moab::UnstructuredElemSeq Class Reference
#include <UnstructuredElemSeq.hpp>
+ Inheritance diagram for moab::UnstructuredElemSeq:
+ Collaboration diagram for moab::UnstructuredElemSeq:
Public Member Functions
 UnstructuredElemSeq (EntityHandle start_handle, EntityID entity_count, unsigned nodes_per_entity, SequenceData *data)
 UnstructuredElemSeq (EntityHandle start_handle, EntityID entity_count, unsigned nodes_per_entity, EntityID sequence_data_size)
virtual ~UnstructuredElemSeq ()
int values_per_entity () const
 Integer value used in finding appropriate SequenceData.
virtual EntitySequencesplit (EntityHandle here)
 Split this sequence into two consecutive sequences.
SequenceDatacreate_data_subset (EntityHandle start, EntityHandle end) const
 Create a new SequenceData that is a copy of a subset of the one referenced by this sequence.
virtual ErrorCode get_connectivity (EntityHandle handle, std::vector< EntityHandle > &connect, bool topological=false) const
virtual ErrorCode get_connectivity (EntityHandle handle, EntityHandle const *&connect, int &connect_length, bool topological=false, std::vector< EntityHandle > *storage=0) const
ErrorCode set_connectivity (EntityHandle handle, EntityHandle const *connect, int connect_length)
EntityHandleget_connectivity_array ()
ErrorCode push_front (EntityID count)
ErrorCode push_back (EntityID count)
void get_const_memory_use (unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const
 Get memory characteristcs that are the same for all entities.
Protected Member Functions
EntityHandle const * get_array () const
EntityHandleget_array ()
 UnstructuredElemSeq (UnstructuredElemSeq &split_from, EntityHandle here)
Detailed Description
Definition at line 10 of file UnstructuredElemSeq.hpp.
moab::UnstructuredElemSeq::UnstructuredElemSeq ( EntityHandle  start_handle,
SequenceData data
Definition at line 8 of file UnstructuredElemSeq.cpp.
Referenced by split().
    : ElementSequence( shandle, entity_count, nodes_per_entity, dat )
Definition at line 16 of file UnstructuredElemSeq.cpp.
References moab::SequenceData::create_sequence_data(), and moab::EntitySequence::data().
                       entity_count,
                       nodes_per_entity,
                       new SequenceData( 1, shandle, shandle + data_size - 1 ) )
    data()->create_sequence_data( 0, nodes_per_entity * sizeof( EntityHandle ) );
Definition at line 28 of file UnstructuredElemSeq.cpp.
moab::UnstructuredElemSeq::UnstructuredElemSeq ( UnstructuredElemSeq split_from,
EntityHandle  here
) [inline, protected]
Definition at line 63 of file UnstructuredElemSeq.hpp.
: ElementSequence( split_from, here ) {}
Member Function Documentation
SequenceData * moab::UnstructuredElemSeq::create_data_subset ( EntityHandle  start_handle,
EntityHandle  end_handle
) const [virtual]
Create a new SequenceData that is a copy of a subset of the SequenceData referenced by this EntitySequence. Do not make any changes to this EntitySequence or the current SequenceData.
Implements moab::EntitySequence.
Definition at line 42 of file UnstructuredElemSeq.cpp.
References moab::EntitySequence::data(), moab::ElementSequence::nodes_per_element(), and moab::SequenceData::subset().
    int esize = nodes_per_element() * sizeof( EntityHandle );
    return data()->subset( start, end, &esize );
ErrorCode moab::UnstructuredElemSeq::get_connectivity ( EntityHandle  handle,
std::vector< EntityHandle > &  connect,
bool  topological = false
) const [virtual]
Implements moab::ElementSequence.
Reimplemented in moab::PolyElementSeq.
Definition at line 54 of file UnstructuredElemSeq.cpp.
References get_array(), MB_SUCCESS, moab::ElementSequence::nodes_per_element(), moab::EntitySequence::start_handle(), moab::EntitySequence::type(), and moab::CN::VerticesPerEntity().
    EntityHandle const* conn = get_array() + nodes_per_element() * ( handle - start_handle() );
    int len                  = topological ? CN::VerticesPerEntity( type() ) : nodes_per_element();
    connect.reserve( connect.size() + len );
    std::copy( conn, conn + len, std::back_inserter( connect ) );
    return MB_SUCCESS;
EntityHandle const *&  connect,
int &  connect_length,
bool  topological = false,
std::vector< EntityHandle > *  storage = 0
) const [virtual]
Definition at line 84 of file UnstructuredElemSeq.cpp.
References get_array().
    return get_array();
void moab::UnstructuredElemSeq::get_const_memory_use ( unsigned long &  bytes_per_entity,
unsigned long &  size_of_sequence
) const [virtual]
Get charactersitic constant memory use for all entities in sequence.
Parameters:
bytes_per_entityThe total bytes consumed for each entity in the underlying SequenceData. It is assumed that the same amount of memory is consumed for unused portions of the SequenceData.
size_of_sequenceThe size of the leaf subclass of this class
Definition at line 48 of file UnstructuredElemSeq.cpp.
References moab::ElementSequence::nodes_per_element().
    bytes_per_entity = nodes_per_element() * sizeof( EntityHandle );
    size_of_sequence = sizeof( *this );
ErrorCode moab::UnstructuredElemSeq::set_connectivity ( EntityHandle  handle,
EntityHandle const *  connect,
int  connect_length
) [virtual]
Definition at line 76 of file UnstructuredElemSeq.cpp.
References get_array(), MB_INDEX_OUT_OF_RANGE, MB_SUCCESS, moab::ElementSequence::nodes_per_element(), and moab::EntitySequence::start_handle().
Referenced by moab::SequenceManager::create_element().
    if( (unsigned)connect_length != nodes_per_element() ) return MB_INDEX_OUT_OF_RANGE;
    EntityHandle* conn_ptr = get_array() + nodes_per_element() * ( handle - start_handle() );
    std::copy( connect, connect + connect_length, conn_ptr );
    return MB_SUCCESS;
Split this sequence into two sequences.
Parameters:
hereNew sequences should be [start_handle(),here) & [here,end_handle()]
Returns:
New sequence containing [here,end_handle()]
Definition at line 35 of file UnstructuredElemSeq.cpp.
References moab::EntitySequence::end_handle(), moab::EntitySequence::start_handle(), and UnstructuredElemSeq().
    if( here <= start_handle() || here > end_handle() ) return 0;
    return new UnstructuredElemSeq( *this, here );
This value is matched to input values by TypeSequenceManager to determine if an available, unused portino of a SequenceData can be used for a specific entity allocation. For example, it is used to find a SequenceData with the appropriate number of vertices per element when allocating elements. The default value is zero.
Reimplemented from moab::EntitySequence.
Definition at line 30 of file UnstructuredElemSeq.cpp.
    return nodes_per_element();
List of all members.
