moab::VarLenTag Class Reference
Class for storing variable-length tag data. More...
#include <VarLenTag.hpp>
+ Collaboration diagram for moab::VarLenTag:
Public Member Functions
 VarLenTag ()
 VarLenTag (unsigned size)
 ~VarLenTag ()
 VarLenTag (const VarLenTag &copy)
 VarLenTag (unsigned size, const void *data)
unsigned size () const
unsigned char * data ()
unsigned long mem () const
const unsigned char * data () const
unsigned char * resize (unsigned size)
void clear ()
void set (const void *dat, unsigned sz)
VarLenTagoperator= (const VarLenTag &other)
Protected Attributes
VarLenTagData mData
Detailed Description
Class for managing variable-length tag data. This class must behave as if it were initialized to empty if it is memset to zero w/out invoking any constructor.
Definition at line 152 of file VarLenTag.hpp.
Definition at line 158 of file VarLenTag.hpp.
References moab::VarLenTagData::mData.
        mData.mData.mPointer.size = 0;
moab::VarLenTag::VarLenTag ( unsigned  size) [inline]
Definition at line 249 of file VarLenTag.hpp.
References moab::VarLenTagData::INLINE_COUNT, and moab::VarLenTagData::mData.
#ifdef VAR_LEN_TAG_ELIDE_DATA
    if( sz > VarLenTagData::INLINE_COUNT )
#endif
        mData.mData.mPointer.array = reinterpret_cast< unsigned char* >( malloc( sz ) );
    mData.mData.mPointer.size = sz;
Definition at line 163 of file VarLenTag.hpp.
        clear();
moab::VarLenTag::VarLenTag ( const VarLenTag copy) [inline]
Definition at line 269 of file VarLenTag.hpp.
References moab::VarLenTagData::INLINE_COUNT, moab::VarLenTagData::mData, mData, moab::VarLenTagData::mPointer, and size().
                                                   : mData( copy.mData )
    if( size() > VarLenTagData::INLINE_COUNT )
#endif
        mData.mData.mPointer.array = reinterpret_cast< unsigned char* >( malloc( size() ) );
        memcpy( mData.mData.mPointer.array, copy.mData.mData.mPointer.array, size() );
moab::VarLenTag::VarLenTag ( unsigned  size,
const void *  data
) [inline]
Definition at line 280 of file VarLenTag.hpp.
References moab::VarLenTagData::mData, mData, moab::VarLenTagData::mPointer, and resize().
    if( sz ) memcpy( resize( sz ), dat, sz );
Member Function Documentation
void moab::VarLenTag::clear ( ) [inline]
Definition at line 258 of file VarLenTag.hpp.
References moab::VarLenTagData::INLINE_COUNT, moab::VarLenTagData::mData, and moab::VarLenTagData::size.
Referenced by moab::SequenceData::release_tag_data(), and moab::VarLenDenseTag::remove_data().
#else
    if( size() )
#endif
        free( mData.mData.mPointer.array );
const unsigned char* moab::VarLenTag::data ( ) const [inline]
Definition at line 197 of file VarLenTag.hpp.
        return const_cast< VarLenTag* >( this )->data();
unsigned long moab::VarLenTag::mem ( ) const [inline]
VarLenTag& moab::VarLenTag::operator= ( const VarLenTag other) [inline]
Definition at line 211 of file VarLenTag.hpp.
References data(), and size().
        set( other.data(), other.size() );
        return *this;
unsigned char * moab::VarLenTag::resize ( unsigned  size) [inline]
Definition at line 218 of file VarLenTag.hpp.
Referenced by VarLenTag().
    if( s <= VarLenTagData::INLINE_COUNT )
            unsigned char* tmp_ptr = mData.mData.mPointer.array;
            memcpy( mData.mData.mInline.array, tmp_ptr, s );
            free( tmp_ptr );
        mData.mData.mInline.size = s;
        return mData.mData.mInline.array;
    else if( size() <= VarLenTagData::INLINE_COUNT )
        void* tmp_ptr = malloc( s );
        memcpy( tmp_ptr, mData.mData.mInline.array, size() );
        mData.mData.mPointer.array = reinterpret_cast< unsigned char* >( tmp_ptr );
    else
#endif
        if( size() < s )
        void* tmp_ptr              = size() ? realloc( mData.mData.mPointer.array, s ) : malloc( s );
    mData.mData.mPointer.size = s;
    return mData.mData.mPointer.array;
void moab::VarLenTag::set ( const void *  dat,
unsigned  sz
) [inline]
Definition at line 206 of file VarLenTag.hpp.
Referenced by moab::VarLenDenseTag::set_data().
Member Data Documentation
Definition at line 155 of file VarLenTag.hpp.
List of all members.
