moab::SparseTag Member List
This is the complete list of members for moab::SparseTag, including all inherited members.
allocate_data(EntityHandle h, MapType::const_iterator iter, bool copy_default=true)moab::SparseTag [inline, private]
check_valid_sizes(const int *sizes, int num_sizes) const moab::TagInfo
clear_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *value_ptr, int value_len=0)moab::SparseTag [virtual]
clear_data(SequenceManager *seqman, Error *error_handler, const Range &entities, const void *value_ptr, int value_len=0)moab::SparseTag [virtual]
equals_default_value(const void *data, int size=-1) const moab::TagInfo
find_entities_with_value(const SequenceManager *seqman, Error *error_handler, Range &output_entities, const void *value, int value_bytes=0, EntityType type=MBMAXTYPE, const Range *intersect_entities=0) const moab::SparseTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void *data) const moab::SparseTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const Range &entities, void *data) const moab::SparseTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void **data_ptrs, int *data_lengths) const moab::SparseTag [virtual]
get_data(const SequenceManager *seqman, Error *error_handler, const Range &entities, const void **data_ptrs, int *data_lengths) const moab::SparseTag [virtual]
get_data(Error *, EntityHandle entity_handle, void *data) const moab::SparseTag [inline, private]
get_data_ptr(EntityHandle entity_handle, const void *&data, bool allocate=true) const moab::SparseTag [inline, private]
get_data_type() const moab::TagInfo [inline]
get_default_value() const moab::TagInfo [inline]
get_default_value_size() const moab::TagInfo [inline]
get_memory_use(const SequenceManager *seqman, unsigned long &total, unsigned long &per_entity) const moab::SparseTag [virtual]
moab::TagInfo::get_memory_use() const moab::TagInfo [inline, protected]
get_name() const moab::TagInfo [inline]
get_number_entities()moab::SparseTag [inline]
get_size() const moab::TagInfo [inline]
get_storage_type() const moab::SparseTag [virtual]
get_tagged_entities(const SequenceManager *seqman, Range &output_entities, EntityType type=MBMAXTYPE, const Range *intersect=0) const moab::SparseTag [virtual]
is_tagged(const SequenceManager *, EntityHandle h) const moab::SparseTag [virtual]
mAllocatormoab::SparseTag [private]
MapType typedefmoab::SparseTag
mDatamoab::SparseTag [private]
num_tagged_entities(const SequenceManager *seqman, size_t &output_count, EntityType type=MBMAXTYPE, const Range *intersect=0) const moab::SparseTag [virtual]
operator=(const SparseTag &)moab::SparseTag [private]
release_all_data(SequenceManager *seqman, Error *error_handler, bool delete_pending)moab::SparseTag [virtual]
remove_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities)moab::SparseTag [virtual]
remove_data(SequenceManager *seqman, Error *error_handler, const Range &entities)moab::SparseTag [virtual]
remove_data(Error *, EntityHandle entity_handle)moab::SparseTag [inline, private]
set_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *data)moab::SparseTag [virtual]
set_data(SequenceManager *seqman, Error *error_handler, const Range &entities, const void *data)moab::SparseTag [virtual]
set_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void const *const *data_ptrs, const int *data_lengths)moab::SparseTag [virtual]
set_data(SequenceManager *seqman, Error *error_handler, const Range &entities, void const *const *data_ptrs, const int *data_lengths)moab::SparseTag [virtual]
set_data(Error *, EntityHandle entity_handle, const void *data)moab::SparseTag [inline, private]
set_name(const std::string &name)moab::TagInfo [inline]
size_from_data_type(DataType t)moab::TagInfo [static]
SparseTag(const char *name, int size, DataType type, const void *default_value)moab::SparseTag
SparseTag(const SparseTag &)moab::SparseTag [private]
tag_iterate(SequenceManager *seqman, Error *error_handler, Range::iterator &iter, const Range::iterator &end, void *&data_ptr, bool allocate=true)moab::SparseTag [virtual]
TagInfo()moab::TagInfo [inline]
TagInfo(const char *name, int size, DataType type, const void *default_value, int default_value_size)moab::TagInfo
validate_lengths(Error *error_handler, const int *lengths, size_t num_lengths) const moab::TagInfo
variable_length() const moab::TagInfo [inline]
~SparseTag()moab::SparseTag
~TagInfo()moab::TagInfo [virtual]
