moab::TreeLayoutPrinter Class Reference
+ Inheritance diagram for moab::TreeLayoutPrinter:
+ Collaboration diagram for moab::TreeLayoutPrinter:
Public Member Functions
 TreeLayoutPrinter (std::ostream &stream, Interface *instance)
virtual ErrorCode visit (EntityHandle node, int depth, bool &descend)
 Visit a node in the tree during a traversal.
virtual ErrorCode leaf (EntityHandle node)
 Process a leaf node during tree traversal.
Private Attributes
Interfaceinstance
std::ostream & outputStream
std::vector< bool > path
Detailed Description
Definition at line 1417 of file OrientedBoxTreeTool.cpp.
moab::TreeLayoutPrinter::TreeLayoutPrinter ( std::ostream &  stream,
Interface instance
Definition at line 1431 of file OrientedBoxTreeTool.cpp.
    : instance( interface ), outputStream( stream )
Member Function Documentation
Implements moab::OrientedBoxTreeTool::Op.
Definition at line 1469 of file OrientedBoxTreeTool.cpp.
References MB_SUCCESS.
    return MB_SUCCESS;
ErrorCode moab::TreeLayoutPrinter::visit ( EntityHandle  node,
int  depth,
bool &  descend
) [virtual]
This method is called for each node in the tree visited during a pre-order traversal.
Parameters:
nodeThe EntityHandle for the entity set for the tree node.
depthThe current depth in the tree.
descendOutput: if false, traversal will skip children of the current node, or if the current node is a leaf, the 'leaf' method will not be called.
Definition at line 1436 of file OrientedBoxTreeTool.cpp.
References moab::Interface::id_from_handle(), instance, MB_SUCCESS, outputStream, and path.
    descend = true;
    if( (unsigned)depth > path.size() )
        // assert(depth+1 == path.size); // preorder traversal
        path.push_back( true );
    else
        path.resize( depth );
        if( depth ) path.back() = false;
    for( unsigned i = 0; i + 1 < path.size(); ++i )
        if( path[i] )
            outputStream << "|   ";
        else
            outputStream << "    ";
    if( depth )
        if( path.back() )
            outputStream << "+---";
        else
            outputStream << "\\---";
    outputStream << instance->id_from_handle( node ) << std::endl;
    return MB_SUCCESS;
Member Data Documentation
Definition at line 1426 of file OrientedBoxTreeTool.cpp.
Referenced by visit().
std::ostream& moab::TreeLayoutPrinter::outputStream [private]
Definition at line 1427 of file OrientedBoxTreeTool.cpp.
std::vector< bool > moab::TreeLayoutPrinter::path [private]
Definition at line 1428 of file OrientedBoxTreeTool.cpp.
List of all members.
