moab::TreeNodePrinter Class Reference
+ Inheritance diagram for moab::TreeNodePrinter:
+ Collaboration diagram for moab::TreeNodePrinter:
Public Member Functions
 TreeNodePrinter (std::ostream &stream, bool list_contents, bool list_box, const char *id_tag_name, OrientedBoxTreeTool *tool_ptr)
virtual ErrorCode visit (EntityHandle node, int depth, bool &descend)
 Visit a node in the tree during a traversal.
virtual ErrorCode leaf (EntityHandle)
 Process a leaf node during tree traversal.
Private Member Functions
ErrorCode print_geometry (EntityHandle node)
ErrorCode print_contents (EntityHandle node)
ErrorCode print_counts (EntityHandle node)
Private Attributes
bool printContents
bool printGeometry
bool haveTag
Tag tag
Tag gidTag
Tag geomTag
Interfaceinstance
OrientedBoxTreeTooltool
std::ostream & outputStream
Detailed Description
Definition at line 1474 of file OrientedBoxTreeTool.cpp.
moab::TreeNodePrinter::TreeNodePrinter ( std::ostream &  stream,
bool  list_contents,
bool  list_box,
const char *  id_tag_name,
OrientedBoxTreeTool tool_ptr
Definition at line 1504 of file OrientedBoxTreeTool.cpp.
References ErrorCode, GEOM_DIMENSION_TAG_NAME, geomTag, gidTag, moab::Interface::globalId_tag(), haveTag, instance, MB_SUCCESS, MB_TYPE_INTEGER, tag, and moab::Interface::tag_get_handle().
    : printContents( list_contents ), printGeometry( list_box ), haveTag( false ), tag( 0 ), gidTag( 0 ), geomTag( 0 ),
      instance( tool_ptr->get_moab_instance() ), tool( tool_ptr ), outputStream( stream )
    ErrorCode rval;
    if( id_tag_name )
        rval = instance->tag_get_handle( id_tag_name, 1, MB_TYPE_INTEGER, tag );
        if( !rval )
            std::cerr << "Could not get tag \"" << id_tag_name << "\"\n";
            stream << "Could not get tag \"" << id_tag_name << "\"\n";
        else
            haveTag = true;
    gidTag = instance->globalId_tag();
    rval = instance->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag );
    if( MB_SUCCESS != rval ) geomTag = 0;
Member Function Documentation
virtual ErrorCode moab::TreeNodePrinter::leaf ( EntityHandle  node) [inline, virtual]
Implements moab::OrientedBoxTreeTool::Op.
Definition at line 1485 of file OrientedBoxTreeTool.cpp.
References MB_SUCCESS.
        return MB_SUCCESS;
Definition at line 1597 of file OrientedBoxTreeTool.cpp.
References moab::Range::begin(), moab::Range::empty(), moab::Range::end(), moab::CN::EntityTypeName(), ErrorCode, moab::Interface::get_entities_by_type(), haveTag, moab::Interface::id_from_handle(), instance, MB_SUCCESS, MBMAXTYPE, MBVERTEX, outputStream, moab::Range::size(), tag, and moab::Interface::tag_get_data().
Referenced by visit().
    // list contents
    for( EntityType type = MBVERTEX; type != MBMAXTYPE; ++type )
        Range range;
        ErrorCode rval = instance->get_entities_by_type( node, type, range );
        if( MB_SUCCESS != rval ) return rval;
        if( range.empty() ) continue;
        outputStream << " " << CN::EntityTypeName( type ) << " ";
        std::vector< int > ids( range.size() );
        if( haveTag )
            rval = instance->tag_get_data( tag, range, &ids[0] );
            std::sort( ids.begin(), ids.end() );
        else
            Range::iterator ri              = range.begin();
            std::vector< int >::iterator vi = ids.begin();
            while( ri != range.end() )
                *vi = instance->id_from_handle( *ri );
                ++ri;
                ++vi;
        unsigned i = 0;
        for( ;; )
            unsigned beg = i, end;
            do
                end = i++;
            } while( i < ids.size() && ids[end] + 1 == ids[i] );
            if( end == beg )
                outputStream << ids[end];
            else if( end == beg + 1 )
                outputStream << ids[beg] << ", " << ids[end];
            else
                outputStream << ids[beg] << "-" << ids[end];
            if( i == ids.size() )
                outputStream << std::endl;
                break;
            else
                outputStream << ", ";
    return MB_SUCCESS;
Definition at line 1585 of file OrientedBoxTreeTool.cpp.
References moab::CN::EntityTypeName(), ErrorCode, moab::Interface::get_number_entities_by_type(), instance, MB_SUCCESS, MBMAXTYPE, MBVERTEX, and outputStream.
        int count      = 0;
        ErrorCode rval = instance->get_number_entities_by_type( node, type, count );
        if( count > 0 ) outputStream << " " << count << " " << CN::EntityTypeName( type ) << std::endl;
    return MB_SUCCESS;
Definition at line 1570 of file OrientedBoxTreeTool.cpp.
References moab::OrientedBox::axis(), moab::OrientedBoxTreeTool::box(), moab::OrientedBox::center, moab::OrientedBox::dimensions(), ErrorCode, moab::OrientedBox::inner_radius(), length(), MB_SUCCESS, moab::OrientedBox::outer_radius(), outputStream, and tool.
    OrientedBox box;
    ErrorCode rval = tool->box( node, box );
    CartVect length = box.dimensions();
    outputStream << box.center << "  Radius: " << box.inner_radius() << " - " << box.outer_radius() << std::endl
                 << '+' << box.axis( 0 ) << " : " << length[0] << std::endl
                 << 'x' << box.axis( 1 ) << " : " << length[1] << std::endl
                 << 'x' << box.axis( 2 ) << " : " << length[2] << std::endl;
    return MB_SUCCESS;
ErrorCode moab::TreeNodePrinter::visit ( EntityHandle  node,
int  depth,
bool &  descend
) [virtual]
This method is called for each node in the tree visited during a pre-order traversal.
Parameters:
nodeThe EntityHandle for the entity set for the tree node.
depthThe current depth in the tree.
descendOutput: if false, traversal will skip children of the current node, or if the current node is a leaf, the 'leaf' method will not be called.
Definition at line 1533 of file OrientedBoxTreeTool.cpp.
References moab::Range::begin(), ErrorCode, geomTag, moab::Interface::get_entities_by_type_and_tag(), gidTag, moab::Interface::id_from_handle(), instance, MB_SUCCESS, MBENTITYSET, outputStream, print_contents(), print_counts(), print_geometry(), printContents, printGeometry, moab::Range::size(), and moab::Interface::tag_get_data().
    descend            = true;
    EntityHandle setid = instance->id_from_handle( node );
    outputStream << setid << ":" << std::endl;
    Range surfs;
    ErrorCode r3 = MB_SUCCESS;
    if( geomTag )
        const int two         = 2;
        const void* tagdata[] = { &two };
        r3 = instance->get_entities_by_type_and_tag( node, MBENTITYSET, &geomTag, tagdata, 1, surfs );
        if( MB_SUCCESS == r3 && surfs.size() == 1 )
            EntityHandle surf = *surfs.begin();
            int id;
            if( gidTag && MB_SUCCESS == instance->tag_get_data( gidTag, &surf, 1, &id ) )
                outputStream << "  Surface " << id << std::endl;
            else
                outputStream << "  Surface w/ unknown ID (" << surf << ")" << std::endl;
    ErrorCode r1 = printGeometry ? print_geometry( node ) : MB_SUCCESS;
    ErrorCode r2 = printContents ? print_contents( node ) : print_counts( node );
    if( MB_SUCCESS != r1 )
        return r1;
    else if( MB_SUCCESS != r2 )
        return r2;
    else
        return r3;
Member Data Documentation
Definition at line 1498 of file OrientedBoxTreeTool.cpp.
Referenced by TreeNodePrinter(), and visit().
Definition at line 1497 of file OrientedBoxTreeTool.cpp.
Referenced by print_contents(), and TreeNodePrinter().
std::ostream& moab::TreeNodePrinter::outputStream [private]
Definition at line 1501 of file OrientedBoxTreeTool.cpp.
Referenced by print_contents(), print_counts(), print_geometry(), and visit().
Definition at line 1495 of file OrientedBoxTreeTool.cpp.
Definition at line 1496 of file OrientedBoxTreeTool.cpp.
Definition at line 1500 of file OrientedBoxTreeTool.cpp.
Referenced by print_geometry().
List of all members.
