moab::ReadSms Class Reference
#include <ReadSms.hpp>
+ Inheritance diagram for moab::ReadSms:
+ Collaboration diagram for moab::ReadSms:
Public Member Functions
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 Load mesh from a file.
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
 ReadSms (Interface *impl=NULL)
 Constructor.
virtual ~ReadSms ()
 Destructor.
Static Public Member Functions
static ReaderIfacefactory (Interface *)
 factory method
Private Member Functions
ErrorCode add_entities (EntityHandle start, EntityHandle count, const Tag *file_id_tag)
ErrorCode load_file_impl (FILE *file, const Tag *file_id_tag)
ErrorCode get_set (std::vector< EntityHandle > *sets, int set_type, int set_id, Tag set_tag, EntityHandle &this_set, const Tag *file_id_tag)
ErrorCode read_parallel_info (FILE *file_ptr)
Private Attributes
ReadUtilIfacereadMeshIface
InterfacemdbImpl
 interface instance
Tag globalId
Tag paramCoords
Tag geomDimension
int setId
Detailed Description
Definition at line 15 of file ReadSms.hpp.
ReadSms::ReadSms ( Interface impl = NULL)
Constructor.
Definition at line 56 of file ReadSms.cpp.
References mdbImpl, moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
ReadSms::~ReadSms ( ) [virtual]
Destructor.
Definition at line 61 of file ReadSms.cpp.
References mdbImpl, readMeshIface, and moab::Interface::release_interface().
Member Function Documentation
ErrorCode ReadSms::add_entities ( EntityHandle  start,
EntityHandle  count,
const Tag file_id_tag
) [private]
Definition at line 483 of file ReadSms.cpp.
References moab::ReadUtilIface::assign_ids(), moab::Range::insert(), and readMeshIface.
Referenced by load_file_impl().
    if( !count || !file_id_tag ) return MB_FAILURE;
    Range range;
    range.insert( start, start + count - 1 );
    return readMeshIface->assign_ids( *file_id_tag, range, 1 );
ReaderIface * ReadSms::factory ( Interface iface) [static]
factory method
Definition at line 51 of file ReadSms.cpp.
References ReadSms().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadSms( iface );
ErrorCode ReadSms::get_set ( std::vector< EntityHandle > *  sets,
int  set_type,
int  set_id,
Tag  set_tag,
EntityHandle this_set,
) [private]
Definition at line 401 of file ReadSms.cpp.
References moab::Interface::create_meshset(), ErrorCode, globalId, MB_FILE_WRITE_ERROR, MB_SUCCESS, mdbImpl, MESHSET_SET, setId, size, and moab::Interface::tag_set_data().
    ErrorCode result = MB_SUCCESS;
    if( set_dim < 0 || set_dim > 3 ) return MB_FILE_WRITE_ERROR;
    if( (int)sets[set_dim].size() <= set_id || !sets[set_dim][set_id] )
        if( (int)sets[set_dim].size() <= set_id ) sets[set_dim].resize( set_id + 1, 0 );
        if( !sets[set_dim][set_id] )
            result = mdbImpl->create_meshset( MESHSET_SET, sets[set_dim][set_id] );
            if( MB_SUCCESS != result ) return result;
            result = mdbImpl->tag_set_data( globalId, &sets[set_dim][set_id], 1, &set_id );
            result = mdbImpl->tag_set_data( dim_tag, &sets[set_dim][set_id], 1, &set_dim );
            if( file_id_tag )
                result = mdbImpl->tag_set_data( *file_id_tag, &sets[set_dim][set_id], 1, &setId );
                ++setId;
    this_set = sets[set_dim][set_id];
    return result;
ErrorCode ReadSms::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [virtual]
Method all readers must provide to import a mesh.
Parameters:
file_nameThe file to read.
file_setOptional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data.
subset_listAn optional struct pointer specifying the tags identifying entity sets to be read.
file_id_tagIf specified, reader should store for each entity it reads, a unique integer ID for this tag.
Author:
Jason Kraftcheck
Implements moab::ReaderIface.
Definition at line 79 of file ReadSms.cpp.
References ErrorCode, load_file_impl(), MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_UNSUPPORTED_OPERATION, and setId.
    if( subset_list )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for Sms" );
    setId = 1;
    // Open file
    FILE* file_ptr = fopen( filename, "r" );
    if( !file_ptr )
        MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, filename << ": " << strerror( errno ) );
    const ErrorCode result = load_file_impl( file_ptr, file_id_tag );
    fclose( file_ptr );
    return result;
ErrorCode ReadSms::load_file_impl ( FILE *  file,
) [private]
Definition at line 105 of file ReadSms.cpp.
References add_entities(), moab::Interface::add_entities(), moab::ReadUtilIface::assign_ids(), moab::Range::begin(), CHECK, CHECKN, moab::Range::clear(), moab::Interface::create_element(), ErrorCode, GEOM_DIMENSION_TAG_NAME, geomDimension, moab::Interface::get_adjacencies(), moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), moab::ReadUtilIface::get_ordered_vertices(), get_set(), globalId, moab::Interface::globalId_tag(), moab::MAX_SUB_ENTITIES, MB_CHK_ERR, MB_FILE_WRITE_ERROR, MB_START_ID, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MBEDGE, MBTRI, mdbImpl, paramCoords, read_parallel_info(), readMeshIface, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::CN::VerticesPerEntity().
Referenced by load_file().
    bool warned         = false;
    double dum_params[] = { 0.0, 0.0, 0.0 };
    globalId = mdbImpl->globalId_tag();
    ErrorCode result =
        mdbImpl->tag_get_handle( "PARAMETER_COORDS", 3, MB_TYPE_DOUBLE, paramCoords, MB_TAG_DENSE | MB_TAG_CREAT );
    CHECK( "Failed to create param coords tag." );
    int negone = -1;
    result     = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomDimension,
                                          MB_TAG_SPARSE | MB_TAG_CREAT, &negone );
    CHECK( "Failed to create geom dim tag." );
    int n;
    char line[256], all_line[1024];
    int file_type;
    if( fgets( all_line, sizeof( all_line ), file_ptr ) == NULL )
        return MB_FAILURE;
    if( sscanf( all_line, "%s %d", line, &file_type ) != 2 )
        return MB_FAILURE;
    if( 3 == file_type )
        result = read_parallel_info( file_ptr );
        CHECK( "Failed to read parallel info." );
    int nregions, nfaces, nedges, nvertices, npoints;
    n = fscanf( file_ptr, "%d %d %d %d %d", &nregions, &nfaces, &nedges, &nvertices, &npoints );
    CHECKN( 5 );
    if( nregions < 0 || nfaces < 0 || nedges < 0 || nvertices < 0 || npoints < 0 ) return MB_FILE_WRITE_ERROR;
    // Create the vertices
    std::vector< double* > coord_arrays;
    EntityHandle vstart = 0;
    result              = readMeshIface->get_node_coords( 3, nvertices, MB_START_ID, vstart, coord_arrays );
    CHECK( "Failed to get node arrays." );
    if( file_id_tag )
        result = add_entities( vstart, nvertices, file_id_tag );MB_CHK_ERR( result );
    EntityHandle this_gent, new_handle;
    std::vector< EntityHandle > gentities[4];
    int gent_id, dum_int;
    int gent_type, num_connections;
    for( int i = 0; i < nvertices; i++ )
        n = fscanf( file_ptr, "%d", &gent_id );
        CHECKN( 1 );
        if( !gent_id ) continue;
        n = fscanf( file_ptr, "%d %d %lf %lf %lf", &gent_type, &num_connections, coord_arrays[0] + i,
                    coord_arrays[1] + i, coord_arrays[2] + i );
        CHECKN( 5 );
        result = get_set( gentities, gent_type, gent_id, geomDimension, this_gent, file_id_tag );MB_CHK_ERR( result );
        new_handle = vstart + i;
        result     = mdbImpl->add_entities( this_gent, &new_handle, 1 );
        CHECK( "Adding vertex to geom set failed." );
        switch( gent_type )
            case 1:
                n = fscanf( file_ptr, "%le", dum_params );
                CHECKN( 1 );
                result = mdbImpl->tag_set_data( paramCoords, &new_handle, 1, dum_params );
                CHECK( "Failed to set param coords tag for vertex." );
                break;
            case 2:
                n = fscanf( file_ptr, "%le %le %d", dum_params, dum_params + 1, &dum_int );
                CHECKN( 3 );
                dum_params[2] = dum_int;
                break;
            default:
                break;
    }  // End of reading vertices
    //  Read Edges
    int vert1, vert2, num_pts;
    std::vector< EntityHandle > everts( 2 );
    EntityHandle estart, *connect;
    result = readMeshIface->get_element_connect( nedges, 2, MBEDGE, 1, estart, connect );
    CHECK( "Failed to create array of edges." );
    if( file_id_tag )
        result = add_entities( estart, nedges, file_id_tag );
    for( int i = 0; i < nedges; i++ )
        CHECKN( 1 );
        n = fscanf( file_ptr, "%d %d %d %d %d", &gent_type, &vert1, &vert2, &num_connections, &num_pts );
        CHECKN( 5 );
        if( vert1 < 1 || vert1 > nvertices ) return MB_FILE_WRITE_ERROR;
        if( vert2 < 1 || vert2 > nvertices ) return MB_FILE_WRITE_ERROR;
        connect[0] = vstart + vert1 - 1;
        connect[1] = vstart + vert2 - 1;
        if( num_pts > 1 && !warned )
            std::cout << "Warning: num_points > 1 not supported; choosing last one." << std::endl;
            warned = true;
        CHECK( "Problem getting geom set for edge." );
        new_handle = estart + i;
        CHECK( "Failed to add edge to geom set." );
        connect += 2;
        for( int j = 0; j < num_pts; j++ )
            switch( gent_type )
                case 1:
                    CHECKN( 1 );
                    CHECK( "Failed to set param coords tag for edge." );
                    break;
                case 2:
                    CHECKN( 3 );
                    break;
                default:
                    break;
    }  // End of reading edges
    //  Read Faces
    std::vector< EntityHandle > bound_ents, bound_verts, new_faces;
    int bound_id;
    Range shverts;
    new_faces.resize( nfaces );
    int num_bounding;
    for( int i = 0; i < nfaces; i++ )
        CHECKN( 1 );
        n = fscanf( file_ptr, "%d %d", &gent_type, &num_bounding );
        CHECKN( 2 );
        CHECK( "Problem getting geom set for face." );
        bound_ents.resize( num_bounding + 1 );
        bound_verts.resize( num_bounding );
        for( int j = 0; j < num_bounding; j++ )
            n = fscanf( file_ptr, "%d ", &bound_id );
            CHECKN( 1 );
            if( 0 > bound_id ) bound_id = abs( bound_id );
            assert( 0 < bound_id && bound_id <= nedges );
            if( bound_id < 1 || bound_id > nedges ) return MB_FILE_WRITE_ERROR;
            bound_ents[j] = estart + abs( bound_id ) - 1;
        // Convert edge-based model to vertex-based one
            if( j == num_bounding - 1 ) bound_ents[j + 1] = bound_ents[0];
            result = mdbImpl->get_adjacencies( &bound_ents[j], 2, 0, false, shverts );
            CHECK( "Failed to get vertices bounding edge." );
            assert( shverts.size() == 1 );
            bound_verts[j] = *shverts.begin();
            shverts.clear();
        result = mdbImpl->create_element( (EntityType)( MBTRI + num_bounding - 3 ), &bound_verts[0], bound_verts.size(),
                                          new_faces[i] );
        CHECK( "Failed to create edge." );
        result = mdbImpl->add_entities( this_gent, &new_faces[i], 1 );
        int num_read = fscanf( file_ptr, "%d", &num_pts );
        if( !num_pts || !num_read ) continue;
            switch( gent_type )
                case 1:
                    CHECKN( 1 );
                    result = mdbImpl->tag_set_data( paramCoords, &new_faces[i], 1, dum_params );
                    CHECK( "Failed to set param coords tag for face." );
                    break;
                case 2:
                    CHECKN( 3 );
                    break;
                default:
                    break;
    }  // End of reading faces
    if( file_id_tag )
        result = readMeshIface->assign_ids( *file_id_tag, &new_faces[0], new_faces.size(), 1 );
    //  Read Regions
    int sense[MAX_SUB_ENTITIES];
    bound_verts.resize( MAX_SUB_ENTITIES );
    std::vector< EntityHandle > regions;
    if( file_id_tag ) regions.resize( nregions );
    for( int i = 0; i < nregions; i++ )
        CHECKN( 1 );
        result = get_set( gentities, 3, gent_id, geomDimension, this_gent, file_id_tag );
        CHECK( "Couldn't get geom set for region." );
        n = fscanf( file_ptr, "%d", &num_bounding );
        CHECKN( 1 );
        bound_ents.resize( num_bounding );
            CHECKN( 1 );
            assert( abs( bound_id ) < (int)new_faces.size() + 1 && bound_id );
            if( !bound_id || abs( bound_id ) > nfaces ) return MB_FILE_WRITE_ERROR;
            sense[j]      = ( bound_id < 0 ) ? -1 : 1;
            bound_ents[j] = new_faces[abs( bound_id ) - 1];
        EntityType etype;
        result = readMeshIface->get_ordered_vertices( &bound_ents[0], sense, num_bounding, 3, &bound_verts[0], etype );
        CHECK( "Failed in get_ordered_vertices." );
        // Make the element
        result = mdbImpl->create_element( etype, &bound_verts[0], CN::VerticesPerEntity( etype ), new_handle );
        CHECK( "Failed to create region." );
        CHECK( "Failed to add region to geom set." );
        if( file_id_tag ) regions[i] = new_handle;
        n = fscanf( file_ptr, "%d ", &dum_int );
        CHECKN( 1 );
    }  // End of reading regions
    if( file_id_tag )
        result = readMeshIface->assign_ids( *file_id_tag, &regions[0], regions.size(), 1 );
    return MB_SUCCESS;
ErrorCode ReadSms::read_parallel_info ( FILE *  file_ptr) [private]
Definition at line 438 of file ReadSms.cpp.
References MB_SUCCESS, and nparts.
    // ErrorCode result;
    // Read partition info
    int nparts, part_id, num_ifaces, num_corner_ents;
    int num_read = fscanf( file_ptr, "%d %d %d %d", &nparts, &part_id, &num_ifaces, &num_corner_ents );
    if( !num_read ) return MB_FAILURE;
    // Read interfaces
    int iface_id, iface_dim, iface_own, num_iface_corners;
    // EntityHandle this_iface;
    std::vector< int >* iface_corners = NULL;
    for( int i = 0; i < num_ifaces; i++ )
        num_read = fscanf( file_ptr, "%d %d %d %d", &iface_id, &iface_dim, &iface_own, &num_iface_corners );
        // result = get_set(sets, iface_dim, iface_id, dim_tag, iface_own, this_iface);
        // CHECK("Failed to make iface set.");
        // Read the corner ids and store them on the set for now
        iface_corners = new std::vector< int >( num_iface_corners );
        for( int j = 0; j < num_iface_corners; j++ )
            num_read = fscanf( file_ptr, "%d", &( *iface_corners )[j] );
            if( !num_read )
                delete iface_corners;
                return MB_FAILURE;
        // result = tag_set_data(ifaceCornerTag, &this_iface, 1,
        //&iface_corners);
        // CHECK("Failed to set iface corner tag.");
    // Interface data has been read
    return MB_SUCCESS;
ErrorCode ReadSms::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 70 of file ReadSms.cpp.
References MB_NOT_IMPLEMENTED.
    return MB_NOT_IMPLEMENTED;
Member Data Documentation
Definition at line 59 of file ReadSms.hpp.
Referenced by get_set(), and load_file_impl().
interface instance
Definition at line 57 of file ReadSms.hpp.
Referenced by get_set(), load_file_impl(), ReadSms(), and ~ReadSms().
Definition at line 54 of file ReadSms.hpp.
Referenced by add_entities(), load_file_impl(), ReadSms(), and ~ReadSms().
int moab::ReadSms::setId [private]
Definition at line 61 of file ReadSms.hpp.
Referenced by get_set(), and load_file().
List of all members.
