moab::Tree Class Reference
Parent class of various tree types in MOAB. More...
#include <Tree.hpp>
+ Inheritance diagram for moab::Tree:
+ Collaboration diagram for moab::Tree:
Public Member Functions
 Tree (Interface *iface)
 Constructor (bare)
virtual ~Tree ()
 Destructor.
virtual ErrorCode reset_tree ()=0
 Destroy the tree maintained by this object, optionally checking we have the right root.
ErrorCode delete_tree_sets ()
 Delete the entity sets associated with the tree, starting with the root and traversing children.
virtual ErrorCode build_tree (const Range &entities, EntityHandle *tree_root_set=NULL, FileOptions *options=NULL)=0
virtual ErrorCode get_bounding_box (BoundBox &box, EntityHandle *tree_node=NULL) const
 Get bounding box for tree below tree_node, or entire tree If no tree has been built yet, returns +/- DBL_MAX for all dimensions. Note for some tree types, boxes are not available for non-root nodes, and this function will return failure if non-root is passed in.
virtual ErrorCode get_info (EntityHandle root, double min[3], double max[3], unsigned int &max_dep)
 Return some basic information about the tree Stats are returned for tree starting from input node or tree root (root = 0)
ErrorCode find_all_trees (Range &results)
 Find all trees, by bounding box tag.
virtual ErrorCode point_search (const double *point, EntityHandle &leaf_out, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, bool *multiple_leaves=NULL, EntityHandle *start_node=NULL, CartVect *params=NULL)=0
 Get leaf containing input position.
virtual ErrorCode distance_search (const double *point, const double distance, std::vector< EntityHandle > &leaves_out, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, std::vector< double > *dists_out=NULL, std::vector< CartVect > *params_out=NULL, EntityHandle *start_node=NULL)=0
 Find all leaves within a given distance from point If dists_out input non-NULL, also returns distances from each leaf; if point i is inside leaf, 0 is given as dists_out[i]. If params_out is non-NULL and myEval is non-NULL, will evaluate individual entities in tree nodes and return containing entities in leaves_out. In those cases, if params_out is also non-NULL, will return parameters in those elements in that vector.
Interfacemoab ()
 Return the MOAB interface associated with this tree.
const Interfacemoab () const
double get_max_depth ()
 Get max depth set on tree.
double get_max_per_leaf ()
 Get max entities per leaf set on tree.
TreeStatstree_stats ()
 Get tree traversal stats object.
const TreeStatstree_stats () const
ErrorCode create_root (const double box_min[3], const double box_max[3], EntityHandle &root_handle)
 Create tree root and tag with bounding box.
virtual ErrorCode print ()=0
 print various things about this tree
ElemEvaluatorget_eval ()
 get/set the ElemEvaluator
void set_eval (ElemEvaluator *eval)
virtual ErrorCode parse_options (FileOptions &opts)=0
 Parse options for this tree, including common options for all trees.
Protected Member Functions
ErrorCode parse_common_options (FileOptions &options)
 Parse options common to all trees.
Tag get_box_tag (bool create_if_missing=true)
 Get the box tag, possibly constructing it first.
Protected Attributes
InterfacembImpl
BoundBox boundBox
int maxPerLeaf
int maxDepth
int treeDepth
double minWidth
unsigned int meshsetFlags
bool cleanUp
EntityHandle myRoot
Tag boxTag
std::string boxTagName
TreeStats treeStats
ElemEvaluatormyEval
Detailed Description
Definition at line 27 of file Tree.hpp.
moab::Tree::Tree ( Interface iface) [inline]
Constructor (bare)
Parameters:
ifaceMOAB instance
Definition at line 257 of file Tree.hpp.
    : mbImpl( iface ), maxPerLeaf( 6 ), maxDepth( 30 ), treeDepth( -1 ), minWidth( 1.0e-10 ), meshsetFlags( 0 ),
      cleanUp( true ), myRoot( 0 ), boxTag( 0 ), myEval( 0 )
moab::Tree::~Tree ( ) [inline, virtual]
Destructor.
Definition at line 263 of file Tree.hpp.
Member Function Documentation
virtual ErrorCode moab::Tree::build_tree ( const Range entities,
EntityHandle tree_root_set = NULL,
FileOptions options = NULL
) [pure virtual]
Build the tree Build a tree with the entities input. If a non-NULL tree_root_set pointer is input, use the pointed-to set as the root of this tree (*tree_root_set!=0) otherwise construct a new root set and pass its handle back in *tree_root_set. Options vary by tree type, with a few common to all types of trees. Common options: MAX_PER_LEAF: max entities per leaf; default = 6 MAX_DEPTH: max depth of the tree; default = 30 MIN_WIDTH: minimum width of box, used like a tolerance; default = 1.0e-10 MESHSET_FLAGS: flags passed into meshset creation for tree nodes; should be a value from ENTITY_SET_PROPERTY (see Types.hpp); default = MESHSET_SET CLEAN_UP: if false, do not delete tree sets upon tree class destruction; default = true TAG_NAME: tag name to store tree information on tree nodes; default determined by tree type
Parameters:
entitiesEntities with which to build the tree
tree_rootRoot set for tree (see function description)
optsOptions for tree (see function description)
Returns:
Error is returned only on build failure
Implemented in moab::BVHTree, and moab::AdaptiveKDTree.
Referenced by moab::SpatialLocator::add_elems(), and moab::SpatialLocator::SpatialLocator().
ErrorCode moab::Tree::create_root ( const double  box_min[3],
EntityHandle root_handle
Definition at line 63 of file Tree.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, boundBox, box_max(), box_min(), moab::Interface::create_meshset(), ErrorCode, get_box_tag(), MB_SUCCESS, mbImpl, meshsetFlags, myRoot, and moab::Interface::tag_set_data().
Referenced by moab::AdaptiveKDTree::build_tree(), and moab::BVHTree::build_tree().
    ErrorCode rval = mbImpl->create_meshset( meshsetFlags, root_handle );
    if( MB_SUCCESS != rval ) return rval;
    myRoot = root_handle;
    double box_tag[6];
    for( int i = 0; i < 3; i++ )
        box_tag[i]     = box_min[i];
        box_tag[3 + i] = box_max[i];
    rval = mbImpl->tag_set_data( get_box_tag(), &root_handle, 1, box_tag );
    boundBox.bMin = box_min;
    boundBox.bMax = box_max;
    return MB_SUCCESS;
Definition at line 85 of file Tree.cpp.
References boxTag, children, moab::Interface::delete_entities(), ErrorCode, moab::Interface::get_child_meshsets(), MB_SUCCESS, mbImpl, myRoot, and moab::Interface::tag_delete_data().
Referenced by moab::BVHTree::reset_tree(), and moab::AdaptiveKDTree::reset_tree().
    if( !myRoot ) return MB_SUCCESS;
    ErrorCode rval;
    std::vector< EntityHandle > children, dead_sets, current_sets;
    current_sets.push_back( myRoot );
    while( !current_sets.empty() )
        EntityHandle set = current_sets.back();
        current_sets.pop_back();
        dead_sets.push_back( set );
        rval = mbImpl->get_child_meshsets( set, children );
        std::copy( children.begin(), children.end(), std::back_inserter( current_sets ) );
        children.clear();
    rval = mbImpl->tag_delete_data( boxTag, &myRoot, 1 );
    rval = mbImpl->delete_entities( &dead_sets[0], dead_sets.size() );
    myRoot = 0;
    return MB_SUCCESS;
virtual ErrorCode moab::Tree::distance_search ( const double *  point,
std::vector< EntityHandle > &  leaves_out,
const double  iter_tol = 1.0e-10,
const double  inside_tol = 1.0e-6,
std::vector< double > *  dists_out = NULL,
std::vector< CartVect > *  params_out = NULL,
EntityHandle start_node = NULL
) [pure virtual]
Parameters:
pointPoint to be located in tree
distanceDistance within which to query
leaves_outLeaves within distance or containing point
iter_tolTolerance for convergence of point search
inside_tolTolerance for inside element calculation
dists_outIf non-NULL, will contain distsances to leaves
params_outIf non-NULL, will contain parameters of the point in the ents in leaves_out
start_nodeStart from this tree node (non-NULL) instead of tree root (NULL)
Implemented in moab::AdaptiveKDTree.
Definition at line 47 of file Tree.cpp.
References moab::Range::begin(), boundBox, moab::Range::empty(), ErrorCode, get_box_tag(), moab::Interface::get_entities_by_type_and_tag(), MB_SUCCESS, MBENTITYSET, moab(), myRoot, moab::Range::size(), moab::Interface::tag_get_data(), and moab::BoundBox::update().
Referenced by main().
    Tag tag        = get_box_tag();
    ErrorCode rval = moab()->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, results );
    if( MB_SUCCESS != rval || results.empty() ) return rval;
    std::vector< BoundBox > boxes( results.size() );
    rval = moab()->tag_get_data( tag, results, &boxes[0] );
    for( std::vector< BoundBox >::iterator vit = boxes.begin(); vit != boxes.end(); ++vit )
        boundBox.update( *vit );
    if( results.size() == 1 ) myRoot = *results.begin();
    return MB_SUCCESS;
ErrorCode moab::Tree::get_bounding_box ( BoundBox box,
EntityHandle tree_node = NULL
) const [inline, virtual]
Parameters:
boxThe box for this tree
tree_nodeIf non-NULL, node for which box is requested, tree root if NULL
Returns:
Only returns error on fatal condition
Reimplemented in moab::BVHTree.
Definition at line 265 of file Tree.hpp.
References boundBox, MB_SUCCESS, and myRoot.
Referenced by moab::AdaptiveKDTree::distance_search(), moab::AdaptiveKDTree::get_info(), moab::Coupler::initialize_tree(), moab::AdaptiveKDTree::point_search(), moab::AdaptiveKDTree::print(), moab::AdaptiveKDTree::ray_intersect_triangles(), moab::SpatialLocator::SpatialLocator(), and moab::Coupler::test_local_box().
    if( ( tree_node && *tree_node == myRoot ) || !tree_node )
        box = boundBox;
        return MB_SUCCESS;
    else
        return MB_FAILURE;
Tag moab::Tree::get_box_tag ( bool  create_if_missing = true) [inline, protected]
Parameters:
create_if_missingIf true and it has not been made yet, make it
Definition at line 284 of file Tree.hpp.
References boxTag, boxTagName, ErrorCode, MB_INVALID_SIZE, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_DOUBLE, moab(), moab::Interface::tag_delete(), and moab::Interface::tag_get_handle().
Referenced by create_root(), and find_all_trees().
    if( !boxTag && create_if_missing )
        assert( boxTagName.length() > 0 );
        ErrorCode rval =
            moab()->tag_get_handle( boxTagName.c_str(), 6, MB_TYPE_DOUBLE, boxTag, MB_TAG_CREAT | MB_TAG_SPARSE );
        if( MB_INVALID_SIZE == rval )
            // delete the tag and get it again, legacy file...
            rval = moab()->tag_delete( boxTag );
            if( MB_SUCCESS != rval ) return 0;
            boxTag = 0;
            return get_box_tag( true );
    return boxTag;
Definition at line 187 of file Tree.hpp.
References myEval.
Referenced by moab::SpatialLocator::locate_points().
        return myEval;
ErrorCode moab::Tree::get_info ( EntityHandle  root,
double  min[3],
double  max[3],
unsigned int &  max_dep
) [inline, virtual]
Parameters:
rootIf non-0, give stats below and including root
minMinimum corner of bounding box
maxMaximum corner of bounding box
max_depMaximum depth of tree below root
Reimplemented in moab::AdaptiveKDTree.
Definition at line 276 of file Tree.hpp.
References MB_NOT_IMPLEMENTED.
    return MB_NOT_IMPLEMENTED;
double moab::Tree::get_max_depth ( ) [inline]
Definition at line 156 of file Tree.hpp.
References maxDepth.
        return maxDepth;
double moab::Tree::get_max_per_leaf ( ) [inline]
Definition at line 162 of file Tree.hpp.
References maxPerLeaf.
        return maxPerLeaf;
const Interface* moab::Tree::moab ( ) const [inline]
Definition at line 150 of file Tree.hpp.
References mbImpl.
        return mbImpl;
Parameters:
optionsOptions for representing tree; see Tree::build_tree() and subclass build_tree() functions for allowed options
Returns:
Non-success returned from base class function only under catastrophic circumstances; derived classes also can recognize subclass-specific options
Definition at line 9 of file Tree.cpp.
References boxTagName, cleanUp, ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_real_option(), moab::FileOptions::get_str_option(), moab::FileOptions::get_toggle_option(), maxDepth, maxPerLeaf, MB_SUCCESS, meshsetFlags, and minWidth.
Referenced by moab::BVHTree::parse_options(), and moab::AdaptiveKDTree::parse_options().
    double tmp_dbl;
    int tmp_int;
    // MAX_PER_LEAF: max entities per leaf; default = 6
    ErrorCode rval = options.get_int_option( "MAX_PER_LEAF", tmp_int );
    if( MB_SUCCESS == rval ) maxPerLeaf = std::max( tmp_int, 1 );
    // MAX_DEPTH: max depth of the tree; default = 30
    rval = options.get_int_option( "MAX_DEPTH", tmp_int );
    if( MB_SUCCESS == rval ) maxDepth = tmp_int;
    if( maxDepth < 1 ) maxDepth = std::numeric_limits< unsigned >::max();
    // MIN_WIDTH: minimum width of box, used like a tolerance; default = 1.0e-10
    rval = options.get_real_option( "MIN_WIDTH", tmp_dbl );
    if( MB_SUCCESS == rval ) minWidth = tmp_dbl;
    // MESHSET_FLAGS: flags passed into meshset creation for tree nodes; should be a value from
    //          ENTITY_SET_PROPERTY (see Types.hpp); default = MESHSET_SET
    rval = options.get_int_option( "MESHSET_FLAGS", tmp_int );
    if( MB_SUCCESS == rval && 0 <= tmp_int )
        meshsetFlags = (unsigned)tmp_int;
    else if( 0 > tmp_int )
        return MB_FAILURE;
    // CLEAN_UP: if false, do not delete tree sets upon tree class destruction; default = true
    bool tmp_bool;
    rval = options.get_toggle_option( "CLEAN_UP", true, tmp_bool );
    if( MB_SUCCESS == rval && !tmp_bool ) cleanUp = false;
    // TAG_NAME: tag name to store tree information on tree nodes; default = "AKDTree"
    std::string tmp_str;
    rval = options.get_str_option( "TAG_NAME", tmp_str );
    if( MB_SUCCESS == rval ) boxTagName = tmp_str;
    return MB_SUCCESS;
virtual ErrorCode moab::Tree::parse_options ( FileOptions opts) [pure virtual]
Parameters:
optsOptions
Implemented in moab::AdaptiveKDTree, and moab::BVHTree.
virtual ErrorCode moab::Tree::point_search ( const double *  point,
EntityHandle leaf_out,
bool *  multiple_leaves = NULL,
EntityHandle start_node = NULL,
CartVect params = NULL
) [pure virtual]
Does not take into account global bounding box of tree.
  • Therefore there is always one leaf containing the point.
  • If caller wants to account for global bounding box, then caller can test against that box and not call this method at all if the point is outside the box, as there is no leaf containing the point in that case.
    Parameters:
    leaf_outLeaf containing point
    multiple_leavesSome tree types can have multiple leaves containing a point; if non-NULL, this parameter is returned true if multiple leaves contain the input point
    Returns:
    Non-success returned only in case of failure; not-found indicated by leaf_out=0
virtual ErrorCode moab::Tree::print ( ) [pure virtual]
virtual ErrorCode moab::Tree::reset_tree ( ) [pure virtual]
Parameters:
rootIf non-NULL, check that this is the root, return failure if not
void moab::Tree::set_eval ( ElemEvaluator eval) [inline]
Definition at line 193 of file Tree.hpp.
References myEval.
Referenced by moab::SpatialLocator::elem_eval(), and moab::SpatialLocator::locate_points().
        myEval = eval;
Definition at line 168 of file Tree.hpp.
References treeStats.
Referenced by DeformMeshRemap::execute(), and moab::AdaptiveKDTree::intersect_children_with_elems().
        return treeStats;
const TreeStats& moab::Tree::tree_stats ( ) const [inline]
Definition at line 174 of file Tree.hpp.
        return treeStats;
Member Data Documentation
bool moab::Tree::cleanUp [protected]
Definition at line 239 of file Tree.hpp.
Referenced by parse_common_options(), and moab::AdaptiveKDTree::~AdaptiveKDTree().
double moab::Tree::minWidth [protected]
Definition at line 233 of file Tree.hpp.
Referenced by moab::AdaptiveKDTree::build_tree(), and parse_common_options().
int moab::Tree::treeDepth [protected]
Definition at line 230 of file Tree.hpp.
Referenced by moab::BVHTree::build_tree().
List of all members.
