moab::TempestRemapper Member List
This is the complete list of members for moab::TempestRemapper, including all inherited members.
assign_vertex_element_IDs(Tag idtag, EntityHandle this_set, const int dimension=2, const int start_id=1)moab::TempestRemapper
augment_overlap_set()moab::TempestRemapper [private]
clear()moab::TempestRemapper [virtual]
ComputeGlobalLocalMaps()moab::TempestRemapper
ComputeOverlapMesh(bool kdtree_search=true, bool use_tempest=false)moab::TempestRemapper
ConstructCoveringSet(double tolerance=1e-8, double radius_src=1.0, double radius_tgt=1.0, double boxeps=0.1, bool regional_mesh=false)moab::TempestRemapper
constructEdgeMapmoab::TempestRemapper
convert_mesh_to_tempest_private(Mesh *mesh, moab::EntityHandle meshset, moab::Range &entities, moab::Range *pverts)moab::TempestRemapper [private]
convert_overlap_mesh_sorted_by_source()moab::TempestRemapper [private]
convert_tempest_mesh_private(TempestMeshType type, Mesh *mesh, moab::EntityHandle &meshset, moab::Range &entities, moab::Range *vertices)moab::TempestRemapper [private]
ConvertMeshToTempest(Remapper::IntersectionContext ctx)moab::TempestRemapper
ConvertTempestMesh(Remapper::IntersectionContext ctx)moab::TempestRemapper
CoveringMesh enum valuemoab::Remapper
CS enum valuemoab::TempestRemapper
DEFAULT enum valuemoab::TempestRemapper
GenerateCSMeshMetadata(const int ntot_elements, moab::Range &entities, moab::Range *secondary_entities, const std::string &dofTagName, int nP)moab::TempestRemapper
GenerateMesh(Remapper::IntersectionContext ctx, TempestMeshType type)moab::TempestRemapper
GenerateMeshMetadata(Mesh &mesh, const int ntot_elements, moab::Range &entities, moab::Range *secondary_entities, const std::string dofTagName, int nP)moab::TempestRemapper
get_interface()moab::Remapper [inline]
get_intx_name()moab::TempestRemapper [inline]
GetCoveringMesh()moab::TempestRemapper [inline]
GetCoveringSet()moab::TempestRemapper [inline]
GetGlobalID(Remapper::IntersectionContext ctx, int localID)moab::TempestRemapper [inline]
GetIMasks(Remapper::IntersectionContext ctx, std::vector< int > &masks)moab::TempestRemapper
GetLocalID(Remapper::IntersectionContext ctx, int globalID)moab::TempestRemapper [inline]
GetMesh(Remapper::IntersectionContext ctx)moab::TempestRemapper [inline]
GetMeshEntities(Remapper::IntersectionContext ctx)moab::TempestRemapper [inline]
GetMeshEntities(Remapper::IntersectionContext ctx) const moab::TempestRemapper [inline]
GetMeshSet(Remapper::IntersectionContext ctx)moab::TempestRemapper [inline]
GetMeshSet(Remapper::IntersectionContext ctx) const moab::TempestRemapper [inline]
GetMeshType(Remapper::IntersectionContext ctx) const moab::TempestRemapper [inline]
GetMeshVertices(Remapper::IntersectionContext ctx)moab::TempestRemapper [inline]
GetMeshVertices(Remapper::IntersectionContext ctx) const moab::TempestRemapper [inline]
GetOverlapAugmentedEntities(moab::Range &sharedGhostEntities)moab::TempestRemapper
gid_to_lid_covsrcmoab::TempestRemapper [private]
gid_to_lid_srcmoab::TempestRemapper [private]
gid_to_lid_tgtmoab::TempestRemapper [private]
ICO enum valuemoab::TempestRemapper
ICOD enum valuemoab::TempestRemapper
initialize(bool initialize_fsets=true)moab::TempestRemapper [virtual]
IntersectionContext enum namemoab::Remapper
intx_namemoab::TempestRemapper [private]
is_parallelmoab::TempestRemapper [private]
is_rootmoab::TempestRemapper [private]
lid_to_gid_covsrcmoab::TempestRemapper [private]
lid_to_gid_srcmoab::TempestRemapper [private]
lid_to_gid_tgtmoab::TempestRemapper [private]
load_tempest_mesh_private(std::string inputFilename, Mesh **tempest_mesh)moab::TempestRemapper [private]
LoadMesh(Remapper::IntersectionContext ctx, std::string inputFilename, TempestMeshType type)moab::TempestRemapper
LoadNativeMesh(std::string filename, moab::EntityHandle &meshset, std::vector< int > &metadata, const char *readopts=0)moab::Remapper [inline]
m_area_methodmoab::TempestRemapper [private]
m_covering_sourcemoab::TempestRemapper [private]
m_covering_source_entitiesmoab::TempestRemapper [private]
m_covering_source_setmoab::TempestRemapper [private]
m_covering_source_verticesmoab::TempestRemapper [private]
m_interfacemoab::Remapper [protected]
m_overlapmoab::TempestRemapper [private]
m_overlap_entitiesmoab::TempestRemapper [private]
m_overlap_setmoab::TempestRemapper [private]
m_overlap_typemoab::TempestRemapper [private]
m_sorted_overlap_ordermoab::TempestRemapper [private]
m_sourcemoab::TempestRemapper [private]
m_source_entitiesmoab::TempestRemapper [private]
m_source_metadatamoab::TempestRemapper [private]
m_source_setmoab::TempestRemapper [private]
m_source_typemoab::TempestRemapper [private]
m_source_verticesmoab::TempestRemapper [private]
m_targetmoab::TempestRemapper [private]
m_target_entitiesmoab::TempestRemapper [private]
m_target_metadatamoab::TempestRemapper [private]
m_target_setmoab::TempestRemapper [private]
m_target_typemoab::TempestRemapper [private]
m_target_verticesmoab::TempestRemapper [private]
max_source_edgesmoab::TempestRemapper [private]
max_target_edgesmoab::TempestRemapper [private]
mbintxmoab::TempestRemapper [private]
meshValidatemoab::TempestRemapper
OVERLAP_FILES enum valuemoab::TempestRemapper
OVERLAP_MEMORY enum valuemoab::TempestRemapper
OVERLAP_MOAB enum valuemoab::TempestRemapper
OverlapMesh enum valuemoab::Remapper
point_cloud_sourcemoab::TempestRemapper [private]
point_cloud_targetmoab::TempestRemapper [private]
rankmoab::TempestRemapper [private]
Remapper(moab::Interface *mbInt)moab::Remapper [inline]
RLL enum valuemoab::TempestRemapper
rrmgridsmoab::TempestRemapper [private]
set_intx_name(std::string in)moab::TempestRemapper [inline]
SetMesh(Remapper::IntersectionContext ctx, Mesh *mesh, bool overwrite=true)moab::TempestRemapper [inline]
SetMeshSet(Remapper::IntersectionContext ctx, moab::EntityHandle mset, moab::Range &entities)moab::TempestRemapper
SetMeshType(Remapper::IntersectionContext ctx, TempestMeshType type, const std::vector< int > *metadata=nullptr)moab::TempestRemapper [inline]
sizemoab::TempestRemapper [private]
SourceMesh enum valuemoab::Remapper
TargetMesh enum valuemoab::Remapper
TempestMeshType enum namemoab::TempestRemapper
TempestOnlineMap classmoab::TempestRemapper [friend]
TempestRemapper(moab::Interface *mbInt)moab::TempestRemapper [inline]
verbosemoab::TempestRemapper [static]
WriteTempestIntersectionMesh(std::string strOutputFileName, const bool fAllParallel, const bool fInputConcave, const bool fOutputConcave)moab::TempestRemapper
~Remapper()moab::Remapper [inline, virtual]
~TempestRemapper()moab::TempestRemapper [virtual]
