moab::StructuredElementSeq Class Reference
#include <StructuredElementSeq.hpp>
+ Inheritance diagram for moab::StructuredElementSeq:
+ Collaboration diagram for moab::StructuredElementSeq:
Public Member Functions
 StructuredElementSeq (EntityHandle start_handle, const int imin, const int jmin, const int kmin, const int imax, const int jmax, const int kmax, int *is_periodic=NULL)
 constructor
virtual ~StructuredElementSeq ()
ScdElementDatasdata ()
ScdElementData const * sdata () const
EntityHandle get_vertex (const int i, const int j, const int k) const
 get handle of vertex at i, j, k
EntityHandle get_vertex (const HomCoord &coords) const
 get handle of vertex at homogeneous coords
EntityHandle get_element (const int i, const int j, const int k) const
 get handle of element at i, j, k
EntityHandle get_element (const HomCoord &coords) const
 get handle of element at homogeneous coords
const HomCoordmin_params () const
 get min params for this element
void min_params (HomCoord &coords) const
void min_params (int &i, int &j, int &k) const
const HomCoordmax_params () const
 get max params for this element
void max_params (HomCoord &coords) const
void max_params (int &i, int &j, int &k) const
void param_extents (int &di, int &dj, int &dk) const
 get the number of vertices in each direction, inclusive
ErrorCode get_params (const EntityHandle ehandle, int &i, int &j, int &k) const
 given a handle, get the corresponding parameters
int i_min () const
 convenience functions for parameter extents
int j_min () const
int k_min () const
int i_max () const
int j_max () const
int k_max () const
bool boundary_complete () const
 test the bounding vertex sequences and determine whether they fully define the vertices covering this element block's parameter space
bool contains (const int i, const int j, const int k) const
 test whether this sequence contains these parameters
bool contains (const HomCoord &coords) const
ErrorCode get_params_connectivity (const int i, const int j, const int k, std::vector< EntityHandle > &connectivity) const
 get connectivity of an entity given entity's parameters
int is_periodic_i () const
 Return whether box is periodic in i.
int is_periodic_j () const
 Return whether box is periodic in j.
void is_periodic (int is_periodic_ij[2]) const
 Return whether box is periodic in i and j.
virtual ErrorCode get_connectivity (EntityHandle handle, std::vector< EntityHandle > &connect, bool topological=false) const
virtual ErrorCode get_connectivity (EntityHandle handle, EntityHandle const *&connect, int &connect_length, bool topological=false, std::vector< EntityHandle > *storage=0) const
virtual ErrorCode set_connectivity (EntityHandle handle, EntityHandle const *connect, int connect_length)
virtual EntityHandleget_connectivity_array ()
virtual int values_per_entity () const
 Integer value used in finding appropriate SequenceData.
virtual EntitySequencesplit (EntityHandle here)
 Split this sequence into two consecutive sequences.
virtual SequenceDatacreate_data_subset (EntityHandle start_handle, EntityHandle end_handle) const
 Create a new SequenceData that is a copy of a subset of the one referenced by this sequence.
virtual void get_const_memory_use (unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const
 Get memory characteristcs that are the same for all entities.
Protected Member Functions
 StructuredElementSeq (StructuredElementSeq &split_from, EntityHandle here)
Detailed Description
Definition at line 36 of file StructuredElementSeq.hpp.
moab::StructuredElementSeq::StructuredElementSeq ( EntityHandle  start_handle,
const int  imin,
const int  jmin,
const int  kmin,
const int  imax,
const int  jmax,
const int  kmax,
int *  is_periodic = NULL
constructor
Definition at line 27 of file StructuredElementSeq.cpp.
Referenced by split().
    : ElementSequence( shandle,
                       ScdElementData::calc_num_entities( shandle, imax - imin, jmax - jmin, kmax - kmin, is_per ),
                       CN::VerticesPerEntity( TYPE_FROM_HANDLE( shandle ) ),
                       new ScdElementData( shandle, imin, jmin, kmin, imax, jmax, kmax, is_per ) )
Definition at line 238 of file StructuredElementSeq.hpp.
: ElementSequence( split_from, here ) {}
Member Function Documentation
Definition at line 156 of file StructuredElementSeq.hpp.
References moab::ScdElementData::boundary_complete(), and sdata().
Referenced by moab::ScdBox::boundary_complete().
        return sdata()->boundary_complete();
bool moab::StructuredElementSeq::contains ( const int  i,
const int  j,
const int  k
) const [inline]
Definition at line 162 of file StructuredElementSeq.hpp.
References moab::ScdElementData::contains(), and sdata().
        return sdata()->contains( HomCoord( i, j, k ) );
bool moab::StructuredElementSeq::contains ( const HomCoord coords) const [inline]
Definition at line 166 of file StructuredElementSeq.hpp.
        return sdata()->contains( coords );
SequenceData * moab::StructuredElementSeq::create_data_subset ( EntityHandle  start_handle,
) const [virtual]
Create a new SequenceData that is a copy of a subset of the SequenceData referenced by this EntitySequence. Do not make any changes to this EntitySequence or the current SequenceData.
Implements moab::EntitySequence.
Definition at line 94 of file StructuredElementSeq.cpp.
    return 0;
ErrorCode moab::StructuredElementSeq::get_connectivity ( EntityHandle  handle,
std::vector< EntityHandle > &  connect,
bool  topological = false
) const [virtual]
Implements moab::ElementSequence.
Definition at line 44 of file StructuredElementSeq.cpp.
References ErrorCode, get_params(), get_params_connectivity(), and MB_SUCCESS.
Referenced by get_connectivity().
    int i, j, k;
    ErrorCode rval = get_params( handle, i, j, k );
    if( MB_SUCCESS == rval ) rval = get_params_connectivity( i, j, k, connect );
    return rval;
EntityHandle const *&  connect,
int &  connect_length,
bool  topological = false,
std::vector< EntityHandle > *  storage = 0
) const [virtual]
Definition at line 54 of file StructuredElementSeq.cpp.
References ErrorCode, get_connectivity(), and MB_STRUCTURED_MESH.
    if( !storage )
        connect        = 0;
        connect_length = 0;
        return MB_STRUCTURED_MESH;
    storage->clear();
    ErrorCode rval = get_connectivity( handle, *storage, topo );
    connect        = &( *storage )[0];
    connect_length = storage->size();
    return rval;
Definition at line 79 of file StructuredElementSeq.cpp.
    return 0;
void moab::StructuredElementSeq::get_const_memory_use ( unsigned long &  bytes_per_entity,
unsigned long &  size_of_sequence
) const [virtual]
Get charactersitic constant memory use for all entities in sequence.
Parameters:
bytes_per_entityThe total bytes consumed for each entity in the underlying SequenceData. It is assumed that the same amount of memory is consumed for unused portions of the SequenceData.
size_of_sequenceThe size of the leaf subclass of this class
Definition at line 99 of file StructuredElementSeq.cpp.
References moab::ScdElementData::get_memory_use(), sdata(), and moab::SequenceData::size().
    sequence_size    = sizeof( *this );
    bytes_per_entity = sdata()->get_memory_use() / sdata()->size();
EntityHandle moab::StructuredElementSeq::get_element ( const int  i,
const int  j,
const int  k
) const [inline]
Definition at line 73 of file StructuredElementSeq.hpp.
References moab::ScdElementData::get_element(), and sdata().
        return sdata()->get_element( i, j, k );
Definition at line 79 of file StructuredElementSeq.hpp.
References moab::ScdElementData::get_element(), moab::HomCoord::i(), moab::HomCoord::j(), moab::HomCoord::k(), and sdata().
        return sdata()->get_element( coords.i(), coords.j(), coords.k() );
ErrorCode moab::StructuredElementSeq::get_params ( const EntityHandle  ehandle,
int &  i,
int &  j,
int &  k
) const [inline]
Definition at line 123 of file StructuredElementSeq.hpp.
References moab::ScdElementData::get_params(), and sdata().
Referenced by get_connectivity(), and moab::ScdBox::get_params().
        return sdata()->get_params( ehandle, i, j, k );
ErrorCode moab::StructuredElementSeq::get_params_connectivity ( const int  i,
const int  j,
const int  k,
std::vector< EntityHandle > &  connectivity
) const [inline]
Definition at line 172 of file StructuredElementSeq.hpp.
References moab::ScdElementData::get_params_connectivity(), and sdata().
        return sdata()->get_params_connectivity( i, j, k, connectivity );
EntityHandle moab::StructuredElementSeq::get_vertex ( const int  i,
const int  j,
const int  k
) const [inline]
Definition at line 61 of file StructuredElementSeq.hpp.
Referenced by moab::ScdBox::get_vertex_from_seq().
        return get_vertex( HomCoord( i, j, k ) );
EntityHandle moab::StructuredElementSeq::get_vertex ( const HomCoord coords) const [inline]
Definition at line 67 of file StructuredElementSeq.hpp.
References moab::ScdElementData::get_vertex(), and sdata().
        return sdata()->get_vertex( coords );
int moab::StructuredElementSeq::i_max ( ) const [inline]
Definition at line 141 of file StructuredElementSeq.hpp.
References moab::HomCoord::i(), and max_params().
        return max_params().i();
int moab::StructuredElementSeq::i_min ( ) const [inline]
Definition at line 129 of file StructuredElementSeq.hpp.
References moab::HomCoord::i(), and min_params().
        return min_params().i();
void moab::StructuredElementSeq::is_periodic ( int  is_periodic_ij[2]) const [inline]
Parameters:
is_periodic_ijNon-zero if periodic in i [0] or j [1]
Definition at line 202 of file StructuredElementSeq.hpp.
References moab::ScdElementData::is_periodic(), and sdata().
Referenced by moab::ScdBox::elem_seq().
        sdata()->is_periodic( is_periodic_ij );
Returns:
True if box is periodic in i direction
Definition at line 184 of file StructuredElementSeq.hpp.
References moab::ScdElementData::is_periodic_i(), and sdata().
        return sdata()->is_periodic_i();
Returns:
True if box is periodic in j direction
Definition at line 193 of file StructuredElementSeq.hpp.
References moab::ScdElementData::is_periodic_j(), and sdata().
        return sdata()->is_periodic_j();
int moab::StructuredElementSeq::j_max ( ) const [inline]
Definition at line 145 of file StructuredElementSeq.hpp.
References moab::HomCoord::j(), and max_params().
        return max_params().j();
int moab::StructuredElementSeq::j_min ( ) const [inline]
Definition at line 133 of file StructuredElementSeq.hpp.
References moab::HomCoord::j(), and min_params().
        return min_params().j();
int moab::StructuredElementSeq::k_max ( ) const [inline]
Definition at line 149 of file StructuredElementSeq.hpp.
References moab::HomCoord::k(), and max_params().
        return max_params().k();
int moab::StructuredElementSeq::k_min ( ) const [inline]
Definition at line 137 of file StructuredElementSeq.hpp.
References moab::HomCoord::k(), and min_params().
        return min_params().k();
Definition at line 101 of file StructuredElementSeq.hpp.
References moab::ScdElementData::max_params(), and sdata().
Referenced by i_max(), j_max(), k_max(), and max_params().
        return sdata()->max_params();
void moab::StructuredElementSeq::max_params ( HomCoord coords) const [inline]
Definition at line 105 of file StructuredElementSeq.hpp.
References max_params().
        coords = max_params();
void moab::StructuredElementSeq::max_params ( int &  i,
int &  j,
int &  k
) const [inline]
Definition at line 109 of file StructuredElementSeq.hpp.
References moab::HomCoord::i(), moab::HomCoord::j(), moab::HomCoord::k(), and max_params().
        i = max_params().i();
        j = max_params().j();
        k = max_params().k();
Definition at line 85 of file StructuredElementSeq.hpp.
References moab::ScdElementData::min_params(), and sdata().
Referenced by i_min(), j_min(), k_min(), and min_params().
        return sdata()->min_params();
void moab::StructuredElementSeq::min_params ( HomCoord coords) const [inline]
Definition at line 89 of file StructuredElementSeq.hpp.
References min_params().
        coords = min_params();
void moab::StructuredElementSeq::min_params ( int &  i,
int &  j,
int &  k
) const [inline]
Definition at line 93 of file StructuredElementSeq.hpp.
References moab::HomCoord::i(), moab::HomCoord::j(), moab::HomCoord::k(), and min_params().
        i = min_params().i();
        j = min_params().j();
        k = min_params().k();
void moab::StructuredElementSeq::param_extents ( int &  di,
int &  dj,
int &  dk
) const [inline]
Definition at line 117 of file StructuredElementSeq.hpp.
References moab::ScdElementData::param_extents(), and sdata().
        sdata()->param_extents( di, dj, dk );
Definition at line 55 of file StructuredElementSeq.hpp.
References moab::EntitySequence::data().
        return reinterpret_cast< const ScdElementData* >( data() );
ErrorCode moab::StructuredElementSeq::set_connectivity ( EntityHandle  handle,
EntityHandle const *  connect,
int  connect_length
) [virtual]
Definition at line 74 of file StructuredElementSeq.cpp.
References MB_STRUCTURED_MESH.
Split this sequence into two sequences.
Parameters:
hereNew sequences should be [start_handle(),here) & [here,end_handle()]
Returns:
New sequence containing [here,end_handle()]
Definition at line 89 of file StructuredElementSeq.cpp.
References StructuredElementSeq().
    return new StructuredElementSeq( *this, here );
This value is matched to input values by TypeSequenceManager to determine if an available, unused portino of a SequenceData can be used for a specific entity allocation. For example, it is used to find a SequenceData with the appropriate number of vertices per element when allocating elements. The default value is zero.
Reimplemented from moab::EntitySequence.
Definition at line 84 of file StructuredElementSeq.cpp.
    return -1;
}  // never reuse freed handles for structured elements
List of all members.
