moab::RangeMap< KeyType, ValType, NullVal > Class Template Reference
Map ranges of values. More...
#include <RangeMap.hpp>
+ Inheritance diagram for moab::RangeMap< KeyType, ValType, NullVal >:
+ Collaboration diagram for moab::RangeMap< KeyType, ValType, NullVal >:
Classes
struct  Range
Public Types
typedef KeyType key_type
typedef ValType value_type
typedef std::vector< RangeRangeList
typedef RangeList::const_iterator iterator
typedef RangeList::const_iterator const_iterator
Public Member Functions
bool empty () const
const Rangeback () const
const Rangefront () const
std::pair< iterator, bool > insert (KeyType first_key, ValType first_val, KeyType count)
 Insert mapping between range of keys and range of values.
bool merge (const RangeMap< KeyType, ValType, NullVal > &other)
ValType find (KeyType key) const
bool find (KeyType key, ValType &val_out) const
bool exists (KeyType key) const
bool intersects (KeyType start, KeyType count) const
iterator erase (KeyType beg, KeyType count)
unsigned num_ranges () const
iterator begin () const
iterator end () const
iterator lower_bound (KeyType key) const
iterator upper_bound (KeyType key) const
std::pair< iterator, iteratorequal_range (KeyType key) const
void clear ()
Static Public Member Functions
static iterator lower_bound (iterator s, iterator e, KeyType key)
static iterator upper_bound (iterator s, iterator e, KeyType key)
Protected Attributes
RangeList data
Detailed Description
template<typename KeyType, typename ValType, ValType NullVal = 0>
class moab::RangeMap< KeyType, ValType, NullVal >
This class provides a map between ranges of values, such as a map between file IDs and EntityHandles. It is intended for use in situations where there are relatively few insertions of large contiguous ranges of values.
Definition at line 38 of file RangeMap.hpp.
Member Typedef Documentation
typedef RangeList::const_iterator moab::RangeMap< KeyType, ValType, NullVal >::const_iterator
Definition at line 55 of file RangeMap.hpp.
typedef RangeList::const_iterator moab::RangeMap< KeyType, ValType, NullVal >::iterator
Definition at line 54 of file RangeMap.hpp.
typedef KeyType moab::RangeMap< KeyType, ValType, NullVal >::key_type
Definition at line 41 of file RangeMap.hpp.
typedef std::vector< Range > moab::RangeMap< KeyType, ValType, NullVal >::RangeList
Definition at line 53 of file RangeMap.hpp.
typedef ValType moab::RangeMap< KeyType, ValType, NullVal >::value_type
Definition at line 42 of file RangeMap.hpp.
Member Function Documentation
const Range& moab::RangeMap< KeyType, ValType, NullVal >::back ( ) const [inline]
Definition at line 62 of file RangeMap.hpp.
Referenced by moab::ReadHDF5::insert_in_id_map().
        return data.back();
void moab::RangeMap< KeyType, ValType, NullVal >::clear ( ) [inline]
bool moab::RangeMap< KeyType, ValType, NullVal >::empty ( ) const [inline]
Definition at line 57 of file RangeMap.hpp.
Referenced by moab::ReadHDF5::insert_in_id_map(), and moab::set_map_intersect().
        return data.empty();
std::pair< iterator, iterator > moab::RangeMap< KeyType, ValType, NullVal >::equal_range ( KeyType  key) const [inline]
Definition at line 139 of file RangeMap.hpp.
Referenced by moab::RangeMap< damsel_handle, EntityHandle, 0 >::equal_range().
        Range b = { key, 1, NullVal };
        return std::equal_range( begin(), end(), b );
template<typename KeyType, typename ValType , ValType NullVal>
RangeMap< KeyType, ValType, NullVal >::iterator moab::RangeMap< KeyType, ValType, NullVal >::erase ( KeyType  beg,
KeyType  count
) [inline]
Remove a block of values
Definition at line 296 of file RangeMap.hpp.
References moab::RangeMap< KeyType, ValType, NullVal >::Range::begin.
Referenced by moab::ReadHDF5::delete_non_side_elements().
    Range search = { key, 1, NullVal };
    typename RangeList::iterator i, j;
    i = std::lower_bound( data.begin(), data.end(), search );
    if( i == data.end() ) return i;
    if( key > i->begin )
        KeyType offset = key - i->begin;
        // special case - split existing entry
        if( ( offset + count ) < i->count )
            Range ins = { i->begin, offset, i->value };
            offset += count;
            i->begin += offset;
            i->value += offset;
            i->count -= offset;
            return data.insert( i, ins ) + 1;
        // otherwise remove the latter part of i
        i->count = offset;
        ++i;
    // remove any entries entirely convered by the input range
    for( j = i; j != data.end() && ( j->begin + j->count ) <= ( key + count ); ++j )
    i = data.erase( i, j );
    // remove beginning of last block
    if( i != data.end() && ( key + count ) >= i->begin )
        KeyType offset = key + count - i->begin;
        i->begin += offset;
        i->value += offset;
        i->count -= offset;
    return i;
bool moab::RangeMap< KeyType, ValType, NullVal >::exists ( KeyType  key) const [inline]
Check if range contains key
Definition at line 280 of file RangeMap.hpp.
Referenced by moab::set_map_intersect().
    typename RangeList::const_iterator i = std::lower_bound( data.begin(), data.end(), search );
    return i != data.end() && key >= i->begin;
ValType moab::RangeMap< KeyType, ValType, NullVal >::find ( KeyType  key) const [inline]
template<typename KeyType, typename ValType, ValType NullVal>
bool moab::RangeMap< KeyType, ValType, NullVal >::find ( KeyType  key,
ValType &  val_out
) const [inline]
Find the value corresponding to the specified key. Returns false if not found
Definition at line 265 of file RangeMap.hpp.
References moab::RangeMap< KeyType, ValType, NullVal >::Range::value.
    if( i == data.end() || i->begin > key )
        val = NullVal;
        return false;
    val = i->value + key - i->begin;
    return true;
const Range& moab::RangeMap< KeyType, ValType, NullVal >::front ( ) const [inline]
Definition at line 66 of file RangeMap.hpp.
        return data.front();
std::pair< typename RangeMap< KeyType, ValType, NullVal >::iterator, bool > moab::RangeMap< KeyType, ValType, NullVal >::insert ( KeyType  first_key,
ValType  first_val,
KeyType  count
) [inline]
Insert mapping from [first_key, first_key+count) to [first_val, first_val+count)
Input range of keys many not overlap any other input range. If it does overlap an existing range, the second value of the pair will be returned as false and the iterator will point to (one of) the overlapping ranges.
Definition at line 158 of file RangeMap.hpp.
References moab::RangeMap< KeyType, ValType, NullVal >::Range::count.
Referenced by moab::WriteHDF5::assign_ids(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ReadHDF5::insert_in_id_map(), moab::ReadNASTRAN::load_file(), moab::ParallelComm::pack_range_map(), moab::ReadDamsel::process_ent_info(), moab::ReadNASTRAN::read_element(), and moab::ReadHDF5::read_node_adj_elems().
    Range block                    = { first_key, count, first_val };
    typename RangeList::iterator i = std::lower_bound( data.begin(), data.end(), block );
        if( i != data.begin() )
            --i;
            if( i->begin + i->count == first_key && i->value + i->count == first_val )
                i->count += count;
                return std::pair< iterator, bool >( i, true );
        data.push_back( block );
        return std::pair< iterator, bool >( data.end() - 1, true );
    if( i->begin < first_key + count ) return std::pair< iterator, bool >( i, false );
    if( i->begin == first_key + count && i->value == first_val + count )
        i->begin = first_key;
        i->value = first_val;
        i->count += count;
            count = i->count;
            --i;
                i->count += count;
                ++i;
                i = data.erase( i );
                --i;
        --i;
            i->count += count;
        ++i;
    return std::pair< iterator, bool >( data.insert( i, block ), true );
bool moab::RangeMap< KeyType, ValType, NullVal >::intersects ( KeyType  start,
KeyType  count
) const [inline]
Definition at line 288 of file RangeMap.hpp.
    Range search                         = { start, count, NullVal };
    return i != data.end() && start + count > i->begin && i->begin + i->count > start;
iterator moab::RangeMap< KeyType, ValType, NullVal >::lower_bound ( KeyType  key) const [inline]
static iterator moab::RangeMap< KeyType, ValType, NullVal >::lower_bound ( iterator  s,
iterator  e,
KeyType  key
) [inline, static]
Definition at line 124 of file RangeMap.hpp.
        return std::lower_bound( s, e, b );
bool moab::RangeMap< KeyType, ValType, NullVal >::merge ( const RangeMap< KeyType, ValType, NullVal > &  other) [inline]
Definition at line 215 of file RangeMap.hpp.
References moab::RangeMap< KeyType, ValType, NullVal >::data.
    // grow map sufficiently to hold new ranges
    RangeList new_data;
    new_data.reserve( other.data.size() + data.size() );
    // merge
    typename RangeList::const_iterator i = other.data.begin();
    typename RangeList::const_iterator j = data.begin();
    typename RangeList::const_iterator k;
    while( i != other.data.end() || j != data.end() )
        if( j != data.end() && ( i == other.data.end() || j->begin < i->begin ) )
            k = j;
            ++j;
        else if( i != other.data.end() )
            k = i;
            ++i;
        // check if we need to merge with the end of the previous block
        if( new_data.empty() )
            new_data.push_back( *k );
        else if( new_data.back().begin + new_data.back().count > k->begin )
            return false;
        else if( new_data.back().begin + new_data.back().count == k->begin &&
                 new_data.back().value + new_data.back().count == k->value )
            new_data.back().count += k->count;
        else
    data.swap( new_data );
    return true;
unsigned moab::RangeMap< KeyType, ValType, NullVal >::num_ranges ( ) const [inline]
Definition at line 106 of file RangeMap.hpp.
        return data.size();
iterator moab::RangeMap< KeyType, ValType, NullVal >::upper_bound ( KeyType  key) const [inline]
Definition at line 129 of file RangeMap.hpp.
Referenced by moab::RangeMap< damsel_handle, EntityHandle, 0 >::upper_bound().
        return std::upper_bound( begin(), end(), b );
static iterator moab::RangeMap< KeyType, ValType, NullVal >::upper_bound ( iterator  s,
iterator  e,
KeyType  key
) [inline, static]
Definition at line 134 of file RangeMap.hpp.
        return std::upper_bound( s, e, b );
Member Data Documentation
List of all members.
