterator it = split_ranges.begin(); it != split_ranges.end(); it++ )
            int sender_proc = it->first;
            Range ents      = it->second;  // primary entities, with the tag data, we will receive
            int size_buffer = 4 + total_bytes_per_entity *
                                      (int)ents.size();  // hopefully, below 2B; if more, we have a big problem ...
            ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer );
            *( (int*)buffer->mem_ptr ) = size_buffer;
            // int size_pack = buffer->get_current_size(); // debug check
            ierr = MPI_Recv( buffer->mem_ptr, size_buffer, MPI_CHAR, sender_proc, 222, jcomm, &status );
            if( ierr != 0 ) return MB_FAILURE;
            // now set the tag
            // copy to tag
                rval = mb->tag_set_data( tag_handles[i], ents, (void*)( buffer->buff_ptr ) );
                buffer->buff_ptr += vect_bytes_per_tag[i] * ents.size();
            delete buffer;  // no need for it afterwards
            MB_CHK_ERR( rval );
    else if( graph_type == COVERAGE )  // receive buffer, then extract tag data, in a loop
        // we know that we will need to receive some tag data in a specific order (by ids stored)
        // first, get the ids of the local elements, from owned Range; unpack the buffer in order
        std::vector< int > gids;
        gids.resize( owned.size() );
        rval = mb->tag_get_data( gidTag, owned, &gids[0] );MB_CHK_ERR( rval );
        std::map< int, EntityHandle > gidToHandle;
        size_t i = 0;
        for( Range::iterator it = owned.begin(); it != owned.end(); it++ )
            gidToHandle[gids[i++]] = eh;
        // now, unpack the data and set it to the tag
                                      (int)eids.size();  // hopefully, below 2B; if more, we have a big problem ...
            *( (int*)buffer->mem_ptr ) = size_buffer;  // this is really not necessary, it should receive this too
            // receive the buffer
// start copy
#ifdef VERBOSE
            outf << "recvFrom_" << sender_proc << "_on_proc_" << rankInJoin << ".txt";
            dbfile << "recvFrom_" << sender_proc << " on proc  " << rankInJoin << "\n";
#endif
            // copy tag data from buffer->buff_ptr
            // data is arranged by tag , and repeat the loop for each entity ()
            // maybe it should be arranged by entity now, not by tag (so one loop for entities,
            // outside)
            for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++ )
                int eID                                      = *it;
                std::map< int, EntityHandle >::iterator mit2 = gidToHandle.find( eID );
                if( mit2 == gidToHandle.end() )
                    std::cout << " on rank: " << rankInJoin << " cannot find entity handle with global ID " << eID
                              << "\n";
                    return MB_FAILURE;
                EntityHandle eh = mit2->second;
                for( i = 0; i < tag_handles.size(); i++ )
                    rval = mb->tag_set_data( tag_handles[i], &eh, 1, (void*)( buffer->buff_ptr ) );MB_CHK_ERR( rval );
#ifdef VERBOSE
                    dbfile << "global ID " << eID << " local handle " << mb->id_from_handle( eh ) << " vals: ";
                    double* vals = (double*)( buffer->buff_ptr );
                    for( int kk = 0; kk < tag_sizes[i]; kk++ )
                        dbfile << " " << *vals;
                        vals++;
                    dbfile << "\n";
#endif
                    buffer->buff_ptr += vect_bytes_per_tag[i];
            // delete receive buffer
            delete buffer;
#ifdef VERBOSE
            dbfile.close();
#endif
        // need to fill up the values for each tag, in the order desired, from the buffer received
        // get all the tags, for all owned entities, and pack the buffers accordingly
        // we do not want to get the tags by entity, it may be too expensive
        std::vector< std::vector< double > > valuesTags;
        valuesTags.resize( tag_handles.size() );
            int bytes_per_tag;
            valuesTags[i].resize( owned.size() * bytes_per_tag / sizeof( double ) );
            // fill the whole array, we will pick up from here
            // we will fill this array, using data from received buffer
            // rval = mb->tag_get_data(owned, (void*)( &(valuesTags[i][0])) );MB_CHK_ERR ( rval );
        // now, unpack the data and set the tags
            std::vector< int >& index_in_values = map_index[sender_proc];
            std::vector< int >& index_ptr       = map_ptr[sender_proc];  // this is eids.size()+1;
            // use the values in buffer to populate valuesTag arrays, fill it up!
            int j = 0;
            for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++, j++ )
                    // right now, move just doubles; but it could be any type of tag
                    double val = *( (double*)( buffer->buff_ptr ) );
                    buffer->buff_ptr += 8;  // we know we are working with doubles only !!!
                    for( int k = index_ptr[j]; k < index_ptr[j + 1]; k++ )
                        valuesTags[i][index_in_values[k]] = val;
            // we are done with the buffer in which we received tags, release / delete it
            delete buffer;
        // now we populated the values for all tags; set now the tags!
            rval = mb->tag_set_data( tag_handles[i], owned, (void*)( &( valuesTags[i][0] ) ) );MB_CHK_ERR( rval );
    return MB_SUCCESS;
int moab::ParCommGraph::receiver ( int  index) [inline]
Definition at line 148 of file ParCommGraph.hpp.
References receiverTasks.
        return receiverTasks[index];
const std::vector< int >& moab::ParCommGraph::receivers ( ) [inline]
Definition at line 213 of file ParCommGraph.hpp.
Referenced by split_owned_range().
        return receiverTasks;
Definition at line 591 of file ParCommGraph.cpp.
References comm_graph, localSendBuffs, MB_SUCCESS, sendReqs, and zBuff.
    int ierr, nsize = (int)sendReqs.size();
    std::vector< MPI_Status > mult_status;
    mult_status.resize( sendReqs.size() );
    ierr = MPI_Waitall( nsize, &sendReqs[0], &mult_status[0] );
    // now we can free all buffers
    comm_graph.clear();
    zBuff.clear();  // this is for zoltan buffer, it will be used only when sending the
                    // the RCB tree from component (sender) root to coupler (receiver) root
    std::vector< ParallelComm::Buffer* >::iterator vit;
    for( vit = localSendBuffs.begin(); vit != localSendBuffs.end(); ++vit )
        delete( *vit );
    localSendBuffs.clear();
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::send_graph ( MPI_Comm  jcomm,
std::vector< char > &  zBuff
Definition at line 263 of file ParCommGraph.cpp.
References comm_graph, ErrorCode, is_root_sender(), MB_SUCCESS, pack_receivers_graph(), receiver(), sendReqs, and zBuff.
Referenced by send_graph_partition().
    if( is_root_sender() )
        int ierr;
        // will need to build a communication graph, because each sender knows now to which receiver
        // to send data the receivers need to post receives for each sender that will send data to
        // them will need to gather on rank 0 on the sender comm, global ranks of sender with
        // receivers to send build communication matrix, each receiver will receive from what sender
        std::vector< int > packed_recv_array;
        ErrorCode rval = pack_receivers_graph( packed_recv_array );
        int size_pack_array = (int)packed_recv_array.size() + 1;
        // the last integer
        // will signal if we have to send zoltan buffer too, in a separate message 0 for no, 1 for yes
        comm_graph = packed_recv_array;
        comm_graph.resize( size_pack_array );  // bigger by 1, to store the semaphore about zBuff
        // will add 1 or 2 requests; first one with comm graph, second with zoltan buffer if needed
        if( zoltanBuffer.size() > 0 )
            sendReqs.resize( 2 );
            comm_graph[size_pack_array - 1] = 1;  // send zoltanBuffer too :)
            zBuff = zoltanBuffer;  // do a deep copy here, because the zoltanBuffer will go out of scope, and
            // we need to keep the sent buffer, after the non-blocking sent is executed; thanks Karen Devine !
        else
            sendReqs.resize( 1 );
            comm_graph[size_pack_array - 1] = 0;  // do not send zoltan buffer
        // we have to use global communicator if (ierr!=0) return MB_FAILURE;*/
        ierr = MPI_Isend( &comm_graph[0], size_pack_array, MPI_INT, receiver( 0 ), 20, jcomm,
                          &sendReqs[0] );  // we have to use global communicator
        if( zBuff.size() > 0 )
            ierr = MPI_Isend( &zBuff[0], (int)zBuff.size(), MPI_CHAR, receiver( 0 ), 30, jcomm,
                              &sendReqs[1] );  // we have to use global communicator
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::send_graph_partition ( ParallelComm pco,
MPI_Comm  jcomm,
Definition at line 1534 of file ParCommGraph.cpp.
References buffer, moab::ParallelComm::comm(), compid1, compid2, ErrorCode, is_root_sender(), MB_CHK_ERR, MB_SUCCESS, recv_graph, send_graph(), senders(), senderTasks, and split_ranges.
    // first, accumulate the info to root of sender; use gatherv
    // first, accumulate number of receivers from each sender, to the root receiver
    int numberReceivers =
        (int)split_ranges.size();            // these are ranges of elements to be sent to each receiver, from this task
    int nSenders = (int)senderTasks.size();  //
    // this sender will have to send to this many receivers
    std::vector< int > displs( 1 );  // displacements for gatherv
    std::vector< int > counts( 1 );
        displs.resize( nSenders + 1 );
        counts.resize( nSenders );
    int ierr = MPI_Gather( &numberReceivers, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, pco->comm() );
    if( ierr != MPI_SUCCESS ) return MB_FAILURE;
    // compute now displacements
        displs[0] = 0;
        for( int k = 0; k < nSenders; k++ )
            displs[k + 1] = displs[k] + counts[k];
    std::vector< int > buffer;
    if( is_root_sender() ) buffer.resize( displs[nSenders] );  // the last one will have the total count now
    std::vector< int > recvs;
        recvs.push_back( mit->first );
    ierr =
        MPI_Gatherv( &recvs[0], numberReceivers, MPI_INT, &buffer[0], &counts[0], &displs[0], MPI_INT, 0, pco->comm() );
    // now form recv_graph map; points from the
    // now form the graph to be sent to the other side; only on root
#ifdef GRAPH_INFO
        std::ofstream dbfileSender;
        outf << "S_" << compid1 << "_R_" << compid2 << "_SenderGraph.txt";
        dbfileSender.open( outf.str().c_str() );
        dbfileSender << " number senders: " << nSenders << "\n";
        dbfileSender << " senderRank \treceivers \n";
            int indexInBuff = displs[k];
            int senderTask  = senderTasks[k];
            dbfileSender << senderTask << "\t\t";
            for( int j = 0; j < counts[k]; j++ )
                int recvTask = buffer[indexInBuff + j];
                dbfileSender << recvTask << " ";
            dbfileSender << "\n";
        dbfileSender.close();
#endif
                recv_graph[recvTask].push_back( senderTask );  // this will be packed and sent to root receiver, with
                                                               // nonblocking send
#ifdef GRAPH_INFO
        std::stringstream outf2;
        outf2 << "S_" << compid1 << "_R_" << compid2 << "_RecvGraph.txt";
        dbfile.open( outf2.str().c_str() );
        dbfile << " number receivers: " << recv_graph.size() << "\n";
        dbfile << " receiverRank \tsenders \n";
        for( std::map< int, std::vector< int > >::iterator mit = recv_graph.begin(); mit != recv_graph.end(); mit++ )
            int recvTask                = mit->first;
            std::vector< int >& senders = mit->second;
            dbfile << recvTask << "\t\t";
            for( std::vector< int >::iterator vit = senders.begin(); vit != senders.end(); vit++ )
                dbfile << *vit << " ";
            dbfile << "\n";
        dbfile.close();
#endif
        // this is the same as trivial partition
        ErrorCode rval = send_graph( jcomm, zoltanBuffer );MB_CHK_ERR( rval );
    return MB_SUCCESS;
not anymore !
Definition at line 311 of file ParCommGraph.cpp.
References buffer, corr_sizes, corr_tasks, ErrorCode, moab::Interface::get_adjacencies(), moab::ParallelComm::Buffer::get_current_size(), moab::ParallelComm::get_moab(), moab::ParallelComm::INITIAL_BUFF_SIZE, is_root_sender(), localSendBuffs, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, moab::Range::merge(), moab::ParallelComm::pack_buffer(), rankInGroup1, moab::ParallelComm::Buffer::reset_ptr(), sender_graph, sender_sizes, senderTasks, sendReqs, split_owned_range(), split_ranges, and moab::Interface::UNION.
    ErrorCode rval;
    if( split_ranges.empty() )  // in trivial partition
        rval = split_owned_range( rankInGroup1, owned );
        if( rval != MB_SUCCESS ) return rval;
        // we know this on the sender side:
        corr_tasks = sender_graph[senderTasks[rankInGroup1]];  // copy
        corr_sizes = sender_sizes[senderTasks[rankInGroup1]];  // another copy
    int indexReq = 0;
    int ierr;                                                // MPI error
    if( is_root_sender() ) indexReq = (int)sendReqs.size();  // we could have 1 or 2 MPI_Request's already
    sendReqs.resize( indexReq + split_ranges.size() );
        int receiver_proc = it->first;
        // add necessary vertices too
        Range verts;
        rval = pco->get_moab()->get_adjacencies( ents, 0, false, verts, Interface::UNION );
            std::cout << " can't get adjacencies. for entities to send\n";
            return rval;
        ents.merge( verts );
        ParallelComm::Buffer* buffer = new ParallelComm::Buffer( ParallelComm::INITIAL_BUFF_SIZE );
        rval = pco->pack_buffer( ents, false, true, false, -1, buffer );
            std::cout << " can't pack buffer for entities to send\n";
            return rval;
        // TODO there could be an issue with endian things; check !!!!!
        // we are sending the size of the buffer first as an int!!!
        /// not anymore !
        /* ierr = MPI_Isend(buffer->mem_ptr, 1, MPI_INT, receiver_proc, 1, jcomm,
         &sendReqs[indexReq]); // we have to use global communicator if (ierr!=0) return MB_FAILURE;
         indexReq++;*/
        ierr = MPI_Isend( buffer->mem_ptr, size_pack, MPI_CHAR, receiver_proc, 2, jcomm,
                          &sendReqs[indexReq] );  // we have to use global communicator
        indexReq++;
        localSendBuffs.push_back(
            buffer );  // these buffers will be cleared only after all MPI_Request's have been waited upon
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::send_tag_values ( MPI_Comm  jcomm,
ParallelComm pco,
Range owned,
Definition at line 612 of file ParCommGraph.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, buffer, COVERAGE, DOF_BASED, moab::Range::end(), ErrorCode, moab::ParallelComm::get_moab(), moab::Core::globalId_tag(), graph_type, moab::Core::id_from_handle(), INITIAL_MIGRATE, involved_IDs_map, localSendBuffs, map_index, map_ptr, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, rankInJoin, moab::ParallelComm::Buffer::reset_ptr(), sendReqs, moab::Range::size(), split_ranges, moab::Core::tag_get_bytes(), moab::Core::tag_get_data(), and moab::Core::tag_get_length().
    int ierr;
    int total_bytes_per_entity = 0;  // we need to know, to allocate buffers
    ErrorCode rval;
#ifdef VERBOSE
#endif
        int bytes_per_tag;
        int tag_size1;  // length
        rval = mb->tag_get_length( tag_handles[i], tag_size1 );MB_CHK_ERR( rval );
            bytes_per_tag = bytes_per_tag / tag_size1;  // we know we have one double per tag , per ID sent;
                                                        // could be 8 for double, 4 for int, etc
#ifdef VERBOSE
        int tag_size;
#endif
    int indexReq = 0;
    if( graph_type == INITIAL_MIGRATE )  // original send
        // use the buffers data structure to allocate memory for sending the tags
        sendReqs.resize( split_ranges.size() );
                // copy tag data to buffer->buff_ptr, and send the buffer (we could have used
                // regular char arrays)
                rval = mb->tag_get_data( tag_handles[i], ents, (void*)( buffer->buff_ptr ) );MB_CHK_ERR( rval );
                // advance the butter
            ierr = MPI_Isend( buffer->mem_ptr, size_buffer, MPI_CHAR, receiver_proc, 222, jcomm,
            indexReq++;
            localSendBuffs.push_back( buffer );  // we will release them after nonblocking sends are completed
        // we know that we will need to send some tag data in a specific order
        // first, get the ids of the local elements, from owned Range; arrange the buffer in order
        // of increasing global id
        size_t i = 0;
        // now, pack the data and send it
        sendReqs.resize( involved_IDs_map.size() );
#ifdef VERBOSE
            outf << "from_" << rankInJoin << "_send_to_" << receiver_proc << ".txt";
            dbfile << "from " << rankInJoin << " send to " << receiver_proc << "\n";
#endif
            // copy tag data to buffer->buff_ptr, and send the buffer (we could have used regular
            // char arrays) pack data by tag, to be consistent with above, even though we loop
            // through the entities for each tag
                int eID         = *it;
                EntityHandle eh = gidToHandle[eID];
                    rval = mb->tag_get_data( tag_handles[i], &eh, 1, (void*)( buffer->buff_ptr ) );
                        delete buffer;  // free parallel comm buffer first
                        MB_SET_ERR( rval, "Tag get data failed" );
#ifdef VERBOSE
                        vals++;
                    dbfile << "\n";
#endif
#ifdef VERBOSE
            dbfile.close();
#endif
            indexReq++;
        // need to fill up the buffer, in the order desired, send it
            int bytes_per_tag;
            rval = mb->tag_get_data( tag_handles[i], owned, (void*)( &( valuesTags[i][0] ) ) );MB_CHK_ERR( rval );
            std::vector< int >& index_in_values = map_index[receiver_proc];
            std::vector< int >& index_ptr       = map_ptr[receiver_proc];  // this is eids.size()+1;
#ifdef VERBOSE
#endif
            // pack data by tag, to be consistent with above
            int j = 0;
                int index_in_v = index_in_values[index_ptr[j]];
                    *( (double*)( buffer->buff_ptr ) ) = valuesTags[i][index_in_v];
            indexReq++;
    return MB_SUCCESS;
int moab::ParCommGraph::sender ( int  index) [inline]
Definition at line 143 of file ParCommGraph.hpp.
References senderTasks.
Referenced by receive_comm_graph().
        return senderTasks[index];
const std::vector< int >& moab::ParCommGraph::senders ( ) [inline]
Definition at line 209 of file ParCommGraph.hpp.
Referenced by pack_receivers_graph(), and send_graph_partition().
        return senderTasks;
    }  // reference copy; refers to sender tasks in joint comm
void moab::ParCommGraph::set_context_id ( int  other_id) [inline]
Definition at line 166 of file ParCommGraph.hpp.
        context_id = other_id;
Definition at line 175 of file ParCommGraph.hpp.
        cover_set = cover;
ErrorCode moab::ParCommGraph::set_split_ranges ( int  comp,
TupleList TLBackToComp1,
std::vector< int > &  valuesComp1,
int  lenTag,
Range ents_of_interest,
int  type
Definition at line 1293 of file ParCommGraph.cpp.
References moab::TupleList::get_n(), MB_SUCCESS, rootSender, moab::Range::size(), split_ranges, and moab::TupleList::vi_wr.
    // settle split_ranges // same role as partitioning
    if( rootSender ) std::cout << " find split_ranges on component " << comp << "  according to read map \n";
    // Vector to store element
    // with respective present index
    int n = TLBackToComp1.get_n();
    // third_method = true; // do not rely only on involved_IDs_map.size(); this can be 0 in some
    // cases
    std::map< int, std::set< int > > uniqueIDs;
        int to_proc  = TLBackToComp1.vi_wr[3 * i + 2];
        int globalId = TLBackToComp1.vi_wr[3 * i + 1];
        uniqueIDs[to_proc].insert( globalId );
    for( int i = 0; i < (int)ents_of_interest.size(); i++ )
        EntityHandle ent = ents_of_interest[i];
        for( int j = 0; j < lenTag; j++ )
            int marker = valuesComp1[i * lenTag + j];
            for( auto mit = uniqueIDs.begin(); mit != uniqueIDs.end(); mit++ )
                int proc                = mit->first;
                std::set< int >& setIds = mit->second;
                if( setIds.find( marker ) != setIds.end() )
                    split_ranges[proc].insert( ent );
    return MB_SUCCESS;
void moab::ParCommGraph::SetReceivingAfterCoverage ( std::map< int, std::set< int > > &  idsFromProcs)
Definition at line 1051 of file ParCommGraph.cpp.
References COVERAGE, graph_type, and involved_IDs_map.
    for( std::map< int, std::set< int > >::iterator mt = idsFromProcs.begin(); mt != idsFromProcs.end(); mt++ )
        int fromProc            = mt->first;
        std::set< int >& setIds = mt->second;
        involved_IDs_map[fromProc].resize( setIds.size() );
        std::vector< int >& listIDs = involved_IDs_map[fromProc];
        size_t indx                 = 0;
        for( std::set< int >::iterator st = setIds.begin(); st != setIds.end(); st++ )
            int valueID     = *st;
            listIDs[indx++] = valueID;
    graph_type = COVERAGE;
    return;
void moab::ParCommGraph::settle_comm_by_ids ( int  comp,
TupleList TLBackToComp,
Definition at line 1071 of file ParCommGraph.cpp.
References DOF_BASED, moab::GeomUtil::first(), moab::TupleList::get_n(), graph_type, involved_IDs_map, map_index, map_ptr, rankInJoin, rootReceiver, rootSender, and moab::TupleList::vi_wr.
    // settle comm graph on comp
    if( rootSender || rootReceiver ) std::cout << " settle comm graph by id on component " << comp << "\n";
    int n = TLBackToComp.get_n();
    // cases
        int to_proc  = TLBackToComp.vi_wr[3 * i + 2];
        int globalId = TLBackToComp.vi_wr[3 * i + 1];
    std::vector< std::pair< int, int > > vp;
    vp.reserve( valuesComp.size() );
    // Inserting element in pair vector
    // to keep track of previous indexes in valuesComp
    for( int i = 0; i < (int)valuesComp.size(); ++i )
        vp.push_back( std::make_pair( valuesComp[i], i ) );
    // Sorting pair vector
    sort( vp.begin(), vp.end() );
    // vp[i].first, second
    // count now how many times some value appears in ordered (so in valuesComp)
    for( std::map< int, std::set< int > >::iterator it = uniqueIDs.begin(); it != uniqueIDs.end(); it++ )
        int procId                  = it->first;
        std::set< int >& nums       = it->second;
        std::vector< int >& indx    = map_ptr[procId];
        std::vector< int >& indices = map_index[procId];
        indx.resize( nums.size() + 1 );
        int indexInVp = 0;
        int indexVal  = 0;
        indx[0]       = 0;  // start from 0
        for( std::set< int >::iterator sst = nums.begin(); sst != nums.end(); sst++, indexVal++ )
            int val = *sst;
            involved_IDs_map[procId].push_back( val );
            indx[indexVal + 1] = indx[indexVal];
            while( ( indexInVp < (int)valuesComp.size() ) && ( vp[indexInVp].first <= val ) )  // should be equal !
                if( vp[indexInVp].first == val )
                    indx[indexVal + 1]++;
                    indices.push_back( vp[indexInVp].second );
                indexInVp++;
#ifdef VERBOSE
    std::stringstream f1;
    f1 << "Involve_" << comp << "_" << rankInJoin << ".txt";
    dbfile.open( f1.str().c_str() );
    for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); mit != involved_IDs_map.end();
         mit++ )
        int corrTask                = mit->first;
        std::vector< int >& corrIds = mit->second;
        std::vector< int >& indx    = map_ptr[corrTask];
        std::vector< int >& indices = map_index[corrTask];
        dbfile << " towards proc " << corrTask << " \n";
        for( int i = 0; i < (int)corrIds.size(); i++ )
            dbfile << corrIds[i] << " [" << indx[i] << "," << indx[i + 1] << ")  : ";
            for( int j = indx[i]; j < indx[i + 1]; j++ )
                dbfile << indices[j] << " ";
            dbfile << "\n";
        dbfile << " \n";
    dbfile.close();
#endif
    graph_type = DOF_BASED;
    // now we need to fill back and forth information, needed to fill the arrays
    // for example, from spectral to involved_IDs_map, in case we want to send data from
    // spectral to phys
Definition at line 1023 of file ParCommGraph.cpp.
References COVERAGE, moab::TupleList::get_n(), graph_type, involved_IDs_map, MB_SUCCESS, and moab::TupleList::vi_wr.
    // fill involved_IDs_map with data
    // will have "receiving proc" and global id of element
    int n      = TLcovIDs.get_n();
    graph_type = COVERAGE;  // do not rely only on involved_IDs_map.size(); this can be 0 in some cases
        int to_proc      = TLcovIDs.vi_wr[2 * i];
        int globalIdElem = TLcovIDs.vi_wr[2 * i + 1];
        involved_IDs_map[to_proc].push_back( globalIdElem );
#ifdef VERBOSE
         mit++ )
        std::cout << " towards task " << mit->first << " send: " << mit->second.size() << " cells " << std::endl;
        for( size_t i = 0; i < mit->second.size(); i++ )
            std::cout << " " << mit->second[i];
        std::cout << std::endl;
#endif
    return MB_SUCCESS;
ErrorCode moab::ParCommGraph::split_owned_range ( int  sender_rank,
Range owned
Definition at line 215 of file ParCommGraph.cpp.
References moab::Range::begin(), moab::Range::insert(), MB_SUCCESS, receivers(), sender_graph, sender_sizes, senderTasks, split_ranges, and moab::subtract().
Referenced by send_mesh_parts().
    int senderTask                   = senderTasks[sender_rank];
    std::vector< int >& distribution = sender_sizes[senderTask];
    std::vector< int >& receivers    = sender_graph[senderTask];
    if( distribution.size() != receivers.size() )  //
        return MB_FAILURE;
    Range current = owned;  // get the full range first, then we will subtract stuff, for
    // the following ranges
    Range rleftover = current;
    for( size_t k = 0; k < receivers.size(); k++ )
        Range newr;
        newr.insert( current.begin(), current.begin() + distribution[k] );
        split_ranges[receivers[k]] = newr;
        rleftover = subtract( current, newr );
        current   = rleftover;
    return MB_SUCCESS;
Definition at line 241 of file ParCommGraph.cpp.
References moab::Range::begin(), corr_sizes, corr_tasks, moab::Range::insert(), MB_SUCCESS, split_ranges, and moab::subtract().
    if( corr_tasks.size() != corr_sizes.size() )  //
        return MB_FAILURE;
    for( size_t k = 0; k < corr_tasks.size(); k++ )
        Range newr;
        newr.insert( current.begin(), current.begin() + corr_sizes[k] );
        split_ranges[corr_tasks[k]] = newr;
    return MB_SUCCESS;
Member Data Documentation
Definition at line 266 of file ParCommGraph.hpp.
std::vector< int > moab::ParCommGraph::comm_graph [private]
Definition at line 291 of file ParCommGraph.hpp.
Referenced by release_send_buffers(), and send_graph().
Definition at line 273 of file ParCommGraph.hpp.
Referenced by get_component_id1(), ParCommGraph(), and send_graph_partition().
Referenced by get_component_id2(), ParCommGraph(), and send_graph_partition().
Definition at line 274 of file ParCommGraph.hpp.
Referenced by get_context_id(), ParCommGraph(), and set_context_id().
std::vector< int > moab::ParCommGraph::corr_sizes [private]
Definition at line 309 of file ParCommGraph.hpp.
Referenced by receive_mesh(), send_mesh_parts(), and split_owned_range().
std::vector< int > moab::ParCommGraph::corr_tasks [private]
Definition at line 307 of file ParCommGraph.hpp.
Definition at line 272 of file ParCommGraph.hpp.
std::map< int, std::vector< int > > moab::ParCommGraph::map_index [private]
Definition at line 319 of file ParCommGraph.hpp.
Referenced by receive_tag_values(), send_tag_values(), and settle_comm_by_ids().
std::map< int, std::vector< int > > moab::ParCommGraph::map_ptr [private]
Definition at line 320 of file ParCommGraph.hpp.
Definition at line 271 of file ParCommGraph.hpp.
Referenced by dump_comm_information(), ParCommGraph(), and send_mesh_parts().
Referenced by dump_comm_information(), ParCommGraph(), and receive_mesh().
std::map< int, std::vector< int > > moab::ParCommGraph::recv_graph [private]
std::map< int, std::vector< int > > moab::ParCommGraph::recv_sizes [private]
Definition at line 282 of file ParCommGraph.hpp.
Referenced by compute_trivial_partition().
std::map< int, std::vector< int > > moab::ParCommGraph::sender_graph [private]
Definition at line 284 of file ParCommGraph.hpp.
Referenced by compute_trivial_partition(), send_mesh_parts(), and split_owned_range().
std::map< int, std::vector< int > > moab::ParCommGraph::sender_sizes [private]
Definition at line 286 of file ParCommGraph.hpp.
std::vector< MPI_Request > moab::ParCommGraph::sendReqs [private]
std::vector< char > moab::ParCommGraph::zBuff [private]
Definition at line 296 of file ParCommGraph.hpp.
List of all members.
