moab::TypeSequenceManager Member List
This is the complete list of members for moab::TypeSequenceManager, including all inherited members.
append_memory_use(EntityHandle first, EntityHandle last, const SequenceData *data, unsigned long long &entity_storage, unsigned long long &total_storage) const moab::TypeSequenceManager [private]
availableListmoab::TypeSequenceManager [private]
begin() const moab::TypeSequenceManager [inline]
begin()moab::TypeSequenceManager [inline]
check_merge_next(iterator i)moab::TypeSequenceManager [private]
check_merge_prev(iterator i)moab::TypeSequenceManager [private]
check_valid_data(const EntitySequence *seq) const moab::TypeSequenceManager [private]
check_valid_handles(Error *error_handler, EntityHandle first, EntityHandle last) const moab::TypeSequenceManager
const_iterator typedefmoab::TypeSequenceManager
data_iterator typedefmoab::TypeSequenceManager
data_set_type typedefmoab::TypeSequenceManager
empty() const moab::TypeSequenceManager [inline]
end() const moab::TypeSequenceManager [inline]
end()moab::TypeSequenceManager [inline]
erase(iterator i)moab::TypeSequenceManager [private]
erase(Error *error_handler, EntityHandle first, EntityHandle last)moab::TypeSequenceManager
erase(Error *error_handler, EntityHandle entity)moab::TypeSequenceManager
find(EntityHandle h) const moab::TypeSequenceManager [inline]
find(EntityHandle h)moab::TypeSequenceManager [inline]
find(EntityHandle h, EntitySequence *&)moab::TypeSequenceManager [inline]
find(EntityHandle h, const EntitySequence *&) const moab::TypeSequenceManager [inline]
find_free_block(EntityID num_entities, EntityHandle min_start_handle, EntityHandle max_end_handle)moab::TypeSequenceManager
find_free_handle(EntityHandle min_start_handle, EntityHandle max_end_handle, bool &append_out, int values_per_ent=0)moab::TypeSequenceManager
find_free_sequence(EntityID num_entities, EntityHandle min_start_handle, EntityHandle max_end_handle, SequenceData *&sequence_data_out, EntityID &sequence_data_size, int values_per_ent=0)moab::TypeSequenceManager
get_entities(Range &entities_out) const moab::TypeSequenceManager [inline]
get_entities(std::vector< EntityHandle > &entities_out) const moab::TypeSequenceManager [inline]
get_last_accessed() const moab::TypeSequenceManager [inline]
get_memory_use(unsigned long long &total_entity_storage, unsigned long long &total_storage) const moab::TypeSequenceManager
get_memory_use(EntityHandle start, EntityHandle end, unsigned long long &total_entity_storage, unsigned long long &total_amortized_storage) const moab::TypeSequenceManager
get_number_entities() const moab::TypeSequenceManager [inline]
get_occupied_size(const SequenceData *) const moab::TypeSequenceManager
get_sequence_count() const moab::TypeSequenceManager [inline]
insert_sequence(EntitySequence *seq_ptr)moab::TypeSequenceManager
is_free_handle(EntityHandle handle, iterator &seq_ptr_out, SequenceData *&data_ptr_out, EntityHandle &block_start, EntityHandle &block_end, int values_per_ent=0)moab::TypeSequenceManager
is_free_sequence(EntityHandle start_handle, EntityID num_entities, SequenceData *&sequence_data_out, int values_per_ent=0)moab::TypeSequenceManager
last_free_handle(EntityHandle after_this) const moab::TypeSequenceManager
lastReferencedmoab::TypeSequenceManager [mutable, private]
lower_bound(EntityHandle h) const moab::TypeSequenceManager [inline]
lower_bound(EntityHandle h)moab::TypeSequenceManager [inline]
merge_internal(iterator keep, iterator dead)moab::TypeSequenceManager [private]
notify_appended(iterator seq)moab::TypeSequenceManager
notify_prepended(iterator seq)moab::TypeSequenceManager
remove_sequence(const EntitySequence *seq_ptr, bool &is_last_user_of_sequence_data)moab::TypeSequenceManager
replace_subsequence(EntitySequence *seq_ptr, const int *tag_sizes, int num_tag_sizes)moab::TypeSequenceManager
sequenceSetmoab::TypeSequenceManager [private]
split_sequence(iterator i, EntityHandle h)moab::TypeSequenceManager [private]
TypeSequenceManager()moab::TypeSequenceManager [inline]
upper_bound(EntityHandle h) const moab::TypeSequenceManager [inline]
~TypeSequenceManager()moab::TypeSequenceManager
