moab::Tqdcfr::NodesetHeader Class Reference
#include <Tqdcfr.hpp>
Public Member Functions
void print ()
 NodesetHeader ()
Static Public Member Functions
static ErrorCode read_info_header (const unsigned int model_offset, const FEModelHeader::ArrayInfo &info, Tqdcfr *instance, NodesetHeader *&entity_headers)
Public Attributes
unsigned int nsID
unsigned int memCt
unsigned int memOffset
unsigned int memTypeCt
unsigned int pointSym
unsigned int nsCol
unsigned int nsLength
EntityHandle setHandle
Detailed Description
Definition at line 177 of file Tqdcfr.hpp.
Definition at line 2958 of file Tqdcfr.cpp.
    : nsID( 0 ), memCt( 0 ), memOffset( 0 ), memTypeCt( 0 ), pointSym( 0 ), nsCol( 0 ), nsLength( 0 ), setHandle( 0 )
Member Function Documentation
Definition at line 2963 of file Tqdcfr.cpp.
Referenced by moab::Tqdcfr::read_nodeset().
    std::cout << "nsID = " << nsID << std::endl;
    std::cout << "memCt = " << memCt << std::endl;
    std::cout << "memOffset = " << memOffset << std::endl;
    std::cout << "memTypeCt = " << memTypeCt << std::endl;
    std::cout << "pointSym = " << pointSym << std::endl;
    std::cout << "nsCol = " << nsCol << std::endl;
    std::cout << "nsLength = " << nsLength << std::endl;
    std::cout << "setHandle = " << setHandle << std::endl;
ErrorCode moab::Tqdcfr::NodesetHeader::read_info_header ( const unsigned int  model_offset,
const FEModelHeader::ArrayInfo info,
Tqdcfr instance,
Tqdcfr::NodesetHeader *&  nodeset_headers
) [static]
Definition at line 2123 of file Tqdcfr.cpp.
References CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, moab::Tqdcfr::categoryTag, moab::Tqdcfr::create_set(), ErrorCode, moab::Tqdcfr::FREADI(), moab::Tqdcfr::FSEEK(), moab::Tqdcfr::globalIdTag, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, moab::Tqdcfr::mdbImpl, memCt, memOffset, memTypeCt, nsCol, nsID, nsLength, moab::Tqdcfr::nsTag, moab::Tqdcfr::FEModelHeader::ArrayInfo::numEntities, pointSym, setHandle, moab::Tqdcfr::FEModelHeader::ArrayInfo::tableOffset, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Tqdcfr::uint_buf.
Referenced by moab::Tqdcfr::ModelEntry::read_header_info().
    nodeset_headers = new NodesetHeader[info.numEntities];
    instance->FSEEK( model_offset + info.tableOffset );
    ErrorCode result;
    if( 0 == instance->categoryTag )
        static const char val[CATEGORY_TAG_SIZE] = { 0 };
        result = instance->mdbImpl->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE,
                                                    instance->categoryTag, MB_TAG_SPARSE | MB_TAG_CREAT, val );
        if( MB_SUCCESS != result ) return result;
    for( unsigned int i = 0; i < info.numEntities; i++ )
        // Create an entity set for this entity
        result = instance->create_set( nodeset_headers[i].setHandle );
        static const char dirichlet_category[CATEGORY_TAG_SIZE] = "Dirichlet Set\0";
        instance->FREADI( 8 );
        nodeset_headers[i].nsID      = instance->uint_buf[0];
        nodeset_headers[i].memCt     = instance->uint_buf[1];
        nodeset_headers[i].memOffset = instance->uint_buf[2];
        nodeset_headers[i].memTypeCt = instance->uint_buf[3];
        nodeset_headers[i].pointSym  = instance->uint_buf[4];  // Point sym
        nodeset_headers[i].nsCol     = instance->uint_buf[5];
        nodeset_headers[i].nsLength  = instance->uint_buf[6];
        // Pad
        // Set the dirichlet set tag and id tag both to id
        result = instance->mdbImpl->tag_set_data( instance->nsTag, &( nodeset_headers[i].setHandle ), 1,
                                                  &( nodeset_headers[i].nsID ) );
        result = instance->mdbImpl->tag_set_data( instance->globalIdTag, &( nodeset_headers[i].setHandle ), 1,
        result = instance->mdbImpl->tag_set_data( instance->categoryTag, &( nodeset_headers[i].setHandle ), 1,
                                                  dirichlet_category );
    return MB_SUCCESS;
Member Data Documentation
Definition at line 180 of file Tqdcfr.hpp.
Referenced by read_info_header().
Referenced by read_info_header(), and moab::Tqdcfr::read_nodeset().
List of all members.
