moab::ReadNASTRAN Class Reference
#include <ReadNASTRAN.hpp>
+ Inheritance diagram for moab::ReadNASTRAN:
+ Collaboration diagram for moab::ReadNASTRAN:
Public Member Functions
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 Load mesh from a file.
 ReadNASTRAN (Interface *impl=NULL)
virtual ~ReadNASTRAN ()
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
Static Public Member Functions
static ReaderIfacefactory (Interface *)
Private Types
enum  line_format { SMALL_FIELD, LARGE_FIELD, FREE_FIELD }
Private Member Functions
ErrorCode determine_line_format (const std::string &line, line_format &format)
ErrorCode tokenize_line (const std::string &line, const line_format format, std::vector< std::string > &tokens)
ErrorCode determine_entity_type (const std::string &token, EntityType &type)
ErrorCode get_real (const std::string &, double &real)
ErrorCode read_node (const std::vector< std::string > &tokens, const bool debug, double *coord_arrays[3], int &node_id)
ErrorCode read_element (const std::vector< std::string > &tokens, std::vector< Range > &materials, const EntityType element_type, const bool debug)
ErrorCode create_materials (const std::vector< Range > &materials)
ErrorCode assign_ids (const Tag *file_id_tag)
Private Attributes
ReadUtilIfacereadMeshIface
InterfaceMBI
RangeMap< int, EntityHandlenodeIdMap
RangeMap< int, EntityHandleelemIdMap
Detailed Description
Definition at line 49 of file ReadNASTRAN.hpp.
Member Enumeration Documentation
Enumerator:
SMALL_FIELD
LARGE_FIELD
FREE_FIELD
Definition at line 83 of file ReadNASTRAN.hpp.
Definition at line 44 of file ReadNASTRAN.cpp.
References MBI, moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
                                          : MBI( impl )
    assert( NULL != impl );
    MBI->query_interface( readMeshIface );
    assert( NULL != readMeshIface );
Member Function Documentation
ErrorCode moab::ReadNASTRAN::assign_ids ( const Tag file_id_tag) [private]
Definition at line 460 of file ReadNASTRAN.cpp.
References moab::ReadUtilIface::assign_ids(), moab::RangeMap< KeyType, ValType, NullVal >::begin(), elemIdMap, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, moab::Interface::globalId_tag(), MB_SUCCESS, MBI, nodeIdMap, readMeshIface, and t.
Referenced by load_file().
    // Create tag
    ErrorCode result;
    Tag id_tag = MBI->globalId_tag();
    RangeMap< int, EntityHandle >::iterator i;
    for( int t = 0; t < 2; ++t )
        RangeMap< int, EntityHandle >& fileIdMap = t ? elemIdMap : nodeIdMap;
        for( i = fileIdMap.begin(); i != fileIdMap.end(); ++i )
            Range range( i->value, i->value + i->count - 1 );
            result = readMeshIface->assign_ids( id_tag, range, i->begin );
            if( MB_SUCCESS != result ) return result;
            if( file_id_tag && *file_id_tag != id_tag )
                result = readMeshIface->assign_ids( *file_id_tag, range, i->begin );
    return MB_SUCCESS;
ErrorCode moab::ReadNASTRAN::create_materials ( const std::vector< Range > &  materials) [private]
Definition at line 428 of file ReadNASTRAN.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), ErrorCode, MATERIAL_SET_TAG_NAME, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBI, MESHSET_SET, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    ErrorCode result;
    Tag material_tag;
    int negone = -1;
    result = MBI->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, material_tag, MB_TAG_SPARSE | MB_TAG_CREAT,
                                  &negone );
    for( size_t i = 0; i < materials.size(); ++i )
        if( materials[i].empty() ) continue;
        // Merge with existing or create new?  Original code effectively
        // created new by only merging with existing in current file set,
        // so do the same here. - j.kraftcheck
        EntityHandle handle;
        result = MBI->create_meshset( MESHSET_SET, handle );
        result = MBI->add_entities( handle, materials[i] );
        int id = i;
        result = MBI->tag_set_data( material_tag, &handle, 1, &id );
    return MB_SUCCESS;
ErrorCode moab::ReadNASTRAN::determine_entity_type ( const std::string &  token,
EntityType &  type
) [private]
Definition at line 252 of file ReadNASTRAN.cpp.
References MB_NOT_IMPLEMENTED, MB_SUCCESS, MBHEX, MBPRISM, MBTET, and MBVERTEX.
    if( 0 == first_token.compare( "GRID    " ) )
        type = MBVERTEX;
    else if( 0 == first_token.compare( "CTETRA  " ) )
        type = MBTET;
    else if( 0 == first_token.compare( "CPENTA  " ) )
        type = MBPRISM;
    else if( 0 == first_token.compare( "CHEXA   " ) )
        type = MBHEX;
    else
        return MB_NOT_IMPLEMENTED;
    return MB_SUCCESS;
ErrorCode moab::ReadNASTRAN::determine_line_format ( const std::string &  line,
line_format format
) [private]
Definition at line 198 of file ReadNASTRAN.cpp.
References FREE_FIELD, LARGE_FIELD, MB_SUCCESS, and SMALL_FIELD.
    std::string::size_type found_asterisk = line.find( "*" );
    if( std::string::npos != found_asterisk )
        format = LARGE_FIELD;
        return MB_SUCCESS;
    else
        std::string::size_type found_comma = line.find( "," );
        if( std::string::npos != found_comma )
            format = FREE_FIELD;
            return MB_SUCCESS;
        else
            format = SMALL_FIELD;
            return MB_SUCCESS;
Definition at line 38 of file ReadNASTRAN.cpp.
References ReadNASTRAN().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadNASTRAN( iface );
ErrorCode moab::ReadNASTRAN::get_real ( const std::string &  token,
double &  real
) [private]
Definition at line 283 of file ReadNASTRAN.cpp.
References MB_SUCCESS.
Referenced by read_node().
    std::string significand = token;
    std::string exponent    = "0";
    // Cut off the first digit because a "-" could be here indicating a negative
    // number. Instead we are looking for a negative exponent.
    std::string back_token = token.substr( 1 );
    // A minus that is not the first digit is always a negative exponent
    std::string::size_type found_minus = back_token.find( "-" );
    if( std::string::npos != found_minus )
        // separate the significand from the exponent at the "-"
        exponent    = token.substr( found_minus + 1 );
        significand = token.substr( 0, found_minus + 1 );
        // If the significand has an "E", remove it
        if( std::string::npos != significand.find( "E" ) )
            // Assume the "E" is at the end of the significand.
            significand = significand.substr( 1, significand.size() - 2 );
        // If a minus does not exist past the 1st digit, but an "E" or "+" does, then
        // it is a positive exponent. First look for an "E",
    else
        std::string::size_type found_E = token.find( "E" );
        if( std::string::npos != found_E )
            significand = token.substr( 0, found_E - 1 );
            exponent    = token.substr( found_E + 1 );
            // If there is a "+" on the exponent, cut it off
            std::size_t found_plus = exponent.find( "+" );
            if( std::string::npos != found_plus )
                exponent = exponent.substr( found_plus + 1 );
        else
            std::size_t found_plus = token.find( "+" );
                significand = token.substr( 0, found_plus - 1 );
                exponent    = token.substr( found_plus + 1 );
    // Now assemble the real number
    double signi = atof( significand.c_str() );
    double expon = atof( exponent.c_str() );
    if( HUGE_VAL == signi || HUGE_VAL == expon ) return MB_FAILURE;
    real = signi * pow( 10, expon );
    return MB_SUCCESS;
ErrorCode moab::ReadNASTRAN::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [virtual]
Method all readers must provide to import a mesh.
Parameters:
file_nameThe file to read.
file_setOptional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data.
subset_listAn optional struct pointer specifying the tags identifying entity sets to be read.
file_id_tagIf specified, reader should store for each entity it reads, a unique integer ID for this tag.
Author:
Jason Kraftcheck
Implements moab::ReaderIface.
Definition at line 71 of file ReadNASTRAN.cpp.
References assign_ids(), moab::RangeMap< KeyType, ValType, NullVal >::clear(), create_materials(), moab::debug, determine_entity_type(), determine_line_format(), elemIdMap, ErrorCode, moab::ReadUtilIface::get_node_coords(), moab::RangeMap< KeyType, ValType, NullVal >::insert(), MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_START_ID, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, MBMAXTYPE, MBVERTEX, nodeIdMap, read_element(), read_node(), readMeshIface, and tokenize_line().
    // At this time there is no support for reading a subset of the file
    if( subset_list )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for NASTRAN" );
    nodeIdMap.clear();
    elemIdMap.clear();
    bool debug = false;
    if( debug ) std::cout << "begin ReadNASTRAN::load_file" << std::endl;
    ErrorCode result;
    // Count the entities of each type in the file. This is used to allocate the node array.
    int entity_count[MBMAXTYPE];
    for( int i = 0; i < MBMAXTYPE; i++ )
        entity_count[i] = 0;
    /* Determine the line_format of the first line. Assume that the entire file
       has the same format. */
    std::string line;
    std::ifstream file( filename );
    if( !getline( file, line ) ) return MB_FILE_DOES_NOT_EXIST;
    line_format format;
    result = determine_line_format( line, format );
    /* Count the number of each entity in the file. This allows one to allocate
       a sequential array of vertex handles. */
    while( !file.eof() )
        // Cut the line into fields as determined by the line format.
        // Use a vector to allow for an unknown number of tokens (continue lines).
        // Continue lines are not implemented.
        std::vector< std::string > tokens;
        tokens.reserve( 10 );  // assume 10 fields to avoid extra vector resizing
        result = tokenize_line( line, format, tokens );
        // Process the tokens of the line. The first token describes the entity type.
        EntityType type;
        result = determine_entity_type( ( tokens.empty() ) ? "" : tokens.front(), type );
        entity_count[type]++;
        getline( file, line );
    if( debug )
            std::cout << "entity_count[" << i << "]=" << entity_count[i] << std::endl;
    // Keep list of material sets
    std::vector< Range > materials;
    // Now that the number of vertices is known, create the vertices.
    EntityHandle start_vert = 0;
    std::vector< double* > coord_arrays( 3 );
    result = readMeshIface->get_node_coords( 3, entity_count[0], MB_START_ID, start_vert, coord_arrays );
    if( 0 == start_vert ) return MB_FAILURE;  // check for NULL
    int id, vert_index = 0;
    if( debug ) std::cout << "allocated coord arrays" << std::endl;
    // Read the file again to create the entities.
    file.clear();     // Clear eof state from object
    file.seekg( 0 );  // Rewind file
        EntityType type;
        result = determine_entity_type( tokens.front(), type );
        // Create the entity.
        if( MBVERTEX == type )
            double* coords[3] = { coord_arrays[0] + vert_index, coord_arrays[1] + vert_index,
                                  coord_arrays[2] + vert_index };
            result            = read_node( tokens, debug, coords, id );
            if( !nodeIdMap.insert( id, start_vert + vert_index, 1 ).second ) return MB_FAILURE;  // Duplicate IDs!
            ++vert_index;
        else
            result = read_element( tokens, materials, type, debug );
    result = create_materials( materials );
    result = assign_ids( file_id_tag );
    file.close();
    nodeIdMap.clear();
    elemIdMap.clear();
    return MB_SUCCESS;
ErrorCode moab::ReadNASTRAN::read_element ( const std::vector< std::string > &  tokens,
std::vector< Range > &  materials,
const bool  debug
) [private]
Definition at line 379 of file ReadNASTRAN.cpp.
References moab::Interface::create_element(), elemIdMap, ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::RangeMap< KeyType, ValType, NullVal >::insert(), MB_SUCCESS, MBI, nodeIdMap, and moab::CN::VerticesPerEntity().
    // Read the element's id (unique) and material set
    ErrorCode result;
    int id       = atoi( tokens[1].c_str() );
    int material = atoi( tokens[2].c_str() );
    // Resize materials list if necessary. This code is somewhat complicated
    // so as to avoid copying of Ranges
    if( material >= (int)materials.size() )
        if( (int)materials.capacity() < material )
            materials.resize( material + 1 );
        else
            std::vector< Range > new_mat( material + 1 );
                new_mat[i].swap( materials[i] );
            materials.swap( new_mat );
    // The size of the connectivity array depends on the element type
    int n_conn = CN::VerticesPerEntity( element_type );
    EntityHandle conn_verts[27];
    assert( n_conn <= (int)( sizeof( conn_verts ) / sizeof( EntityHandle ) ) );
    // Read the connected node ids from the file
    for( int i = 0; i < n_conn; i++ )
        int n         = atoi( tokens[3 + i].c_str() );
        conn_verts[i] = nodeIdMap.find( n );
        if( !conn_verts[i] )  // invalid vertex id
            return MB_FAILURE;
    // Create the element and set the global id from the NASTRAN file
    EntityHandle element;
    result = MBI->create_element( element_type, conn_verts, n_conn, element );
    elemIdMap.insert( id, element, 1 );
    materials[material].insert( element );
    return MB_SUCCESS;
ErrorCode moab::ReadNASTRAN::read_node ( const std::vector< std::string > &  tokens,
const bool  debug,
double *  coord_arrays[3],
int &  node_id
) [private]
Definition at line 347 of file ReadNASTRAN.cpp.
References ErrorCode, get_real(), MB_NOT_IMPLEMENTED, and MB_SUCCESS.
    // Read the node's id (unique)
    ErrorCode result;
    // Read the node's coordinate system number
    // "0" or blank refers to the basic coordinate system.
    int coord_system = atoi( tokens[2].c_str() );
    if( 0 != coord_system )
        std::cerr << "ReadNASTRAN: alternative coordinate systems not implemented" << std::endl;
    // Read the coordinates
    for( unsigned int i = 0; i < 3; i++ )
        result = get_real( tokens[i + 3], *coords[i] );
        if( debug ) std::cout << "read_node: coords[" << i << "]=" << coords[i] << std::endl;
    return MB_SUCCESS;
ErrorCode moab::ReadNASTRAN::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 61 of file ReadNASTRAN.cpp.
References MB_NOT_IMPLEMENTED.
ErrorCode moab::ReadNASTRAN::tokenize_line ( const std::string &  line,
) [private]
Definition at line 223 of file ReadNASTRAN.cpp.
References FREE_FIELD, LARGE_FIELD, MB_NOT_IMPLEMENTED, MB_SUCCESS, and SMALL_FIELD.
    size_t line_size = line.size();
    switch( format )
        case SMALL_FIELD: {
            // Expect 10 fields of 8 characters.
            // The sample file does not have all 10 fields in each line
            const int field_length = 8;
            unsigned int n_tokens  = line_size / field_length;
            for( unsigned int i = 0; i < n_tokens; i++ )
                tokens.push_back( line.substr( i * field_length, field_length ) );
            break;
        case LARGE_FIELD:
        case FREE_FIELD:
        default:
            return MB_FAILURE;
    return MB_SUCCESS;
Member Data Documentation
Definition at line 81 of file ReadNASTRAN.hpp.
Referenced by assign_ids(), load_file(), and read_element().
List of all members.
