moab::ScdNCHelper Class Reference
Child helper class for scd mesh, e.g. CAM_EL or CAM_FV. More...
#include <NCHelper.hpp>
+ Inheritance diagram for moab::ScdNCHelper:
+ Collaboration diagram for moab::ScdNCHelper:
Public Member Functions
 ScdNCHelper (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)
virtual ~ScdNCHelper ()
Protected Attributes
int gDims [6]
 Dimensions of global grid in file.
int lDims [6]
 Dimensions of my local part of grid.
int gCDims [6]
 Center dimensions of global grid in file.
int lCDims [6]
 Center dimensions of my local part of grid.
std::vector< double > ilVals
 Values for i/j.
std::vector< double > jlVals
std::vector< double > ilCVals
 Center values for i/j.
std::vector< double > jlCVals
int iDim
 Dimension numbers for i/j.
int jDim
int iCDim
 Center dimension numbers for i/j.
int jCDim
int locallyPeriodic [3]
 Whether mesh is locally periodic in i or j or k.
int globallyPeriodic [3]
 Whether mesh is globally periodic in i or j or k.
Private Member Functions
virtual ErrorCode check_existing_mesh ()
 Implementation of NCHelper::check_existing_mesh()
virtual ErrorCode create_mesh (Range &faces)
 Implementation of NCHelper::create_mesh()
virtual ErrorCode read_variables (std::vector< std::string > &var_names, std::vector< int > &tstep_nums)
 Implementation of NCHelper::read_variables()
ErrorCode read_scd_variables_to_nonset_allocate (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Read non-set variables for scd mesh.
ErrorCode read_scd_variables_to_nonset (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
ErrorCode create_quad_coordinate_tag ()
 Create COORDS tag for quads coordinate.
template<typename T >
void kji_to_jik (size_t ni, size_t nj, size_t nk, void *dest, T *source)
Detailed Description
Definition at line 124 of file NCHelper.hpp.
moab::ScdNCHelper::ScdNCHelper ( ReadNC readNC,
int  fileId,
const FileOptions opts,
) [inline]
Definition at line 127 of file NCHelper.hpp.
References gCDims, gDims, globallyPeriodic, lCDims, lDims, and locallyPeriodic.
        : NCHelper( readNC, fileId, opts, fileSet ), iDim( -1 ), jDim( -1 ), iCDim( -1 ), jCDim( -1 )
        for( unsigned int i = 0; i < 6; i++ )
            gDims[i]  = -1;
            lDims[i]  = -1;
            gCDims[i] = -1;
            lCDims[i] = -1;
        locallyPeriodic[0] = locallyPeriodic[1] = locallyPeriodic[2] = 0;
        globallyPeriodic[0] = globallyPeriodic[1] = globallyPeriodic[2] = 0;
virtual moab::ScdNCHelper::~ScdNCHelper ( ) [inline, virtual]
Definition at line 141 of file NCHelper.hpp.
Member Function Documentation
Implements moab::NCHelper.
Definition at line 891 of file NCHelper.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_readNC, ErrorCode, moab::Interface::get_number_entities_by_dimension(), lCDims, MB_CHK_SET_ERR, MB_SUCCESS, and moab::ReadNC::mbImpl.
    Interface*& mbImpl = _readNC->mbImpl;
    // Get the number of vertices
    int num_verts;
    ErrorCode rval = mbImpl->get_number_entities_by_dimension( _fileSet, 0, num_verts );MB_CHK_SET_ERR( rval, "Trouble getting number of vertices" );
    // Check against parameters
    // When ghosting is used, this check might fail (to be updated later)
    if (num_verts > 0) {
      int expected_verts = (lDims[3] - lDims[0] + 1) * (lDims[4] - lDims[1] + 1) * (-1 == lDims[2] ?
    1 : lDims[5] - lDims[2] + 1); if (num_verts != expected_verts) { MB_SET_ERR(MB_FAILURE, "Number
    of vertices doesn't match");
    // Check the number of elements too
    int num_elems;
    rval = mbImpl->get_number_entities_by_dimension( _fileSet, ( -1 == lCDims[2] ? 2 : 3 ), num_elems );MB_CHK_SET_ERR( rval, "Trouble getting number of elements" );
    if (num_elems > 0) {
      int expected_elems = (lCDims[3] - lCDims[0] + 1) * (lCDims[4] - lCDims[1] + 1) * (-1 ==
    lCDims[2] ? 1 : (lCDims[5] - lCDims[2] + 1)); if (num_elems != expected_elems) {
        MB_SET_ERR(MB_FAILURE, "Number of elements doesn't match");
    return MB_SUCCESS;
ErrorCode moab::ScdNCHelper::create_mesh ( Range faces) [private, virtual]
Reimplemented in moab::NCHelperScrip, and moab::NCHelperDomain.
Definition at line 928 of file NCHelper.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_readNC, moab::Interface::add_entities(), moab::Range::begin(), moab::ScdBox::boundary_complete(), moab::ScdBox::box_set(), moab::ScdInterface::construct_box(), create_quad_coordinate_tag(), moab::ReadNC::dbgOut, moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::ScdBox::get_coordinate_arrays(), moab::DebugOutput::get_verbosity(), ilVals, moab::Range::insert(), jlVals, lDims, moab::NCHelper::levVals, moab::Interface::list_entities(), locallyPeriodic, MB_CHK_SET_ERR, MB_SUCCESS, moab::ReadNC::mbImpl, moab::ReadNC::mGlobalIdTag, moab::ReadNC::mpFileIdTag, moab::ScdBox::num_elements(), moab::ScdBox::num_vertices(), moab::ReadNC::parData, moab::ReadNC::scdi, moab::ScdBox::start_element(), moab::ScdBox::start_vertex(), moab::Interface::tag_get_data(), moab::Interface::tag_iterate(), moab::DebugOutput::tprintf(), and moab::Interface::UNION.
    Tag& mGlobalIdTag       = _readNC->mGlobalIdTag;
    const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
    DebugOutput& dbgOut     = _readNC->dbgOut;
    ScdInterface* scdi      = _readNC->scdi;
    ScdParData& parData     = _readNC->parData;
    Range tmp_range;
    ScdBox* scd_box;
    ErrorCode rval =
        scdi->construct_box( HomCoord( lDims[0], lDims[1], lDims[2], 1 ), HomCoord( lDims[3], lDims[4], lDims[5], 1 ),
                             NULL, 0, scd_box, locallyPeriodic, &parData, true );MB_CHK_SET_ERR( rval, "Trouble creating scd vertex sequence" );
    // Add verts to tmp_range first, so we can duplicate global ids in vertex ids
    tmp_range.insert( scd_box->start_vertex(), scd_box->start_vertex() + scd_box->num_vertices() - 1 );
    if( mpFileIdTag )
        int count;
        void* data;
        rval = mbImpl->tag_iterate( *mpFileIdTag, tmp_range.begin(), tmp_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file ID tag on local vertices" );
        assert( count == scd_box->num_vertices() );
        int* fid_data = (int*)data;
        rval          = mbImpl->tag_iterate( mGlobalIdTag, tmp_range.begin(), tmp_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global ID tag on local vertices" );
        int* gid_data = (int*)data;
        for( int i = 0; i < count; i++ )
            fid_data[i] = gid_data[i];
    // Then add box set and elements to the range, then to the file set
    tmp_range.insert( scd_box->start_element(), scd_box->start_element() + scd_box->num_elements() - 1 );
    tmp_range.insert( scd_box->box_set() );
    rval = mbImpl->add_entities( _fileSet, tmp_range );MB_CHK_SET_ERR( rval, "Couldn't add new vertices to current file set" );
    dbgOut.tprintf( 1, "scdbox %d quads, %d vertices\n", scd_box->num_elements(), scd_box->num_vertices() );
    // Set the vertex coordinates
    double *xc, *yc, *zc;
    rval = scd_box->get_coordinate_arrays( xc, yc, zc );MB_CHK_SET_ERR( rval, "Couldn't get vertex coordinate arrays" );
    int i, j, k, il, jl, kl;
    int dil = lDims[3] - lDims[0] + 1;
    int djl = lDims[4] - lDims[1] + 1;
    assert( dil == (int)ilVals.size() && djl == (int)jlVals.size() &&
            ( -1 == lDims[2] || lDims[5] - lDims[2] + 1 == (int)levVals.size() ) );
    for( kl = lDims[2]; kl <= lDims[5]; kl++ )
        k = kl - lDims[2];
        for( jl = lDims[1]; jl <= lDims[4]; jl++ )
            j = jl - lDims[1];
            for( il = lDims[0]; il <= lDims[3]; il++ )
                i                = il - lDims[0];
                unsigned int pos = i + j * dil + k * dil * djl;
                xc[pos]          = ilVals[i];
                yc[pos]          = jlVals[j];
                zc[pos]          = ( -1 == lDims[2] ? 0.0 : levVals[k] );
#ifndef NDEBUG
    int num_verts =
        ( lDims[3] - lDims[0] + 1 ) * ( lDims[4] - lDims[1] + 1 ) * ( -1 == lDims[2] ? 1 : lDims[5] - lDims[2] + 1 );
    std::vector< int > gids( num_verts );
    Range verts( scd_box->start_vertex(), scd_box->start_vertex() + scd_box->num_vertices() - 1 );
    rval = mbImpl->tag_get_data( mGlobalIdTag, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of vertices" );
    int vmin = *( std::min_element( gids.begin(), gids.end() ) ),
        vmax = *( std::max_element( gids.begin(), gids.end() ) );
    dbgOut.tprintf( 1, "Vertex gids %d-%d\n", vmin, vmax );
#endif
    // Add elements to the range passed in
    faces.insert( scd_box->start_element(), scd_box->start_element() + scd_box->num_elements() - 1 );
    if( 2 <= dbgOut.get_verbosity() )
        assert( scd_box->boundary_complete() );
        EntityHandle dum_ent = scd_box->start_element();
        rval                 = mbImpl->list_entities( &dum_ent, 1 );MB_CHK_SET_ERR( rval, "Trouble listing first hex" );
        std::vector< EntityHandle > connect;
        rval = mbImpl->get_connectivity( &dum_ent, 1, connect );MB_CHK_SET_ERR( rval, "Trouble getting connectivity" );
        rval = mbImpl->list_entities( &connect[0], connect.size() );MB_CHK_SET_ERR( rval, "Trouble listing element connectivity" );
    Range edges;
    mbImpl->get_adjacencies( faces, 1, true, edges, Interface::UNION );
    // Create COORDS tag for quads
    rval = create_quad_coordinate_tag();MB_CHK_SET_ERR( rval, "Trouble creating COORDS tag for quads" );
    return MB_SUCCESS;
Definition at line 1266 of file NCHelper.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_readNC, moab::Range::begin(), moab::Range::end(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_type(), ilCVals, moab::ReadNC::isParallel, jlCVals, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, moab::ReadNC::mbImpl, MBQUAD, PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::tag_iterate().
Referenced by create_mesh().
    Range ents;
    ErrorCode rval = mbImpl->get_entities_by_type( _fileSet, moab::MBQUAD, ents );MB_CHK_SET_ERR( rval, "Trouble getting quads" );
    std::size_t numOwnedEnts = 0;
#ifdef MOAB_HAVE_MPI
    Range ents_owned;
    bool& isParallel = _readNC->isParallel;
    if( isParallel )
        ParallelComm*& myPcomm = _readNC->myPcomm;
        rval                   = myPcomm->filter_pstatus( ents, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &ents_owned );MB_CHK_SET_ERR( rval, "Trouble getting owned quads" );
        numOwnedEnts = ents_owned.size();
    else
        numOwnedEnts = ents.size();
        ents_owned   = ents;
#else
#endif
    if( numOwnedEnts == 0 ) return MB_SUCCESS;
    assert( numOwnedEnts == ilCVals.size() * jlCVals.size() );
    std::vector< double > coords( numOwnedEnts * 3 );
    std::size_t pos = 0;
    for( std::size_t j = 0; j != jlCVals.size(); ++j )
        for( std::size_t i = 0; i != ilCVals.size(); ++i )
            pos             = j * ilCVals.size() * 3 + i * 3;
            coords[pos]     = ilCVals[i];
            coords[pos + 1] = jlCVals[j];
            coords[pos + 2] = 0.0;
    std::string tag_name = "COORDS";
    Tag tagh             = 0;
    rval = mbImpl->tag_get_handle( tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating COORDS tag" );
    void* data;
    int count;
    rval = mbImpl->tag_iterate( tagh, ents_owned.begin(), ents_owned.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate COORDS tag on quads" );
#else
    rval = mbImpl->tag_iterate( tagh, ents.begin(), ents.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate COORDS tag on quads" );
#endif
    assert( count == (int)numOwnedEnts );
    double* quad_data = (double*)data;
    std::copy( coords.begin(), coords.end(), quad_data );
    return MB_SUCCESS;
void moab::ScdNCHelper::kji_to_jik ( size_t  ni,
size_t  nj,
size_t  nk,
void *  dest,
T source
) [inline, private]
Definition at line 160 of file NCHelper.hpp.
References T.
Referenced by read_scd_variables_to_nonset().
        size_t nik = ni * nk, nij = ni * nj;
        T* tmp_data = reinterpret_cast< T* >( dest );
        for( std::size_t j = 0; j != nj; j++ )
            for( std::size_t i = 0; i != ni; i++ )
                for( std::size_t k = 0; k != nk; k++ )
                    tmp_data[j * nik + i * nk + k] = source[k * nij + j * ni + i];
ErrorCode moab::ScdNCHelper::read_scd_variables_to_nonset ( std::vector< ReadNC::VarData > &  vdatas,
std::vector< int > &  tstep_nums
) [private]
Definition at line 1168 of file NCHelper.cpp.
References moab::NCHelper::_fileId, moab::NCHelper::_readNC, moab::ReadNC::dbgOut, ErrorCode, moab::DebugOutput::get_verbosity(), kji_to_jik(), MB_CHK_SET_ERR, MB_SET_ERR, NCFUNCAG, moab::DebugOutput::printf(), read_scd_variables_to_nonset_allocate(), t, and moab::DebugOutput::tprintf().
Referenced by read_variables().
    ErrorCode rval = read_scd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
    // Finally, read into that space
    int success;
    for( unsigned int i = 0; i < vdatas.size(); i++ )
        std::size_t sz = vdatas[i].sz;
        // A typical supported variable: float T(time, lev, lat, lon)
        // For tag values, need transpose (lev, lat, lon) to (lat, lon, lev)
        size_t ni = vdatas[i].readCounts[3];  // lon or slon
        size_t nj = vdatas[i].readCounts[2];  // lat or slat
        size_t nk = vdatas[i].readCounts[1];  // lev
        for( unsigned int t = 0; t < tstep_nums.size(); t++ )
            // Tag data for this timestep
            void* data = vdatas[i].varDatas[t];
            // Set readStart for each timestep along time dimension
            vdatas[i].readStarts[0] = tstep_nums[t];
            switch( vdatas[i].varDataType )
                case NC_BYTE:
                case NC_CHAR: {
                    std::vector< char > tmpchardata( sz );
                    success = NCFUNCAG( _vara_text )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0],
                                                      &vdatas[i].readCounts[0], &tmpchardata[0] );
                    if( success )
                        MB_SET_ERR( MB_FAILURE, "Failed to read byte/char data for variable " << vdatas[i].varName );
                    if( vdatas[i].numLev > 1 )
                        // Transpose (lev, lat, lon) to (lat, lon, lev)
                        kji_to_jik( ni, nj, nk, data, &tmpchardata[0] );
                    else
                        for( std::size_t idx = 0; idx != tmpchardata.size(); idx++ )
                            ( (char*)data )[idx] = tmpchardata[idx];
                    break;
                case NC_SHORT:
                case NC_INT: {
                    std::vector< int > tmpintdata( sz );
                    success = NCFUNCAG( _vara_int )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0],
                                                     &vdatas[i].readCounts[0], &tmpintdata[0] );
                    if( success )
                        MB_SET_ERR( MB_FAILURE, "Failed to read short/int data for variable " << vdatas[i].varName );
                        kji_to_jik( ni, nj, nk, data, &tmpintdata[0] );
                    else
                        for( std::size_t idx = 0; idx != tmpintdata.size(); idx++ )
                            ( (int*)data )[idx] = tmpintdata[idx];
                    break;
                case NC_FLOAT:
                case NC_DOUBLE: {
                    std::vector< double > tmpdoubledata( sz );
                    success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0],
                                                        &vdatas[i].readCounts[0], &tmpdoubledata[0] );
                    if( success )
                        MB_SET_ERR( MB_FAILURE, "Failed to read float/double data for variable " << vdatas[i].varName );
                        kji_to_jik( ni, nj, nk, data, &tmpdoubledata[0] );
                    else
                        for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
                            ( (double*)data )[idx] = tmpdoubledata[idx];
                    break;
                default:
                    MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
    // Debug output, if requested
    if( 1 == dbgOut.get_verbosity() )
        dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
        for( unsigned int i = 1; i < vdatas.size(); i++ )
            dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
        dbgOut.tprintf( 1, "\n" );
    return rval;
ErrorCode moab::ScdNCHelper::read_scd_variables_to_nonset_allocate ( std::vector< ReadNC::VarData > &  vdatas,
) [private]
Definition at line 1050 of file NCHelper.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_readNC, moab::Range::begin(), moab::ReadNC::dbgOut, moab::ReadNC::dimLens, moab::Range::end(), moab::ReadNC::ENTLOCEDGE, moab::ReadNC::ENTLOCEWEDGE, moab::ReadNC::ENTLOCFACE, moab::ReadNC::ENTLOCNSEDGE, moab::ReadNC::ENTLOCVERT, ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_dimension(), moab::NCHelper::get_tag_to_nonset(), moab::ReadNC::isParallel, lCDims, lDims, MB_CHK_SET_ERR, MB_INDEX_OUT_OF_RANGE, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SET_GLB_ERR, moab::ReadNC::mbImpl, moab::Range::psize(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::size(), t, moab::Interface::tag_iterate(), moab::NCHelper::tDim, and moab::DebugOutput::tprintf().
    std::vector< int >& dimLens = _readNC->dimLens;
    Range* range = NULL;
    // Get vertices
    Range verts;
    ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, verts );MB_CHK_SET_ERR( rval, "Trouble getting vertices in current file set" );
    assert( "Should only have a single vertex subrange, since they were read in one shot" && verts.psize() == 1 );
    Range edges;
    rval = mbImpl->get_entities_by_dimension( _fileSet, 1, edges );MB_CHK_SET_ERR( rval, "Trouble getting edges in current file set" );
    // Get faces
    Range faces;
    rval = mbImpl->get_entities_by_dimension( _fileSet, 2, faces );MB_CHK_SET_ERR( rval, "Trouble getting faces in current file set" );
    assert( "Should only have a single face subrange, since they were read in one shot" && faces.psize() == 1 );
    moab::Range faces_owned;
    if( isParallel )
        rval                   = myPcomm->filter_pstatus( faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &faces_owned );MB_CHK_SET_ERR( rval, "Trouble getting owned faces in current file set" );
    else
        faces_owned = faces;  // Not running in parallel, but still with MPI
#endif
        // Support non-set variables with 4 dimensions like (time, lev, lat, lon)
        assert( 4 == vdatas[i].varDims.size() );
        // For a non-set variable, time should be the first dimension
        assert( tDim == vdatas[i].varDims[0] );
        // Set up readStarts and readCounts
        vdatas[i].readStarts.resize( 4 );
        vdatas[i].readCounts.resize( 4 );
        // First: time
        vdatas[i].readStarts[0] = 0;  // This value is timestep dependent, will be set later
        vdatas[i].readCounts[0] = 1;
        // Next: lev
        vdatas[i].readStarts[1] = 0;
        vdatas[i].readCounts[1] = vdatas[i].numLev;
        // Finally: lat (or slat) and lon (or slon)
        switch( vdatas[i].entLoc )
            case ReadNC::ENTLOCVERT:
                // Vertices
                vdatas[i].readStarts[2] = lDims[1];
                vdatas[i].readCounts[2] = lDims[4] - lDims[1] + 1;
                vdatas[i].readStarts[3] = lDims[0];
                vdatas[i].readCounts[3] = lDims[3] - lDims[0] + 1;
                range                   = &verts;
                break;
            case ReadNC::ENTLOCNSEDGE:
            case ReadNC::ENTLOCEWEDGE:
            case ReadNC::ENTLOCEDGE:
                // Not implemented yet, set a global error
                MB_SET_GLB_ERR( MB_NOT_IMPLEMENTED, "Reading edge data is not implemented yet" );
            case ReadNC::ENTLOCFACE:
                // Faces
                vdatas[i].readStarts[2] = lCDims[1];
                vdatas[i].readCounts[2] = lCDims[4] - lCDims[1] + 1;
                vdatas[i].readStarts[3] = lCDims[0];
                vdatas[i].readCounts[3] = lCDims[3] - lCDims[0] + 1;
                range = &faces_owned;
#else
                range = &faces;
#endif
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
            dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] );
            if( tstep_nums[t] >= dimLens[tDim] )
                MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] );
            // Get the tag to read into
            if( !vdatas[i].varTags[t] )
                rval = get_tag_to_nonset( vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev );MB_CHK_SET_ERR( rval, "Trouble getting tag to non-set variable " << vdatas[i].varName );
            // Get ptr to tag space
            void* data;
            int count;
            rval = mbImpl->tag_iterate( vdatas[i].varTags[t], range->begin(), range->end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate tag for non-set variable " << vdatas[i].varName );
            assert( (unsigned)count == range->size() );
            vdatas[i].varDatas[t] = data;
        // Get variable size
        vdatas[i].sz = 1;
        for( std::size_t idx = 0; idx != vdatas[i].readCounts.size(); idx++ )
            vdatas[i].sz *= vdatas[i].readCounts[idx];
    return rval;
ErrorCode moab::ScdNCHelper::read_variables ( std::vector< std::string > &  var_names,
Definition at line 1030 of file NCHelper.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, read_scd_variables_to_nonset(), moab::NCHelper::read_variables_setup(), and moab::NCHelper::read_variables_to_set().
    std::vector< ReadNC::VarData > vdatas;
    std::vector< ReadNC::VarData > vsetdatas;
    ErrorCode rval = read_variables_setup( var_names, tstep_nums, vdatas, vsetdatas );MB_CHK_SET_ERR( rval, "Trouble setting up to read variables" );
    if( !vsetdatas.empty() )
        rval = read_variables_to_set( vsetdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to set" );
    if( !vdatas.empty() )
        rval = read_scd_variables_to_nonset( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to verts/edges/faces" );
    return MB_SUCCESS;
Member Data Documentation
int moab::ScdNCHelper::gCDims[6] [protected]
Definition at line 178 of file NCHelper.hpp.
Referenced by moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), and ScdNCHelper().
Definition at line 199 of file NCHelper.hpp.
Referenced by moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), and ScdNCHelper().
int moab::ScdNCHelper::iCDim [protected]
Definition at line 193 of file NCHelper.hpp.
Referenced by moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), and moab::NCHelperEuler::init_mesh_vals().
int moab::ScdNCHelper::iDim [protected]
Definition at line 190 of file NCHelper.hpp.
Referenced by moab::NCHelperDomain::init_mesh_vals(), and moab::NCHelperFV::init_mesh_vals().
std::vector< double > moab::ScdNCHelper::ilVals [protected]
Definition at line 196 of file NCHelper.hpp.
Referenced by create_mesh(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), and ScdNCHelper().
List of all members.
