moab::UcdNCHelper Member List
This is the complete list of members for moab::UcdNCHelper, including all inherited members.
_fileIdmoab::NCHelper [protected]
_fileSetmoab::NCHelper [protected]
_optsmoab::NCHelper [protected]
_readNCmoab::NCHelper [protected]
cDimmoab::UcdNCHelper [protected]
check_existing_mesh()=0moab::NCHelper [pure virtual]
create_attrib_string(const std::map< std::string, ReadNC::AttData > &attMap, std::string &attString, std::vector< int > &attLen)moab::NCHelper [protected]
create_conventional_tags(const std::vector< int > &tstep_nums)moab::NCHelper
create_dummy_variables()moab::NCHelper [protected]
create_mesh(Range &faces)=0moab::NCHelper [pure virtual]
dummyVarNamesmoab::NCHelper [protected]
eDimmoab::UcdNCHelper [protected]
get_mesh_type_name()=0moab::NCHelper [pure virtual]
get_nc_helper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelper [static]
get_tag_to_nonset(ReadNC::VarData &var_data, int tstep_num, Tag &tagh, int num_lev)moab::NCHelper [protected]
get_tag_to_set(ReadNC::VarData &var_data, int tstep_num, Tag &tagh)moab::NCHelper [protected]
ignoredVarNamesmoab::NCHelper [protected]
init_mesh_vals()=0moab::NCHelper [pure virtual]
kji_to_jik_stride(size_t, size_t nj, size_t nk, void *dest, T *source, Range &localGid)moab::UcdNCHelper [inline, protected]
levDimmoab::NCHelper [protected]
levValsmoab::NCHelper [protected]
localGidCellsmoab::UcdNCHelper [protected]
localGidEdgesmoab::UcdNCHelper [protected]
localGidVertsmoab::UcdNCHelper [protected]
nCellsmoab::UcdNCHelper [protected]
NCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelper [inline]
nEdgesmoab::UcdNCHelper [protected]
nLevelsmoab::NCHelper [protected]
nLocalCellsmoab::UcdNCHelper [protected]
nLocalEdgesmoab::UcdNCHelper [protected]
nLocalVerticesmoab::UcdNCHelper [protected]
nTimeStepsmoab::NCHelper [protected]
nVerticesmoab::UcdNCHelper [protected]
read_coordinate(const char *var_name, int lmin, int lmax, std::vector< double > &cvals)moab::NCHelper [protected]
read_ucd_variables_to_nonset(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)=0moab::UcdNCHelper [private, pure virtual]
read_ucd_variables_to_nonset_allocate(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)=0moab::UcdNCHelper [private, pure virtual]
read_variables(std::vector< std::string > &var_names, std::vector< int > &tstep_nums)moab::UcdNCHelper [private, virtual]
read_variables_setup(std::vector< std::string > &var_names, std::vector< int > &tstep_nums, std::vector< ReadNC::VarData > &vdatas, std::vector< ReadNC::VarData > &vsetdatas)moab::NCHelper [protected]
read_variables_to_set(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)moab::NCHelper [protected]
tDimmoab::NCHelper [protected]
tValsmoab::NCHelper [protected]
UcdNCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::UcdNCHelper [inline]
update_time_tag_vals()moab::NCHelper
vDimmoab::UcdNCHelper [protected]
xVertValsmoab::UcdNCHelper [protected]
yVertValsmoab::UcdNCHelper [protected]
zVertValsmoab::UcdNCHelper [protected]
~NCHelper()moab::NCHelper [inline, virtual]
~UcdNCHelper()moab::UcdNCHelper [inline, virtual]
