moab::PolyElementSeq Class Reference
#include <PolyElementSeq.hpp>
+ Inheritance diagram for moab::PolyElementSeq:
+ Collaboration diagram for moab::PolyElementSeq:
Public Member Functions
 PolyElementSeq (EntityHandle shandle, EntityID entity_count, unsigned nodes_per_entity, SequenceData *dat)
 PolyElementSeq (EntityHandle shandle, EntityID entity_count, unsigned nodes_per_entity, EntityID sequence_data_size)
virtual ~PolyElementSeq ()
virtual EntitySequencesplit (EntityHandle here)
 Split this sequence into two consecutive sequences.
virtual ErrorCode get_connectivity (EntityHandle handle, std::vector< EntityHandle > &connect, bool topological=false) const
virtual ErrorCode get_connectivity (EntityHandle handle, EntityHandle const *&connect, int &connect_length, bool topological=false, std::vector< EntityHandle > *storage=0) const
Protected Member Functions
 PolyElementSeq (PolyElementSeq &split_from, EntityHandle here)
Detailed Description
Definition at line 9 of file PolyElementSeq.hpp.
moab::PolyElementSeq::PolyElementSeq ( EntityHandle  shandle,
SequenceData dat
) [inline]
Definition at line 12 of file PolyElementSeq.hpp.
Referenced by split().
        : UnstructuredElemSeq( shandle, entity_count, nodes_per_entity, dat )
) [inline]
Definition at line 17 of file PolyElementSeq.hpp.
        : UnstructuredElemSeq( shandle, entity_count, nodes_per_entity, sequence_data_size )
Definition at line 6 of file PolyElementSeq.cpp.
moab::PolyElementSeq::PolyElementSeq ( PolyElementSeq split_from,
EntityHandle  here
) [inline, protected]
Definition at line 40 of file PolyElementSeq.hpp.
: UnstructuredElemSeq( split_from, here ) {}
Member Function Documentation
ErrorCode moab::PolyElementSeq::get_connectivity ( EntityHandle  handle,
std::vector< EntityHandle > &  connect,
bool  topological = false
) const [virtual]
Reimplemented from moab::UnstructuredElemSeq.
Definition at line 13 of file PolyElementSeq.cpp.
References moab::UnstructuredElemSeq::get_array(), MB_SUCCESS, moab::ElementSequence::nodes_per_element(), and moab::EntitySequence::start_handle().
    EntityHandle const* conn = get_array() + nodes_per_element() * ( handle - start_handle() );
    int len                  = nodes_per_element();
    connect.reserve( connect.size() + len );
    std::copy( conn, conn + len, std::back_inserter( connect ) );
    return MB_SUCCESS;
EntityHandle const *&  connect,
int &  connect_length,
bool  topological = false,
std::vector< EntityHandle > *  storage = 0
) const [virtual]
Split this sequence into two sequences.
Parameters:
hereNew sequences should be [start_handle(),here) & [here,end_handle()]
Returns:
New sequence containing [here,end_handle()]
Definition at line 8 of file PolyElementSeq.cpp.
References PolyElementSeq().
    return new PolyElementSeq( *this, here );
List of all members.
