moab::Skinner Member List
This is the complete list of members for moab::Skinner, including all inherited members.
add_adjacency(EntityHandle entity)moab::Skinner [protected]
add_adjacency(EntityHandle entity, const EntityHandle *conn, const int num_nodes)moab::Skinner [protected]
classify_2d_boundary(const Range &boundary, const Range &bar_elements, EntityHandle boundary_edges, EntityHandle inferred_edges, EntityHandle non_manifold_edges, EntityHandle other_edges, int &number_boundary_nodes)moab::Skinner
classify_2d_boundary(const Range &boundary, const Range &mesh_1d_elements, Range &boundary_edges, Range &inferred_edges, Range &non_manifold_edges, Range &other_edges, int &number_boundary_nodes)moab::Skinner
connectivity_match(const EntityHandle *conn1, const EntityHandle *conn2, const int num_verts, Skinner::direction &direct)moab::Skinner [protected]
create_side(const EntityHandle this_set, EntityHandle element, EntityType side_type, const EntityHandle *side_corners, EntityHandle &side_elem_handle_out)moab::Skinner [protected]
deinitialize()moab::Skinner [protected]
direction enum namemoab::Skinner [private]
edge_reversed(EntityHandle face, const EntityHandle edge_ends[2])moab::Skinner [protected]
entity_deletable(EntityHandle entity)moab::Skinner [protected]
face_reversed(EntityHandle region, const EntityHandle *face_conn, EntityType face_type)moab::Skinner [protected]
find_geometric_skin(const EntityHandle meshset, Range &forward_target_entities)moab::Skinner
find_inferred_edges(Range &skin_boundary, Range &candidate_edges, Range &inferred_edges, double reference_angle_degrees)moab::Skinner [protected]
find_match(EntityType type, const EntityHandle *conn, const int num_nodes, EntityHandle &match, Skinner::direction &direct)moab::Skinner [protected]
find_skin(const EntityHandle meshset, const Range &entities, bool get_vertices, Range &output_handles, Range *output_reverse_handles=0, bool create_vert_elem_adjs=false, bool create_skin_elements=true, bool look_for_scd=false)moab::Skinner
find_skin(const EntityHandle this_set, const EntityHandle *entities, int num_entities, bool get_vertices, Range &output_handles, Range *output_reverse_handles=0, bool create_vert_elem_adjs=false, bool create_skin_elements=true, bool look_for_scd=false)moab::Skinner [inline]
find_skin(const EntityHandle this_set, const Range &entities, int dim, Range &skin_entities, bool create_vert_elem_adjs=false, bool create_skin_elements=true)moab::Skinner
find_skin_noadj(const Range &source_entities, Range &forward_target_entities, Range &reverse_target_entities)moab::Skinner [protected]
find_skin_scd(const Range &source_entities, bool get_vertices, Range &output_handles, bool create_skin_elements)moab::Skinner [protected]
find_skin_vertices(const EntityHandle this_set, const Range &entities, Range *skin_verts=0, Range *skin_elems=0, Range *rev_elems=0, bool create_if_missing=true, bool corners_only=false)moab::Skinner [protected]
find_skin_vertices_1D(Tag tag, const Range &edges, Range &skin_verts)moab::Skinner [protected]
find_skin_vertices_2D(const EntityHandle this_set, Tag tag, const Range &faces, Range *skin_verts=0, Range *skin_edges=0, Range *reverse_edges=0, bool create_edges=false, bool corners_only=false)moab::Skinner [protected]
find_skin_vertices_3D(const EntityHandle this_set, Tag tag, const Range &entities, Range *skin_verts=0, Range *skin_faces=0, Range *reverse_faces=0, bool create_faces=false, bool corners_only=false)moab::Skinner [protected]
FORWARD enum valuemoab::Skinner [private]
has_larger_angle(EntityHandle &entity1, EntityHandle &entity2, double reference_angle_cosine)moab::Skinner [protected]
mAdjTagmoab::Skinner [protected]
mDeletableMBTagmoab::Skinner [protected]
mTargetDimmoab::Skinner [protected]
remove_adjacency(EntityHandle entity)moab::Skinner [protected]
REVERSE enum valuemoab::Skinner [private]
skin_box(ScdBox *box, bool get_vertices, Range &output_handles, bool create_skin_elements)moab::Skinner [protected]
Skinner(Interface *mdb)moab::Skinner [inline]
thisMBmoab::Skinner [protected]
~Skinner()moab::Skinner
