moab::SpectralHex Class Reference
#include <SpectralHex.hpp>
+ Collaboration diagram for moab::SpectralHex:
Static Public Member Functions
static ErrorCode evalFcn (const double *params, const double *field, const int ndim, const int num_tuples, double *work, double *result)
 Forward-evaluation of field at parametric coordinates.
static ErrorCode reverseEvalFcn (EvalFcn eval, JacobianFcn jacob, InsideFcn ins, const double *posn, const double *verts, const int nverts, const int ndim, const double iter_tol, const double inside_tol, double *work, double *params, int *is_inside)
 Reverse-evaluation of parametric coordinates at physical space position.
static ErrorCode jacobianFcn (const double *params, const double *verts, const int nverts, const int ndim, double *work, double *result)
 Evaluate the jacobian at a specified parametric position.
static ErrorCode integrateFcn (const double *field, const double *verts, const int nverts, const int ndim, const int num_tuples, double *work, double *result)
static ErrorCode initFcn (const double *verts, const int nverts, double *&work)
 Initialize this EvalSet.
static int insideFcn (const double *params, const int ndim, const double tol)
 Function that returns whether or not the parameters are inside the natural space of the element.
static EvalSet eval_set ()
static bool compatible (EntityType tp, int numv, EvalSet &eset)
Static Protected Attributes
static int _n
static double * _z [3]
static lagrange_data _ld [3]
static opt_data_3 _data
static double * _odwork
static bool init_
Detailed Description
Definition at line 12 of file SpectralHex.hpp.
Member Function Documentation
static bool moab::SpectralHex::compatible ( EntityType  tp,
int  numv,
EvalSet eset
) [inline, static]
Definition at line 66 of file SpectralHex.hpp.
References eval_set(), and MBHEX.
        if( tp != MBHEX ) return false;
        int i;
        for( i = 3; i * i * i == numv || i * i * i > numv; i++ )
        if( i * i * i != numv ) return false;
        eset = eval_set();
        return true;
static EvalSet moab::SpectralHex::eval_set ( ) [inline, static]
Definition at line 61 of file SpectralHex.hpp.
Referenced by compatible().
static ErrorCode moab::SpectralHex::evalFcn ( const double *  params,
const double *  field,
const int  ndim,
double *  work,
double *  result
) [static]
void moab::SpectralHex::initFcn ( const double *  verts,
const int  nverts,
double *&  work
) [static]
Definition at line 18 of file SpectralHex.cpp.
References _data, _ld, _n, _odwork, _z, lagrange_setup(), lobatto_nodes(), opt_alloc_3(), and tmalloc.
    if( _init && _n == order ) return;
    if( _init && _n != order )
        // TODO: free data cached
        freedata();
    // compute stuff that depends only on order
    _init = true;
    _n    = order;
    // triplicates! n is the same in all directions !!!
    for( int d = 0; d < 3; d++ )
        _z[d] = tmalloc( double, _n );
        lobatto_nodes( _z[d], _n );
        lagrange_setup( &_ld[d], _z[d], _n );
    opt_alloc_3( &_data, _ld );
    unsigned int nf = _n * _n, ne = _n, nw = 2 * _n * _n + 3 * _n;
    _odwork = tmalloc( double, 6 * nf + 9 * ne + nw );
int moab::SpectralHex::insideFcn ( const double *  params,
const int  ndim,
const double  tol
) [static]
Definition at line 183 of file SpectralHex.cpp.
    return EvalSet::inside( params, ndim, tol );
static ErrorCode moab::SpectralHex::integrateFcn ( const double *  field,
const int  nverts,
const int  ndim,
double *  work,
double *  result
) [static]
static ErrorCode moab::SpectralHex::jacobianFcn ( const double *  params,
const int  nverts,
const int  ndim,
double *  work,
double *  result
) [static]
static ErrorCode moab::SpectralHex::reverseEvalFcn ( EvalFcn  eval,
JacobianFcn  jacob,
InsideFcn  ins,
const double *  posn,
const int  nverts,
const int  ndim,
double *  work,
double *  params,
int *  is_inside
) [static]
Member Data Documentation
int moab::SpectralHex::_n [static, protected]
Definition at line 78 of file SpectralHex.hpp.
Referenced by initFcn().
real * moab::SpectralHex::_z [static, protected]
Definition at line 79 of file SpectralHex.hpp.
Referenced by moab::Element::SpectralHex::freedata(), and initFcn().
bool moab::SpectralHex::init_ [static, protected]
Definition at line 83 of file SpectralHex.hpp.
List of all members.
