moab::SplitVerticesBase Class Reference
#include <SplitVertices.hpp>
+ Inheritance diagram for moab::SplitVerticesBase:
+ Collaboration diagram for moab::SplitVerticesBase:
Public Member Functions
 SplitVerticesBase (RefinerTagManager *tag_mgr)
virtual ~SplitVerticesBase ()
virtual bool find_or_create (const EntityHandle *split_src, const double *coords, EntityHandle &vert_handle, std::map< ProcessSet, int > &proc_partition_counts, bool handles_on_output_mesh)=0
virtual void assign_global_ids (std::map< ProcessSet, int > &gids)=0
Public Attributes
Interfacemesh_out
RefinerTagManagertag_manager
std::vector< int > split_gids
ProcessSet common_shared_procs
Detailed Description
A non-templated base class that the SplitVertices template subclasses all share.
All methods that need to be accessed by other classes should be declared by the base class so that no knowledge of template parameters is required.
Definition at line 167 of file SplitVertices.hpp.
Definition at line 9 of file SplitVertices.cpp.
References moab::RefinerTagManager::get_output_mesh(), mesh_out, and tag_manager.
    this->tag_manager = tag_mgr;
    this->mesh_out    = tag_mgr->get_output_mesh();
Definition at line 15 of file SplitVertices.cpp.
Member Function Documentation
virtual void moab::SplitVerticesBase::assign_global_ids ( std::map< ProcessSet, int > &  gids) [pure virtual]
Implemented in moab::SplitVertices< _n >.
virtual bool moab::SplitVerticesBase::find_or_create ( const EntityHandle split_src,
const double *  coords,
EntityHandle vert_handle,
std::map< ProcessSet, int > &  proc_partition_counts,
) [pure virtual]
Member Data Documentation
Definition at line 183 of file SplitVertices.hpp.
Referenced by moab::SplitVertices< _n >::SplitVertices().
List of all members.
