moab::SimplexTemplateRefiner Member List
This is the complete list of members for moab::SimplexTemplateRefiner, including all inherited members.
assign_parametric_coordinates(int num_nodes, const double *src, double *tgt)moab::SimplexTemplateRefiner [protected]
best_tets(int *alternates, double *[14], int, int)moab::SimplexTemplateRefiner [inline, protected]
compare_Hopf_cross_string_dist(const double *v00, const double *v01, const double *v10, const double *v11)moab::SimplexTemplateRefiner [protected, static]
coord_heapmoab::EntityRefiner [protected]
corner_coordsmoab::SimplexTemplateRefiner [protected]
corner_handlesmoab::SimplexTemplateRefiner [protected]
corner_tagsmoab::SimplexTemplateRefiner [protected]
current_coordmoab::EntityRefiner [protected]
current_tagmoab::EntityRefiner [protected]
edge_size_evaluatormoab::EntityRefiner [protected]
EntityRefiner()moab::EntityRefiner
get_edge_size_evaluator()moab::EntityRefiner [inline]
get_heap_size_bound(int max_recursions) const moab::SimplexTemplateRefiner [inline, virtual]
get_maximum_number_of_subdivisions() const moab::EntityRefiner [inline]
get_minimum_number_of_subdivisions() const moab::EntityRefiner [inline]
get_output_functor()moab::EntityRefiner [inline]
get_tag_assigner() const moab::SimplexTemplateRefiner [inline]
heap_coord_storage()moab::EntityRefiner [protected]
heap_tag_storage()moab::EntityRefiner [protected]
input_is_outputmoab::SimplexTemplateRefiner [protected]
maximum_number_of_subdivisionsmoab::EntityRefiner [protected]
mesh_inmoab::EntityRefiner [protected]
minimum_number_of_subdivisionsmoab::EntityRefiner [protected]
output_functormoab::EntityRefiner [protected]
permutations_from_indexmoab::SimplexTemplateRefiner [protected, static]
prepare(RefinerTagManager *tmgr, EntityRefinerOutputFunctor *ofunc)moab::SimplexTemplateRefiner [virtual]
refine_0_simplex(const double *v0, const void *t0, EntityHandle h0)moab::SimplexTemplateRefiner [protected]
refine_1_simplex(int max_depth, const double *v0, const void *t0, EntityHandle h0, const double *v1, const void *t1, EntityHandle h1)moab::SimplexTemplateRefiner [protected]
refine_2_simplex(int max_depth, int move, const double *v0, const void *t0, EntityHandle h0, const double *v1, const void *t1, EntityHandle h1, const double *v2, const void *t2, EntityHandle h2)moab::SimplexTemplateRefiner [protected]
refine_3_simplex(int max_depth, double *v0, void *t0, EntityHandle h0, double *v1, void *t1, EntityHandle h1, double *v2, void *t2, EntityHandle h2, double *v3, void *t3, EntityHandle h3)moab::SimplexTemplateRefiner [protected]
refine_entity(EntityType etyp, EntityHandle entity)moab::SimplexTemplateRefiner [virtual]
reset_heap_pointers()moab::EntityRefiner [protected]
set_edge_size_evaluator(EdgeSizeEvaluator *)moab::EntityRefiner [virtual]
set_maximum_number_of_subdivisions(int mx)moab::EntityRefiner [virtual]
set_minimum_number_of_subdivisions(int mn)moab::EntityRefiner [virtual]
set_output_functor(EntityRefinerOutputFunctor *func_obj)moab::EntityRefiner [virtual]
set_tag_assigner(SimplexTemplateTagAssigner *ta)moab::SimplexTemplateRefiner [virtual]
SimplexTemplateRefiner()moab::SimplexTemplateRefiner
tag_assignermoab::SimplexTemplateRefiner [protected]
tag_heapmoab::EntityRefiner [protected]
tag_managermoab::SimplexTemplateRefiner [protected]
template_indexmoab::SimplexTemplateRefiner [protected, static]
templatesmoab::SimplexTemplateRefiner [protected, static]
update_heap_size()moab::EntityRefiner [protected]
~EntityRefiner()moab::EntityRefiner [virtual]
~SimplexTemplateRefiner()moab::SimplexTemplateRefiner [virtual]
